As far as I can tell, that laptop’s keyboard is still PS/2 and doesn’t work in (recent) kernels. Totally unsure 'bout that, so more than ready to be proved wrong.
Hy,
If you add the i8042.dumbkbd parameter to the GRUB_CMDLINE_LINUX the PS/2 keyboard will be shown in the output of the libinput list-devices (or xinput also), but sadly the keyboard still not working.
Here is my case:
[grxb@asus-s14x ~]$ cat /etc/default/grub | grep CMDLINE
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor resume=UUID=eeaa1257-889b-4419-9b95-ba09e5be0184 udev.log_priority=3 i8042.dumbkbd i8042.noaux i8042.noloop i8042.nomux i8042.nopnp i8042.notimeout i8042.reset=Y i8042.unlock i8042.kbdreset i8042.probe_defer"
GRUB_CMDLINE_LINUX=""
dmesg:
[ 1.488694] i8042: PNP detection disabled
[ 1.490802] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.608010] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
libinput list-devices:
Device: AT Translated Set 2 keyboard
Kernel: /dev/input/event2
Group: 9
Seat: seat0, default
Capabilities: keyboard
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Middle emulation: n/a
Calibration: n/a
Scroll methods: none
Click methods: none
Disable-w-typing: n/a
Disable-w-trackpointing: n/a
Accel profiles: n/a
Rotation: n/a
[grxb@asus-s14x ~]$ sudo xinput
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ ASUE120B:00 04F3:31C0 Mouse id=14 [slave pointer (2)]
⎜ ↳ DuckyChannel International Co., Ltd. Ducky Keyboard Mouse id=11 [slave pointer (2)]
⎜ ↳ ASUE120B:00 04F3:31C0 Touchpad id=15 [slave pointer (2)]
⎜ ↳ Logitech MX Ergo id=18 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=7 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=17 [slave keyboard (3)]
↳ Video Bus id=6 [slave keyboard (3)]
↳ DuckyChannel International Co., Ltd. Ducky Keyboard id=8 [slave keyboard (3)]
↳ USB2.0 HD UVC WebCam: USB2.0 HD id=13 [slave keyboard (3)]
↳ Asus WMI hotkeys id=16 [slave keyboard (3)]
↳ DuckyChannel International Co., Ltd. Ducky Keyboard System Control id=9 [slave keyboard (3)]
↳ DuckyChannel International Co., Ltd. Ducky Keyboard Consumer Control id=10 [slave keyboard (3)]
↳ DuckyChannel International Co., Ltd. Ducky Keyboard id=12 [slave keyboard (3)]
↳ Logitech MX Ergo id=19 [slave keyboard (3)]
I have an Asus Vivobook S14 OLED K3402ZA, so I’m also interested the solution so much. ![]()
it’s better to open your own thread even if its the same problem or a similar problem.
Just tried this, downloaded the latest iso, installed using an onscreen keyboard. Still same problem. ![]()
Bios is at latest version.
it looks like this is a widespread issue with this line of laptops. If we can find a solution here this thread will be valuable to other people looking to use manjaro on this hardware
Try kernel 6.0-rc1 when available. It’s a shot in the dark though (I’m too lazy to figure out if there are any asus additions).
(Would be nice if mainline PKGBUILD for manjaro was available somewhere…sigh)
EDIT: Ok, it’s available now (PKGBUILD that is).
this model has even with ms-windows problems and need a specific driver for the normal use of the keyboard. good luck mates but this is a suspicious model.
Hi I have found out the patch for this laptop it is listed in the kernel bugs so it will be officially patched soon!
How can i share the link here?
on the “bugzilla.kernel .org” id is 216158
here you are:
https://bugzilla.kernel.org/show_bug.cgi?id=216158
just one more thing how can i apply the patch myself? listed there
as i understand this is jaus a preliminary, i can’t see any avaiable patch for now.
You need to compile kernel yourself:
git clonedesired kernel from manjaro gitlab - download
.patchfile and put it in same directory - edit PKGBUILD and add the patch
- build with
makepkg
https://wiki.archlinux.org/title/Patching_packages
https://wiki.archlinux.org/title/PKGBUILD
https://wiki.archlinux.org/title/makepkg
Thanks everyone the keyboard now works after patching and building the kernel!
