I have updated my system after two weeks of not using my computer, everything was fine until I started application with wine. Keys were “shifted”, S became D, D - F, F - G, G - H, and H is nothing. I was searching anyone with same problem, but there’s no results. Still in active search of the problem.
Also, here is inxi --admin --verbosity=7 --filter --width
output:
Kernel: 5.15.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=ab82cab1-7b98-420b-b96f-da3555506bcf rw irqpoll apparmor=1
sysrq_always_enabled=1 security=apparmor udev.log_priority=3
libahci.ignore_sss=1
Console: pty pts/2 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Desktop System: ASUS product: N/A v: N/A serial: N/A
Mobo: ASUSTeK model: TUF GAMING A520M-PLUS v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 1004 date: 08/13/2020
RAM: total: 15.01 GiB used: 5.12 GiB (34.1%)
Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB
note: est.
Device-1: DIMM_A1 size: No Module Installed
Device-2: DIMM_A2 size: 8 GiB speed: 3200 MT/s type: DDR4
detail: synchronous unbuffered (unregistered) bus-width: 64 bits
total: 64 bits manufacturer: Kingston part-no: KHX3200C16D4/8GX
serial: <filter>
Device-3: DIMM_B1 size: No Module Installed
Device-4: DIMM_B2 size: 8 GiB speed: 3200 MT/s type: DDR4
serial: <filter>
Info: model: AMD Ryzen 3 PRO 4350G with Radeon Graphics socket: AM4 bits: 64
type: MT MCP arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 3800 min/max: 1400/4104 boost: enabled
base/boost: 3800/4100 scaling: driver: acpi-cpufreq governor: performance
volts: 1.2 V ext-clock: 100 MHz cores: 1: 3800 2: 3800 3: 3800 4: 3800
5: 3800 6: 3800 7: 3800 8: 3800 bogomips: 60710
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
Device-1: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 07:00.0 chip-ID: 1002:1636 class-ID: 0300
Display: server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
loaded: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: DisplayPort-0 res: 1920x1080 hz: 60 dpi: 102
size: 476x268mm (18.7x10.6") diag: 546mm (21.5")
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.15.19-1-MANJARO LLVM 13.0.0)
v: 4.6 Mesa 21.3.5 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 07:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK PRIME B450M-A
driver: snd_hda_intel v: kernel bus-ID: 07:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.15.19-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.20 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.45 running: yes
vendor: ASUSTeK driver: r8169 v: kernel port: f000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: anbox0 state: down mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-7:2 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 942.7 GiB used: 600.82 GiB (63.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Lexar model: 512GB SSD
size: 476.94 GiB block-size: physical: 512 B logical: 512 B sata: 3.2
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 117H temp: 48 C
scheme: GPT
SMART: yes state: enabled health: PASSED on: 91d 1h cycles: 640
read: 2.4 MiB written: 1.7 MiB
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3500418AS
family: Barracuda 7200.12 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B sata: 2.6 speed: 3.0 Gb/s type: HDD rpm: 7200
serial: <filter> rev: CC38 temp: 36 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 2y 48d 7h cycles: 4086
read: 466.9 GiB written: 1.05 TiB Pre-Fail: attribute: Spin_Retry_Count
value: 100 worst: 100 threshold: 97
Optical-1: /dev/sr0 vendor: Optiarc model: DVD RW AD-7240S rev: 1.03
dev-links: cdrom
ID-1: / raw-size: 107.42 GiB size: 105.17 GiB (97.91%)
used: 99.45 GiB (94.6%) fs: ext4 block-size: 4096 B dev: /dev/sdb2
maj-min: 8:18 label: N/A uuid: ab82cab1-7b98-420b-b96f-da3555506bcf
ID-2: /run/media/sergey/windows raw-size: 476.29 GiB
size: 476.29 GiB (100.00%) used: 259.87 GiB (54.6%) fs: ntfs
block-size: 4096 B dev: /dev/sda2 maj-min: 8:2 label: windows
uuid: D64EB7DE4EB7B619
