Kodi randomly crashing when streaming how to downgrade python/dh key too small
so my goal is to have arch based linux on Raspberry pi and working kodi with streaming plugins (some IPTVS, youtube, netflix) but i cannot seem t oget stream based content working
i previously tried this on pure arch and kodi was crashing always when trying to acces any remote content, i even compiled inputstream but it didnt helped,
now on manjaro it works better, sounds works out of box and i can watch streaming content, but it crashed randomly, when it works, and i exit out and play it again, same stream it crashes, when i click too fast it crashed, i dont see the causes even in the crash logs, i amd uploading crash log here, and u can see on the end that it crashes right after it opens the stream\
############## Kodi CRASH LOG ###############
################ SYSTEM INFO ################
 Date: Sat  9 Apr 18:10:44 CEST 2022
 Kodi Options:
 Arch: aarch64
 Kernel: Linux 5.15.28-1-MANJARO-ARM-RPI #1 SMP PREEMPT Tue Mar 15 15:22:54 UTC 2022
 Release: Manjaro-ARM
############## END SYSTEM INFO ##############
############### STACK TRACE #################
gdb not installed, can't get stack trace.
############# END STACK TRACE ###############
################# LOG FILE ##################
2022-04-09 17:57:46.014 T:740      INFO <general>: -----------------------------------------------------------------------
2022-04-09 17:57:46.015 T:740      INFO <general>: Starting Kodi (19.4 (19.4.0) Git:20220305-nogitfound). Platform: Linux ARM 64-bit
2022-04-09 17:57:46.015 T:740      INFO <general>: Using Release Kodi x64
2022-04-09 17:57:46.015 T:740      INFO <general>: Kodi compiled 2022-03-05 by GCC 11.2.0 for Linux ARM 64-bit version 5.16.8 (331784)
2022-04-09 17:57:46.015 T:740      INFO <general>: Running on BCM2835 with Manjaro ARM 22.03, kernel: Linux ARM 64-bit version 5.15.28-1-MANJARO-ARM-RPI
2022-04-09 17:57:46.019 T:740      INFO <general>: FFmpeg version/source: a819818-kodi-4.3.2-Matrix-19.2
2022-04-09 17:57:46.019 T:740      INFO <general>: 4 CPU cores available
2022-04-09 17:57:46.019 T:740      INFO <general>: ARM Features: Neon enabled
2022-04-09 17:57:46.019 T:740      INFO <general>: special://xbmc/ is mapped to: /usr/share/kodi
2022-04-09 17:57:46.019 T:740      INFO <general>: special://xbmcbin/ is mapped to: /usr/lib/kodi
2022-04-09 17:57:46.019 T:740      INFO <general>: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
2022-04-09 17:57:46.019 T:740      INFO <general>: special://masterprofile/ is mapped to: /var/lib/kodi/.kodi/userdata
2022-04-09 17:57:46.019 T:740      INFO <general>: special://envhome/ is mapped to: /var/lib/kodi
2022-04-09 17:57:46.019 T:740      INFO <general>: special://home/ is mapped to: /var/lib/kodi/.kodi
2022-04-09 17:57:46.019 T:740      INFO <general>: special://temp/ is mapped to: /var/lib/kodi/.kodi/temp
2022-04-09 17:57:46.019 T:740      INFO <general>: special://logpath/ is mapped to: /var/lib/kodi/.kodi/temp
2022-04-09 17:57:46.019 T:740      INFO <general>: The executable running is: /usr/lib/kodi/kodi.bin
2022-04-09 17:57:46.019 T:740      INFO <general>: Local hostname: rpi
2022-04-09 17:57:46.020 T:740      INFO <general>: Log File is located: /var/lib/kodi/.kodi/temp/kodi.log
2022-04-09 17:57:46.022 T:740      INFO <general>: -----------------------------------------------------------------------
2022-04-09 17:57:46.037 T:740      INFO <general>: loading settings
2022-04-09 17:57:46.038 T:740      INFO <general>: special://profile/ is mapped to: special://masterprofile/
2022-04-09 17:57:46.078 T:740      INFO <general>: No settings file to load (special://xbmc/system/advancedsettings.xml)
2022-04-09 17:57:46.078 T:740      INFO <general>: No settings file to load (special://masterprofile/advancedsettings.xml)
2022-04-09 17:57:46.078 T:740      INFO <general>: Default Video Player: VideoPlayer
2022-04-09 17:57:46.078 T:740      INFO <general>: Default Audio Player: paplayer
2022-04-09 17:57:46.078 T:740      INFO <general>: Disabled debug logging due to GUI setting. Level 0.
2022-04-09 17:57:46.078 T:740      INFO <general>: Log level changed to "INFO"
2022-04-09 17:57:46.081 T:740      INFO <general>: creating subdirectories
2022-04-09 17:57:46.081 T:740      INFO <general>: userdata folder: special://masterprofile/
2022-04-09 17:57:46.081 T:740      INFO <general>: recording folder:
2022-04-09 17:57:46.081 T:740      INFO <general>: screenshots folder:
2022-04-09 17:57:46.118 T:740      INFO <general>: Running database version Addons33
2022-04-09 17:57:46.352 T:740      INFO <general>: CAddonMgr::FindAddons: audioencoder.kodi.builtin.aac v1.0.2 installed
2022-04-09 17:57:46.353 T:740      INFO <general>: CAddonMgr::FindAddons: audioencoder.kodi.builtin.wma v1.0.2 installed
2022-04-09 17:57:46.353 T:740      INFO <general>: CAddonMgr::FindAddons: game.controller.default v1.0.20 installed
2022-04-09 17:57:46.353 T:740      INFO <general>: CAddonMgr::FindAddons: game.controller.snes v1.0.19 installed
2022-04-09 17:57:46.354 T:740      INFO <general>: CAddonMgr::FindAddons: inputstream.adaptive v2.4.4 installed
2022-04-09 17:57:46.354 T:740      INFO <general>: CAddonMgr::FindAddons: kodi.binary.global.audioengine v1.1.1 installed
2022-04-09 17:57:46.354 T:740      INFO <general>: CAddonMgr::FindAddons: kodi.binary.global.filesystem v1.1.6 installed
2022-04-09 17:57:46.354 T:740      INFO <general>: CAddonMgr::FindAddons: kodi.binary.global.general v1.0.5 installed
2022-04-09 17:57:46.355 T:740      INFO <general>: CAddonMgr::FindAddons: kodi.binary.global.gui v5.15.0 installed
2022-04-09 17:57:46.355 T:740      INFO <general>: CAddonMgr::FindAddons: kodi.binary.global.main v1.3.0 installed
2022-04-09 17:57:46.355 T:740      INFO <general>: CAddonMgr::FindAddons: kodi.binary.global.network v1.0.4 installed
2022-04-09 17:57:46.356 T:740      INFO <general>: CAddonMgr::FindAddons: kodi.binary.global.tools v1.0.4 installed
2022-04-09 17:57:46.356 T:740      INFO <general>: CAddonMgr::FindAddons: kodi.binary.instance.audiodecoder v3.0.0 installed
2022-04-09 17:57:46.356 T:740      INFO <general>: CAddonMgr::FindAddons: kodi.binary.instance.audioencoder v2.1.0 installed
2022-04-09 17:57:46.357 T:740      INFO <general>: CAddonMgr::FindAddons: kodi.binary.instance.game v2.1.1 installed
2022-04-09 17:57:46.357 T:740      INFO <general>: CAddonMgr::FindAddons: kodi.binary.instance.imagedecoder v2.1.1 installed
2022-04-09 17:57:46.357 T:740      INFO <general>: CAddonMgr::FindAddons: kodi.binary.instance.inputstream v3.0.1 installed
2022-04-09 17:57:46.358 T:740      INFO <general>: CAddonMgr::FindAddons: kodi.binary.instance.peripheral v2.0.0 installed
2022-04-09 17:57:46.358 T:740      INFO <general>: CAddonMgr::FindAddons: kodi.binary.instance.pvr v7.1.0 installed
2022-04-09 17:57:46.358 T:740      INFO <general>: CAddonMgr::FindAddons: kodi.binary.instance.screensaver v2.1.0 installed
2022-04-09 17:57:46.358 T:740      INFO <general>: CAddonMgr::FindAddons: kodi.binary.instance.vfs v3.0.0 installed
2022-04-09 17:57:46.359 T:740      INFO <general>: CAddonMgr::FindAddons: kodi.binary.instance.videocodec v2.0.2 installed
2022-04-09 17:57:46.359 T:740      INFO <general>: CAddonMgr::FindAddons: kodi.binary.instance.visualization v3.0.0 installed
2022-04-09 17:57:46.359 T:740      INFO <general>: CAddonMgr::FindAddons: kodi.resource v1.0.0 installed
2022-04-09 17:57:46.360 T:740      INFO <general>: CAddonMgr::FindAddons: metadata.album.universal v3.1.7 installed
2022-04-09 17:57:46.360 T:740      INFO <general>: CAddonMgr::FindAddons: metadata.artists.universal v4.3.7 installed
2022-04-09 17:57:46.360 T:740      INFO <general>: CAddonMgr::FindAddons: metadata.common.allmusic.com v3.2.2 installed
2022-04-09 17:57:46.361 T:740      INFO <general>: CAddonMgr::FindAddons: metadata.common.fanart.tv v3.6.4 installed
2022-04-09 17:57:46.361 T:740      INFO <general>: CAddonMgr::FindAddons: metadata.common.imdb.com v3.2.5 installed
2022-04-09 17:57:46.361 T:740      INFO <general>: CAddonMgr::FindAddons: metadata.common.musicbrainz.org v2.2.4 installed
2022-04-09 17:57:46.361 T:740      INFO <general>: CAddonMgr::FindAddons: metadata.common.theaudiodb.com v2.0.3 installed
2022-04-09 17:57:46.362 T:740      INFO <general>: CAddonMgr::FindAddons: metadata.common.themoviedb.org v3.2.18 installed
2022-04-09 17:57:46.362 T:740      INFO <general>: CAddonMgr::FindAddons: metadata.generic.albums v1.0.14 installed
2022-04-09 17:57:46.362 T:740      INFO <general>: CAddonMgr::FindAddons: metadata.generic.artists v1.0.14 installed
2022-04-09 17:57:46.363 T:740      INFO <general>: CAddonMgr::FindAddons: metadata.local v1.0.1 installed
2022-04-09 17:57:46.363 T:740      INFO <general>: CAddonMgr::FindAddons: metadata.themoviedb.org v5.2.6 installed
2022-04-09 17:57:46.363 T:740      INFO <general>: CAddonMgr::FindAddons: metadata.themoviedb.org.python v1.6.1+matrix.1 installed
2022-04-09 17:57:46.364 T:740      INFO <general>: CAddonMgr::FindAddons: metadata.tvshows.themoviedb.org v3.5.14 installed
2022-04-09 17:57:46.364 T:740      INFO <general>: CAddonMgr::FindAddons: metadata.tvshows.themoviedb.org.python v1.4.10 installed
2022-04-09 17:57:46.364 T:740      INFO <general>: CAddonMgr::FindAddons: plugin.video.joj.sk v1.4.3 installed
2022-04-09 17:57:46.365 T:740      INFO <general>: CAddonMgr::FindAddons: plugin.video.youtube v6.8.18+matrix.1 installed
2022-04-09 17:57:46.365 T:740      INFO <general>: CAddonMgr::FindAddons: repository.xbmc-kodi.cz v1.2.0 installed
2022-04-09 17:57:46.365 T:740      INFO <general>: CAddonMgr::FindAddons: repository.xbmc.org v3.2.5 installed
2022-04-09 17:57:46.365 T:740      INFO <general>: CAddonMgr::FindAddons: resource.images.weathericons.default v1.1.9 installed
2022-04-09 17:57:46.366 T:740      INFO <general>: CAddonMgr::FindAddons: resource.language.en_gb v2.0.2 installed
2022-04-09 17:57:46.366 T:740      INFO <general>: CAddonMgr::FindAddons: resource.uisounds.kodi v1.0.1 installed
