Manjaro ARM on a Raspberry Pi 5. Kodi installs and op
ens fine. Videos have only audio and no video. Just a black screen.
The only error messages in Kodi log are:
Failed to get an OpenGL context supporting core profile 3.2, using legacy mode with reduced feature set
GLES: BaseYUV2RGBGLSLShader - unsupported format 3
PS: I am on X11.
Chatgpt told me that the output of these two commands might be useful:
Output of my glxinfo:
name of display: :0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
GLX_ARB_context_flush_control, GLX_ARB_create_context,
GLX_ARB_create_context_no_error, GLX_ARB_create_context_profile,
GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
GLX_ARB_framebuffer_sRGB, GLX_ARB_multisample,
GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
GLX_EXT_get_drawable_type, GLX_EXT_libglvnd, GLX_EXT_no_config_context,
GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer, GLX_OML_swap_method,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_SGI_make_current_read,
GLX_SGI_swap_control
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_framebuffer_sRGB, GLX_ARB_get_proc_address, GLX_ARB_multisample,
GLX_ATI_pixel_format_float, GLX_EXT_buffer_age,
GLX_EXT_import_context, GLX_EXT_no_config_context, GLX_EXT_swap_control,
GLX_EXT_swap_control_tear, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_INTEL_swap_event,
GLX_MESA_copy_sub_buffer, GLX_MESA_gl_interop, GLX_MESA_query_renderer,
GLX_MESA_swap_control, GLX_NV_float_buffer, GLX_OML_sync_control,
GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
GLX_ARB_fbconfig_float, GLX_ARB_framebuffer_sRGB,
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_buffer_age,
GLX_MESA_swap_control, GLX_OML_sync_control, GLX_SGIS_multisample,
GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group,
GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync
Extended renderer info (GLX_MESA_query_renderer):
Vendor: Broadcom (0x14e4)
Device: V3D 7.1.7.0 (0xffffffff)
Version: 24.2.6
Accelerated: yes
Video memory: 4038MB
Unified memory: yes
Preferred profile: core (0x1)
Max core profile version: 3.1
Max compat profile version: 3.1
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 3.1
OpenGL vendor string: Broadcom
OpenGL renderer string: V3D 7.1.7.0
OpenGL core profile version string: 3.1 Mesa 24.2.6-arch1.1
OpenGL core profile shading language version string: 1.40
OpenGL core profile extensions:
GL_AMD_conservative_depth, GL_AMD_draw_buffers_blend,
GL_AMD_multi_draw_indirect, GL_AMD_performance_monitor,
GL_AMD_shader_trinary_minmax, GL_AMD_texture_texture4,
GL_ANGLE_texture_compression_dxt3, GL_ANGLE_texture_compression_dxt5,
GL_APPLE_packed_pixels, GL_ARB_ES2_compatibility,
GL_ARB_ES3_compatibility, GL_ARB_arrays_of_arrays, GL_ARB_base_instance,
GL_ARB_buffer_storage, GL_ARB_clear_buffer_object, GL_ARB_clear_texture,
GL_ARB_color_buffer_float, GL_ARB_compatibility,
GL_ARB_compressed_texture_pixel_storage,
GL_ARB_conditional_render_inverted, GL_ARB_conservative_depth,
GL_ARB_copy_buffer, GL_ARB_copy_image, GL_ARB_debug_output,
GL_ARB_depth_buffer_float, GL_ARB_depth_clamp, GL_ARB_depth_texture,
GL_ARB_direct_state_access, GL_ARB_draw_buffers,
GL_ARB_draw_buffers_blend, GL_ARB_draw_elements_base_vertex,
GL_ARB_draw_indirect, GL_ARB_draw_instanced,
GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
GL_ARB_fragment_coord_conventions, GL_ARB_fragment_program,
GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader,
GL_ARB_framebuffer_no_attachments, GL_ARB_framebuffer_object,
GL_ARB_framebuffer_sRGB, GL_ARB_get_program_binary,
GL_ARB_get_texture_sub_image, GL_ARB_half_float_pixel,
GL_ARB_half_float_vertex, GL_ARB_instanced_arrays,
GL_ARB_internalformat_query, GL_ARB_internalformat_query2,
GL_ARB_invalidate_subdata, GL_ARB_map_buffer_alignment,
GL_ARB_map_buffer_range, GL_ARB_multi_bind, GL_ARB_multi_draw_indirect,
GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query,
GL_ARB_occlusion_query2, GL_ARB_parallel_shader_compile,
GL_ARB_pixel_buffer_object, GL_ARB_point_parameters, GL_ARB_point_sprite,
GL_ARB_polygon_offset_clamp, GL_ARB_program_interface_query,
GL_ARB_provoking_vertex, GL_ARB_robustness, GL_ARB_sampler_objects,
GL_ARB_separate_shader_objects, GL_ARB_shader_atomic_counter_ops,
GL_ARB_shader_atomic_counters, GL_ARB_shader_bit_encoding,
GL_ARB_shader_objects, GL_ARB_shader_storage_buffer_object,
GL_ARB_shader_subroutine, GL_ARB_shader_texture_lod,
GL_ARB_shading_language_100, GL_ARB_shading_language_420pack,
GL_ARB_shading_language_include, GL_ARB_shading_language_packing,
GL_ARB_shadow, GL_ARB_stencil_texturing, GL_ARB_sync,
GL_ARB_texture_barrier, GL_ARB_texture_border_clamp,
GL_ARB_texture_buffer_object, GL_ARB_texture_buffer_range,
GL_ARB_texture_compression, GL_ARB_texture_compression_rgtc,
GL_ARB_texture_cube_map, GL_ARB_texture_cube_map_array,
GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
GL_ARB_texture_filter_anisotropic, GL_ARB_texture_float,
GL_ARB_texture_gather, GL_ARB_texture_mirror_clamp_to_edge,
GL_ARB_texture_mirrored_repeat, GL_ARB_texture_multisample,
GL_ARB_texture_non_power_of_two, GL_ARB_texture_query_levels,
GL_ARB_texture_query_lod, GL_ARB_texture_rectangle, GL_ARB_texture_rg,
GL_ARB_texture_rgb10_a2ui, GL_ARB_texture_stencil8,
GL_ARB_texture_storage, GL_ARB_texture_storage_multisample,
GL_ARB_texture_swizzle, GL_ARB_texture_view, GL_ARB_transform_feedback2,
GL_ARB_transform_feedback_instanced, GL_ARB_transpose_matrix,
GL_ARB_uniform_buffer_object, GL_ARB_vertex_array_bgra,
GL_ARB_vertex_array_object, GL_ARB_vertex_attrib_binding,
GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
GL_ARB_vertex_type_2_10_10_10_rev, GL_ARB_window_pos,
GL_ATI_blend_equation_separate, GL_ATI_draw_buffers,
GL_ATI_fragment_shader, GL_ATI_separate_stencil,
GL_ATI_texture_compression_3dc, GL_ATI_texture_env_combine3,
GL_ATI_texture_float, GL_EXT_EGL_image_storage,
GL_EXT_EGL_image_storage_compression, GL_EXT_EGL_sync, GL_EXT_abgr,
GL_EXT_bgra, GL_EXT_blend_color, GL_EXT_blend_equation_separate,
GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_compiled_vertex_array, GL_EXT_copy_texture, GL_EXT_debug_label,
GL_EXT_direct_state_access, GL_EXT_draw_buffers2, GL_EXT_draw_instanced,
GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_blit,
GL_EXT_framebuffer_multisample, GL_EXT_framebuffer_multisample_blit_scaled,
GL_EXT_framebuffer_object, GL_EXT_framebuffer_sRGB,
GL_EXT_gpu_program_parameters, GL_EXT_gpu_shader4,
GL_EXT_multi_draw_arrays, GL_EXT_packed_depth_stencil,
GL_EXT_packed_float, GL_EXT_packed_pixels, GL_EXT_pixel_buffer_object,
GL_EXT_point_parameters, GL_EXT_polygon_offset_clamp,
GL_EXT_provoking_vertex, GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color, GL_EXT_shader_integer_mix,
GL_EXT_shadow_funcs, GL_EXT_stencil_two_side, GL_EXT_stencil_wrap,
GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D,
GL_EXT_texture_array, GL_EXT_texture_buffer_object,
GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_rgtc,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
GL_EXT_texture_filter_anisotropic, GL_EXT_texture_integer,
GL_EXT_texture_lod_bias, GL_EXT_texture_object, GL_EXT_texture_rectangle,
GL_EXT_texture_sRGB, GL_EXT_texture_sRGB_decode,
GL_EXT_texture_shared_exponent, GL_EXT_texture_snorm,
GL_EXT_texture_storage, GL_EXT_texture_swizzle, GL_EXT_transform_feedback,
GL_EXT_vertex_array, GL_EXT_vertex_array_bgra,
GL_IBM_multimode_draw_arrays, GL_IBM_rasterpos_clip,
GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate,
GL_KHR_context_flush_control, GL_KHR_debug, GL_KHR_no_error,
GL_KHR_parallel_shader_compile, GL_KHR_texture_compression_astc_ldr,
GL_KHR_texture_compression_astc_sliced_3d, GL_MESA_pack_invert,
GL_MESA_shader_integer_functions, GL_MESA_texture_signed_rgba,
GL_MESA_window_pos, GL_NV_ES1_1_compatibility, GL_NV_blend_square,
GL_NV_conditional_render, GL_NV_copy_image, GL_NV_depth_clamp,
GL_NV_fog_distance, GL_NV_half_float, GL_NV_light_max_exponent,
GL_NV_packed_depth_stencil, GL_NV_primitive_restart,
GL_NV_texgen_reflection, GL_NV_texture_barrier,
GL_NV_texture_env_combine4, GL_NV_texture_rectangle, GL_OES_EGL_image,
GL_OES_read_format, GL_S3_s3tc, GL_SGIS_generate_mipmap,
GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp,
GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
OpenGL version string: 3.1 Mesa 24.2.6-arch1.1
OpenGL shading language version string: 1.40
OpenGL context flags: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.1 Mesa 24.2.6-arch1.1
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.10
OpenGL ES profile extensions:
