I’m trying Konqueror as an alternative to firefox and i started using it today and i’m having some troubles with it:
1- when i click the software icon in the task bar it shows another icon
2- when i open then i close the configuration panel it does not open again
3- i didn’t not find where to change the link colors.
I tried Konqueror once, and uninstalled it soon after; gave it a second chance some time later, until my humour ran its course; then uninstalled it again.
I believe Vivaldi will be worth your attention; it’s based on Chromium; and is available in the official Manjaro repositories:
sudo pacman -S vivaldi
Aside:- If you decide to keep using Firefox, the Plasma Integration addon/extension is a worthwhile addition.
I primarily use both Firefox and Vivaldi in Manjaro, but sometimes trial others for differing reasons. Konquerer simply couldn’t/wouldn’t suit my workflow. Falkon is also worth trying; lighter than most browsers.
Ultimately, with so many browsers available, the choice is up to you.
