Keyboard won't wake up from suspend
Having a strange issue with my keyboard not waking up from suspend on certain apps.
Running a dell inspiron 2-in-1 ( think this might be why I have the issue) on latest gnome testing branch. Everything works, touchscreen, tablet mode, auto rotate but when my pc wakes from suspend/sleep the physical keyboard won’t work on certain apps Vivaldi, Bluemail and Gitkracken to name a few but will still work on firefox, libre office, evolution etc. If I log out and log back in then the keyboard works again on vivaldi etc.
The issue only happens after I wake the laptop up from suspend and only on certain apps, any further info you need let me know
  Info: model: 13th Gen Intel Core i7-1360P bits: 64 type: MST AMCP
    arch: Raptor Lake level: v3 note: check built: 2022+ process: Intel 7 (10nm)
    family: 6 model-id: 0xBA (186) stepping: 2 microcode: 0x4122
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 12 threads: 16 mt: 4 tpc: 2
    st: 8 smt: enabled cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32
    KiB, 8x64 KiB L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
  Speed (MHz): avg: 400 min/max: 400/5000:3700 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400 15: 400 16: 400
    bogomips: 83584
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb pebs
    pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good
    sdbg sep serialize sha_ni smap smep smx split_lock_detect ss ssbd sse sse2
    tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
    vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves
    xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Perhaps the following might be relevant;
from Known issues and solutions:
Cheers.
It’s only on certain apps though which is strange and only the keyboard nothing else. Firefox is ok but chromium and Vivaldi aren’t, what’s the difference in the browsers is it gtk?
An obvious difference is that Vivaldi is Chromium-based and Firefox is, well, Firefox-based.
Gnome isn’t my DE of choice so I’m out suggestions if its configuration related.
Can you reproduce this in a fresh User account?
Perhaps if you provide full system information, it might prove useful to others wishing to help.
journalctl --boot=-1 --priority=3 --catalog --no-pager