GL_AMD_performance_monitor, GL_ANGLE_pack_reverse_row_order,
GL_APPLE_sync, GL_APPLE_texture_max_level, GL_EXT_EGL_image_storage,
GL_EXT_EGL_image_storage_compression, GL_EXT_base_instance,
GL_EXT_blend_minmax, GL_EXT_buffer_storage, GL_EXT_clear_texture,
GL_EXT_color_buffer_float, GL_EXT_color_buffer_half_float,
GL_EXT_compressed_ETC1_RGB8_sub_texture, GL_EXT_copy_image,
GL_EXT_debug_label, GL_EXT_depth_clamp, GL_EXT_discard_framebuffer,
GL_EXT_draw_buffers, GL_EXT_draw_buffers_indexed,
GL_EXT_draw_elements_base_vertex, GL_EXT_draw_instanced,
GL_EXT_float_blend, GL_EXT_frag_depth, GL_EXT_geometry_point_size,
GL_EXT_geometry_shader, GL_EXT_instanced_arrays, GL_EXT_map_buffer_range,
GL_EXT_multi_draw_arrays, GL_EXT_occlusion_query_boolean,
GL_EXT_polygon_offset_clamp, GL_EXT_primitive_bounding_box,
GL_EXT_read_format_bgra, GL_EXT_sRGB_write_control,
GL_EXT_separate_shader_objects, GL_EXT_shader_implicit_conversions,
GL_EXT_shader_integer_mix, GL_EXT_shader_io_blocks,
GL_EXT_shadow_samplers, GL_EXT_texture_border_clamp,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_compression_s3tc_srgb,
GL_EXT_texture_cube_map_array, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_format_BGRA8888, GL_EXT_texture_mirror_clamp_to_edge,
GL_EXT_texture_query_lod, GL_EXT_texture_rg, GL_EXT_texture_sRGB_decode,
GL_EXT_texture_storage, GL_EXT_texture_storage_compression,
GL_EXT_texture_type_2_10_10_10_REV, GL_EXT_texture_view,
GL_EXT_unpack_subimage, GL_KHR_context_flush_control, GL_KHR_debug,
GL_KHR_no_error, GL_KHR_parallel_shader_compile,
GL_KHR_texture_compression_astc_sliced_3d, GL_MESA_bgra,
GL_MESA_framebuffer_flip_y, GL_MESA_sampler_objects,
GL_MESA_shader_integer_functions, GL_NV_conditional_render,
GL_NV_draw_buffers, GL_NV_fbo_color_attachments,
GL_NV_generate_mipmap_sRGB, GL_NV_image_formats, GL_NV_pack_subimage,
GL_NV_pixel_buffer_object, GL_NV_read_buffer, GL_NV_read_depth,
GL_NV_read_depth_stencil, GL_NV_read_stencil,
GL_NV_shader_noperspective_interpolation, GL_NV_texture_barrier,
GL_OES_EGL_image, GL_OES_EGL_image_external,
GL_OES_EGL_image_external_essl3, GL_OES_EGL_sync,
GL_OES_compressed_ETC1_RGB8_texture, GL_OES_copy_image, GL_OES_depth24,
GL_OES_depth_texture, GL_OES_depth_texture_cube_map,
GL_OES_draw_buffers_indexed, GL_OES_draw_elements_base_vertex,
GL_OES_element_index_uint, GL_OES_fbo_render_mipmap,
GL_OES_geometry_point_size, GL_OES_geometry_shader,
GL_OES_get_program_binary, GL_OES_mapbuffer, GL_OES_packed_depth_stencil,
GL_OES_primitive_bounding_box, GL_OES_required_internalformat,
GL_OES_rgb8_rgba8, GL_OES_shader_image_atomic, GL_OES_shader_io_blocks,
GL_OES_standard_derivatives, GL_OES_stencil8, GL_OES_surfaceless_context,
GL_OES_texture_3D, GL_OES_texture_border_clamp,
GL_OES_texture_cube_map_array, GL_OES_texture_float,
GL_OES_texture_half_float, GL_OES_texture_half_float_linear,
GL_OES_texture_npot, GL_OES_texture_stencil8,
GL_OES_texture_storage_multisample_2d_array, GL_OES_texture_view,
GL_OES_vertex_array_object, GL_OES_vertex_half_float
144 GLX Visuals
visual x bf lv rg d st colorbuffer sr ax dp st accumbuffer ms sw cav
id dep cl sp sz l ci b ro r g b a F gb bf th cl r g b a ns b ap eat
0x021 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 . None
0x022 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 . None
0x180 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 . None
0x181 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 . None
0x182 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 . None
0x183 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 . None
0x184 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 . None
0x185 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 . None
0x186 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 . None
0x187 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 . None
0x188 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 . None
0x189 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 . None
0x18a 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 . None
0x18b 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 . None
0x18c 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 . None
0x18d 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 . None
0x18e 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 . None
0x18f 24 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 . None
0x190 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 . None
0x191 24 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 . None
0x192 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 . None
0x193 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 . None
0x194 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 . None
0x195 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 . None
0x196 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 . None
0x197 24 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 4 1 . None
0x198 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 4 1 . None
0x199 24 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 4 1 . None
0x19a 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 4 1 . None
0x19b 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 4 1 . None
0x19c 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 4 1 . None
0x19d 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 4 1 . None
0x19e 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 4 1 . None
0x19f 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 . None
0x1a0 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 . None
0x1a1 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 . None
0x1a2 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 . None
0x1a3 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 . None
0x1a4 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 . None
0x1a5 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 . None
0x1a6 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 . None
0x1a7 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 . None
0x1a8 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 . None
0x1a9 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 . None
0x1aa 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 . None
0x1ab 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 . None
0x1ac 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 . None
0x1ad 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 . None
0x1ae 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 . None
0x1af 24 tc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 . None
0x1b0 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 . None
0x1b1 24 tc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 . None
0x1b2 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 . None
0x1b3 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 . None
0x1b4 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 . None
0x1b5 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 . None
0x1b6 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 . None
0x1b7 24 tc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 4 1 . None
0x1b8 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 4 1 . None
0x1b9 24 tc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 4 1 . None
0x1ba 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 4 1 . None
0x1bb 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 4 1 . None
0x1bc 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 4 1 . None
0x1bd 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 4 1 . None
0x1be 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 4 1 . None
0x1bf 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 . None
0x1c0 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 . None
0x1c1 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 . None
0x1c2 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 . None
0x1c3 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 . None
0x1c4 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 . None
0x1c5 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 . None
0x1c6 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 . None
0x1c7 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 . None
0x1c8 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 . None
0x1c9 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 . None
0x1ca 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 . None
0x1cb 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 . None
0x1cc 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 . None