ID-3: /run/media/sergey/документы raw-size: 353.39 GiB
size: 353.39 GiB (100.00%) used: 241.49 GiB (68.3%) fs: ntfs
block-size: 4096 B dev: /dev/sdb1 maj-min: 8:17
label: \xd0\xb4\xd0\xbe\xd0\xba\xd1\x83\xd0\xbc\xd0\xb5\xd0\xbd\xd1\x82\xd1\x8b
uuid: BE10D6DB10D69A2B
Kernel: swappiness: 20 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: file size: 512 MiB used: 43.3 MiB (8.5%) priority: 50
file: /var/lib/systemd-swap/swapfc/1
ID-2: swap-2 type: file size: 512 MiB used: 172 KiB (0.0%) priority: 49
file: /var/lib/systemd-swap/swapfc/2
ID-3: swap-3 type: file size: 512 MiB used: 8 KiB (0.0%) priority: 48
file: /var/lib/systemd-swap/swapfc/3
ID-4: swap-4 type: file size: 512 MiB used: 20 KiB (0.0%) priority: 47
file: /var/lib/systemd-swap/swapfc/4
ID-1: /dev/sda1 maj-min: 8:1 size: 50 MiB fs: ntfs
label: \xd0\x97\xd0\xb0\xd1\x80\xd0\xb5\xd0\xb7\xd0\xb5\xd1\x80\xd0\xb2\xd0\xb8\xd1\x80\xd0\xbe\xd0\xb2\xd0\xb0\xd0\xbd\xd0\xbe \xd1\x81\xd0\xb8\xd1\x81\xd1\x82\xd0\xb5\xd0\xbc\xd0\xbe\xd0\xb9
uuid: 4890B29090B283CA
ID-2: /dev/sda3 maj-min: 8:3 size: 100 MiB fs: vfat label: N/A
uuid: 2CC8-6A7F
ID-3: /dev/sda4 maj-min: 8:4 size: 509 MiB fs: ntfs label: N/A
uuid: 264ABC374ABC0599
ID-4: /dev/sdb3 maj-min: 8:19 size: 4.88 GiB fs: ext2 label: recovery_iso
uuid: dc32d219-9620-4de4-8d96-ee6e012c7e66
ID-5: /dev/sdb4 maj-min: 8:20 size: 60 MiB fs: vfat label: RECOVERYEFI
uuid: 5A4A-2F57
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 9 rev: 2.0
Device-1: 1-7:2 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
Hub-2: 2-0:1 info: Super-speed hub ports: 3 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-1:2 info: [Maxxter] Optical gaming mouse type: Mouse,Keyboard
power: 100mA chip-ID: 18f8:0f99 class-ID: 0301
Device-2: 5-2:3 info: A4Tech USB Device type: Keyboard,Mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 09da:f624 class-ID: 0300
Hub-6: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 54.8 C mobo: N/A gpu: amdgpu temp: 44.0 C
Processes: 322 Uptime: 5h 46m wakeups: 0 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 2112
pacman: 2086 lib: 542 flatpak: 15 snap: 11 Shell: Zsh (sudo) v: 5.8
default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.12
And latest Wine log:
lutris-wrapper: No Man's Sky
Started initial process 333745 from gamemoderun /home/sergey/.local/share/lutris/runners/wine/lutris-ge-lol-7.0-1-x86_64/bin/wine /home/sergey/Games/no-mans-sky/drive_c/Program Files/No Man's Sky/Binaries/NMS.exe
Start monitoring process.
gamemodeauto:
fsync: up and running.
Wine cannot find the FreeType font library. To enable Wine to
use TrueType fonts please install a version of FreeType greater than
or equal to 2.0.5.
http://www.freetype.org
or equal to 2.0.5.
or equal to 2.0.5.
or equal to 2.0.5.
or equal to 2.0.5.
or equal to 2.0.5.
or equal to 2.0.5.
or equal to 2.0.5.
info: Game: NMS.exe
info: DXVK: v1.9.4-1-g03234ffc
info: Built-in extension providers:
info: Win32 WSI
info: OpenVR
info: OpenXR
info: OpenVR: could not open registry key, status 2
warn: OpenVR: Failed to initialize OpenVR
info: Enabled instance extensions:
info: VK_KHR_get_surface_capabilities2
info: VK_KHR_surface
info: VK_KHR_win32_surface
info: AMD RADV RENOIR:
info: Driver: 21.3.5
info: Vulkan: 1.2.195
info: Memory Heap[0]:
info: Size: 1194 MiB
info: Flags: 0x0
info: Memory Type[1]: Property Flags = 0x6
info: Memory Type[3]: Property Flags = 0xe
info: Memory Type[5]: Property Flags = 0xc6
info: Memory Type[7]: Property Flags = 0xce
info: Memory Heap[1]:
info: Size: 2389 MiB
info: Flags: 0x1
info: Memory Type[0]: Property Flags = 0x1
info: Memory Type[2]: Property Flags = 0x7
info: Memory Type[4]: Property Flags = 0xc1
info: Memory Type[6]: Property Flags = 0xc7
wine: Call from 0000000170031FB8 to unimplemented function api-ms-win-crt-private-l1-1-0.dll._o___std_type_info_destroy_list, aborting
wine: Call from 0000000170031FB8 to unimplemented function api-ms-win-crt-private-l1-1-0.dll._o__seh_filter_dll, aborting
