I’ve installed kmymoney in Manjaro from the community repo.
Install goes fine, all dependencies are met. However I get the console error:
kmymoney: symbol lookup error: /usr/lib/libkmm_csvimportercore.so.5: undefined symbol: _ZNK14MyMoneyAccount10currencyIdEv
and then KMyMoney quits.
STEPS TO REPRODUCE
From an amd64 Manjaro installation, with KDE SC, install the kmymoney from the community repo.
Try to start it.
OBSERVED RESULT
It doesn’t start.
KDE Plasma Version: 5.27.3
KDE Frameworks Version: 5.104.0
Qt Version: 5.15.8
Kernel Version: 5.15.104-2-MANJARO (64-bit)
Graphics Platform: X11
Processors: 16 × Intel® Core™ i7-10700KF CPU @ 3.80GHz
Memory: 31.2 GiB of RAM
Graphics Processor: NVIDIA GeForce GTX 1650/PCIe/SSE2
Manufacturer: ASUS
I’ve filed upstream at the KDE bug spot, but they’re sure it’s a packaging/dependency issue. I can’t post links, but it’s bug report 468010 on their tracker. Furthermore, this issue is not occurring on ArchLinux according to my attempts to raise the bug report there.
Once i finish the “wizard” i can chose the storage, i chose XML for instance. Once that is done, i get the Configure window and the test.kmy window i just created …