0x1cd 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 . None
0x1ce 24 dc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 . None
0x1cf 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 . None
0x1d0 24 dc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 . None
0x1d1 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 . None
0x1d2 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 . None
0x1d3 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 . None
0x1d4 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 . None
0x1d5 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 . None
0x1d6 24 dc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 4 1 . None
0x1d7 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 4 1 . None
0x1d8 24 dc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 4 1 . None
0x1d9 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 4 1 . None
0x1da 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 4 1 . None
0x1db 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 4 1 . None
0x1dc 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 4 1 . None
0x1dd 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 4 1 . None
0x1de 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 . None
0x1df 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 . None
0x1e0 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 . None
0x1e1 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 . None
0x1e2 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 . None
0x1e3 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 . None
0x1e4 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 . None
0x1e5 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 . None
0x1e6 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 . None
0x1e7 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 . None
0x1e8 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 . None
0x1e9 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 . None
0x1ea 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 . None
0x1eb 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 . None
0x1ec 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 . None
0x1ed 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 . None
0x1ee 24 dc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 . None
0x1ef 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 . None
0x1f0 24 dc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 . None
0x1f1 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 . None
0x1f2 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 . None
0x1f3 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 . None
0x1f4 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 . None
0x1f5 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 . None
0x1f6 24 dc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 4 1 . None
0x1f7 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 4 1 . None
0x1f8 24 dc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 4 1 . None
0x1f9 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 4 1 . None
0x1fa 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 4 1 . None
0x1fb 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 4 1 . None
0x1fc 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 4 1 . None
0x1fd 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 4 1 . None
0x06f 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 . None
0x1fe 32 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 . None
0x1ff 32 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 . None
0x200 32 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 . None
0x201 32 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 . None
0x202 32 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 . None
0x203 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 . None
0x204 32 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 . None
0x205 32 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 . None
0x206 32 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 . None
0x207 32 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 . None
0x208 32 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 . None
0x209 32 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 . None
0x20a 32 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 . None
0x20b 32 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 . None
0x20c 32 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 . None
240 GLXFBConfigs:
0x070 0 tc 0 32 0 r . . 10 10 10 2 . . 0 0 0 0 0 0 0 0 0 . None
0x071 0 tc 0 32 0 r y . 10 10 10 2 . . 0 0 0 0 0 0 0 0 0 . None
0x072 0 tc 0 32 0 r . . 10 10 10 2 . . 0 16 0 0 0 0 0 0 0 . None
0x073 0 tc 0 32 0 r y . 10 10 10 2 . . 0 16 0 0 0 0 0 0 0 . None
0x074 0 tc 0 32 0 r . . 10 10 10 2 . . 0 24 0 0 0 0 0 0 0 . None
0x075 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 0 0 0 0 0 0 0 . None
0x076 0 tc 0 32 0 r . . 10 10 10 2 . . 0 24 8 0 0 0 0 0 0 . None
0x077 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 8 0 0 0 0 0 0 . None
0x078 0 tc 0 32 0 r . . 10 10 10 2 . . 0 0 0 0 0 0 0 4 1 . None
0x079 0 tc 0 32 0 r y . 10 10 10 2 . . 0 0 0 0 0 0 0 4 1 . None
0x07a 0 tc 0 32 0 r . . 10 10 10 2 . . 0 16 0 0 0 0 0 4 1 . None
0x07b 0 tc 0 32 0 r y . 10 10 10 2 . . 0 16 0 0 0 0 0 4 1 . None
0x07c 0 tc 0 32 0 r . . 10 10 10 2 . . 0 24 0 0 0 0 0 4 1 . None
0x07d 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 0 0 0 0 0 4 1 . None
0x07e 0 tc 0 32 0 r . . 10 10 10 2 . . 0 24 8 0 0 0 0 4 1 . None
0x07f 0 tc 0 32 0 r y . 10 10 10 2 . . 0 24 8 0 0 0 0 4 1 . None
0x080 0 tc 0 30 0 r . . 10 10 10 0 . . 0 0 0 0 0 0 0 0 0 . None
0x081 0 tc 0 30 0 r y . 10 10 10 0 . . 0 0 0 0 0 0 0 0 0 . None
0x082 0 tc 0 30 0 r . . 10 10 10 0 . . 0 16 0 0 0 0 0 0 0 . None
0x083 0 tc 0 30 0 r y . 10 10 10 0 . . 0 16 0 0 0 0 0 0 0 . None
0x084 0 tc 0 30 0 r . . 10 10 10 0 . . 0 24 0 0 0 0 0 0 0 . None
0x085 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 0 0 0 0 0 0 0 . None
0x086 0 tc 0 30 0 r . . 10 10 10 0 . . 0 24 8 0 0 0 0 0 0 . None
0x087 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 8 0 0 0 0 0 0 . None
0x088 0 tc 0 30 0 r . . 10 10 10 0 . . 0 0 0 0 0 0 0 4 1 . None
0x089 0 tc 0 30 0 r y . 10 10 10 0 . . 0 0 0 0 0 0 0 4 1 . None
0x08a 0 tc 0 30 0 r . . 10 10 10 0 . . 0 16 0 0 0 0 0 4 1 . None
0x08b 0 tc 0 30 0 r y . 10 10 10 0 . . 0 16 0 0 0 0 0 4 1 . None
0x08c 0 tc 0 30 0 r . . 10 10 10 0 . . 0 24 0 0 0 0 0 4 1 . None
0x08d 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 0 0 0 0 0 4 1 . None
0x08e 0 tc 0 30 0 r . . 10 10 10 0 . . 0 24 8 0 0 0 0 4 1 . None
0x08f 0 tc 0 30 0 r y . 10 10 10 0 . . 0 24 8 0 0 0 0 4 1 . None
0x090 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 . None
0x091 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 . None
0x092 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 . None
0x093 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 . None
0x094 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 . None
0x095 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 . None
0x096 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 . None
0x097 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 . None
0x098 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 . None
0x099 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 . None
0x09a 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 . None
0x09b 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 . None
0x09c 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 . None
0x09d 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 . None
0x09e 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 . None
0x09f 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 . None
0x0a0 24 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 . None
0x0a1 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 . None
0x0a2 24 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 . None
0x0a3 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 . None
0x0a4 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 . None
0x0a5 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 . None
0x0a6 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 . None
0x0a7 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 . None
0x0a8 24 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 4 1 . None
0x0a9 24 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 4 1 . None
0x0aa 24 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 4 1 . None