2022-04-09 17:57:46.366 T:740      INFO <general>: CAddonMgr::FindAddons: screensaver.xbmc.builtin.black v1.0.34 installed
2022-04-09 17:57:46.367 T:740      INFO <general>: CAddonMgr::FindAddons: screensaver.xbmc.builtin.dim v1.0.64 installed
2022-04-09 17:57:46.367 T:740      INFO <general>: CAddonMgr::FindAddons: script.common.plugin.cache v2.6.3+matrix.1 installed
2022-04-09 17:57:46.367 T:740      INFO <general>: CAddonMgr::FindAddons: script.module.beautifulsoup4 v4.9.3+matrix.1 installed
2022-04-09 17:57:46.368 T:740      INFO <general>: CAddonMgr::FindAddons: script.module.certifi v2020.12.05+matrix.1 installed
2022-04-09 17:57:46.368 T:740      INFO <general>: CAddonMgr::FindAddons: script.module.chardet v4.0.0+matrix.1 installed
2022-04-09 17:57:46.368 T:740      INFO <general>: CAddonMgr::FindAddons: script.module.demjson v2.3.0 installed
2022-04-09 17:57:46.368 T:740      INFO <general>: CAddonMgr::FindAddons: script.module.html5lib v1.0.1+matrix.2 installed
2022-04-09 17:57:46.369 T:740      INFO <general>: CAddonMgr::FindAddons: script.module.idna v2.10.0+matrix.1 installed
2022-04-09 17:57:46.369 T:740      INFO <general>: CAddonMgr::FindAddons: script.module.pil v5.1.0 installed
2022-04-09 17:57:46.369 T:740      INFO <general>: CAddonMgr::FindAddons: script.module.pycryptodome v3.4.3 installed
2022-04-09 17:57:46.370 T:740      INFO <general>: CAddonMgr::FindAddons: script.module.requests v2.25.1+matrix.1 installed
2022-04-09 17:57:46.370 T:740      INFO <general>: CAddonMgr::FindAddons: script.module.six v1.15.0+matrix.1 installed
2022-04-09 17:57:46.370 T:740      INFO <general>: CAddonMgr::FindAddons: script.module.soupsieve v2.1.0+matrix.1 installed
2022-04-09 17:57:46.370 T:740      INFO <general>: CAddonMgr::FindAddons: script.module.stream.resolver v1.7.3 installed
2022-04-09 17:57:46.371 T:740      INFO <general>: CAddonMgr::FindAddons: script.module.urllib3 v1.26.4+matrix.1 installed
2022-04-09 17:57:46.371 T:740      INFO <general>: CAddonMgr::FindAddons: script.module.webencodings v0.5.1+matrix.2 installed
2022-04-09 17:57:46.371 T:740      INFO <general>: CAddonMgr::FindAddons: service.xbmc.versioncheck v0.5.22+matrix.1 installed
2022-04-09 17:57:46.372 T:740      INFO <general>: CAddonMgr::FindAddons: skin.estouchy v3.0.6 installed
2022-04-09 17:57:46.372 T:740      INFO <general>: CAddonMgr::FindAddons: skin.estuary v3.0.5 installed
2022-04-09 17:57:46.372 T:740      INFO <general>: CAddonMgr::FindAddons: webinterface.default v19.x-2.4.8 installed
2022-04-09 17:57:46.373 T:740      INFO <general>: CAddonMgr::FindAddons: xbmc.addon v19.1.0 installed
2022-04-09 17:57:46.373 T:740      INFO <general>: CAddonMgr::FindAddons: xbmc.core v0.1.0 installed
2022-04-09 17:57:46.373 T:740      INFO <general>: CAddonMgr::FindAddons: xbmc.gui v5.15.0 installed
2022-04-09 17:57:46.373 T:740      INFO <general>: CAddonMgr::FindAddons: xbmc.json v12.4.0 installed
2022-04-09 17:57:46.374 T:740      INFO <general>: CAddonMgr::FindAddons: xbmc.metadata v2.1.0 installed
2022-04-09 17:57:46.374 T:740      INFO <general>: CAddonMgr::FindAddons: xbmc.python v3.0.0 installed
2022-04-09 17:57:46.374 T:740      INFO <general>: CAddonMgr::FindAddons: xbmc.webinterface v1.0.0 installed
2022-04-09 17:57:46.400 T:740      INFO <general>: Selected Logind/UPower as PowerSyscall
2022-04-09 17:57:46.400 T:740     ERROR <general>: DBus error: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
2022-04-09 17:57:46.400 T:740      INFO <general>: LogindUPowerSyscall - UPower not found, battery information will not be available
2022-04-09 17:57:46.569 T:747      INFO <general>: Found 1 Lists of Devices
2022-04-09 17:57:46.569 T:747      INFO <general>: Enumerated ALSA devices:
2022-04-09 17:57:46.569 T:747      INFO <general>:     Device 1
2022-04-09 17:57:46.570 T:747      INFO <general>:         m_deviceName      : default
2022-04-09 17:57:46.570 T:747      INFO <general>:         m_displayName     : Default (bcm2835 HDMI 1 bcm2835 HDMI 1)
2022-04-09 17:57:46.570 T:747      INFO <general>:         m_displayNameExtra:
2022-04-09 17:57:46.570 T:747      INFO <general>:         m_deviceType      : AE_DEVTYPE_PCM
2022-04-09 17:57:46.570 T:747      INFO <general>:         m_channels        : FL, FR, BL, BR, FC, LFE, SL, SR
2022-04-09 17:57:46.570 T:747      INFO <general>:         m_sampleRates     : 8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
2022-04-09 17:57:46.570 T:747      INFO <general>:         m_dataFormats     : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
2022-04-09 17:57:46.570 T:747      INFO <general>:         m_streamTypes     : No passthrough capabilities
2022-04-09 17:57:46.570 T:747      INFO <general>:     Device 2
2022-04-09 17:57:46.570 T:747      INFO <general>:         m_deviceName      : sysdefault:CARD=b1
2022-04-09 17:57:46.570 T:747      INFO <general>:         m_displayName     : bcm2835 HDMI 1
2022-04-09 17:57:46.570 T:747      INFO <general>:         m_displayNameExtra: bcm2835 HDMI 1
2022-04-09 17:57:46.570 T:747      INFO <general>:     Device 3
2022-04-09 17:57:46.570 T:747      INFO <general>:         m_deviceName      : sysdefault:CARD=Headphones
2022-04-09 17:57:46.570 T:747      INFO <general>:         m_displayName     : bcm2835 Headphones
2022-04-09 17:57:46.570 T:747      INFO <general>:         m_displayNameExtra: bcm2835 Headphones
2022-04-09 17:57:46.570 T:748      INFO <general>: CActiveAESink::OpenSink - initialize sink
2022-04-09 17:57:46.570 T:748      INFO <general>: CAESinkALSA::Initialize - Attempting to open device "default"
2022-04-09 17:57:46.575 T:748      INFO <general>: CAESinkALSA::Initialize - Opened device "default"
2022-04-09 17:57:46.576 T:748      INFO <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2022-04-09 17:57:46.576 T:748      INFO <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S16NE
2022-04-09 17:57:46.594 T:740      INFO <general>: CKeyboardLayoutManager: loading keyboard layouts from special://xbmc/system/keyboardlayouts...
2022-04-09 17:57:46.812 T:740      INFO <general>: RetroPlayer[PROCESS]: Registering process control for GBM
2022-04-09 17:57:46.813 T:740      INFO <general>: RetroPlayer[RENDER]: Registering renderer factory for DMA
2022-04-09 17:57:46.813 T:740      INFO <general>: RetroPlayer[RENDER]: Registering renderer factory for OpenGLES
2022-04-09 17:57:46.870 T:740      INFO <general>: CDRMUtils::FindConnector - using connector: 89
2022-04-09 17:57:46.925 T:740      INFO <general>: Skipped 1 duplicate messages..
2022-04-09 17:57:46.925 T:740      INFO <general>: CDRMUtils::FindEncoder - using encoder: 88
2022-04-09 17:57:46.926 T:740      INFO <general>: CDRMUtils::FindPlanes - using crtc: 87
2022-04-09 17:57:47.012 T:746      INFO <general>: Loading special://xbmc/system/Lircmap.xml
2022-04-09 17:57:47.017 T:746      INFO <general>: * Adding remote mapping for device 'mceusb'
2022-04-09 17:57:47.017 T:746      INFO <general>: * Adding remote mapping for device 'XboxDVDDongle'
2022-04-09 17:57:47.017 T:746      INFO <general>: * Adding remote mapping for device 'Microsoft_Xbox'
2022-04-09 17:57:47.017 T:746      INFO <general>: * Adding remote mapping for device 'PinnacleSysPCTVRemote'
2022-04-09 17:57:47.017 T:746      INFO <general>: * Adding remote mapping for device 'anysee'
2022-04-09 17:57:47.017 T:746      INFO <general>: * Adding remote mapping for device 'iMON-PAD'
2022-04-09 17:57:47.017 T:746      INFO <general>: * Adding remote mapping for device 'Antec_Veris_RM200'
2022-04-09 17:57:47.017 T:746      INFO <general>: * Adding remote mapping for device 'MCE_via_iMON'
2022-04-09 17:57:47.017 T:746      INFO <general>: * Adding remote mapping for device 'TwinHanRemote'
2022-04-09 17:57:47.017 T:746      INFO <general>: * Adding remote mapping for device 'linux-input-layer'
2022-04-09 17:57:47.018 T:746      INFO <general>: * Linking remote mapping for 'linux-input-layer' to 'cx23885_remote'
2022-04-09 17:57:47.018 T:746      INFO <general>: * Adding remote mapping for device 'mediacenter'
2022-04-09 17:57:47.018 T:746      INFO <general>: * Adding remote mapping for device 'devinput'
2022-04-09 17:57:47.018 T:746      INFO <general>: * Adding remote mapping for device 'devinput-32'
2022-04-09 17:57:47.018 T:746      INFO <general>: * Adding remote mapping for device 'devinput-64'
2022-04-09 17:57:48.875 T:740      INFO <general>: Found resolution 1280x720 with 1280x720 @ 50.000000 Hz
2022-04-09 17:57:48.875 T:740      INFO <general>: Found resolution 1920x1080 with 1920x1080i @ 50.000000 Hz
2022-04-09 17:57:48.875 T:740      INFO <general>: Found resolution 1024x768 with 1024x768 @ 75.000000 Hz
2022-04-09 17:57:48.875 T:740      INFO <general>: Found resolution 1024x768 with 1024x768 @ 70.000000 Hz
2022-04-09 17:57:48.875 T:740      INFO <general>: Found resolution 1024x768 with 1024x768 @ 60.000000 Hz
2022-04-09 17:57:48.875 T:740      INFO <general>: Found resolution 832x624 with 832x624 @ 74.925079 Hz
2022-04-09 17:57:48.875 T:740      INFO <general>: Found resolution 800x600 with 800x600 @ 75.000000 Hz
2022-04-09 17:57:48.875 T:740      INFO <general>: Found resolution 800x600 with 800x600 @ 72.000000 Hz
2022-04-09 17:57:48.875 T:740      INFO <general>: Found resolution 800x600 with 800x600 @ 60.000000 Hz
2022-04-09 17:57:48.875 T:740      INFO <general>: Found resolution 800x600 with 800x600 @ 56.000000 Hz
2022-04-09 17:57:48.875 T:740      INFO <general>: Found resolution 720x576 with 720x576 @ 50.000000 Hz
2022-04-09 17:57:48.875 T:740      INFO <general>: Found resolution 640x480 with 640x480 @ 75.000000 Hz
2022-04-09 17:57:48.875 T:740      INFO <general>: Found resolution 640x480 with 640x480 @ 73.000000 Hz
2022-04-09 17:57:48.875 T:740      INFO <general>: Found resolution 640x480 with 640x480 @ 67.000000 Hz
2022-04-09 17:57:48.876 T:740      INFO <general>: Found resolution 640x480 with 640x480 @ 60.000000 Hz
2022-04-09 17:57:48.876 T:740      INFO <general>: Skipped 1 duplicate messages..
