Hello,
After every boot/reboot/sleep the keyboard would become unresponsive for a few seconds. Sometimes it would be unresponsive for up to a minute. The touchpad works without any issues.
Any help regarding how I can fix this issue will be very helpful.
Here are a few outputs that might be helpful.
Kernel: 5.15.76-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=1eec5467-4b20-47ca-9b42-094182a60025 rw quiet
resume=UUID=af51981d-e865-4db7-960b-4d2ed2271af2 udev.log_priority=3
Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP Laptop 14s-dy2xxx v: N/A
Mobo: HP model: 87FD v: 57.20 serial: <superuser required> UEFI: AMI
v: F.21 date: 03/21/2022
ID-1: BAT0 charge: 5.7 Wh (14.7%) condition: 38.7/41.0 Wh (94.3%) volts: 10.8
min: 11.4 model: HP Primary type: Li-ion serial: <filter> status: discharging
cycles: 177
RAM: total: 7.41 GiB used: 4.01 GiB (54.1%)
Info: model: 11th Gen Intel Core i3-1125G4 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xA4
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 884 high: 1159 min/max: 400/3700 scaling:
driver: intel_pstate governor: powersave cores: 1: 967 2: 624 3: 1044 4: 1113
5: 1159 6: 620 7: 637 8: 908 bogomips: 31960
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel Tiger Lake-LP GT2 [UHD Graphics G4] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
bus-ID: 0000:00:02.0 chip-ID: 8086:9a78 class-ID: 0300
Device-2: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-3:3 chip-ID: 0408:5365 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1400 built: 2018 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.2.1 renderer: Mesa Intel UHD Graphics (TGL GT2)
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Hewlett-Packard
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Sound API: ALSA v: k5.15.76-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
port: 3000 bus-ID: 0000:01:00.0 chip-ID: 10ec:c822 class-ID: 0280
IF-ID-1: CloudflareWARP state: unknown speed: 10 Mbps duplex: full mac: N/A
IP v4: <filter> scope: global
IP v6: <filter> scope: global
IP v6: <filter> virtual: stable-privacy scope: link
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-10:4 chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 238.47 GiB used: 68.1 GiB (28.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLQ256HBJD-00BH1
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: HPS1NFAV temp: 43.9 C scheme: GPT
ID-1: / raw-size: 130.17 GiB size: 127.07 GiB (97.62%)
used: 26.21 GiB (20.6%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
label: N/A uuid: 1eec5467-4b20-47ca-9b42-094182a60025
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4
label: NO_LABEL uuid: D944-9043
ID-3: /home raw-size: 100 GiB size: 97.87 GiB (97.87%)
used: 41.89 GiB (42.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 1d299b04-41aa-40a3-a93e-951a08cd6d8f
ID-1: swap-1 type: partition size: 8 GiB used: 256 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: af51981d-e865-4db7-960b-4d2ed2271af2
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-2:2 info: Sunplus Innovation Gaming mouse [Philips SPK9304]
type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 98mA chip-ID: 1bcf:08a0 class-ID: 0301
Device-2: 1-3:3 info: Quanta HP TrueVision HD Camera type: Video
Device-3: 1-10:4 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 41.0 C mobo: N/A
Processes: 272 Uptime: 16m wakeups: 1540 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: 1391 pm: pacman pkgs: 1374 libs: 358 tools: pamac,yay pm: flatpak
pkgs: 17 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.23
xinput list
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ HID 1bcf:08a0 Mouse id=9 [slave pointer (2)]
⎜ ↳ HID 1bcf:08a0 Keyboard id=10 [slave pointer (2)]
⎜ ↳ SYNA32AD:00 06CB:CD50 Mouse id=13 [slave pointer (2)]
⎜ ↳ SYNA32AD:00 06CB:CD50 Touchpad id=14 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Power Button id=8 [slave keyboard (3)]
↳ HP TrueVision HD Camera: HP Tru id=12 [slave keyboard (3)]
↳ Wireless hotkeys id=16 [slave keyboard (3)]
↳ HP WMI hotkeys id=15 [slave keyboard (3)]
↳ HID 1bcf:08a0 id=11 [slave keyboard (3)]
↳ HID 1bcf:08a0 Keyboard id=17 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=18 [slave keyboard (3)]
ls --recursive /etc/X11/
/etc/X11/:
mhwd.d xinit xorg.conf.d
/etc/X11/mhwd.d:
/etc/X11/xinit:
xinitrc xinitrc.d xserverrc
/etc/X11/xinit/xinitrc.d:
40-libcanberra-gtk-module.sh 50-systemd-user.sh 80xapp-gtk3-module.sh
/etc/X11/xorg.conf.d:
00-keyboard.conf 30-touchpad.conf