0x0ab 24 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 4 1 . None
0x0ac 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 4 1 . None
0x0ad 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 4 1 . None
0x0ae 24 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 4 1 . None
0x0af 24 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 4 1 . None
0x0b0 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 . None
0x0b1 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 . None
0x0b2 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 . None
0x0b3 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 . None
0x0b4 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 . None
0x0b5 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 . None
0x0b6 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 . None
0x0b7 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 . None
0x0b8 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 . None
0x0b9 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 . None
0x0ba 24 tc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 . None
0x0bb 24 tc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 . None
0x0bc 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 . None
0x0bd 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 . None
0x0be 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 . None
0x0bf 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 . None
0x0c0 24 tc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 . None
0x0c1 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 . None
0x0c2 24 tc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 . None
0x0c3 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 . None
0x0c4 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 . None
0x0c5 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 . None
0x0c6 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 . None
0x0c7 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 . None
0x0c8 24 tc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 4 1 . None
0x0c9 24 tc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 4 1 . None
0x0ca 24 tc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 4 1 . None
0x0cb 24 tc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 4 1 . None
0x0cc 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 4 1 . None
0x0cd 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 4 1 . None
0x0ce 24 tc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 4 1 . None
0x0cf 24 tc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 4 1 . None
0x0d0 0 tc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 . None
0x0d1 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 . None
0x0d2 0 tc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 . None
0x0d3 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 . None
0x0d4 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 . None
0x0d5 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 . None
0x0d6 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 . None
0x0d7 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 . None
0x0d8 0 tc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 4 1 . None
0x0d9 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 4 1 . None
0x0da 0 tc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 4 1 . None
0x0db 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 4 1 . None
0x0dc 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 0 0 0 0 0 4 1 . None
0x0dd 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 4 1 . None
0x0de 0 tc 0 16 0 r . . 5 6 5 0 . . 0 24 8 0 0 0 0 4 1 . None
0x0df 0 tc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 4 1 . None
0x0f0 0 dc 0 32 0 r . . 10 10 10 2 . . 0 0 0 0 0 0 0 0 0 . None
0x0f1 0 dc 0 32 0 r y . 10 10 10 2 . . 0 0 0 0 0 0 0 0 0 . None
0x0f2 0 dc 0 32 0 r . . 10 10 10 2 . . 0 16 0 0 0 0 0 0 0 . None
0x0f3 0 dc 0 32 0 r y . 10 10 10 2 . . 0 16 0 0 0 0 0 0 0 . None
0x0f4 0 dc 0 32 0 r . . 10 10 10 2 . . 0 24 0 0 0 0 0 0 0 . None
0x0f5 0 dc 0 32 0 r y . 10 10 10 2 . . 0 24 0 0 0 0 0 0 0 . None
0x0f6 0 dc 0 32 0 r . . 10 10 10 2 . . 0 24 8 0 0 0 0 0 0 . None
0x0f7 0 dc 0 32 0 r y . 10 10 10 2 . . 0 24 8 0 0 0 0 0 0 . None
0x0f8 0 dc 0 32 0 r . . 10 10 10 2 . . 0 0 0 0 0 0 0 4 1 . None
0x0f9 0 dc 0 32 0 r y . 10 10 10 2 . . 0 0 0 0 0 0 0 4 1 . None
0x0fa 0 dc 0 32 0 r . . 10 10 10 2 . . 0 16 0 0 0 0 0 4 1 . None
0x0fb 0 dc 0 32 0 r y . 10 10 10 2 . . 0 16 0 0 0 0 0 4 1 . None
0x0fc 0 dc 0 32 0 r . . 10 10 10 2 . . 0 24 0 0 0 0 0 4 1 . None
0x0fd 0 dc 0 32 0 r y . 10 10 10 2 . . 0 24 0 0 0 0 0 4 1 . None
0x0fe 0 dc 0 32 0 r . . 10 10 10 2 . . 0 24 8 0 0 0 0 4 1 . None
0x0ff 0 dc 0 32 0 r y . 10 10 10 2 . . 0 24 8 0 0 0 0 4 1 . None
0x100 0 dc 0 30 0 r . . 10 10 10 0 . . 0 0 0 0 0 0 0 0 0 . None
0x101 0 dc 0 30 0 r y . 10 10 10 0 . . 0 0 0 0 0 0 0 0 0 . None
0x102 0 dc 0 30 0 r . . 10 10 10 0 . . 0 16 0 0 0 0 0 0 0 . None
0x103 0 dc 0 30 0 r y . 10 10 10 0 . . 0 16 0 0 0 0 0 0 0 . None
0x104 0 dc 0 30 0 r . . 10 10 10 0 . . 0 24 0 0 0 0 0 0 0 . None
0x105 0 dc 0 30 0 r y . 10 10 10 0 . . 0 24 0 0 0 0 0 0 0 . None
0x106 0 dc 0 30 0 r . . 10 10 10 0 . . 0 24 8 0 0 0 0 0 0 . None
0x107 0 dc 0 30 0 r y . 10 10 10 0 . . 0 24 8 0 0 0 0 0 0 . None
0x108 0 dc 0 30 0 r . . 10 10 10 0 . . 0 0 0 0 0 0 0 4 1 . None
0x109 0 dc 0 30 0 r y . 10 10 10 0 . . 0 0 0 0 0 0 0 4 1 . None
0x10a 0 dc 0 30 0 r . . 10 10 10 0 . . 0 16 0 0 0 0 0 4 1 . None
0x10b 0 dc 0 30 0 r y . 10 10 10 0 . . 0 16 0 0 0 0 0 4 1 . None
0x10c 0 dc 0 30 0 r . . 10 10 10 0 . . 0 24 0 0 0 0 0 4 1 . None
0x10d 0 dc 0 30 0 r y . 10 10 10 0 . . 0 24 0 0 0 0 0 4 1 . None
0x10e 0 dc 0 30 0 r . . 10 10 10 0 . . 0 24 8 0 0 0 0 4 1 . None
0x10f 0 dc 0 30 0 r y . 10 10 10 0 . . 0 24 8 0 0 0 0 4 1 . None
0x110 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 . None
0x111 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 . None
0x112 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 . None
0x113 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 . None
0x114 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 . None
0x115 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 . None
0x116 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 . None
0x117 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 . None
0x118 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 . None
0x119 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 4 1 . None
0x11a 24 dc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 . None
0x11b 24 dc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 4 1 . None
0x11c 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 . None
0x11d 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 4 1 . None
0x11e 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 . None
0x11f 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 4 1 . None
0x120 24 dc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 . None
0x121 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 . None
0x122 24 dc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 . None
0x123 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 . None
0x124 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 . None
0x125 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 . None
0x126 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 . None
0x127 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 . None
0x128 24 dc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 4 1 . None
0x129 24 dc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 4 1 . None
0x12a 24 dc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 4 1 . None
0x12b 24 dc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 4 1 . None
0x12c 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 4 1 . None
0x12d 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 4 1 . None
0x12e 24 dc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 4 1 . None
0x12f 24 dc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 4 1 . None
0x130 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 . None
0x131 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 . None
0x132 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 . None
0x133 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 0 0 . None
0x134 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 . None
0x135 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 0 0 . None
0x136 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 . None
0x137 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 . None