2022-04-09 17:57:48.876 T:740      INFO <general>: Found resolution 720x400 with 720x400 @ 70.000000 Hz
2022-04-09 17:57:48.881 T:740      INFO <general>: EGL_VERSION = 1.4
2022-04-09 17:57:48.881 T:740      INFO <general>: EGL_VENDOR = Mesa Project
2022-04-09 17:57:48.882 T:740      INFO <general>: EGL_EXTENSIONS = EGL_ANDROID_blob_cache EGL_EXT_buffer_age EGL_EXT_image_dma_buf_import EGL_EXT_image_dma_buf_import_modifiers EGL_KHR_cl_event2 EGL_KHR_config_attribs EGL_KHR_create_context EGL_KHR_create_context_no_error EGL_KHR_fence_sync EGL_KHR_get_all_proc_addresses EGL_KHR_gl_colorspace EGL_KHR_gl_renderbuffer_image EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_3D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_no_config_context EGL_KHR_reusable_sync EGL_KHR_surfaceless_context EGL_EXT_pixel_format_float EGL_KHR_wait_sync EGL_MESA_configless_context EGL_MESA_drm_image EGL_MESA_image_dma_buf_export EGL_MESA_query_driver EGL_WL_bind_wayland_display
2022-04-09 17:57:48.882 T:740      INFO <general>: EGL_CLIENT_EXTENSIONS = EGL_EXT_device_base EGL_EXT_device_enumeration EGL_EXT_device_query EGL_EXT_platform_base EGL_KHR_client_get_all_proc_addresses EGL_EXT_client_extensions EGL_KHR_debug EGL_EXT_platform_device EGL_EXT_platform_wayland EGL_KHR_platform_wayland EGL_EXT_platform_x11 EGL_KHR_platform_x11 EGL_MESA_platform_xcb EGL_MESA_platform_gbm EGL_KHR_platform_gbm EGL_MESA_platform_surfaceless
2022-04-09 17:57:48.998 T:740      INFO <general>: CApplication::CreateGUI - using the gbm windowing system
2022-04-09 17:57:48.998 T:740      INFO <general>: Checking resolution 19
2022-04-09 17:57:49.034 T:740      INFO <general>: GL_VENDOR = Broadcom
2022-04-09 17:57:49.034 T:740      INFO <general>: GL_RENDERER = V3D 4.2
2022-04-09 17:57:49.035 T:740      INFO <general>: GL_VERSION = OpenGL ES 3.1 Mesa 21.3.7
2022-04-09 17:57:49.035 T:740      INFO <general>: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.10
2022-04-09 17:57:49.035 T:740      INFO <general>: GL_EXTENSIONS = GL_EXT_blend_minmax GL_EXT_multi_draw_arrays GL_EXT_texture_compression_s3tc GL_EXT_texture_compression_dxt1 GL_EXT_texture_format_BGRA8888 GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth24 GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_mapbuffer GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_stencil8 GL_OES_texture_3D GL_OES_texture_float GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_half_float GL_EXT_draw_instanced GL_EXT_texture_sRGB_decode GL_OES_EGL_image GL_OES_depth_texture GL_AMD_performance_monitor GL_OES_packed_depth_stencil GL_EXT_texture_type_2_10_10_10_REV GL_OES_get_program_binary GL_APPLE_texture_max_level GL_EXT_discard_framebuffer GL_EXT_read_format_bgra GL_EXT_frag_depth GL_NV_fbo_color_attachments GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_vertex_array_object GL_ANGLE_pack_reverse_row_order GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_EXT_occlusion_query_boolean GL_EXT_texture_rg GL_EXT_unpack_subimage GL_NV_draw_buffers GL_NV_read_buffer GL_NV_read_depth GL_NV_read_depth_stencil GL_NV_read_stencil GL_EXT_draw_buffers GL_EXT_map_buffer_range GL_KHR_debug GL_KHR_texture_compression_astc_ldr GL_NV_pixel_buffer_object GL_OES_depth_texture_cube_map GL_OES_required_internalformat GL_OES_surfaceless_context GL_EXT_color_buffer_float GL_EXT_sRGB_write_control GL_EXT_separate_shader_objects GL_EXT_shader_implicit_conversions GL_EXT_shader_integer_mix GL_EXT_base_instance GL_EXT_compressed_ETC1_RGB8_sub_texture GL_EXT_draw_elements_base_vertex GL_EXT_primitive_bounding_box GL_EXT_shader_io_blocks GL_EXT_texture_border_clamp GL_KHR_context_flush_control GL_NV_image_formats GL_OES_draw_elements_base_vertex GL_OES_primitive_bounding_box GL_OES_shader_io_blocks GL_OES_texture_border_clamp GL_OES_texture_stencil8 GL_OES_texture_storage_multisample_2d_array GL_EXT_buffer_storage GL_EXT_float_blend GL_EXT_geometry_point_size GL_EXT_geometry_shader GL_KHR_no_error GL_KHR_texture_compression_astc_sliced_3d GL_OES_EGL_image_external_essl3 GL_OES_geometry_point_size GL_OES_geometry_shader GL_OES_shader_image_atomic GL_EXT_texture_compression_s3tc_srgb GL_MESA_shader_integer_functions GL_EXT_texture_mirror_clamp_to_edge GL_KHR_parallel_shader_compile GL_EXT_EGL_image_storage GL_MESA_framebuffer_flip_y GL_EXT_texture_query_lod GL_MESA_bgra
2022-04-09 17:57:49.968 T:740      INFO <general>: GLES: Maximum texture width: 4096
2022-04-09 17:57:50.612 T:740      INFO <general>: load keymapping
2022-04-09 17:57:50.615 T:740      INFO <general>: Loading special://xbmc/system/keymaps/appcommand.xml
2022-04-09 17:57:50.616 T:740      INFO <general>: Loading special://xbmc/system/keymaps/customcontroller.AppleRemote.xml
2022-04-09 17:57:50.620 T:740      INFO <general>: Loading special://xbmc/system/keymaps/customcontroller.Harmony.xml
2022-04-09 17:57:50.625 T:740      INFO <general>: Loading special://xbmc/system/keymaps/customcontroller.SiriRemote.xml
2022-04-09 17:57:50.627 T:740      INFO <general>: Loading special://xbmc/system/keymaps/gamepad.xml
2022-04-09 17:57:50.630 T:740      INFO <general>: Loading special://xbmc/system/keymaps/joystick.xml
2022-04-09 17:57:50.634 T:740      INFO <general>: Loading special://xbmc/system/keymaps/keyboard.xml
2022-04-09 17:57:50.643 T:740      INFO <general>: Loading special://xbmc/system/keymaps/mouse.xml
2022-04-09 17:57:50.644 T:740      INFO <general>: Loading special://xbmc/system/keymaps/remote.xml
2022-04-09 17:57:50.647 T:740      INFO <general>: Loading special://xbmc/system/keymaps/touchscreen.xml
2022-04-09 17:57:50.649 T:740      INFO <general>: GUI format 1024x768, Display 1024x768 @ 75.000000 Hz
2022-04-09 17:57:50.649 T:740      INFO <general>: CLangInfo: loading resource.language.en_gb language information...
2022-04-09 17:57:50.678 T:740      INFO <general>: global locale set to C
2022-04-09 17:57:50.678 T:740      INFO <general>: CLangInfo: loading resource.language.en_gb language strings...
2022-04-09 17:57:50.784 T:764      INFO <general>: Running database version Addons33
2022-04-09 17:57:50.786 T:764      INFO <general>: Running database version ViewModes6
2022-04-09 17:57:50.789 T:764      INFO <general>: Running database version Textures13
2022-04-09 17:57:50.800 T:764      INFO <general>: Running database version MyMusic82
2022-04-09 17:57:50.812 T:764      INFO <general>: Running database version MyVideos119
2022-04-09 17:57:50.815 T:764      INFO <general>: Running database version TV38
2022-04-09 17:57:50.818 T:764      INFO <general>: Running database version Epg13
2022-04-09 17:57:50.832 T:740      INFO <general>: start dvd mediatype detection
2022-04-09 17:57:51.431 T:764      INFO <general>: ADDON: waiting for add-ons to update...
2022-04-09 17:57:51.791 T:764      INFO <general>: ADDON: inputstream.adaptive version 2.4.4 is incompatible
2022-04-09 17:57:51.943 T:740      INFO <general>: Unloaded skin
2022-04-09 17:57:51.949 T:740      INFO <general>:   load skin from: /usr/share/kodi/addons/skin.estuary/ (version: 3.0.5)
2022-04-09 17:57:51.949 T:740      INFO <general>:   load fonts for skin...
2022-04-09 17:57:51.954 T:740      INFO <general>: Loading skin includes from /usr/share/kodi/addons/skin.estuary/xml/Includes.xml
2022-04-09 17:57:52.032 T:740      INFO <general>: Loading fonts from /usr/share/kodi/addons/skin.estuary/xml/Font.xml
2022-04-09 17:57:52.158 T:740      INFO <general>:   load new skin...
2022-04-09 17:57:52.158 T:740      INFO <general>: Loading custom window XMLs from skin path /usr/share/kodi/addons/skin.estuary/xml
2022-04-09 17:57:52.174 T:740      INFO <general>:   initialize new skin...
2022-04-09 17:57:52.174 T:740      INFO <general>: Loading skin file: Custom_1109_TopBarOverlay.xml, load type: LOAD_ON_GUI_INIT
2022-04-09 17:57:52.206 T:740      INFO <general>: Loading skin file: DialogVolumeBar.xml, load type: LOAD_ON_GUI_INIT
2022-04-09 17:57:52.210 T:740      INFO <general>: Loading skin file: DialogBusy.xml, load type: LOAD_ON_GUI_INIT
2022-04-09 17:57:52.212 T:740      INFO <general>: Loading skin file: Pointer.xml, load type: LOAD_ON_GUI_INIT
2022-04-09 17:57:52.216 T:740      INFO <general>: Loading skin file: DialogExtendedProgressBar.xml, load type: LOAD_ON_GUI_INIT
2022-04-09 17:57:52.219 T:740      INFO <general>: Loading skin file: DialogSeekBar.xml, load type: LOAD_ON_GUI_INIT
2022-04-09 17:57:52.240 T:740      INFO <general>: Loading skin file: DialogNotification.xml, load type: LOAD_ON_GUI_INIT
2022-04-09 17:57:52.242 T:740      INFO <general>: Loading skin file: DialogBusy.xml, load type: LOAD_ON_GUI_INIT
2022-04-09 17:57:52.245 T:740      INFO <general>: Loading resource://resource.uisounds.kodi/sounds.xml
2022-04-09 17:57:52.323 T:740      INFO <general>:   skin loaded...
