Currently running Manjaro Gnome 41.3 (linux516
), I switched from X11 to Wayland and found that one of my shortcuts quit working.
In Gnome Settings - Keyboard Shortcuts - View and Customize Shortcuts - Screenshots, I have set “Save a screenshot of a window to pictures” to Shift+Ctrl+$
(4
) (ancient OSX muscle memory). This shortcut works well in an X11 session, but when running Wayland, it does not.
Strange also: when setting it to some other key combination, e.g. Shift+Ctrl+"
(2
), it does work in a Wayland session.
The shortcuts for area selection Shift+Ctrl+%
(5
) and for the entire screen Shift+Ctrl+§
(3
) work fine on both X11 and Wayland.
Funnily, the shortcut to record a screencast does not work on Shift+Ctrl+&
(6
) but it does on Shift+Ctrl+/
(7
What is going on with these shortcuts on the 4
and the 6
keys? Are they used by some other Gnome feature? Why is this happening only in a Wayland session? How can I debug this?