0x138 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 . None
0x139 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 4 1 . None
0x13a 24 dc 0 24 0 r . . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 . None
0x13b 24 dc 0 24 0 r y . 8 8 8 0 . . 0 16 0 0 0 0 0 4 1 . None
0x13c 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 . None
0x13d 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 0 0 0 0 0 4 1 . None
0x13e 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 . None
0x13f 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 4 1 . None
0x140 24 dc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 . None
0x141 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 0 0 . None
0x142 24 dc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 . None
0x143 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 0 0 . None
0x144 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 . None
0x145 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 0 0 . None
0x146 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 . None
0x147 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 0 0 . None
0x148 24 dc 0 24 0 r . . 8 8 8 0 . s 0 0 0 0 0 0 0 4 1 . None
0x149 24 dc 0 24 0 r y . 8 8 8 0 . s 0 0 0 0 0 0 0 4 1 . None
0x14a 24 dc 0 24 0 r . . 8 8 8 0 . s 0 16 0 0 0 0 0 4 1 . None
0x14b 24 dc 0 24 0 r y . 8 8 8 0 . s 0 16 0 0 0 0 0 4 1 . None
0x14c 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 0 0 0 0 0 4 1 . None
0x14d 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 0 0 0 0 0 4 1 . None
0x14e 24 dc 0 24 0 r . . 8 8 8 0 . s 0 24 8 0 0 0 0 4 1 . None
0x14f 24 dc 0 24 0 r y . 8 8 8 0 . s 0 24 8 0 0 0 0 4 1 . None
0x150 0 dc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 . None
0x151 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 . None
0x152 0 dc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 . None
0x153 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 . None
0x154 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 . None
0x155 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 0 0 . None
0x156 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 . None
0x157 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 0 0 . None
0x158 0 dc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 4 1 . None
0x159 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 4 1 . None
0x15a 0 dc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 4 1 . None
0x15b 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 4 1 . None
0x15c 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 0 0 0 0 0 4 1 . None
0x15d 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 0 0 0 0 0 4 1 . None
0x15e 0 dc 0 16 0 r . . 5 6 5 0 . . 0 24 8 0 0 0 0 4 1 . None
0x15f 0 dc 0 16 0 r y . 5 6 5 0 . . 0 24 8 0 0 0 0 4 1 . None
0x170 32 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 . None
0x171 32 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 . None
0x172 32 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 . None
0x173 32 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 . None
0x174 32 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 . None
0x175 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 . None
0x176 32 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 . None
0x177 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 . None
0x178 32 tc 0 32 0 r . . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 . None
0x179 32 tc 0 32 0 r y . 8 8 8 8 . s 0 0 0 0 0 0 0 0 0 . None
0x17a 32 tc 0 32 0 r . . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 . None
0x17b 32 tc 0 32 0 r y . 8 8 8 8 . s 0 16 0 0 0 0 0 0 0 . None
0x17c 32 tc 0 32 0 r . . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 . None
0x17d 32 tc 0 32 0 r y . 8 8 8 8 . s 0 24 0 0 0 0 0 0 0 . None
0x17e 32 tc 0 32 0 r . . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 . None
0x17f 32 tc 0 32 0 r y . 8 8 8 8 . s 0 24 8 0 0 0 0 0 0 . None
Output of my vulkaninfo:
VULKANINFO
Vulkan Instance Version: 1.3.295
Instance Extensions: count = 23
VK_EXT_acquire_drm_display : extension revision 1
VK_EXT_acquire_xlib_display : extension revision 1
VK_EXT_debug_report : extension revision 10
VK_EXT_debug_utils : extension revision 2
VK_EXT_direct_mode_display : extension revision 1
VK_EXT_headless_surface : extension revision 1
VK_EXT_surface_maintenance1 : extension revision 1
VK_EXT_swapchain_colorspace : extension revision 4
VK_KHR_device_group_creation : extension revision 1
VK_KHR_display : extension revision 23
VK_KHR_external_fence_capabilities : extension revision 1
VK_KHR_external_memory_capabilities : extension revision 1
VK_KHR_external_semaphore_capabilities : extension revision 1
VK_KHR_get_display_properties2 : extension revision 1
VK_KHR_get_physical_device_properties2 : extension revision 2
VK_KHR_get_surface_capabilities2 : extension revision 1
VK_KHR_portability_enumeration : extension revision 1
VK_KHR_surface : extension revision 25
VK_KHR_surface_protected_capabilities : extension revision 1
VK_KHR_wayland_surface : extension revision 6
VK_KHR_xcb_surface : extension revision 6
VK_KHR_xlib_surface : extension revision 6
VK_LUNARG_direct_driver_loading : extension revision 1
Layers: count = 2
VK_LAYER_MESA_device_select (Linux device selection layer) Vulkan version 1.3.211, layer version 1:
Layer Extensions: count = 0
Devices: count = 1
GPU id = 0 (V3D 7.1.7.0)
Layer-Device Extensions: count = 0
VK_LAYER_MESA_overlay (Mesa Overlay layer) Vulkan version 1.3.211, layer version 1:
Devices: count = 1
Presentable Surfaces:
GPU id : 0 (V3D 7.1.7.0):
Surface types: count = 2
VK_KHR_xcb_surface
VK_KHR_xlib_surface
Formats: count = 2
SurfaceFormat[0]:
format = FORMAT_B8G8R8A8_SRGB
colorSpace = COLOR_SPACE_SRGB_NONLINEAR_KHR
SurfaceFormat[1]:
format = FORMAT_B8G8R8A8_UNORM
Present Modes: count = 4
PRESENT_MODE_IMMEDIATE_KHR
PRESENT_MODE_MAILBOX_KHR
PRESENT_MODE_FIFO_KHR
PRESENT_MODE_FIFO_RELAXED_KHR
VkSurfaceCapabilitiesKHR:
minImageCount = 3
maxImageCount = 0
currentExtent:
width = 256
height = 256
minImageExtent:
width = 256
height = 256
maxImageExtent:
width = 256
height = 256
maxImageArrayLayers = 1
supportedTransforms: count = 1
SURFACE_TRANSFORM_IDENTITY_BIT_KHR
currentTransform = SURFACE_TRANSFORM_IDENTITY_BIT_KHR
supportedCompositeAlpha: count = 2
COMPOSITE_ALPHA_OPAQUE_BIT_KHR
COMPOSITE_ALPHA_INHERIT_BIT_KHR
supportedUsageFlags: count = 7
IMAGE_USAGE_TRANSFER_SRC_BIT
IMAGE_USAGE_TRANSFER_DST_BIT
IMAGE_USAGE_SAMPLED_BIT
IMAGE_USAGE_STORAGE_BIT
IMAGE_USAGE_COLOR_ATTACHMENT_BIT
IMAGE_USAGE_INPUT_ATTACHMENT_BIT
IMAGE_USAGE_ATTACHMENT_FEEDBACK_LOOP_BIT_EXT
VkSurfaceProtectedCapabilitiesKHR:
supportsProtected = false
VK_EXT_surface_maintenance_1:
PRESENT_MODE_IMMEDIATE_KHR:
VkSurfacePresentScalingCapabilitiesEXT:
supportedPresentScaling:
None
supportedPresentGravityX:
None
supportedPresentGravityY:
None
minScaledImageExtent:
width = 256
height = 256
maxScaledImageExtent:
width = 256
height = 256
VkSurfacePresentModeCompatibilityEXT:
presentModeCount = 4
pPresentModes: count = 4
PRESENT_MODE_MAILBOX_KHR:
None
None
None
width = 256
height = 256
width = 256
height = 256
PRESENT_MODE_FIFO_KHR:
None
None
None
width = 256
height = 256
width = 256
height = 256
PRESENT_MODE_FIFO_RELAXED_KHR:
None
None
None
width = 256
height = 256
width = 256
height = 256
Device Properties and Extensions:
GPU0:
VkPhysicalDeviceProperties:
apiVersion = 1.2.289 (4202785)
driverVersion = 24.2.6 (100671494)
vendorID = 0x14e4
deviceID = 0x55701c33
deviceType = PHYSICAL_DEVICE_TYPE_INTEGRATED_GPU
deviceName = V3D 7.1.7.0
pipelineCacheUUID = 349d6e8c-c915-a1d0-f96a-e6d718be973a
VkPhysicalDeviceLimits:
maxImageDimension1D = 4096
maxImageDimension2D = 4096
maxImageDimension3D = 4096
maxImageDimensionCube = 4096
maxImageArrayLayers = 2048
maxTexelBufferElements = 268435456
maxUniformBufferRange = 1073741824
maxStorageBufferRange = 1073741824
maxPushConstantsSize = 128
maxMemoryAllocationCount = 516958
maxSamplerAllocationCount = 65536
bufferImageGranularity = 0x00000100
sparseAddressSpaceSize = 0x00000000
maxBoundDescriptorSets = 16
maxPerStageDescriptorSamplers = 24
maxPerStageDescriptorUniformBuffers = 16
maxPerStageDescriptorStorageBuffers = 8
maxPerStageDescriptorSampledImages = 16
maxPerStageDescriptorStorageImages = 4
maxPerStageDescriptorInputAttachments = 4
maxPerStageResources = 128
maxDescriptorSetSamplers = 96
maxDescriptorSetUniformBuffers = 64
maxDescriptorSetUniformBuffersDynamic = 8
maxDescriptorSetStorageBuffers = 32
maxDescriptorSetStorageBuffersDynamic = 4