2022-04-09 17:57:52.323 T:740      INFO <general>: Loading skin file: Startup.xml, load type: LOAD_EVERY_TIME
2022-04-09 17:57:52.324 T:740      INFO <general>: Loading skin file: Home.xml, load type: KEEP_IN_MEMORY
2022-04-09 17:57:52.596 T:740   WARNING <general>: JSONRPC: Could not parse type "Setting.Details.SettingList"
2022-04-09 17:57:52.596 T:740      INFO <general>: JSONRPC: Adding type "Setting.Details.SettingList" to list of incomplete definitions (waiting for "Setting.Details.Setting")
2022-04-09 17:57:52.596 T:740      INFO <general>: JSONRPC: Resolving incomplete types/methods referencing Setting.Details.Setting
2022-04-09 17:57:52.618 T:740      INFO <general>: JSONRPC v12.4.0: Successfully initialized
2022-04-09 17:57:52.628 T:740      INFO <general>: Register - new keyboard device registered on application->keyboard: Keyboard (0000:0000)
2022-04-09 17:57:52.631 T:740      INFO <general>: Register - new mouse device registered on application->mouse: Mouse (0000:0000)
2022-04-09 17:57:52.632 T:740      INFO <general>: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
2022-04-09 17:57:52.634 T:740      INFO <general>: Loaded playercorefactory configuration
2022-04-09 17:57:52.634 T:740      INFO <general>: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
2022-04-09 17:57:52.634 T:740      INFO <general>: special://masterprofile/playercorefactory.xml does not exist. Skipping.
2022-04-09 17:57:52.634 T:740      INFO <general>: removing tempfiles
2022-04-09 17:57:52.648 T:779      INFO <general>: initializing python engine.
2022-04-09 17:57:52.649 T:740      INFO <general>: Skipped 1 duplicate messages..
2022-04-09 17:57:52.649 T:740      INFO <general>: initialize done
2022-04-09 17:57:52.649 T:740      INFO <general>: Running the application...
2022-04-09 17:57:52.649 T:740      INFO <general>: Loading skin file: DialogConfirm.xml, load type: KEEP_IN_MEMORY
2022-04-09 17:57:52.649 T:781      INFO <general>: initializing python engine.
2022-04-09 17:57:52.677 T:740      INFO <general>: CZeroconfAvahi::clientCallback: avahi server not available. But may become later...
2022-04-09 17:57:52.677 T:740      INFO <general>: starting zeroconf publishing
2022-04-09 17:57:52.678 T:783      INFO <general>: ES: Starting UDP Event server on port 9777
2022-04-09 17:57:52.679 T:783      INFO <general>: UDP: Listening on port 9777 (ipv6 : false)
2022-04-09 17:57:52.679 T:740      INFO <general>: JSONRPC Server: Successfully initialized
2022-04-09 17:57:58.838 T:781      INFO <general>: CPythonInvoker(2, /var/lib/kodi/.kodi/addons/service.xbmc.versioncheck/resources/lib/runner.py): script successfully run
2022-04-09 17:57:58.886 T:781      INFO <general>: Python interpreter stopped
2022-04-09 18:08:51.533 T:748      INFO <general>: CActiveAESink::OpenSink - initialize sink
2022-04-09 18:08:51.533 T:748      INFO <general>: CAESinkALSA::Initialize - Attempting to open device "default"
2022-04-09 18:08:51.538 T:748      INFO <general>: CAESinkALSA::Initialize - Opened device "default"
2022-04-09 18:08:51.539 T:748      INFO <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2022-04-09 18:08:51.540 T:748      INFO <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S16NE
2022-04-09 18:08:56.146 T:740      INFO <general>: Loading skin file: MyVideoNav.xml, load type: KEEP_IN_MEMORY
2022-04-09 18:08:56.337 T:2262     INFO <general>: initializing python engine.
2022-04-09 18:08:57.405 T:2262     INFO <general>: ["Initializing provider joj.sk with settings {'downloads': '', 'quality': '0', 'lang': '0'}"]
2022-04-09 18:08:57.433 T:2262     INFO <general>: CPythonInvoker(3, /var/lib/kodi/.kodi/addons/plugin.video.joj.sk/default.py): script successfully run
2022-04-09 18:08:57.538 T:2262     INFO <general>: Python interpreter stopped
2022-04-09 18:08:58.928 T:2284     INFO <general>: initializing python engine.
2022-04-09 18:08:59.758 T:2284     INFO <general>: ["Initializing provider joj.sk with settings {'downloads': '', 'quality': '0', 'lang': '0'}"]
2022-04-09 18:08:59.758 T:2284     INFO <general>: ['[joj.sk] list https://www.joj.sk']
2022-04-09 18:08:59.758 T:2284     INFO <general>: ['[joj.sk] list_base https://www.joj.sk/archiv-filter']
2022-04-09 18:09:02.064 T:2284     INFO <general>: CPythonInvoker(4, /var/lib/kodi/.kodi/addons/plugin.video.joj.sk/default.py): script successfully run
2022-04-09 18:09:02.200 T:2284     INFO <general>: Python interpreter stopped
2022-04-09 18:09:06.997 T:2323     INFO <general>: initializing python engine.
2022-04-09 18:09:07.852 T:2323     INFO <general>: ["Initializing provider joj.sk with settings {'downloads': '', 'quality': '0', 'lang': '0'}"]
2022-04-09 18:09:07.852 T:2323     INFO <general>: ['[joj.sk] list https://videoportal.joj.sk/bez-servitky#s']
2022-04-09 18:09:07.852 T:2323     INFO <general>: ['[joj.sk] list_show https://videoportal.joj.sk/bez-servitky#s']
2022-04-09 18:09:11.768 T:2323     INFO <general>: CPythonInvoker(5, /var/lib/kodi/.kodi/addons/plugin.video.joj.sk/default.py): script successfully run
2022-04-09 18:09:11.894 T:2323     INFO <general>: Python interpreter stopped
2022-04-09 18:09:18.068 T:2350     INFO <general>: initializing python engine.
2022-04-09 18:09:18.878 T:2350     INFO <general>: ["Initializing provider joj.sk with settings {'downloads': '', 'quality': '0', 'lang': '0'}"]
2022-04-09 18:09:19.460 T:2350     INFO <general>: ['filtering by quality setting 0']
2022-04-09 18:09:19.460 T:2350     INFO <general>: ['filtering by language setting 0']
2022-04-09 18:09:19.462 T:740      INFO <general>: Loading skin file: DialogSelect.xml, load type: KEEP_IN_MEMORY
2022-04-09 18:09:25.860 T:2350     INFO <general>: CPythonInvoker(6, /var/lib/kodi/.kodi/addons/plugin.video.joj.sk/default.py): script successfully run
2022-04-09 18:09:25.930 T:740      INFO <general>: VideoPlayer::OpenFile: plugin://plugin.video.joj.sk/?cp=6a6f6a2e736b&play=68747470733a2f2f766964656f706f7274616c2e6a6f6a2e736b2f62657a2d7365727669746b792f6570697a6f64612f39383230322d62657a2d7365727669746b79&
2022-04-09 18:09:25.983 T:2350     INFO <general>: Python interpreter stopped
2022-04-09 18:09:26.063 T:2369     INFO <general>: Creating InputStream
2022-04-09 18:09:26.744 T:2369     INFO <general>: Creating Demuxer
2022-04-09 18:09:29.338 T:2369     INFO <general>: Opening stream: 0 source: 256
2022-04-09 18:09:29.338 T:2369     INFO <general>: Creating video codec with codec id: 27
2022-04-09 18:09:29.338 T:2369     INFO <general>: CDVDVideoCodecDRMPRIME::Open - using decoder V4L2 mem2mem H.264 decoder wrapper
2022-04-09 18:09:29.370 T:2369     INFO <general>: Creating video thread
2022-04-09 18:09:29.370 T:2379     INFO <general>: running thread: video_thread
2022-04-09 18:09:29.371 T:2369     INFO <general>: Opening stream: 1 source: 256
2022-04-09 18:09:29.371 T:2369     INFO <general>: Finding audio codec for: 86018
2022-04-09 18:09:29.372 T:2369     INFO <general>: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder aac
2022-04-09 18:09:29.372 T:2369     INFO <general>: Creating audio thread
2022-04-09 18:09:29.372 T:2380     INFO <general>: running thread: CVideoPlayerAudio::Process()
2022-04-09 18:09:29.383 T:2380     INFO <general>: Creating audio stream (codec id: 86018, channels: 2, sample rate: 48000, no pass-through)
2022-04-09 18:09:29.394 T:748      INFO <general>: CActiveAESink::OpenSink - initialize sink
2022-04-09 18:09:29.603 T:748      INFO <general>: CAESinkALSA::Initialize - Attempting to open device "default"
2022-04-09 18:09:29.610 T:748      INFO <general>: CAESinkALSA::Initialize - Opened device "default"
2022-04-09 18:09:29.611 T:748      INFO <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2022-04-09 18:09:29.611 T:748      INFO <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S16NE
2022-04-09 18:09:29.660 T:740      INFO <general>: Loading skin file: VideoFullScreen.xml, load type: KEEP_IN_MEMORY
2022-04-09 18:09:38.053 T:740      INFO <general>: CVideoPlayer::CloseFile()
2022-04-09 18:09:38.054 T:740      INFO <general>: VideoPlayer: waiting for threads to exit
2022-04-09 18:09:38.061 T:2369     INFO <general>: CVideoPlayer::OnExit()
2022-04-09 18:09:38.061 T:2369     INFO <general>: Closing stream player 1
2022-04-09 18:09:38.061 T:2369     INFO <general>: Waiting for audio thread to exit
2022-04-09 18:09:38.072 T:2380     INFO <general>: thread end: CVideoPlayerAudio::OnExit()
2022-04-09 18:09:38.073 T:2369     INFO <general>: Closing audio device
2022-04-09 18:09:38.123 T:2369     INFO <general>: Deleting audio codec
2022-04-09 18:09:38.123 T:748      INFO <general>: CActiveAESink::OpenSink - initialize sink
2022-04-09 18:09:38.124 T:2369     INFO <general>: Closing stream player 2
2022-04-09 18:09:38.124 T:2369     INFO <general>: waiting for video thread to exit
2022-04-09 18:09:38.140 T:2379  WARNING <general>: OutputPicture - timeout waiting for buffer
2022-04-09 18:09:38.141 T:2379     INFO <general>: thread end: video_thread
2022-04-09 18:09:38.141 T:2369     INFO <general>: deleting video codec
2022-04-09 18:09:38.171 T:740      INFO <general>: VideoPlayer: finished waiting
2022-04-09 18:09:38.171 T:740      INFO <general>: CVideoPlayer::CloseFile()
2022-04-09 18:09:38.171 T:740      INFO <general>: VideoPlayer: waiting for threads to exit
2022-04-09 18:09:38.172 T:740      INFO <general>: VideoPlayer: finished waiting
2022-04-09 18:09:38.296 T:740     ERROR <general>: Control 55 in window 10025 has been asked to focus, but it can't
2022-04-09 18:09:38.299 T:748      INFO <general>: CAESinkALSA::Initialize - Attempting to open device "default"
2022-04-09 18:09:38.307 T:748      INFO <general>: CAESinkALSA::Initialize - Opened device "default"
2022-04-09 18:09:38.308 T:748      INFO <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2022-04-09 18:09:38.309 T:748      INFO <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S16NE
2022-04-09 18:09:38.576 T:2413     INFO <general>: initializing python engine.
