kolourpaint is in conflict with kdelibs4support or something. I haven’t found anything about it on Manjaro forums. Here’s pacman’s compaint:
error: failed to commit transaction (conflicting files)
kolourpaint: /etc/xdg/colors/40.colors exists in filesystem (owned by kdelibs4support)
kolourpaint: /etc/xdg/colors/Oxygen.colors exists in filesystem (owned by kdelibs4support)
kolourpaint: /etc/xdg/colors/Rainbow.colors exists in filesystem (owned by kdelibs4support)
kolourpaint: /etc/xdg/colors/Royal.colors exists in filesystem (owned by kdelibs4support)
kolourpaint: /etc/xdg/colors/Web.colors exists in filesystem (owned by kdelibs4support)
I didn’t need kolourpaint because I prefer pinta. I removed it and completed the update: sudo pacman -R kolourpaint
Info:- You can remove a package and it’s (unused) dependencies with:
sudo pacman -Rns <package>
Note that the use of software sourced from the AUR is officially unsupported by Manjaro. If the AUR absolutely must be used, it is recommended to switch to the Unstable branch, which is the closest match to Arch (stable).