maxDescriptorSetSampledImages = 64
maxDescriptorSetStorageImages = 16
maxDescriptorSetInputAttachments = 4
maxVertexInputAttributes = 16
maxVertexInputBindings = 16
maxVertexInputAttributeOffset = 4294967295
maxVertexInputBindingStride = 65535
maxVertexOutputComponents = 64
maxTessellationGenerationLevel = 0
maxTessellationPatchSize = 0
maxTessellationControlPerVertexInputComponents = 0
maxTessellationControlPerVertexOutputComponents = 0
maxTessellationControlPerPatchOutputComponents = 0
maxTessellationControlTotalOutputComponents = 0
maxTessellationEvaluationInputComponents = 0
maxTessellationEvaluationOutputComponents = 0
maxGeometryShaderInvocations = 32
maxGeometryInputComponents = 64
maxGeometryOutputComponents = 64
maxGeometryOutputVertices = 256
maxGeometryTotalOutputComponents = 1024
maxFragmentInputComponents = 64
maxFragmentOutputAttachments = 4
maxFragmentDualSrcAttachments = 0
maxFragmentCombinedOutputResources = 20
maxComputeSharedMemorySize = 16384
maxComputeWorkGroupCount: count = 3
65535
65535
65535
maxComputeWorkGroupInvocations = 256
maxComputeWorkGroupSize: count = 3
256
256
256
subPixelPrecisionBits = 6
subTexelPrecisionBits = 8
mipmapPrecisionBits = 8
maxDrawIndexedIndexValue = 4294967295
maxDrawIndirectCount = 2147483647
maxSamplerLodBias = 14
maxSamplerAnisotropy = 16
maxViewports = 1
maxViewportDimensions: count = 2
4096
4096
viewportBoundsRange: count = 2
-8192
8191
viewportSubPixelBits = 0
minMemoryMapAlignment = 4096
minTexelBufferOffsetAlignment = 0x00000040
minUniformBufferOffsetAlignment = 0x00000020
minStorageBufferOffsetAlignment = 0x00000020
minTexelOffset = -8
maxTexelOffset = 7
minTexelGatherOffset = -8
maxTexelGatherOffset = 7
minInterpolationOffset = -0.5
maxInterpolationOffset = 0.5
subPixelInterpolationOffsetBits = 6
maxFramebufferWidth = 4096
maxFramebufferHeight = 4096
maxFramebufferLayers = 256
framebufferColorSampleCounts: count = 2
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_4_BIT
framebufferDepthSampleCounts: count = 2
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_4_BIT
framebufferStencilSampleCounts: count = 2
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_4_BIT
framebufferNoAttachmentsSampleCounts: count = 2
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_4_BIT
maxColorAttachments = 8
sampledImageColorSampleCounts: count = 2
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_4_BIT
sampledImageIntegerSampleCounts: count = 2
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_4_BIT
sampledImageDepthSampleCounts: count = 2
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_4_BIT
sampledImageStencilSampleCounts: count = 2
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_4_BIT
storageImageSampleCounts: count = 1
SAMPLE_COUNT_1_BIT
maxSampleMaskWords = 1
timestampComputeAndGraphics = true
timestampPeriod = 1
maxClipDistances = 8
maxCullDistances = 0
maxCombinedClipAndCullDistances = 8
discreteQueuePriorities = 2
pointSizeRange: count = 2
0.03125
512
lineWidthRange: count = 2
1
32
pointSizeGranularity = 0.03125
lineWidthGranularity = 0.03125
strictLines = true
standardSampleLocations = false
optimalBufferCopyOffsetAlignment = 0x00000020
optimalBufferCopyRowPitchAlignment = 0x00000020
nonCoherentAtomSize = 0x00000100
VkPhysicalDeviceSparseProperties:
residencyStandard2DBlockShape = false
residencyStandard2DMultisampleBlockShape = false
residencyStandard3DBlockShape = false
residencyAlignedMipSize = false
residencyNonResidentStrict = false
VkPhysicalDeviceCustomBorderColorPropertiesEXT:
maxCustomBorderColorSamplers = 24
VkPhysicalDeviceDepthStencilResolveProperties:
supportedDepthResolveModes: count = 1
RESOLVE_MODE_SAMPLE_ZERO_BIT
supportedStencilResolveModes: count = 1
independentResolveNone = false
independentResolve = false
VkPhysicalDeviceDescriptorIndexingProperties:
maxUpdateAfterBindDescriptorsInAllPools = 0
shaderUniformBufferArrayNonUniformIndexingNative = false
shaderSampledImageArrayNonUniformIndexingNative = false
shaderStorageBufferArrayNonUniformIndexingNative = false
shaderStorageImageArrayNonUniformIndexingNative = false
shaderInputAttachmentArrayNonUniformIndexingNative = false
robustBufferAccessUpdateAfterBind = false
quadDivergentImplicitLod = false
maxPerStageDescriptorUpdateAfterBindSamplers = 24
maxPerStageDescriptorUpdateAfterBindUniformBuffers = 16
maxPerStageDescriptorUpdateAfterBindStorageBuffers = 8
maxPerStageDescriptorUpdateAfterBindSampledImages = 16
maxPerStageDescriptorUpdateAfterBindStorageImages = 4
maxPerStageDescriptorUpdateAfterBindInputAttachments = 4
maxPerStageUpdateAfterBindResources = 128
maxDescriptorSetUpdateAfterBindSamplers = 96
maxDescriptorSetUpdateAfterBindUniformBuffers = 64
maxDescriptorSetUpdateAfterBindUniformBuffersDynamic = 8
maxDescriptorSetUpdateAfterBindStorageBuffers = 32
maxDescriptorSetUpdateAfterBindStorageBuffersDynamic = 8
maxDescriptorSetUpdateAfterBindSampledImages = 64
maxDescriptorSetUpdateAfterBindStorageImages = 16
maxDescriptorSetUpdateAfterBindInputAttachments = 4
VkPhysicalDeviceDriverProperties:
driverID = DRIVER_ID_MESA_V3DV
driverName = V3DV Mesa
driverInfo = Mesa 24.2.6-arch1.1
conformanceVersion:
major = 1
minor = 3
subminor = 6
patch = 1
VkPhysicalDeviceDrmPropertiesEXT:
hasPrimary = true
hasRender = true
primaryMajor = 226
primaryMinor = 1
renderMajor = 226
renderMinor = 128
VkPhysicalDeviceFloatControlsProperties:
denormBehaviorIndependence = SHADER_FLOAT_CONTROLS_INDEPENDENCE_ALL
roundingModeIndependence = SHADER_FLOAT_CONTROLS_INDEPENDENCE_ALL
shaderSignedZeroInfNanPreserveFloat16 = true
shaderSignedZeroInfNanPreserveFloat32 = true
shaderSignedZeroInfNanPreserveFloat64 = false
shaderDenormPreserveFloat16 = true
shaderDenormPreserveFloat32 = true
shaderDenormPreserveFloat64 = false
shaderDenormFlushToZeroFloat16 = false
shaderDenormFlushToZeroFloat32 = false
shaderDenormFlushToZeroFloat64 = false
shaderRoundingModeRTEFloat16 = true
shaderRoundingModeRTEFloat32 = true
shaderRoundingModeRTEFloat64 = false
shaderRoundingModeRTZFloat16 = false
shaderRoundingModeRTZFloat32 = false
shaderRoundingModeRTZFloat64 = false
VkPhysicalDeviceIDProperties:
deviceUUID = 5fd8106e-741a-cafa-e080-fdb16cf11a80
driverUUID = 114116dc-092f-4d47-f140-432050866c25
deviceNodeMask = 0
deviceLUIDValid = false
VkPhysicalDeviceInlineUniformBlockPropertiesEXT:
maxInlineUniformBlockSize = 4096
maxPerStageDescriptorInlineUniformBlocks = 4
maxPerStageDescriptorUpdateAfterBindInlineUniformBlocks = 4
maxDescriptorSetInlineUniformBlocks = 4
maxDescriptorSetUpdateAfterBindInlineUniformBlocks = 4
VkPhysicalDeviceLineRasterizationPropertiesEXT:
lineSubPixelPrecisionBits = 6
VkPhysicalDeviceMaintenance3Properties:
maxPerSetDescriptors = 67108863
maxMemoryAllocationSize = 0x40000000
VkPhysicalDeviceMaintenance4PropertiesKHR:
maxBufferSize = 0x40000000
VkPhysicalDeviceMaintenance5PropertiesKHR:
earlyFragmentMultisampleCoverageAfterSampleCounting = true
earlyFragmentSampleMaskTestBeforeSampleCounting = true
depthStencilSwizzleOneSupport = true
polygonModePointSize = true
nonStrictSinglePixelWideLinesUseParallelogram = true
nonStrictWideLinesUseParallelogram = true
VkPhysicalDeviceMultiDrawPropertiesEXT:
maxMultiDrawCount = 2048
VkPhysicalDeviceMultiviewProperties:
maxMultiviewViewCount = 16
maxMultiviewInstanceIndex = 4294967294
VkPhysicalDevicePerformanceQueryPropertiesKHR:
allowCommandBufferQueryCopies = true
VkPhysicalDevicePipelineRobustnessPropertiesEXT:
defaultRobustnessStorageBuffers = PIPELINE_ROBUSTNESS_BUFFER_BEHAVIOR_DEVICE_DEFAULT_EXT
defaultRobustnessUniformBuffers = PIPELINE_ROBUSTNESS_BUFFER_BEHAVIOR_DEVICE_DEFAULT_EXT
defaultRobustnessVertexInputs = PIPELINE_ROBUSTNESS_BUFFER_BEHAVIOR_DEVICE_DEFAULT_EXT
defaultRobustnessImages = PIPELINE_ROBUSTNESS_IMAGE_BEHAVIOR_DEVICE_DEFAULT_EXT
VkPhysicalDevicePointClippingProperties:
pointClippingBehavior = POINT_CLIPPING_BEHAVIOR_ALL_CLIP_PLANES
VkPhysicalDeviceProtectedMemoryProperties:
protectedNoFault = false
VkPhysicalDeviceProvokingVertexPropertiesEXT:
provokingVertexModePerPipeline = true
transformFeedbackPreservesTriangleFanProvokingVertex = false
VkPhysicalDeviceSamplerFilterMinmaxProperties:
filterMinmaxSingleComponentFormats = false
filterMinmaxImageComponentMapping = false
VkPhysicalDeviceShaderIntegerDotProductPropertiesKHR:
integerDotProduct8BitUnsignedAccelerated = false
integerDotProduct8BitSignedAccelerated = false
integerDotProduct8BitMixedSignednessAccelerated = false
integerDotProduct4x8BitPackedUnsignedAccelerated = false
integerDotProduct4x8BitPackedSignedAccelerated = false