2022-04-09 18:09:39.394 T:2413     INFO <general>: ["Initializing provider joj.sk with settings {'downloads': '', 'quality': '0', 'lang': '0'}"]
2022-04-09 18:09:39.394 T:2413     INFO <general>: ['[joj.sk] list https://videoportal.joj.sk/bez-servitky#s']
2022-04-09 18:09:39.395 T:2413     INFO <general>: ['[joj.sk] list_show https://videoportal.joj.sk/bez-servitky#s']
2022-04-09 18:09:42.873 T:2413     INFO <general>: CPythonInvoker(7, /var/lib/kodi/.kodi/addons/plugin.video.joj.sk/default.py): script successfully run
2022-04-09 18:09:43.012 T:2413     INFO <general>: Python interpreter stopped
2022-04-09 18:09:49.247 T:2438     INFO <general>: initializing python engine.
2022-04-09 18:09:50.070 T:2438    ERROR <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                                    - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
                                                   Error Type: <class 'AttributeError'>
                                                   Error Contents: 'int' object has no attribute 'Addon'
                                                   -->End of Python script error report<--
2022-04-09 18:09:50.070 T:2438    ERROR <general>: Exception ignored in:
2022-04-09 18:09:50.070 T:2438    ERROR <general>: 768
2022-04-09 18:09:50.070 T:2438    ERROR <general>: AttributeError
2022-04-09 18:09:50.070 T:2438    ERROR <general>: :
2022-04-09 18:09:50.070 T:2438    ERROR <general>: 'int' object has no attribute '_shutdown'
############### END LOG FILE ################
############ END Kodi CRASH LOG #############
do you have any idea what could be wrong? i am hopeless
some new info, i tried some other streaming service i got this new error, dh key too small this could all be related? i found out i need to increase openssl’s seclevel to 1 and i did and still have the error
i appended
[system_default_sect]
MinProtocol = TLSv1.2
CipherString=DEFAULT@SECLEVEL=1
[openssl_init]
ssl_conf = ssl_sect
[ssl_sect]
system_default = system_default_sect
to the end and on the first line
openssl_conf = openssl_init
did i do it right? or is arch’s ssl configuration different one to ubuntus?
here is the new log
 Date: Sat  9 Apr 18:51:12 CEST 2022
 Kodi Options:
 Arch: aarch64
2022-04-09 18:49:39.737 T:780      INFO <general>: -----------------------------------------------------------------------
2022-04-09 18:49:39.737 T:780      INFO <general>: Starting Kodi (19.4 (19.4.0) Git:20220305-nogitfound). Platform: Linux ARM 64-bit
2022-04-09 18:49:39.737 T:780      INFO <general>: Using Release Kodi x64
2022-04-09 18:49:39.737 T:780      INFO <general>: Kodi compiled 2022-03-05 by GCC 11.2.0 for Linux ARM 64-bit version 5.16.8 (331784)
2022-04-09 18:49:39.737 T:780      INFO <general>: Running on BCM2835 with Manjaro ARM 22.03, kernel: Linux ARM 64-bit version 5.15.28-1-MANJARO-ARM-RPI
2022-04-09 18:49:39.741 T:780      INFO <general>: FFmpeg version/source: a819818-kodi-4.3.2-Matrix-19.2
2022-04-09 18:49:39.741 T:780      INFO <general>: 4 CPU cores available
2022-04-09 18:49:39.741 T:780      INFO <general>: ARM Features: Neon enabled
2022-04-09 18:49:39.741 T:780      INFO <general>: special://xbmc/ is mapped to: /usr/share/kodi
2022-04-09 18:49:39.741 T:780      INFO <general>: special://xbmcbin/ is mapped to: /usr/lib/kodi
2022-04-09 18:49:39.741 T:780      INFO <general>: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
2022-04-09 18:49:39.741 T:780      INFO <general>: special://masterprofile/ is mapped to: /var/lib/kodi/.kodi/userdata
2022-04-09 18:49:39.741 T:780      INFO <general>: special://envhome/ is mapped to: /var/lib/kodi
2022-04-09 18:49:39.741 T:780      INFO <general>: special://home/ is mapped to: /var/lib/kodi/.kodi
2022-04-09 18:49:39.741 T:780      INFO <general>: special://temp/ is mapped to: /var/lib/kodi/.kodi/temp
2022-04-09 18:49:39.741 T:780      INFO <general>: special://logpath/ is mapped to: /var/lib/kodi/.kodi/temp
2022-04-09 18:49:39.741 T:780      INFO <general>: The executable running is: /usr/lib/kodi/kodi.bin
2022-04-09 18:49:39.741 T:780      INFO <general>: Local hostname: rpi
2022-04-09 18:49:39.741 T:780      INFO <general>: Log File is located: /var/lib/kodi/.kodi/temp/kodi.log
2022-04-09 18:49:39.747 T:780      INFO <general>: -----------------------------------------------------------------------
2022-04-09 18:49:39.773 T:780      INFO <general>: loading settings
2022-04-09 18:49:39.778 T:780      INFO <general>: special://profile/ is mapped to: special://masterprofile/
2022-04-09 18:49:39.830 T:780      INFO <general>: No settings file to load (special://xbmc/system/advancedsettings.xml)
2022-04-09 18:49:39.830 T:780      INFO <general>: No settings file to load (special://masterprofile/advancedsettings.xml)
2022-04-09 18:49:39.830 T:780      INFO <general>: Default Video Player: VideoPlayer
2022-04-09 18:49:39.830 T:780      INFO <general>: Default Audio Player: paplayer
2022-04-09 18:49:39.830 T:780      INFO <general>: Disabled debug logging due to GUI setting. Level 0.
2022-04-09 18:49:39.830 T:780      INFO <general>: Log level changed to "INFO"
2022-04-09 18:49:39.833 T:780      INFO <general>: creating subdirectories
2022-04-09 18:49:39.833 T:780      INFO <general>: userdata folder: special://masterprofile/
2022-04-09 18:49:39.833 T:780      INFO <general>: recording folder:
2022-04-09 18:49:39.833 T:780      INFO <general>: screenshots folder:
2022-04-09 18:49:39.881 T:780      INFO <general>: Running database version Addons33
2022-04-09 18:49:40.234 T:780      INFO <general>: CAddonMgr::FindAddons: audioencoder.kodi.builtin.aac v1.0.2 installed
2022-04-09 18:49:40.235 T:780      INFO <general>: CAddonMgr::FindAddons: audioencoder.kodi.builtin.wma v1.0.2 installed
2022-04-09 18:49:40.235 T:780      INFO <general>: CAddonMgr::FindAddons: game.controller.default v1.0.20 installed
2022-04-09 18:49:40.235 T:780      INFO <general>: CAddonMgr::FindAddons: game.controller.snes v1.0.19 installed
2022-04-09 18:49:40.235 T:780      INFO <general>: CAddonMgr::FindAddons: inputstream.adaptive v2.4.4 installed
2022-04-09 18:49:40.235 T:780      INFO <general>: CAddonMgr::FindAddons: kodi.binary.global.audioengine v1.1.1 installed
2022-04-09 18:49:40.235 T:780      INFO <general>: CAddonMgr::FindAddons: kodi.binary.global.filesystem v1.1.6 installed
2022-04-09 18:49:40.235 T:780      INFO <general>: CAddonMgr::FindAddons: kodi.binary.global.general v1.0.5 installed
2022-04-09 18:49:40.236 T:780      INFO <general>: CAddonMgr::FindAddons: kodi.binary.global.gui v5.15.0 installed
2022-04-09 18:49:40.236 T:780      INFO <general>: CAddonMgr::FindAddons: kodi.binary.global.main v1.3.0 installed
2022-04-09 18:49:40.236 T:780      INFO <general>: CAddonMgr::FindAddons: kodi.binary.global.network v1.0.4 installed
2022-04-09 18:49:40.236 T:780      INFO <general>: CAddonMgr::FindAddons: kodi.binary.global.tools v1.0.4 installed
2022-04-09 18:49:40.236 T:780      INFO <general>: CAddonMgr::FindAddons: kodi.binary.instance.audiodecoder v3.0.0 installed
2022-04-09 18:49:40.236 T:780      INFO <general>: CAddonMgr::FindAddons: kodi.binary.instance.audioencoder v2.1.0 installed
2022-04-09 18:49:40.236 T:780      INFO <general>: CAddonMgr::FindAddons: kodi.binary.instance.game v2.1.1 installed
2022-04-09 18:49:40.236 T:780      INFO <general>: CAddonMgr::FindAddons: kodi.binary.instance.imagedecoder v2.1.1 installed
2022-04-09 18:49:40.237 T:780      INFO <general>: CAddonMgr::FindAddons: kodi.binary.instance.inputstream v3.0.1 installed
2022-04-09 18:49:40.237 T:780      INFO <general>: CAddonMgr::FindAddons: kodi.binary.instance.peripheral v2.0.0 installed
2022-04-09 18:49:40.237 T:780      INFO <general>: CAddonMgr::FindAddons: kodi.binary.instance.pvr v7.1.0 installed
2022-04-09 18:49:40.237 T:780      INFO <general>: CAddonMgr::FindAddons: kodi.binary.instance.screensaver v2.1.0 installed
2022-04-09 18:49:40.237 T:780      INFO <general>: CAddonMgr::FindAddons: kodi.binary.instance.vfs v3.0.0 installed
2022-04-09 18:49:40.237 T:780      INFO <general>: CAddonMgr::FindAddons: kodi.binary.instance.videocodec v2.0.2 installed
2022-04-09 18:49:40.237 T:780      INFO <general>: CAddonMgr::FindAddons: kodi.binary.instance.visualization v3.0.0 installed
2022-04-09 18:49:40.237 T:780      INFO <general>: CAddonMgr::FindAddons: kodi.resource v1.0.0 installed
2022-04-09 18:49:40.238 T:780      INFO <general>: CAddonMgr::FindAddons: metadata.album.universal v3.1.7 installed
2022-04-09 18:49:40.238 T:780      INFO <general>: CAddonMgr::FindAddons: metadata.artists.universal v4.3.7 installed
2022-04-09 18:49:40.238 T:780      INFO <general>: CAddonMgr::FindAddons: metadata.common.allmusic.com v3.2.2 installed
2022-04-09 18:49:40.238 T:780      INFO <general>: CAddonMgr::FindAddons: metadata.common.fanart.tv v3.6.4 installed
2022-04-09 18:49:40.238 T:780      INFO <general>: CAddonMgr::FindAddons: metadata.common.imdb.com v3.2.5 installed
2022-04-09 18:49:40.238 T:780      INFO <general>: CAddonMgr::FindAddons: metadata.common.musicbrainz.org v2.2.4 installed
2022-04-09 18:49:40.238 T:780      INFO <general>: CAddonMgr::FindAddons: metadata.common.theaudiodb.com v2.0.3 installed
2022-04-09 18:49:40.239 T:780      INFO <general>: CAddonMgr::FindAddons: metadata.common.themoviedb.org v3.2.18 installed
2022-04-09 18:49:40.239 T:780      INFO <general>: CAddonMgr::FindAddons: metadata.generic.albums v1.0.14 installed
2022-04-09 18:49:40.239 T:780      INFO <general>: CAddonMgr::FindAddons: metadata.generic.artists v1.0.14 installed
2022-04-09 18:49:40.239 T:780      INFO <general>: CAddonMgr::FindAddons: metadata.local v1.0.1 installed
