Kjots lost all my notes, I suspect a problem with akonadi similar to last time:
org.kde.pim.akonadicore: "QLocalSocket: Remote closed" "/run/user/1000/akonadi/akonadiserver-cmd.socket"
org.kde.pim.akonadicore: Socket error occurred: "QLocalSocket: Remote closed"
org.kde.pim.akonadicore: Job error: "Cannot connect to the Akonadi service." for collection: QVector()
Any suggestions?
Maybe begin with system information, as we dont know anything.
(and/or if we are to go by your profile then your system is in an unsupported state, using EOL kernel, etc)
inxi -Farz
Kernel: 6.8.9-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.8-x86_64
root=UUID=e276dad2-7983-44e7-a105-322feb3f86d3 rw quiet
udev.log_priority=3 set amd_iommu=on iommu=pt
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.1.0
wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop System: Micro-Star product: MS-7C35 v: 2.0
serial:
Mobo: Micro-Star model: MEG X570 UNIFY (MS-7C35) v: 2.0
serial: uuid: UEFI: American
Megatrends LLC. v: A.J0 date: 03/29/2024
ID-1: hidpp_battery_10 charge: 55% condition: N/A volts: 3.8 min: N/A
model: Logitech G Pro Wireless Gaming Mouse type: N/A serial:
status: discharging
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA20102B
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2235 high: 2631 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2199 2: 2200
3: 2200 4: 2631 5: 2202 6: 2200 7: 2200 8: 2198 9: 2200 10: 2200 11: 2200
12: 2200 bogomips: 88844
affected
Device-1: NVIDIA TU117GL [T600] driver: vfio-pci v: N/A alternate: nouveau
non-free: 550.xx+ status: current (as of 2024-04; EOL~2026-12-xx)
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 24:00.0 chip-ID: 10de:1fb1 class-ID: 0300
Device-2: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M] driver: amdgpu
v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1,
DP-2, DP-3, Writeback-1 bus-ID: 2f:00.0 chip-ID: 1002:744c class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
compositor: kwin_x11 driver: X: loaded: amdgpu dri: radeonsi gpu: amdgpu
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.00x22.48")
s-diag: 1165mm (45.88")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung serial:
built: 2018 res: 3840x2160 hz: 60 dpi: 52 gamma: 1.2
size: 1872x1053mm (73.7x41.46") diag: 1388mm (54.6") ratio: 16:9 modes:
max: 3840x2160 min: 720x400
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.6-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XT (radeonsi
navi31 LLVM 17.0.6 DRM 3.57 6.8.9-3-MANJARO) device-ID: 1002:744c
memory: 19.53 GiB unified: no
API: Vulkan v: 1.3.279 layers: 12 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XT (RADV NAVI31) driver: mesa radv v: 24.0.6-manjaro1.1
device-ID: 1002:744c surfaces: xcb,xlib
Device-1: NVIDIA driver: vfio-pci alternate: snd_hda_intel pcie:
speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s bus-ID: 24:00.1
chip-ID: 10de:10fa class-ID: 0403
Device-2: AMD Navi 31 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2f:00.1 chip-ID: 1002:ab30
class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: Corsair VIRTUOSO Wireless Gaming Headset
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 7-3:7 chip-ID: 1b1c:0a42 class-ID: 0300
serial:
API: ALSA v: k6.8.9-3-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin tools: pactl,pw-cat,pw-cli
Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac:
IF-ID-1: virbr0 state: down mac:
Info: services: NetworkManager, smbd, systemd-timesyncd
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 8087:0029
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: bt-v: 5.2 lmp-v: 11
status: discoverable: no pairing: no
Local Storage: total: 4.55 TiB used: 1.81 TiB (39.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 4TB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: fw-rev: 4B2QJXD7 temp: 50.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
tech: SSD serial: fw-rev: 2B6Q scheme: MBR
ID-1: / raw-size: 92.64 GiB size: 90.63 GiB (97.83%) used: 49.16 GiB (54.2%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 838.38 GiB size: 824.65 GiB (98.36%)
used: 564.98 GiB (68.5%) fs: ext4 dev: /dev/sda4 maj-min: 8:4
System Temperatures: cpu: 37.0 C mobo: 35.0 C gpu: amdgpu temp: 47.0 C
mem: 52.0 C
Fan Speeds (rpm): fan-1: 1569 fan-2: 1348 fan-3: 0 fan-4: 0 fan-5: 0
fan-6: 0 fan-7: 0 gpu: amdgpu fan: 487
Packages: 2126 pm: pacman pkgs: 2114 libs: 547 tools: pamac,yay pm: flatpak
pkgs: 12
1: https://mirror.easyname.at/manjaro/stable/$repo/$arch
2: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
Memory: total: 32 GiB available: 31.26 GiB used: 7.52 GiB (24.0%)
Processes: 351 Power: uptime: 12h 52m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 12.5 GiB
services: org_kde_powerdevil,upowerd Init: systemd v: 255
Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.34
While trying to start akonadi I get the following output:
akonadictl start
Detected locale "C" with character encoding "ANSI_X3.4-1968", which is not UTF-8.
Qt depends on a UTF-8 locale, and has switched to "C.UTF-8" instead.
If this causes problems, reconfigure your locale. See the locale(1) manual
for more information.
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
D-Bus session bus is not available!
Aborted (core dumped)
Is the “D-Bus session bus” the problem?
Ok I figured it out… The Kjots is not jet updated to latest 6.0.0 that is compatible with KDE6 therefore it cannot work.
system
Closed
24 May 2024 14:28
6
