My terminals cursor is way ahead and its annoying , the more i write the more far it goes
Hi @Wolf_a,
I’ve read about this before. IIRC the problem is the font used and the solution, therefore, is to try a different font.
- Open Konsole.
- Go9 to Settings → Configure Konsole…:
- Go to Profile, on the left, select the profile right, and click Edit
On the window that appears, change the font as required. I’ve set mine to Nerd Mono, and have never had a problem like this.
OK/Apply out of the screen/window.
It should, theoretically be working after ensuring the profile is applied.
Hope this helps!
You have removed the default konsole font - reinstall that font
sudo pacman -Syu ttf-hack
You need to close the terminal emulator to apply the change.
Thanks it worked .