2022-04-09 18:49:40.239 T:780      INFO <general>: CAddonMgr::FindAddons: metadata.themoviedb.org v5.2.6 installed
2022-04-09 18:49:40.239 T:780      INFO <general>: CAddonMgr::FindAddons: metadata.themoviedb.org.python v1.6.1+matrix.1 installed
2022-04-09 18:49:40.239 T:780      INFO <general>: CAddonMgr::FindAddons: metadata.tvshows.themoviedb.org v3.5.14 installed
2022-04-09 18:49:40.239 T:780      INFO <general>: CAddonMgr::FindAddons: metadata.tvshows.themoviedb.org.python v1.4.10 installed
2022-04-09 18:49:40.240 T:780      INFO <general>: CAddonMgr::FindAddons: plugin.video.joj.sk v1.4.3 installed
2022-04-09 18:49:40.240 T:780      INFO <general>: CAddonMgr::FindAddons: plugin.video.markiza.sk v1.5.2 installed
2022-04-09 18:49:40.240 T:780      INFO <general>: CAddonMgr::FindAddons: plugin.video.rtvs.sk v1.9.1 installed
2022-04-09 18:49:40.240 T:780      INFO <general>: CAddonMgr::FindAddons: plugin.video.youtube v6.8.18+matrix.1 installed
2022-04-09 18:49:40.240 T:780      INFO <general>: CAddonMgr::FindAddons: repository.xbmc-kodi.cz v1.2.0 installed
2022-04-09 18:49:40.240 T:780      INFO <general>: CAddonMgr::FindAddons: repository.xbmc.org v3.2.5 installed
2022-04-09 18:49:40.240 T:780      INFO <general>: CAddonMgr::FindAddons: resource.images.weathericons.default v1.1.9 installed
2022-04-09 18:49:40.240 T:780      INFO <general>: CAddonMgr::FindAddons: resource.language.en_gb v2.0.2 installed
2022-04-09 18:49:40.241 T:780      INFO <general>: CAddonMgr::FindAddons: resource.uisounds.kodi v1.0.1 installed
2022-04-09 18:49:40.241 T:780      INFO <general>: CAddonMgr::FindAddons: screensaver.xbmc.builtin.black v1.0.34 installed
2022-04-09 18:49:40.241 T:780      INFO <general>: CAddonMgr::FindAddons: screensaver.xbmc.builtin.dim v1.0.64 installed
2022-04-09 18:49:40.241 T:780      INFO <general>: CAddonMgr::FindAddons: script.common.plugin.cache v2.6.3+matrix.1 installed
2022-04-09 18:49:40.241 T:780      INFO <general>: CAddonMgr::FindAddons: script.module.beautifulsoup4 v4.9.3+matrix.1 installed
2022-04-09 18:49:40.241 T:780      INFO <general>: CAddonMgr::FindAddons: script.module.certifi v2020.12.05+matrix.1 installed
2022-04-09 18:49:40.241 T:780      INFO <general>: CAddonMgr::FindAddons: script.module.chardet v4.0.0+matrix.1 installed
2022-04-09 18:49:40.241 T:780      INFO <general>: CAddonMgr::FindAddons: script.module.demjson v2.3.0 installed
2022-04-09 18:49:40.242 T:780      INFO <general>: CAddonMgr::FindAddons: script.module.html5lib v1.0.1+matrix.2 installed
2022-04-09 18:49:40.242 T:780      INFO <general>: CAddonMgr::FindAddons: script.module.idna v2.10.0+matrix.1 installed
2022-04-09 18:49:40.242 T:780      INFO <general>: CAddonMgr::FindAddons: script.module.pil v5.1.0 installed
2022-04-09 18:49:40.242 T:780      INFO <general>: CAddonMgr::FindAddons: script.module.pycryptodome v3.4.3 installed
2022-04-09 18:49:40.242 T:780      INFO <general>: CAddonMgr::FindAddons: script.module.requests v2.25.1+matrix.1 installed
2022-04-09 18:49:40.242 T:780      INFO <general>: CAddonMgr::FindAddons: script.module.six v1.15.0+matrix.1 installed
2022-04-09 18:49:40.242 T:780      INFO <general>: CAddonMgr::FindAddons: script.module.soupsieve v2.1.0+matrix.1 installed
2022-04-09 18:49:40.242 T:780      INFO <general>: CAddonMgr::FindAddons: script.module.stream.resolver v1.7.3 installed
2022-04-09 18:49:40.243 T:780      INFO <general>: CAddonMgr::FindAddons: script.module.urllib3 v1.26.4+matrix.1 installed
2022-04-09 18:49:40.243 T:780      INFO <general>: CAddonMgr::FindAddons: script.module.webencodings v0.5.1+matrix.2 installed
2022-04-09 18:49:40.243 T:780      INFO <general>: CAddonMgr::FindAddons: service.xbmc.versioncheck v0.5.22+matrix.1 installed
2022-04-09 18:49:40.243 T:780      INFO <general>: CAddonMgr::FindAddons: skin.estouchy v3.0.6 installed
2022-04-09 18:49:40.243 T:780      INFO <general>: CAddonMgr::FindAddons: skin.estuary v3.0.5 installed
2022-04-09 18:49:40.243 T:780      INFO <general>: CAddonMgr::FindAddons: webinterface.default v19.x-2.4.8 installed
2022-04-09 18:49:40.243 T:780      INFO <general>: CAddonMgr::FindAddons: xbmc.addon v19.1.0 installed
2022-04-09 18:49:40.243 T:780      INFO <general>: CAddonMgr::FindAddons: xbmc.core v0.1.0 installed
2022-04-09 18:49:40.244 T:780      INFO <general>: CAddonMgr::FindAddons: xbmc.gui v5.15.0 installed
2022-04-09 18:49:40.244 T:780      INFO <general>: CAddonMgr::FindAddons: xbmc.json v12.4.0 installed
2022-04-09 18:49:40.244 T:780      INFO <general>: CAddonMgr::FindAddons: xbmc.metadata v2.1.0 installed
2022-04-09 18:49:40.244 T:780      INFO <general>: CAddonMgr::FindAddons: xbmc.python v3.0.0 installed
2022-04-09 18:49:40.244 T:780      INFO <general>: CAddonMgr::FindAddons: xbmc.webinterface v1.0.0 installed
2022-04-09 18:49:40.273 T:780      INFO <general>: Selected Logind/UPower as PowerSyscall
2022-04-09 18:49:40.274 T:780     ERROR <general>: DBus error: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
2022-04-09 18:49:40.274 T:780      INFO <general>: LogindUPowerSyscall - UPower not found, battery information will not be available
2022-04-09 18:49:40.473 T:800      INFO <general>: Found 1 Lists of Devices
2022-04-09 18:49:40.473 T:800      INFO <general>: Enumerated ALSA devices:
2022-04-09 18:49:40.473 T:800      INFO <general>:     Device 1
2022-04-09 18:49:40.473 T:800      INFO <general>:         m_deviceName      : default
2022-04-09 18:49:40.473 T:800      INFO <general>:         m_displayName     : Default (bcm2835 HDMI 1 bcm2835 HDMI 1)
2022-04-09 18:49:40.473 T:800      INFO <general>:         m_displayNameExtra:
2022-04-09 18:49:40.473 T:800      INFO <general>:         m_deviceType      : AE_DEVTYPE_PCM
2022-04-09 18:49:40.473 T:800      INFO <general>:         m_channels        : FL, FR, BL, BR, FC, LFE, SL, SR
2022-04-09 18:49:40.473 T:800      INFO <general>:         m_sampleRates     : 8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
2022-04-09 18:49:40.473 T:800      INFO <general>:         m_dataFormats     : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
2022-04-09 18:49:40.473 T:800      INFO <general>:         m_streamTypes     : No passthrough capabilities
2022-04-09 18:49:40.473 T:800      INFO <general>:     Device 2
2022-04-09 18:49:40.473 T:800      INFO <general>:         m_deviceName      : sysdefault:CARD=b1
2022-04-09 18:49:40.473 T:800      INFO <general>:         m_displayName     : bcm2835 HDMI 1
2022-04-09 18:49:40.473 T:800      INFO <general>:         m_displayNameExtra: bcm2835 HDMI 1
2022-04-09 18:49:40.473 T:800      INFO <general>:     Device 3
2022-04-09 18:49:40.473 T:800      INFO <general>:         m_deviceName      : sysdefault:CARD=Headphones
2022-04-09 18:49:40.473 T:800      INFO <general>:         m_displayName     : bcm2835 Headphones
2022-04-09 18:49:40.473 T:800      INFO <general>:         m_displayNameExtra: bcm2835 Headphones
2022-04-09 18:49:40.474 T:801      INFO <general>: CActiveAESink::OpenSink - initialize sink
2022-04-09 18:49:40.474 T:801      INFO <general>: CAESinkALSA::Initialize - Attempting to open device "default"
2022-04-09 18:49:40.477 T:801      INFO <general>: CAESinkALSA::Initialize - Opened device "default"
2022-04-09 18:49:40.477 T:801      INFO <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2022-04-09 18:49:40.477 T:801      INFO <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S16NE
2022-04-09 18:49:40.504 T:780      INFO <general>: CKeyboardLayoutManager: loading keyboard layouts from special://xbmc/system/keyboardlayouts...
2022-04-09 18:49:40.732 T:799      INFO <general>: Loading special://xbmc/system/Lircmap.xml
2022-04-09 18:49:40.748 T:799      INFO <general>: * Adding remote mapping for device 'mceusb'
2022-04-09 18:49:40.748 T:799      INFO <general>: * Adding remote mapping for device 'XboxDVDDongle'
2022-04-09 18:49:40.749 T:799      INFO <general>: * Adding remote mapping for device 'Microsoft_Xbox'
2022-04-09 18:49:40.749 T:799      INFO <general>: * Adding remote mapping for device 'PinnacleSysPCTVRemote'
2022-04-09 18:49:40.749 T:799      INFO <general>: * Adding remote mapping for device 'anysee'
2022-04-09 18:49:40.749 T:799      INFO <general>: * Adding remote mapping for device 'iMON-PAD'
2022-04-09 18:49:40.749 T:799      INFO <general>: * Adding remote mapping for device 'Antec_Veris_RM200'
2022-04-09 18:49:40.749 T:799      INFO <general>: * Adding remote mapping for device 'MCE_via_iMON'
2022-04-09 18:49:40.749 T:799      INFO <general>: * Adding remote mapping for device 'TwinHanRemote'
2022-04-09 18:49:40.749 T:799      INFO <general>: * Adding remote mapping for device 'linux-input-layer'
2022-04-09 18:49:40.749 T:799      INFO <general>: * Linking remote mapping for 'linux-input-layer' to 'cx23885_remote'
2022-04-09 18:49:40.749 T:799      INFO <general>: * Adding remote mapping for device 'mediacenter'
2022-04-09 18:49:40.749 T:799      INFO <general>: * Adding remote mapping for device 'devinput'
2022-04-09 18:49:40.749 T:799      INFO <general>: * Adding remote mapping for device 'devinput-32'
2022-04-09 18:49:40.749 T:799      INFO <general>: * Adding remote mapping for device 'devinput-64'
2022-04-09 18:49:41.565 T:780      INFO <general>: RetroPlayer[PROCESS]: Registering process control for GBM
2022-04-09 18:49:41.565 T:780      INFO <general>: RetroPlayer[RENDER]: Registering renderer factory for DMA
2022-04-09 18:49:41.565 T:780      INFO <general>: RetroPlayer[RENDER]: Registering renderer factory for OpenGLES
2022-04-09 18:49:41.620 T:780      INFO <general>: CDRMUtils::FindConnector - using connector: 89
2022-04-09 18:49:41.680 T:780      INFO <general>: Skipped 1 duplicate messages..