integerDotProduct4x8BitPackedMixedSignednessAccelerated = false
integerDotProduct16BitUnsignedAccelerated = false
integerDotProduct16BitSignedAccelerated = false
integerDotProduct16BitMixedSignednessAccelerated = false
integerDotProduct32BitUnsignedAccelerated = false
integerDotProduct32BitSignedAccelerated = false
integerDotProduct32BitMixedSignednessAccelerated = false
integerDotProduct64BitUnsignedAccelerated = false
integerDotProduct64BitSignedAccelerated = false
integerDotProduct64BitMixedSignednessAccelerated = false
integerDotProductAccumulatingSaturating8BitUnsignedAccelerated = false
integerDotProductAccumulatingSaturating8BitSignedAccelerated = false
integerDotProductAccumulatingSaturating8BitMixedSignednessAccelerated = false
integerDotProductAccumulatingSaturating4x8BitPackedUnsignedAccelerated = false
integerDotProductAccumulatingSaturating4x8BitPackedSignedAccelerated = false
integerDotProductAccumulatingSaturating4x8BitPackedMixedSignednessAccelerated = false
integerDotProductAccumulatingSaturating16BitUnsignedAccelerated = false
integerDotProductAccumulatingSaturating16BitSignedAccelerated = false
integerDotProductAccumulatingSaturating16BitMixedSignednessAccelerated = false
integerDotProductAccumulatingSaturating32BitUnsignedAccelerated = false
integerDotProductAccumulatingSaturating32BitSignedAccelerated = false
integerDotProductAccumulatingSaturating32BitMixedSignednessAccelerated = false
integerDotProductAccumulatingSaturating64BitUnsignedAccelerated = false
integerDotProductAccumulatingSaturating64BitSignedAccelerated = false
integerDotProductAccumulatingSaturating64BitMixedSignednessAccelerated = false
VkPhysicalDeviceShaderModuleIdentifierPropertiesEXT:
shaderModuleIdentifierAlgorithmUUID = 4d455341-2d42-4c41-4b45-330000000000
VkPhysicalDeviceSubgroupProperties:
subgroupSize = 16
supportedStages: count = 2
SHADER_STAGE_FRAGMENT_BIT
SHADER_STAGE_COMPUTE_BIT
supportedOperations: count = 6
SUBGROUP_FEATURE_BASIC_BIT
SUBGROUP_FEATURE_VOTE_BIT
SUBGROUP_FEATURE_BALLOT_BIT
SUBGROUP_FEATURE_SHUFFLE_BIT
SUBGROUP_FEATURE_SHUFFLE_RELATIVE_BIT
SUBGROUP_FEATURE_QUAD_BIT
quadOperationsInAllStages = false
VkPhysicalDeviceSubgroupSizeControlPropertiesEXT:
minSubgroupSize = 16
maxSubgroupSize = 16
maxComputeWorkgroupSubgroups = 16
requiredSubgroupSizeStages: count = 1
VkPhysicalDeviceTexelBufferAlignmentPropertiesEXT:
storageTexelBufferOffsetAlignmentBytes = 0x00000040
storageTexelBufferOffsetSingleTexelAlignment = false
uniformTexelBufferOffsetAlignmentBytes = 0x00000040
uniformTexelBufferOffsetSingleTexelAlignment = false
VkPhysicalDeviceTimelineSemaphoreProperties:
maxTimelineSemaphoreValueDifference = 18446744073709551615
VkPhysicalDeviceVertexAttributeDivisorPropertiesEXT:
maxVertexAttribDivisor = 65535
VkPhysicalDeviceVulkan11Properties:
deviceNodeMask = 0
subgroupSize = 16
subgroupSupportedStages: count = 2
subgroupSupportedOperations: count = 6
subgroupQuadOperationsInAllStages = false
VkPhysicalDeviceVulkan12Properties:
conformanceVersion:
major = 1
minor = 3
subminor = 6
patch = 1
framebufferIntegerColorSampleCounts: count = 2
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_4_BIT
VkPhysicalDeviceHostImageCopyPropertiesEXT:
copySrcLayoutCount = 0
pCopySrcLayouts:
copyDstLayoutCount = 0
pCopyDstLayouts:
optimalTilingLayoutUUID = 00000000-0000-0000-0000-000000000000
identicalMemoryTypeRequirements = false
Device Extensions: count = 90
VK_EXT_4444_formats : extension revision 1
VK_EXT_attachment_feedback_loop_layout : extension revision 2
VK_EXT_border_color_swizzle : extension revision 1
VK_EXT_color_write_enable : extension revision 1
VK_EXT_custom_border_color : extension revision 12
VK_EXT_depth_clamp_zero_one : extension revision 1
VK_EXT_depth_clip_control : extension revision 1
VK_EXT_depth_clip_enable : extension revision 1
VK_EXT_extended_dynamic_state : extension revision 1
VK_EXT_extended_dynamic_state2 : extension revision 1
VK_EXT_external_memory_dma_buf : extension revision 1
VK_EXT_host_query_reset : extension revision 1
VK_EXT_image_drm_format_modifier : extension revision 2
VK_EXT_image_robustness : extension revision 1
VK_EXT_index_type_uint8 : extension revision 1
VK_EXT_inline_uniform_block : extension revision 1
VK_EXT_line_rasterization : extension revision 1
VK_EXT_load_store_op_none : extension revision 1
VK_EXT_memory_budget : extension revision 1
VK_EXT_multi_draw : extension revision 1
VK_EXT_physical_device_drm : extension revision 1
VK_EXT_pipeline_creation_cache_control : extension revision 3
VK_EXT_pipeline_creation_feedback : extension revision 1
VK_EXT_pipeline_robustness : extension revision 1
VK_EXT_primitive_topology_list_restart : extension revision 1
VK_EXT_private_data : extension revision 1
VK_EXT_provoking_vertex : extension revision 1
VK_EXT_separate_stencil_usage : extension revision 1
VK_EXT_shader_demote_to_helper_invocation : extension revision 1
VK_EXT_shader_module_identifier : extension revision 1
VK_EXT_subgroup_size_control : extension revision 2
VK_EXT_swapchain_maintenance1 : extension revision 1
VK_EXT_texel_buffer_alignment : extension revision 1
VK_EXT_tooling_info : extension revision 1
VK_EXT_vertex_attribute_divisor : extension revision 3
VK_KHR_16bit_storage : extension revision 1
VK_KHR_8bit_storage : extension revision 1
VK_KHR_bind_memory2 : extension revision 1
VK_KHR_buffer_device_address : extension revision 1
VK_KHR_copy_commands2 : extension revision 1
VK_KHR_create_renderpass2 : extension revision 1
VK_KHR_dedicated_allocation : extension revision 3
VK_KHR_depth_stencil_resolve : extension revision 1
VK_KHR_descriptor_update_template : extension revision 1
VK_KHR_device_group : extension revision 4
VK_KHR_driver_properties : extension revision 1
VK_KHR_dynamic_rendering : extension revision 1
VK_KHR_external_fence : extension revision 1
VK_KHR_external_fence_fd : extension revision 1
VK_KHR_external_memory : extension revision 1
VK_KHR_external_memory_fd : extension revision 1
VK_KHR_external_semaphore : extension revision 1
VK_KHR_external_semaphore_fd : extension revision 1
VK_KHR_format_feature_flags2 : extension revision 2
VK_KHR_get_memory_requirements2 : extension revision 1
VK_KHR_image_format_list : extension revision 1
VK_KHR_imageless_framebuffer : extension revision 1
VK_KHR_incremental_present : extension revision 2
VK_KHR_index_type_uint8 : extension revision 1
VK_KHR_line_rasterization : extension revision 1
VK_KHR_load_store_op_none : extension revision 1
VK_KHR_maintenance1 : extension revision 2
VK_KHR_maintenance2 : extension revision 1
VK_KHR_maintenance3 : extension revision 1
VK_KHR_maintenance4 : extension revision 2
VK_KHR_maintenance5 : extension revision 1
VK_KHR_multiview : extension revision 1
VK_KHR_performance_query : extension revision 1
VK_KHR_pipeline_executable_properties : extension revision 1
VK_KHR_relaxed_block_layout : extension revision 1
VK_KHR_sampler_mirror_clamp_to_edge : extension revision 3
VK_KHR_sampler_ycbcr_conversion : extension revision 14
VK_KHR_separate_depth_stencil_layouts : extension revision 1
VK_KHR_shader_expect_assume : extension revision 1
VK_KHR_shader_float_controls : extension revision 4
VK_KHR_shader_integer_dot_product : extension revision 1
VK_KHR_shader_non_semantic_info : extension revision 1
VK_KHR_shader_terminate_invocation : extension revision 1
VK_KHR_spirv_1_4 : extension revision 1
VK_KHR_storage_buffer_storage_class : extension revision 1
VK_KHR_swapchain : extension revision 70
VK_KHR_swapchain_mutable_format : extension revision 1
VK_KHR_synchronization2 : extension revision 1
VK_KHR_timeline_semaphore : extension revision 2
VK_KHR_uniform_buffer_standard_layout : extension revision 1
VK_KHR_variable_pointers : extension revision 1
VK_KHR_vertex_attribute_divisor : extension revision 1
VK_KHR_vulkan_memory_model : extension revision 3
VK_KHR_workgroup_memory_explicit_layout : extension revision 1
VK_KHR_zero_initialize_workgroup_memory : extension revision 1
VkQueueFamilyProperties:
queueProperties[0]:
minImageTransferGranularity = (1,1,1)
queueCount = 1
queueFlags = QUEUE_GRAPHICS_BIT | QUEUE_COMPUTE_BIT | QUEUE_TRANSFER_BIT
timestampValidBits = 64
present support = true
VkPhysicalDeviceMemoryProperties:
memoryHeaps: count = 1
memoryHeaps[0]:
size = 2117459968 (0x7e35e000) (1.97 GiB)
budget = 2117459968 (0x7e35e000) (1.97 GiB)
usage = 0 (0x00000000) (0.00 B)
flags: count = 1
MEMORY_HEAP_DEVICE_LOCAL_BIT
memoryTypes: count = 1
memoryTypes[0]:
heapIndex = 0
propertyFlags = 0x0007: count = 3
MEMORY_PROPERTY_DEVICE_LOCAL_BIT
