I’m experiencing this issue for a while already.
Whenever I don’t use them for a bit (~5-10s) they are “stuck” and a lag occurs. Sometimes sending the input multiple times.
e.g. with Strg+w
accidentally closing 2 tabs in firefox,
or the courser moves a bit gets stuck and then moves again
With a keyboard the lag only happens after an idle time, while moving the mouse it sometimes happens in between as well.
some observations
- It only occurs when no external monitor is connected.
- How the monitor is connected does not seem to matter (hdmi, Usb-c+db)
- Tried with different monitors
- it happens on external and internal keyboards/mices
- power plugged in or not does not seem to matter
Right now it was hard to reproduce the issue, the next time this gets annoying what log messages could I check?
Some system infos.
$ inxi -Fazy
/System:
Kernel: 5.10.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=d533e8d0-5320-414e-b164-3f637e551613 rw quiet
cryptdevice=UUID=29ad5aaf-a3f2-4b54-bcc8-3ae4e551cf75:luks-29ad5aaf-a3f2-4b54-bcc8-3ae4e551cf75
root=/dev/mapper/luks-29ad5aaf-a3f2-4b54-bcc8-3ae4e551cf75
resume=/dev/mapper/luks-29ad5aaf-a3f2-4b54-bcc8-3ae4e551cf75 apparmor=1
Desktop: awesome 4.3 dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 20QNCTO1WW v: ThinkPad P53
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20QNCTO1WW v: SDK0R32862 WIN serial: <filter>
UEFI: LENOVO v: N2NET31W (1.16 ) date: 10/09/2019
ID-1: BAT0 charge: 49.7 Wh condition: 84.2/90.0 Wh (94%) volts: 11.6/11.2
model: SMP 02DL028 type: Li-poly serial: <filter> status: Unknown cycles: 75
Device-1: hidpp_battery_1 model: Logitech Wireless Mouse MX Master 3
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: DE L2 cache: 12 MiB
bogomips: 62431
Speed: 800 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: Lenovo driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3e9b class ID: 0300
Device-2: NVIDIA TU117GLM [Quadro T2000 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 460.56 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1fb8 class ID: 0300
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus ID: 1-8:4 chip ID: 13d3:56bc class ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 driver: loaded: modesetting,nvidia
display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 111 s-size: 878x494mm (34.6x19.4")
s-diag: 1007mm (39.7")
Monitor-1: HDMI-0 res: 3840x2160 hz: 30 dpi: 111
size: 878x485mm (34.6x19.1") diag: 1003mm (39.5")
OpenGL: renderer: Quadro T2000/PCIe/SSE2 v: 4.6.0 NVIDIA 460.56
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:a348 class ID: 0403
Device-2: JMTek LLC. USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-5.2.3:16
chip ID: 0c76:153f class ID: 0300
Sound Server: ALSA v: k5.10.19-1-MANJARO
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus ID: 1-14:9 chip ID: 8087:0029 class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 1.86 TiB used: 413.74 GiB (21.7%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung model: MZVLB1T0HBLR-000L7
size: 953.87 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: 4M2QEXF7 temp: 38.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: MZVLB1T0HBLR-000L7
lanes: 4 rotation: SSD serial: <filter> rev: 4M2QEXF7 temp: 43.9 C
scheme: GPT
ID-1: / raw size: 953.57 GiB size: 937.61 GiB (98.33%)
used: 206.87 GiB (22.1%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-29ad5aaf-a3f2-4b54-bcc8-3ae4e551cf75
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 424 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
System Temperatures: cpu: 48.0 C mobo: N/A gpu: nvidia temp: 48 C
Processes: 373 Uptime: 1h 33m wakeups: 4744 Memory: 31.01 GiB
used: 6.04 GiB (19.5%) Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.1.0 Packages: pacman: 1744 lib: 446 flatpak: 0 Shell: fish
v: 3.1.2 default: Zsh v: 5.8 running in: alacritty inxi: 3.3.01
