kid3
QCommandLineParser: already having an option named "h"
QCommandLineParser: already having an option named "help-all"
QCommandLineParser: already having an option named "v"
kf.i18n: KLocalizedString: Domain is not set for this string, translation will not work. Please see https://api.kde.org/frameworks/ki18n/html/prg_guide.html msgid: "Your emails" msgid_plural: "" msgctxt: "EMAIL OF TRANSLATORS"
kf.i18n: KLocalizedString: Domain is not set for this string, translation will not work. Please see https://api.kde.org/frameworks/ki18n/html/prg_guide.html msgid: "Your names" msgid_plural: "" msgctxt: "NAME OF TRANSLATORS"
qt.multimedia.ffmpeg: Using Qt multimedia with FFmpeg version n7.1 GPL version 3 or later
qt.multimedia.ffmpeg: Available HW decoding frameworks:
Segmentation fault (core dumped)
system
Kernel: 6.12.20-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=66c34da3-3ab4-45d2-94ed-5dbe6b76fc09 rw
resume=UUID=806f110d-2578-4c43-a545-cc4cac83b303 udev.log_priority=3
Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0 with: tint2
tools: light-locker avail: lxlock vt: 7 dm: LightDM v: 1.32.0
Type: Desktop System: Dell product: Precision T1700 v: 01
serial: <superuser required> Chassis: type: 6 serial: <superuser required>
Mobo: Dell model: 073MMW v: A02 serial: <superuser required>
part-nu: Precision T1700 uuid: <superuser required> BIOS: Dell v: A08
date: 04/25/2014
System RAM: total: 16 GiB available: 15.56 GiB used: 2.93 GiB (18.8%)
Array-1: capacity: 32 GiB slots: 4 modules: 4 EC: None
Device-1: DIMM3 type: DDR3 detail: synchronous size: 4 GiB
speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: Hynix/Hyundai part-no: HMT351U6EFR8C-PB serial: <filter>
Device-2: DIMM1 type: DDR3 detail: synchronous size: 4 GiB
Device-3: DIMM4 type: DDR3 detail: synchronous size: 4 GiB
Device-4: DIMM2 type: DDR3 detail: synchronous size: 4 GiB
Info: model: Intel Xeon E3-1240 v3 bits: 64 type: MT MCP arch: Haswell
level: v3 note: check built: 2013-15 process: Intel 22nm family: 6
model-id: 0x3C (60) stepping: 3 microcode: 0x28
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3406 min/max: 800/3800 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 3406 2: 3406 3: 3406 4: 3406 5: 3406 6: 3406
7: 3406 8: 3406 bogomips: 54299
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
rep_good sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: NVIDIA GK107GL [Quadro K2000] driver: nvidia v: 470.256.02
alternate: nouveau,nvidia_drm non-free: series: 470.xx+
status: legacy-active (EOL~2024-09-xx) arch: Kepler-2 code: GKxxx
process: TSMC 28nm built: 2012-2018 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 2 speed: 5 GT/s ports: active: none off: DVI-I-1
empty: DP-1,DP-2 bus-ID: 01:00.0 chip-ID: 10de:0ffe class-ID: 0300
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: xfwm4 v: 4.20.0 driver: X: loaded: nvidia
gpu: nvidia,nvidia-nvswitch display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 424x239mm (16.69x9.41")
s-diag: 487mm (19.16")
Monitor-1: DVI-I-1 mapped: DVI-I-0 note: disabled res: mode: 1600x900
hz: 60 scale: 100% (1) size: N/A modes: 1024x768, 800x600, 640x480
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
Info: Tools: de: xfce4-display-settings gpu: nvidia-smi
x11: xdpyinfo, xprop, xrandr
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Device-2: NVIDIA GK107 HDMI Audio driver: snd_hda_intel v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 2 speed: 5 GT/s
bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
Device-3: Arturia MiniFuse 2 driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.6.2:6 chip-ID: 1c75:af90
API: ALSA v: k6.12.20-2-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Message: No PCI device data found.