2022-04-09 18:49:41.680 T:780      INFO <general>: CDRMUtils::FindEncoder - using encoder: 88
2022-04-09 18:49:41.680 T:780      INFO <general>: CDRMUtils::FindPlanes - using crtc: 87
2022-04-09 18:49:44.052 T:780      INFO <general>: Found resolution 1280x720 with 1280x720 @ 50.000000 Hz
2022-04-09 18:49:44.052 T:780      INFO <general>: Found resolution 1920x1080 with 1920x1080i @ 50.000000 Hz
2022-04-09 18:49:44.052 T:780      INFO <general>: Found resolution 1024x768 with 1024x768 @ 75.000000 Hz
2022-04-09 18:49:44.052 T:780      INFO <general>: Found resolution 1024x768 with 1024x768 @ 70.000000 Hz
2022-04-09 18:49:44.052 T:780      INFO <general>: Found resolution 1024x768 with 1024x768 @ 60.000000 Hz
2022-04-09 18:49:44.052 T:780      INFO <general>: Found resolution 832x624 with 832x624 @ 74.925079 Hz
2022-04-09 18:49:44.053 T:780      INFO <general>: Found resolution 800x600 with 800x600 @ 75.000000 Hz
2022-04-09 18:49:44.053 T:780      INFO <general>: Found resolution 800x600 with 800x600 @ 72.000000 Hz
2022-04-09 18:49:44.053 T:780      INFO <general>: Found resolution 800x600 with 800x600 @ 60.000000 Hz
2022-04-09 18:49:44.053 T:780      INFO <general>: Found resolution 800x600 with 800x600 @ 56.000000 Hz
2022-04-09 18:49:44.053 T:780      INFO <general>: Found resolution 720x576 with 720x576 @ 50.000000 Hz
2022-04-09 18:49:44.053 T:780      INFO <general>: Found resolution 640x480 with 640x480 @ 75.000000 Hz
2022-04-09 18:49:44.053 T:780      INFO <general>: Found resolution 640x480 with 640x480 @ 73.000000 Hz
2022-04-09 18:49:44.053 T:780      INFO <general>: Found resolution 640x480 with 640x480 @ 67.000000 Hz
2022-04-09 18:49:44.053 T:780      INFO <general>: Found resolution 640x480 with 640x480 @ 60.000000 Hz
2022-04-09 18:49:44.053 T:780      INFO <general>: Skipped 1 duplicate messages..
2022-04-09 18:49:44.053 T:780      INFO <general>: Found resolution 720x400 with 720x400 @ 70.000000 Hz
2022-04-09 18:49:44.058 T:780      INFO <general>: EGL_VERSION = 1.4
2022-04-09 18:49:44.058 T:780      INFO <general>: EGL_VENDOR = Mesa Project
2022-04-09 18:49:44.058 T:780      INFO <general>: EGL_EXTENSIONS = EGL_ANDROID_blob_cache EGL_EXT_buffer_age EGL_EXT_image_dma_buf_import EGL_EXT_image_dma_buf_import_modifiers EGL_KHR_cl_event2 EGL_KHR_config_attribs EGL_KHR_create_context EGL_KHR_create_context_no_error EGL_KHR_fence_sync EGL_KHR_get_all_proc_addresses EGL_KHR_gl_colorspace EGL_KHR_gl_renderbuffer_image EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_3D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_no_config_context EGL_KHR_reusable_sync EGL_KHR_surfaceless_context EGL_EXT_pixel_format_float EGL_KHR_wait_sync EGL_MESA_configless_context EGL_MESA_drm_image EGL_MESA_image_dma_buf_export EGL_MESA_query_driver EGL_WL_bind_wayland_display
2022-04-09 18:49:44.058 T:780      INFO <general>: EGL_CLIENT_EXTENSIONS = EGL_EXT_device_base EGL_EXT_device_enumeration EGL_EXT_device_query EGL_EXT_platform_base EGL_KHR_client_get_all_proc_addresses EGL_EXT_client_extensions EGL_KHR_debug EGL_EXT_platform_device EGL_EXT_platform_wayland EGL_KHR_platform_wayland EGL_EXT_platform_x11 EGL_KHR_platform_x11 EGL_MESA_platform_xcb EGL_MESA_platform_gbm EGL_KHR_platform_gbm EGL_MESA_platform_surfaceless
2022-04-09 18:49:44.127 T:780      INFO <general>: CApplication::CreateGUI - using the gbm windowing system
2022-04-09 18:49:44.127 T:780      INFO <general>: Checking resolution 19
2022-04-09 18:49:44.155 T:780      INFO <general>: GL_VENDOR = Broadcom
2022-04-09 18:49:44.155 T:780      INFO <general>: GL_RENDERER = V3D 4.2
2022-04-09 18:49:44.155 T:780      INFO <general>: GL_VERSION = OpenGL ES 3.1 Mesa 21.3.7
2022-04-09 18:49:44.155 T:780      INFO <general>: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.10
2022-04-09 18:49:44.155 T:780      INFO <general>: GL_EXTENSIONS = GL_EXT_blend_minmax GL_EXT_multi_draw_arrays GL_EXT_texture_compression_s3tc GL_EXT_texture_compression_dxt1 GL_EXT_texture_format_BGRA8888 GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth24 GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_mapbuffer GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_stencil8 GL_OES_texture_3D GL_OES_texture_float GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_half_float GL_EXT_draw_instanced GL_EXT_texture_sRGB_decode GL_OES_EGL_image GL_OES_depth_texture GL_AMD_performance_monitor GL_OES_packed_depth_stencil GL_EXT_texture_type_2_10_10_10_REV GL_OES_get_program_binary GL_APPLE_texture_max_level GL_EXT_discard_framebuffer GL_EXT_read_format_bgra GL_EXT_frag_depth GL_NV_fbo_color_attachments GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_vertex_array_object GL_ANGLE_pack_reverse_row_order GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_EXT_occlusion_query_boolean GL_EXT_texture_rg GL_EXT_unpack_subimage GL_NV_draw_buffers GL_NV_read_buffer GL_NV_read_depth GL_NV_read_depth_stencil GL_NV_read_stencil GL_EXT_draw_buffers GL_EXT_map_buffer_range GL_KHR_debug GL_KHR_texture_compression_astc_ldr GL_NV_pixel_buffer_object GL_OES_depth_texture_cube_map GL_OES_required_internalformat GL_OES_surfaceless_context GL_EXT_color_buffer_float GL_EXT_sRGB_write_control GL_EXT_separate_shader_objects GL_EXT_shader_implicit_conversions GL_EXT_shader_integer_mix GL_EXT_base_instance GL_EXT_compressed_ETC1_RGB8_sub_texture GL_EXT_draw_elements_base_vertex GL_EXT_primitive_bounding_box GL_EXT_shader_io_blocks GL_EXT_texture_border_clamp GL_KHR_context_flush_control GL_NV_image_formats GL_OES_draw_elements_base_vertex GL_OES_primitive_bounding_box GL_OES_shader_io_blocks GL_OES_texture_border_clamp GL_OES_texture_stencil8 GL_OES_texture_storage_multisample_2d_array GL_EXT_buffer_storage GL_EXT_float_blend GL_EXT_geometry_point_size GL_EXT_geometry_shader GL_KHR_no_error GL_KHR_texture_compression_astc_sliced_3d GL_OES_EGL_image_external_essl3 GL_OES_geometry_point_size GL_OES_geometry_shader GL_OES_shader_image_atomic GL_EXT_texture_compression_s3tc_srgb GL_MESA_shader_integer_functions GL_EXT_texture_mirror_clamp_to_edge GL_KHR_parallel_shader_compile GL_EXT_EGL_image_storage GL_MESA_framebuffer_flip_y GL_EXT_texture_query_lod GL_MESA_bgra
2022-04-09 18:49:44.402 T:780      INFO <general>: GLES: Maximum texture width: 4096
2022-04-09 18:49:45.113 T:780      INFO <general>: load keymapping
2022-04-09 18:49:45.119 T:780      INFO <general>: Loading special://xbmc/system/keymaps/appcommand.xml
2022-04-09 18:49:45.121 T:780      INFO <general>: Loading special://xbmc/system/keymaps/customcontroller.AppleRemote.xml
2022-04-09 18:49:45.123 T:780      INFO <general>: Loading special://xbmc/system/keymaps/customcontroller.Harmony.xml
2022-04-09 18:49:45.127 T:780      INFO <general>: Loading special://xbmc/system/keymaps/customcontroller.SiriRemote.xml
2022-04-09 18:49:45.128 T:780      INFO <general>: Loading special://xbmc/system/keymaps/gamepad.xml
2022-04-09 18:49:45.133 T:780      INFO <general>: Loading special://xbmc/system/keymaps/joystick.xml
2022-04-09 18:49:45.140 T:780      INFO <general>: Loading special://xbmc/system/keymaps/keyboard.xml
2022-04-09 18:49:45.154 T:780      INFO <general>: Loading special://xbmc/system/keymaps/mouse.xml
2022-04-09 18:49:45.156 T:780      INFO <general>: Loading special://xbmc/system/keymaps/remote.xml
2022-04-09 18:49:45.160 T:780      INFO <general>: Loading special://xbmc/system/keymaps/touchscreen.xml
2022-04-09 18:49:45.162 T:780      INFO <general>: GUI format 1024x768, Display 1024x768 @ 75.000000 Hz
2022-04-09 18:49:45.163 T:780      INFO <general>: CLangInfo: loading resource.language.en_gb language information...
2022-04-09 18:49:45.200 T:780      INFO <general>: global locale set to C
2022-04-09 18:49:45.200 T:780      INFO <general>: CLangInfo: loading resource.language.en_gb language strings...
2022-04-09 18:49:45.333 T:804      INFO <general>: Running database version Addons33
2022-04-09 18:49:45.335 T:804      INFO <general>: Running database version ViewModes6
2022-04-09 18:49:45.338 T:804      INFO <general>: Running database version Textures13
2022-04-09 18:49:45.348 T:804      INFO <general>: Running database version MyMusic82
2022-04-09 18:49:45.359 T:804      INFO <general>: Running database version MyVideos119
2022-04-09 18:49:45.362 T:804      INFO <general>: Running database version TV38
2022-04-09 18:49:45.364 T:804      INFO <general>: Running database version Epg13
2022-04-09 18:49:45.376 T:780      INFO <general>: start dvd mediatype detection
2022-04-09 18:49:45.430 T:780      INFO <general>: Unloaded skin
2022-04-09 18:49:45.433 T:780      INFO <general>:   load skin from: /usr/share/kodi/addons/skin.estuary/ (version: 3.0.5)
2022-04-09 18:49:45.433 T:780      INFO <general>:   load fonts for skin...
2022-04-09 18:49:45.439 T:780      INFO <general>: Loading skin includes from /usr/share/kodi/addons/skin.estuary/xml/Includes.xml
2022-04-09 18:49:45.544 T:780      INFO <general>: Loading fonts from /usr/share/kodi/addons/skin.estuary/xml/Font.xml
2022-04-09 18:49:45.703 T:780      INFO <general>:   load new skin...
2022-04-09 18:49:45.703 T:780      INFO <general>: Loading custom window XMLs from skin path /usr/share/kodi/addons/skin.estuary/xml
2022-04-09 18:49:45.726 T:780      INFO <general>:   initialize new skin...
2022-04-09 18:49:45.726 T:780      INFO <general>: Loading skin file: Custom_1109_TopBarOverlay.xml, load type: LOAD_ON_GUI_INIT
2022-04-09 18:49:45.769 T:780      INFO <general>: Loading skin file: DialogVolumeBar.xml, load type: LOAD_ON_GUI_INIT
2022-04-09 18:49:45.790 T:780      INFO <general>: Loading skin file: DialogBusy.xml, load type: LOAD_ON_GUI_INIT
2022-04-09 18:49:45.793 T:780      INFO <general>: Loading skin file: Pointer.xml, load type: LOAD_ON_GUI_INIT
2022-04-09 18:49:45.796 T:780      INFO <general>: Loading skin file: DialogExtendedProgressBar.xml, load type: LOAD_ON_GUI_INIT
2022-04-09 18:49:45.801 T:780      INFO <general>: Loading skin file: DialogSeekBar.xml, load type: LOAD_ON_GUI_INIT
2022-04-09 18:49:45.821 T:780      INFO <general>: Loading skin file: DialogNotification.xml, load type: LOAD_ON_GUI_INIT
2022-04-09 18:49:45.823 T:780      INFO <general>: Loading skin file: DialogBusy.xml, load type: LOAD_ON_GUI_INIT
2022-04-09 18:49:45.826 T:780      INFO <general>: Loading resource://resource.uisounds.kodi/sounds.xml
2022-04-09 18:49:45.945 T:780      INFO <general>:   skin loaded...
