“KDE desktop session restore feature” - Is it responsible for restoring Konsole tabs?
Because recently I had my regular 3-4 tabs in Konsole restored on every restart. Now it’s gone.
Moreover, now Konsole fails with background transparency appearance on system restart.
That’s another issue try to not mix everything in one thread. Check your compositor settings, see if it is enabled, without it, no transparency I think.
I’ve just checked and it really has “wrong” options selected, though I had no reason to change them - I highly interested in recovering my previous work/applications/state.
I felt that you might note that, sorry for my piled-up emotions.
Thanks.
(P.S. I wish the mentioned settings won’t be reset unexpectedly by one of those next upgrades)
Alright, then mark the thread as solved by selecting the appropriate post (under […] click SOLUTION).
For the KDE settings resetting, I guess it could happen if the config file gets corrupted, or if something goes wrong when using some customization, or other reasons but it is hard to guess. For sure I didn’t have any reset I think since I use KDE.
Sometimes I had to play with config due to this issue Plasmashell (taskbar) does not work.
But I’m not sure if that could effect such global (mentioned) KDE settings.
Yeah it definitely can. This is the main KDE settings file I think.
//EDIT: something you could do is to track and remove all KDE config files from a TTY after logging out, and restart, then it will generate fresh proper KDE configs, then you would have to reconfigure your whole KDE but at least you would have clean config files and it should be OK after that.
