Hello,
Installed kio-gdrive, when clicking on Network/Google drive in dolphin the authentication window is not displayed and dolphin is stcuk on “Loading…”. It workes OK on an older installation. What am I missing?
Edit: Rechecked older install, this too doesn’t work anymore.
TIA
I’m not sure, but I think you may need to activate KWallet and have it store your login credentials for Google.
Hi,
Thanks for answering.
I opened kdewallet but couldn’t locate anything usefull there.
Have you tried launching the Wallet Manager at the bottom right of the window?
same issue. It keeps on loading
Open terminal and type
kioclient5 exec gdrive:/
Paste results. Show screenshot.
Not sure how to check this.
GUI KSystemLog app.
Or
journalctl -b
04/02/2022 15:41 systemd systemd-coredump@7-370689-0.service: Deactivated successfully.
04/02/2022 15:41 kernel audit: type=1131 audit(1643982071.861:1129): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@7-370689-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
04/02/2022 15:41 audit SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@7-370689-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
04/02/2022 15:41 audit BPF prog-id=0 op=UNLOAD
04/02/2022 15:41 kernel audit: type=1334 audit(1643982071.955:1130): prog-id=0 op=UNLOAD
04/02/2022 15:41 kernel audit: type=1334 audit(1643982071.955:1131): prog-id=0 op=UNLOAD
04/02/2022 15:41 kernel audit: type=1334 audit(1643982071.955:1132): prog-id=0 op=UNLOAD
I launched KWalletManager, not sure about right-bottom of window.
PeliC
February 4, 2022, 10:25pm
14
I have the same issue as you. KIO Gdrive wont work
this is happening to me too.
giacomo
February 5, 2022, 1:17pm
16
The stable update from today, 2022-02-05, seems to have fixed this issue for me.
True, works OK after today’s update.
system
Closed
February 8, 2022, 10:52pm
19
