Since the update to Plasma 6, most of my keyboard shortcuts are fine except for three of them vanished and no changes I make to shortcuts via System Settings persist across reboots. I’m not the only person this has happened to, but they got no response since March.
I have found online about using kwriteconfig5 to update ~/.config/kglobalshortcutsrc and have figured out the kwriteconfig6 commands to add my missing shortcuts to that file… but the shortcuts don’t work or show up in System Settings.
One thread I found included the following commands to “activate” the changes:
~ which kglobalaccel6 INT ✘
kglobalaccel6 not found
~ which kglobalaccel 1 ✘
kglobalaccel not found
~ which kglobalaccel5 1 ✘
kglobalaccel5 not found
A more recent article said to update both kglobalshortcutsrc and kwinrc with the desired shortcuts and then run qdbus org.kde.KWin /KWin reconfigure but this, also, has not worked for me. The shortcuts still don’t work or show in System Settings.
Has anyone here managed to fix this this sort of issue before, or know what is now the correct command to “activate” changes written to kglobalshortcutsrc from terminal?
Thats your problem then.
You are correct khotkeys is deprecated. Even if you previously used it for shortcuts, you would need to remove it and apply them again using kglobalaccel.
I dont know how you are missing kglobalaccel, as its part of plasma.
As mentioned, kglobalaccel is a dependency of plasma-desktop.
Your shortcuts should be configurable through System Settings as usual.
And/or directly by kglobalaccel.
PS
Your missing core packages makes me wonder about the general integrity of your system.
Have you accidentally removed things?
Performed a partial-upgrade?
Thank you for the response and commands to fix it; I’ll run them in a minute and report back.
As far as I’m aware I have never consciously used khotkeys nor any other terminal method; until now, I have always configured keyboard shortcuts in the System Settings GUI.
As far as I’m aware, no. I installed the Big Bag of Updates™ a day or two after it was announced, via the Add/Remove Software GUI, and everything competed. Other than my font sizes needing adjusting and this shortcut issue, everything seemed to go smoothly. Clearly not so smooth after all.
And khotkeys would have been there. Until it was not.
Without logs or something we cannot know for sure.
If you used pamac with the AUR enabled maybe some core packages were replaced?
Maybe certain packages were removed previously at some point?
You could, for example, check mapare just to print default packages not installed;
plasma-desktop reinstalled but still no kglobalaccel:
~ sudo pacman -Syu plasma-desktop
:: Synchronising package databases...
core is up to date
extra 8.3 MiB 1968 KiB/s 00:04 [############] 100%
community is up to date
multilib is up to date
warning: plasma-desktop-6.0.4-1 is up to date -- reinstalling
resolving dependencies...
Packages (1) plasma-desktop-6.0.4-1
Total Installed Size: 30.60 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring [############] 100%
(1/1) checking package integrity [############] 100%
(1/1) loading package files [############] 100%
(1/1) checking for file conflicts [############] 100%
(1/1) checking available disk space [############] 100%
(1/1) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(1/1) reinstalling plasma-desktop [############] 100%
(1/6) Arming ConditionNeedsUpdate...
(2/6) Refreshing PackageKit...
(3/6) Reloading system bus configuration...
(4/6) Updating icon theme caches...
(5/6) Checking which packages need to be rebuilt
(6/6) Updating the desktop file MIME type cache...
mapare lists no missing packages:
~ bash <(curl -s https://gitlab.com/cscs/mapare/-/raw/main/mapare) -IP
Manjaro Package Restore
Retrieve and reinstall package lists
Please provide desktop environment (kde,xfce,gnome): kde
Packages for installation:
I’ll reboot, without my kwriteconfig stuff set to run on login, and see what System Setting’s behaviour is like.
In that case, it seems I do have it installed after all. Looks like uninstalling khotkeys has fixed my shortcuts issue; changes made in System Settings are now persistent across reboots.
I have now removed the [community] section from /etc/pacman.conf.
I have no idea what that is so I doubt I’d have gone out of my way to install it. According to pacman -Qi it is required by packagekit-qt5 and packagekit-qt6 which aren’t required by anything but are optional for, respectively:
frameworkintegration5
frameworkintegration and plasma-desktop
I must have accepted it as an optional dependency at some point, assuming it wasn’t part of my initial Manjaro install.