IF-ID-1: enp0s26u1u6 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Cypress CYW20704A2 driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 4-1.4:5 chip-ID: 04b4:f901
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.0
lmp-v: 9 status: discoverable: no pairing: no class-ID: 6c0104
Device-2: T & A Mobile Phones Alcatel 1S driver: rndis_host v: kernel
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 4-1.6:6
chip-ID: 1bbb:0173 class-ID: 0a00 serial: <filter>
Local Storage: total: 2.02 TiB used: 919.18 GiB (44.4%)
ID-1: /dev/sda maj-min: 8:0 model: SATA SSD size: 447.13 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 61.3 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 043 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: PSSD T7
size: 465.76 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 model: SATA SSD size: 223.57 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1
mode: 2.0 tech: SSD serial: <filter> scheme: MBR
Optical-1: /dev/sr0 vendor: â– â– â– â– â– â– â– â– model: DVD+-RW SW830 rev: D.02
dev-links: cdrom
ID-1: / raw-size: 32 GiB size: 31.2 GiB (97.50%) used: 27.7 GiB (88.8%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 66c34da3-3ab4-45d2-94ed-5dbe6b76fc09
ID-2: /home raw-size: 171.13 GiB size: 167.38 GiB (97.81%)
used: 40.11 GiB (24.0%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: a1922b61-64a8-44bb-8a1f-b0ec73630c9b
ID-3: /run/media/yt/Ava2 raw-size: 111.79 GiB size: 109.47 GiB (97.93%)
used: 101.16 GiB (92.4%) fs: ext4 dev: /dev/sdd1 maj-min: 8:49 label: Ava2
uuid: 5bff41cf-b179-41ee-8b9d-fb5d22df1168
ID-4: /run/media/yt/Badger raw-size: 116.44 GiB size: 114.05 GiB (97.95%)
used: 82.22 GiB (72.1%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: Badger
uuid: 1db91210-d727-42c9-b7bf-b17bd77c5faa
ID-5: /run/media/yt/Confusion raw-size: 232.88 GiB
size: 228.16 GiB (97.98%) used: 98.73 GiB (43.3%) fs: ext4 dev: /dev/sdb2
maj-min: 8:18 label: Confusion uuid: 76484507-22da-497e-9905-3f080705489c
ID-6: /run/media/yt/Dog raw-size: 232.88 GiB size: 228.17 GiB (97.98%)
used: 139.45 GiB (61.1%) fs: ext4 dev: /dev/sdc3 maj-min: 8:35 label: Dog
uuid: 5a5bfe12-f199-41e0-ab1d-a14246f22119
ID-7: /run/media/yt/Fox raw-size: 116.44 GiB size: 114.05 GiB (97.95%)
used: 90.79 GiB (79.6%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34 label: Fox
uuid: 665911b7-6293-44f4-ad5f-ff443334ea0f
ID-8: /run/media/yt/Nathan raw-size: 111.78 GiB size: 109.47 GiB (97.93%)
used: 72.9 GiB (66.6%) fs: ext4 dev: /dev/sdd2 maj-min: 8:50 label: Nathan
uuid: 5a465a93-cb3b-4d4a-af8d-e748e003972d
ID-9: /run/media/yt/Quicksilver raw-size: 232.88 GiB
size: 228.16 GiB (97.98%) used: 128.98 GiB (56.5%) fs: ext4 dev: /dev/sdb1
maj-min: 8:17 label: Quicksilver
uuid: 2e155450-644c-4952-b9a4-6f01242215af
ID-10: /run/media/yt/System raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
used: 4.6 MiB (0.0%) fs: ext4 dev: /dev/sdb3 maj-min: 8:19 label: System
uuid: c9b00fe6-d224-4393-a45f-6d9c758afb53
ID-11: /run/media/yt/shaftoe raw-size: 240 GiB size: 235.17 GiB (97.99%)
used: 137.12 GiB (58.3%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: a19a7a28-6912-4fb7-b701-75cd8dbc2902
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 806f110d-2578-4c43-a545-cc4cac83b303
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 15 rev: 2.0
Hub-2: 2-0:1 info: full speed or root hub ports: 3 rev: 2.0
Hub-3: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
Device-1: 2-1.3:3 info: CHERRY Keyboard type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 046a:b090 class-ID: 0300
Device-2: 2-1.4:4 info: Logitech Mouse type: mouse
chip-ID: 046d:c077 class-ID: 0301
Hub-4: 2-1.6:5 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Device-1: 2-1.6.2:6 info: Arturia MiniFuse 2 type: audio
driver: snd-usb-audio interfaces: 6 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 1c75:af90 class-ID: fe01
serial: <filter>
Hub-5: 3-0:1 info: super-speed hub ports: 6 rev: 3.0
Hub-6: 4-0:1 info: full speed or root hub ports: 3 rev: 2.0
Hub-7: 4-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8008
Device-1: 4-1.1:3 info: Samsung PSSD T7 type: mass storage driver: uas
interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 04e8:4001 class-ID: 0806 serial: <filter>
Device-2: 4-1.2:4 info: Integral Memory Fusion Flash Drive
type: mass storage driver: uas interfaces: 1 rev: 2.1
chip-ID: 26bd:9917 class-ID: 0806 serial: <filter>
Device-3: 4-1.4:5 info: Cypress CYW20704A2 type: bluetooth driver: btusb
interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
chip-ID: 04b4:f901 class-ID: fe01 serial: <filter>
Device-4: 4-1.6:6 info: T & A Mobile Phones Alcatel 1S
type: bluetooth,CDC-data driver: rndis_host interfaces: 3 rev: 2.0
System Temperatures: cpu: 34.0 C mobo: 20.0 C
Fan Speeds (rpm): cpu: 1035 mobo: 1314
Packages: pm: pacman pkgs: 1820 libs: 475 tools: pamac
1: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
2: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
3: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
5: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
6: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
7: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
8: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
9: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
10: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
11: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
12: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
13: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
14: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
15: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
16: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
17: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
18: https://mirror.init7.net/manjaro/stable/$repo/$arch
