Hi everyone, a new member to this forum and manjaro (less than 1 week), coming from Ubuntu. The transition was smooth and the performance of my XPS 13 9300 drastically improved.
Problem: Kodi starts very slow, and generates the following message when started from the terminal:
“Failed to open VDPAU backend libvdpau_va_gl.so: cannot open shared object file: No such file or directory”
I have searched the net and the forum and found that inserting the following in the /etc/environment:
DRI_PRIME=1
LIBVA_DRIVER_NAME=i915
may help. I’ve looked at the /usr/lib/dri and changed i915 for i965 or iris, however, it not helped. I’m looking for some advice. Since this was brand new install, kodi start it slow starts only after some time, so probably some software I’ve installed (Virtualbox???) must have cause the conflict.
Here is the system info:
I have installed manjaro with Xface, and then installed vanilla i3wm.
OS: Manjaro Linux x86_64
Host: XPS 13 9300
Kernel: 5.8.18-1-MANJARO
Packages: 1250 (pacman), 2 (snap)
Shell: bash 5.0.18
Resolution: 3840x2400
WM: i3
Theme: Adwaita [GTK3]
Icons: Adwaita [GTK3]
Terminal: xfce4-terminal
Terminal Font: Monospace 10
CPU: Intel i7-1065G7 (8) @ 3.900GHz
GPU: Intel Iris Plus Graphics G7
Memory: 2454MiB / 15593MiB
Here is the output of the: $ vdpauinfo
display: :0 screen: 0
Error creating VDPAU device: 1
I would appreciate any help, as I ran out of ideas (and google searches ).
Thanks,
tekker