2022-04-09 18:49:45.946 T:780      INFO <general>: Loading skin file: Startup.xml, load type: LOAD_EVERY_TIME
2022-04-09 18:49:45.947 T:780      INFO <general>: Loading skin file: Home.xml, load type: KEEP_IN_MEMORY
2022-04-09 18:49:46.286 T:780   WARNING <general>: JSONRPC: Could not parse type "Setting.Details.SettingList"
2022-04-09 18:49:46.286 T:780      INFO <general>: JSONRPC: Adding type "Setting.Details.SettingList" to list of incomplete definitions (waiting for "Setting.Details.Setting")
2022-04-09 18:49:46.286 T:780      INFO <general>: JSONRPC: Resolving incomplete types/methods referencing Setting.Details.Setting
2022-04-09 18:49:46.309 T:780      INFO <general>: JSONRPC v12.4.0: Successfully initialized
2022-04-09 18:49:46.334 T:780      INFO <general>: Register - new keyboard device registered on application->keyboard: Keyboard (0000:0000)
2022-04-09 18:49:46.338 T:780      INFO <general>: Register - new mouse device registered on application->mouse: Mouse (0000:0000)
2022-04-09 18:49:46.338 T:780      INFO <general>: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
2022-04-09 18:49:46.345 T:780      INFO <general>: Loaded playercorefactory configuration
2022-04-09 18:49:46.345 T:780      INFO <general>: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
2022-04-09 18:49:46.346 T:780      INFO <general>: special://masterprofile/playercorefactory.xml does not exist. Skipping.
2022-04-09 18:49:46.346 T:780      INFO <general>: removing tempfiles
2022-04-09 18:49:46.364 T:814      INFO <general>: initializing python engine.
2022-04-09 18:49:46.366 T:780      INFO <general>: Skipped 2 duplicate messages..
2022-04-09 18:49:46.365 T:780      INFO <general>: initialize done
2022-04-09 18:49:46.366 T:780      INFO <general>: Running the application...
2022-04-09 18:49:46.384 T:780      INFO <general>: CZeroconfAvahi::clientCallback: avahi server not available. But may become later...
2022-04-09 18:49:46.384 T:780      INFO <general>: starting zeroconf publishing
2022-04-09 18:49:46.385 T:818      INFO <general>: ES: Starting UDP Event server on port 9777
2022-04-09 18:49:46.385 T:818      INFO <general>: UDP: Listening on port 9777 (ipv6 : false)
2022-04-09 18:49:46.428 T:780      INFO <general>: JSONRPC Server: Successfully initialized
2022-04-09 18:49:52.751 T:816      INFO <general>: CPythonInvoker(2, /var/lib/kodi/.kodi/addons/service.xbmc.versioncheck/resources/lib/runner.py): script successfully run
2022-04-09 18:49:52.787 T:816      INFO <general>: Python interpreter stopped
2022-04-09 18:49:59.041 T:780      INFO <general>: Loading skin file: MyVideoNav.xml, load type: KEEP_IN_MEMORY
2022-04-09 18:49:59.213 T:883      INFO <general>: initializing python engine.
2022-04-09 18:50:00.560 T:883      INFO <general>: ["Initializing provider markiza.sk with settings {'downloads': '', 'quality': '1', 'lang': '0'}"]
2022-04-09 18:50:00.760 T:883      INFO <general>: CPythonInvoker(3, /var/lib/kodi/.kodi/addons/plugin.video.markiza.sk/default.py): script successfully run
2022-04-09 18:50:00.914 T:883      INFO <general>: Python interpreter stopped
2022-04-09 18:50:02.963 T:893      INFO <general>: initializing python engine.
2022-04-09 18:50:03.841 T:893      INFO <general>: ["Initializing provider markiza.sk with settings {'downloads': '', 'quality': '1', 'lang': '0'}"]
2022-04-09 18:50:04.031 T:893     ERROR <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                                   Error Type: <class 'urllib.error.URLError'>
                                                   Error Contents: <urlopen error [SSL: DH_KEY_TOO_SMALL] dh key too small (_ssl.c:997)>
                                                     File "/usr/lib/python3.10/urllib/request.py", line 1348, in do_open
                                                       h.request(req.get_method(), req.selector, req.data, headers,
                                                     File "/usr/lib/python3.10/http/client.py", line 1282, in request
                                                       self._send_request(method, url, body, headers, encode_chunked)
                                                     File "/usr/lib/python3.10/http/client.py", line 1328, in _send_request
                                                       self.endheaders(body, encode_chunked=encode_chunked)
                                                     File "/usr/lib/python3.10/http/client.py", line 1277, in endheaders
                                                       self._send_output(message_body, encode_chunked=encode_chunked)
                                                     File "/usr/lib/python3.10/http/client.py", line 1037, in _send_output
                                                       self.send(msg)
                                                     File "/usr/lib/python3.10/http/client.py", line 975, in send
                                                       self.connect()
                                                     File "/usr/lib/python3.10/http/client.py", line 1454, in connect
                                                       self.sock = self._context.wrap_socket(self.sock,
                                                     File "/usr/lib/python3.10/ssl.py", line 512, in wrap_socket
                                                       return self.sslsocket_class._create(
                                                     File "/usr/lib/python3.10/ssl.py", line 1070, in _create
                                                       self.do_handshake()
                                                     File "/usr/lib/python3.10/ssl.py", line 1341, in do_handshake
                                                       self._sslobj.do_handshake()
                                                   ssl.SSLError: [SSL: DH_KEY_TOO_SMALL] dh key too small (_ssl.c:997)
                                                   During handling of the above exception, another exception occurred:
                                                     File "/var/lib/kodi/.kodi/addons/plugin.video.markiza.sk/default.py", line 43, in <module>
                                                       XBMCMarkizaContentProvider(provider,settings,__addon__).run(params)
                                                     File "/var/lib/kodi/.kodi/addons/script.module.stream.resolver/lib/contentprovider/xbmcprovider.py", line 88, in run
                                                       return self.play({'url': params['play'], 'info': params})
                                                     File "/var/lib/kodi/.kodi/addons/script.module.stream.resolver/lib/contentprovider/xbmcprovider.py", line 187, in play
                                                       stream = self.resolve(item['url'])
                                                     File "/var/lib/kodi/.kodi/addons/script.module.stream.resolver/lib/contentprovider/xbmcprovider.py", line 355, in resolve
                                                       return self.provider.resolve(item, select_cb=select_cb)
                                                     File "/var/lib/kodi/.kodi/addons/plugin.video.markiza.sk/resources/lib/markiza.py", line 207, in resolve
                                                       result = self._resolve_live(item, relogin=True)
                                                     File "/var/lib/kodi/.kodi/addons/plugin.video.markiza.sk/resources/lib/markiza.py", line 261, in _resolve_live
                                                       httpdata = fetchUrl(loginurl, self.opener)
                                                     File "/var/lib/kodi/.kodi/addons/plugin.video.markiza.sk/resources/lib/markiza.py", line 50, in fetchUrl
                                                       resp = opener.open(req)
                                                     File "/usr/lib/python3.10/urllib/request.py", line 519, in open
                                                       response = self._open(req, data)
                                                     File "/usr/lib/python3.10/urllib/request.py", line 536, in _open
                                                       result = self._call_chain(self.handle_open, protocol, protocol +
                                                     File "/usr/lib/python3.10/urllib/request.py", line 496, in _call_chain
                                                       result = func(*args)
                                                     File "/usr/lib/python3.10/urllib/request.py", line 1391, in https_open
                                                       return self.do_open(http.client.HTTPSConnection, req,
                                                     File "/usr/lib/python3.10/urllib/request.py", line 1351, in do_open
                                                       raise URLError(err)
                                                   urllib.error.URLError: <urlopen error [SSL: DH_KEY_TOO_SMALL] dh key too small (_ssl.c:997)>
2022-04-09 18:50:04.152 T:893      INFO <general>: Python interpreter stopped
2022-04-09 18:50:04.182 T:780     ERROR <general>: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.markiza.sk/?cp=6d61726b697a612e736b&play=68747470733a2f2f766964656f6172636869762e6d61726b697a612e736b2f6c6976652f322d64616a746f&]
2022-04-09 18:50:08.015 T:913      INFO <general>: initializing python engine.
2022-04-09 18:50:09.308 T:913      INFO <general>: ["Initializing provider markiza.sk with settings {'downloads': '', 'quality': '1', 'lang': '0'}"]
2022-04-09 18:50:09.464 T:913     ERROR <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                                       self.send(msg)
                                                       self.connect()
                                                       self.do_handshake()
                                                       raise URLError(err)
2022-04-09 18:50:09.594 T:913      INFO <general>: Python interpreter stopped
2022-04-09 18:50:09.620 T:780     ERROR <general>: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.markiza.sk/?cp=6d61726b697a612e736b&play=68747470733a2f2f766964656f6172636869762e6d61726b697a612e736b2f6c6976652f332d646f6d61&]
2022-04-09 18:50:13.240 T:780     ERROR <general>: Control 55 in window 10025 has been asked to focus, but it can't
2022-04-09 18:50:13.302 T:922      INFO <general>: initializing python engine.
2022-04-09 18:50:14.241 T:922      INFO <general>: ["Initializing provider joj.sk with settings {'downloads': '', 'quality': '1', 'lang': '0'}"]
2022-04-09 18:50:14.380 T:922      INFO <general>: CPythonInvoker(6, /var/lib/kodi/.kodi/addons/plugin.video.joj.sk/default.py): script successfully run
and also this all seems to be related to new python 10, so is there to a way to downgrade it to python 9? or ? (by python 9 i mean python 3.9) i tried downloading and installing package from archive but i just got invalid pgp signature error and couldnt bounce back , what are my options ?
I have watched some streaming but not for very long and had no issues. There is not any diff with our kodi-rpi and arch-arm. I use their PKGBUILD with some changes due to some distro differences. I do know there was some issues do to some python changes. Have you completely upgraded all packages to bring them up to date?
Another thought is there may be something in a stream that kodi does not know how to handle. I have seen this with satellite streams where one player would crash and another would not.
hello could you elobarate whose pkgbuild you used? i am not sure what you are referencing, and well yeas my system is up to date pacman -Syu all done, i just freshly installed it today
Like I said above I use arch-arm’s PKGBUILD.
I have never tested kodi-rpi on any other pi device other than the pi4.
I noticed kodi is not crashing on 3.10.2. but It crashes randomly every day when using addons like twitch or SendToKodi if using 3.10.3 or 3.10.4. So for now I am stuck on 3.10.2
So none knows how to fiz dh key too small issue?, editing openssl.conf didnt worked for me, what are options
Never seen that error but this guy has:
https://imlc.me/dh-key-too-small#:~:text=The%20default%20security%20level%20is%201%20for%20OpenSSL.,ECC%20keys%20shorter%20than%20224%20bits%20are%20prohibited.
Hello did u red my.post? I already added this to openssl.conf as seen above but error persists, not sure what i did wronf