19: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
20: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
21: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
22: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
23: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
24: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
25: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
26: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
27: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
28: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
29: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
30: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
31: https://mirrors.manjaro.org/repo/stable/$repo/$arch
32: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
33: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
34: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
35: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
36: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
37: http://mirror.fcix.net/manjaro/stable/$repo/$arch
38: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
39: https://mirror.easyname.at/manjaro/stable/$repo/$arch
40: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
41: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
42: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
43: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
44: https://muug.ca/mirror/manjaro/stable/$repo/$arch
45: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
46: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
47: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
48: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
49: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
50: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
51: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
52: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
53: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
54: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
55: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
56: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
57: http://manjaro.grena.ge/stable/$repo/$arch
58: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
59: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
60: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
61: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
62: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
63: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
64: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
65: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
66: https://manjaro.ynh.ovh/stable/$repo/$arch
67: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
68: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
69: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
70: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
71: https://mirror.zetup.net/manjaro/stable/$repo/$arch
72: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
73: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
74: https://mirror.koddos.net/manjaro/stable/$repo/$arch
75: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
76: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
77: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
78: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
79: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
80: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
81: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
82: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
83: https://manjaro.kurdy.org/stable/$repo/$arch
84: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
85: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
86: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
87: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
88: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
89: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
90: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
91: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
92: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
93: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
94: https://mirror.23m.com/manjaro/stable/$repo/$arch
95: https://mirrors2.manjaro.org/stable/$repo/$arch
96: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
97: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
98: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
99: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
100: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
101: https://linorg.usp.br/manjaro/stable/$repo/$arch
102: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
103: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
104: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 278
1: cpu: 13.9% command: brave pid: 27603 mem: 314.5 MiB (1.9%)
2: cpu: 9.0% command: deadbeef pid: 18057 mem: 135.9 MiB (0.8%)
3: cpu: 6.5% command: brave pid: 26939 mem: 370.9 MiB (2.3%)
4: cpu: 4.4% command: brave pid: 1531 mem: 252.8 MiB (1.5%)
5: cpu: 3.2% command: Xorg pid: 1239 mem: 89.9 MiB (0.5%)
Memory top: 5 of 278
1: mem: 375.7 MiB (2.3%) command: brave pid: 1495 cpu: 1.7%
2: mem: 370.9 MiB (2.3%) command: brave pid: 26939 cpu: 6.5%
3: mem: 343.4 MiB (2.1%) command: seamonkey pid: 25209 cpu: 0.7%
4: mem: 315.4 MiB (1.9%) command: brave pid: 1790 cpu: 0.1%
5: mem: 314.5 MiB (1.9%) command: brave pid: 27603 cpu: 13.9%
Processes: 278 Power: uptime: 1h 35m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: upowerd,xfce4-power-manager
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Bash v: 5.2.37
running-in: xfce4-terminal inxi: 3.3.37
I have tried kid3-qt, gives similar error. kid3-cli works.
