I want to use KMPlayer for playing my mp3 files. But with every click in dolphin to a new mp3-file starts a new session from KMPlayer, so there will be more and more KMPlayers on the desktop.
I don’t want to use or need a playlist into KMPlayer. I will start every mp3 to exercise with my guitar-playing.
Do you have a hint for me?
Thank you very much
regards
caho
For some reason KMPlayers is seg faulting on my end and crashing when i try to go to settings (not using it usually), but i prefer SMPlayer as front end for MPlayer … and is running just one instance … Maybe somebody else has a clue or speaks german and can identify things from your screenshot.
I use SMPlayer on my other computers and it works very well. I would like to prefer it, but here I have a brandnew manjaro-kde-installation on my new tuxedo - laptop. Here works SMPlayer very unstable and it freezes every time. KMPlayer works fine here.
… well
perhaps the file manager is not the right tool for the job that you want to do?
perhaps a suitable audio player - and a custom playlist which you can control via it’s interface is …?
I was basically just translating the meaning of the items that are visible in the screenshot - and relaying that.