MEMORY_PROPERTY_HOST_VISIBLE_BIT
MEMORY_PROPERTY_HOST_COHERENT_BIT
usable for:
IMAGE_TILING_OPTIMAL:
color images
FORMAT_D16_UNORM
FORMAT_X8_D24_UNORM_PACK32
FORMAT_D32_SFLOAT
FORMAT_D24_UNORM_S8_UINT
(non-sparse)
IMAGE_TILING_LINEAR:
color images
(non-sparse)
VkPhysicalDeviceFeatures:
robustBufferAccess = true
fullDrawIndexUint32 = true
imageCubeArray = true
independentBlend = true
geometryShader = true
tessellationShader = false
sampleRateShading = true
dualSrcBlend = false
logicOp = true
multiDrawIndirect = false
drawIndirectFirstInstance = true
depthClamp = true
depthBiasClamp = true
fillModeNonSolid = true
depthBounds = true
wideLines = true
largePoints = true
alphaToOne = true
multiViewport = false
samplerAnisotropy = true
textureCompressionETC2 = true
textureCompressionASTC_LDR = true
textureCompressionBC = false
occlusionQueryPrecise = true
pipelineStatisticsQuery = false
vertexPipelineStoresAndAtomics = true
fragmentStoresAndAtomics = true
shaderTessellationAndGeometryPointSize = true
shaderImageGatherExtended = true
shaderStorageImageExtendedFormats = true
shaderStorageImageMultisample = false
shaderStorageImageReadWithoutFormat = true
shaderStorageImageWriteWithoutFormat = false
shaderUniformBufferArrayDynamicIndexing = false
shaderSampledImageArrayDynamicIndexing = false
shaderStorageBufferArrayDynamicIndexing = false
shaderStorageImageArrayDynamicIndexing = false
shaderClipDistance = true
shaderCullDistance = false
shaderFloat64 = false
shaderInt64 = false
shaderInt16 = false
shaderResourceResidency = false
shaderResourceMinLod = false
sparseBinding = false
sparseResidencyBuffer = false
sparseResidencyImage2D = false
sparseResidencyImage3D = false
sparseResidency2Samples = false
sparseResidency4Samples = false
sparseResidency8Samples = false
sparseResidency16Samples = false
sparseResidencyAliased = false
variableMultisampleRate = false
inheritedQueries = true
VkPhysicalDevice16BitStorageFeatures:
storageBuffer16BitAccess = true
uniformAndStorageBuffer16BitAccess = true
storagePushConstant16 = true
storageInputOutput16 = false
VkPhysicalDevice4444FormatsFeaturesEXT:
formatA4R4G4B4 = true
formatA4B4G4R4 = true
VkPhysicalDevice8BitStorageFeatures:
storageBuffer8BitAccess = true
uniformAndStorageBuffer8BitAccess = true
storagePushConstant8 = true
VkPhysicalDeviceAttachmentFeedbackLoopLayoutFeaturesEXT:
attachmentFeedbackLoopLayout = true
VkPhysicalDeviceBorderColorSwizzleFeaturesEXT:
borderColorSwizzle = true
borderColorSwizzleFromImage = true
VkPhysicalDeviceBufferDeviceAddressFeatures:
bufferDeviceAddress = true
bufferDeviceAddressCaptureReplay = false
bufferDeviceAddressMultiDevice = false
VkPhysicalDeviceColorWriteEnableFeaturesEXT:
colorWriteEnable = true
VkPhysicalDeviceCustomBorderColorFeaturesEXT:
customBorderColors = true
customBorderColorWithoutFormat = false
VkPhysicalDeviceDepthClampZeroOneFeaturesEXT:
depthClampZeroOne = true
VkPhysicalDeviceDepthClipControlFeaturesEXT:
depthClipControl = true
VkPhysicalDeviceDepthClipEnableFeaturesEXT:
depthClipEnable = true
VkPhysicalDeviceDescriptorIndexingFeatures:
shaderInputAttachmentArrayDynamicIndexing = false
shaderUniformTexelBufferArrayDynamicIndexing = false
shaderStorageTexelBufferArrayDynamicIndexing = false
shaderUniformBufferArrayNonUniformIndexing = false
shaderSampledImageArrayNonUniformIndexing = false
shaderStorageBufferArrayNonUniformIndexing = false
shaderStorageImageArrayNonUniformIndexing = false
shaderInputAttachmentArrayNonUniformIndexing = false
shaderUniformTexelBufferArrayNonUniformIndexing = false
shaderStorageTexelBufferArrayNonUniformIndexing = false
descriptorBindingUniformBufferUpdateAfterBind = false
descriptorBindingSampledImageUpdateAfterBind = false
descriptorBindingStorageImageUpdateAfterBind = false
descriptorBindingStorageBufferUpdateAfterBind = false
descriptorBindingUniformTexelBufferUpdateAfterBind = false
descriptorBindingStorageTexelBufferUpdateAfterBind = false
descriptorBindingUpdateUnusedWhilePending = false
descriptorBindingPartiallyBound = false
descriptorBindingVariableDescriptorCount = false
runtimeDescriptorArray = false
VkPhysicalDeviceDynamicRenderingFeaturesKHR:
dynamicRendering = true
VkPhysicalDeviceExtendedDynamicState2FeaturesEXT:
extendedDynamicState2 = true
extendedDynamicState2LogicOp = false
extendedDynamicState2PatchControlPoints = false
VkPhysicalDeviceExtendedDynamicStateFeaturesEXT:
extendedDynamicState = true
VkPhysicalDeviceHostQueryResetFeatures:
hostQueryReset = true
VkPhysicalDeviceImageRobustnessFeaturesEXT:
robustImageAccess = true
VkPhysicalDeviceImagelessFramebufferFeatures:
imagelessFramebuffer = true
VkPhysicalDeviceIndexTypeUint8FeaturesEXT:
indexTypeUint8 = true
VkPhysicalDeviceInlineUniformBlockFeaturesEXT:
inlineUniformBlock = true
descriptorBindingInlineUniformBlockUpdateAfterBind = false
VkPhysicalDeviceLineRasterizationFeaturesEXT:
rectangularLines = true
bresenhamLines = true
smoothLines = true
stippledRectangularLines = false
stippledBresenhamLines = false
stippledSmoothLines = false
VkPhysicalDeviceMaintenance4FeaturesKHR:
maintenance4 = true
VkPhysicalDeviceMaintenance5FeaturesKHR:
maintenance5 = true
VkPhysicalDeviceMultiDrawFeaturesEXT:
multiDraw = true
VkPhysicalDeviceMultiviewFeatures:
multiview = true
multiviewGeometryShader = false
multiviewTessellationShader = false
VkPhysicalDevicePerformanceQueryFeaturesKHR:
performanceCounterQueryPools = true
performanceCounterMultipleQueryPools = false
VkPhysicalDevicePipelineCreationCacheControlFeaturesEXT:
pipelineCreationCacheControl = true
VkPhysicalDevicePipelineExecutablePropertiesFeaturesKHR:
pipelineExecutableInfo = true
VkPhysicalDevicePipelineRobustnessFeaturesEXT:
pipelineRobustness = true
VkPhysicalDevicePrimitiveTopologyListRestartFeaturesEXT:
primitiveTopologyListRestart = true
primitiveTopologyPatchListRestart = false
VkPhysicalDevicePrivateDataFeaturesEXT:
privateData = true
VkPhysicalDeviceProtectedMemoryFeatures:
protectedMemory = false
VkPhysicalDeviceProvokingVertexFeaturesEXT:
provokingVertexLast = true
transformFeedbackPreservesProvokingVertex = false
VkPhysicalDeviceSamplerYcbcrConversionFeatures:
samplerYcbcrConversion = true
VkPhysicalDeviceScalarBlockLayoutFeatures:
scalarBlockLayout = true
VkPhysicalDeviceSeparateDepthStencilLayoutsFeatures:
separateDepthStencilLayouts = true
VkPhysicalDeviceShaderAtomicInt64Features:
shaderBufferInt64Atomics = false
shaderSharedInt64Atomics = false
VkPhysicalDeviceShaderDemoteToHelperInvocationFeaturesEXT:
shaderDemoteToHelperInvocation = true
VkPhysicalDeviceShaderDrawParametersFeatures:
shaderDrawParameters = false
VkPhysicalDeviceShaderFloat16Int8Features:
shaderFloat16 = false
shaderInt8 = false
VkPhysicalDeviceShaderIntegerDotProductFeaturesKHR:
shaderIntegerDotProduct = true
VkPhysicalDeviceShaderModuleIdentifierFeaturesEXT:
shaderModuleIdentifier = true
VkPhysicalDeviceShaderSubgroupExtendedTypesFeatures:
shaderSubgroupExtendedTypes = true
VkPhysicalDeviceShaderTerminateInvocationFeaturesKHR:
shaderTerminateInvocation = true
VkPhysicalDeviceSubgroupSizeControlFeaturesEXT:
subgroupSizeControl = true
computeFullSubgroups = true
VkPhysicalDeviceSwapchainMaintenance1FeaturesEXT:
swapchainMaintenance1 = true
VkPhysicalDeviceSynchronization2FeaturesKHR:
synchronization2 = true
VkPhysicalDeviceTexelBufferAlignmentFeaturesEXT:
texelBufferAlignment = true
VkPhysicalDeviceTimelineSemaphoreFeatures:
timelineSemaphore = true
VkPhysicalDeviceUniformBufferStandardLayoutFeatures:
uniformBufferStandardLayout = true
VkPhysicalDeviceVariablePointersFeatures:
variablePointersStorageBuffer = true
variablePointers = false
VkPhysicalDeviceVertexAttributeDivisorFeaturesEXT:
vertexAttributeInstanceRateDivisor = true
vertexAttributeInstanceRateZeroDivisor = false
VkPhysicalDeviceVulkan11Features:
multiview = true
VkPhysicalDeviceVulkan12Features:
samplerMirrorClampToEdge = true
drawIndirectCount = false
shaderInt8 = false
descriptorIndexing = false
samplerFilterMinmax = false
vulkanMemoryModel = true
vulkanMemoryModelDeviceScope = true
vulkanMemoryModelAvailabilityVisibilityChains = true
shaderOutputViewportIndex = false
shaderOutputLayer = false
subgroupBroadcastDynamicId = true
VkPhysicalDeviceVulkanMemoryModelFeatures:
VkPhysicalDeviceWorkgroupMemoryExplicitLayoutFeaturesKHR:
workgroupMemoryExplicitLayout = true
workgroupMemoryExplicitLayoutScalarBlockLayout = false
workgroupMemoryExplicitLayout8BitAccess = true
workgroupMemoryExplicitLayout16BitAccess = true
VkPhysicalDeviceZeroInitializeWorkgroupMemoryFeaturesKHR:
shaderZeroInitializeWorkgroupMemory = true
