I’ve got following messages:
*** pw_stream_destroy called from wrong context, check thread and locking: Operation not permitted
‘this->recurse > 0’ failed at …/pipewire/src/pipewire/thread-loop.c:63 do_unlock()
In the Kodi audio settings the pipewire device is marked red.
I have no idea how to handle this. This issue I have with XFCE and Plasma at different computers.
Gottfried
---- One day later
I installed the new Manjaro version 24.0 with the iso file. The issue disappeared. Maybe the rolling system makes the issue.
Gottfried
I am also getting errors about kodi not being able to connect to pipewire.
Could you expand on what you mean or where you got this Kodi iso?
OS: Manjaro Linux x86_64
Host: Z390 AORUS PRO
Kernel: 6.6.32-1-MANJARO
Shell: bash 5.2.26
DE: Xfce 4.18
WM: Xfwm4
Terminal: xfce4-terminal
Terminal Font: Monospace 12
CPU: Intel i7-9700K (8) @ 4.900GHz
GPU: NVIDIA GeForce GTX 1080 Ti
Memory: 3198MiB / 32033MiB
but same ■■■■ on Vorke mini computer.
on android all ok…
hi. same here.
some snippets from log
2024-05-31 13:44:29.549 T:60641 info : CActiveAESink::OpenSink - initialize sink
2024-05-31 13:44:29.549 T:60641 error : CPipewireStream: failed to connect stream: Unknown error -22
2024-05-31 13:44:29.549 T:60641 error : CActiveAESink::OpenSink - no sink was returned
2024-05-31 13:44:29.549 T:60640 error : ActiveAE::InitSink - returned error
2024-05-31 13:44:29.563 T:60652 error : EXCEPTION: Invalid setting type
2024-05-31 13:44:29.744 T:60633 info : Skipped 1 duplicate messages…
2024-05-31 13:44:29.744 T:60633 info : Loading special://xbmc/system/Lircmap.xml**
2024-05-31 13:44:30.049 T:60641 info : CActiveAESink::OpenSink - initialize sink
2024-05-31 13:44:30.050 T:60641 error : CPipewireStream: failed to connect stream: Unknown error -22
2024-05-31 13:44:30.050 T:60641 error : CActiveAESink::OpenSink - no sink was returned
2024-05-31 13:44:30.050 T:60640 error : ActiveAE::InitSink - returned error
2024-05-31 13:44:30.550 T:60641 info : CActiveAESink::OpenSink - initialize sink
2024-05-31 13:44:30.550 T:60641 error : CPipewireStream: failed to connect stream: Unknown error -22
Hi
Getting this too on arch armv7,
Any final conclusion ?
Necrobumping is not encouraged. Topic closed.
