I installed LXQT after I installed Manjaro KDE. So, Iḿ using KDE apps under LXQT (Dolphin. K3B…)
As I am used to KDE and like it, especially the start menu, I tried to make it my start menu in LXQT.
I made a launcher to:
plasmawindowed org.kde.plasma.kickoff
But it wasn’t a start menu as such it was like an app window, so I tried to customize it, like window type, window size, location… etc.
It seems I messed things up. It ended up to be a window on top left corner, can´t drag, can´t modify and can´t close. My fault I know.
So, how can I fix this issue?
How can I make Kickoff my default app launcher/ start menu in LXQT?
I mainly like it because of the search box where it searches apps and documents. That´s why!
Any help highly appreciated.
Thank you.
P.S. I hope this is the right forum as it is mainly related to a KDE app,
I already rebooted, and checked system monitor. Nothing running.
Just to be sure I understand, ¨plasmoids" are different from aplications?
Iḿ already using Dolphin and itaybe because KDE Plasma is already installed by default?
I will appreciate if you can help me fix the bad configurations I made so I can move and close the window!
I don´t feel ok just ignoring something not ok on my machine!
