Hi,
I’m having a strange issue with a Logitech Mx Keys S keyboard on Manjaro KDE (Wayland) which was working fine before.
Current behavior:
- The keyboard works at the SDDM/login screen.
- The keyboard is detected in Solaar.
- The Logitech mouse still works fine through the same Logi Bolt receiver.
- But once the KDE session starts, key presses stop working completely.
- The keyboard can still reconnect/pair normally.
What happened:
I was using another USB keyboard for a few days. I installed last Manjaro upgrades. I noticed my touchpad stopped working.
I installed the following packages while trying to troubleshoot my touchpad:
sudo pacman -Syu libinput xf86-input-libinput
Few days later I tried to use my logitech keyboard but it didn’t work.
I already tried:
- rebooting
- disconnecting/reconnecting the keyboard for Solaar
- removing xf86-input-void (adviced by ChatGPT)
- checking lsusb (receiver detected correctly)
sudo evtest /dev/input/event3correctly receives the keyboard inputs (adviced by ChatGPT)systemctl --user stop ydotoold(but still ko)
I also got this warning from Fcitx5 at some point, which I disabled then uninstalled:
“Fcitx should be launched by KWin under KDE Wayland…”
Any ideas on what to check next?
System information:
Kernel: 6.12.90-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
root=UUID=9a713eb6-3b19-4e57-96d2-46e15d2a47d4 ro quiet apparmor=1
security=apparmor resume=UUID=fc2be996-aac5-49bf-8ff3-07e101a56602
udev.log_priority=3
Desktop: KDE Plasma v: 6.6.5 tk: Qt v: N/A info: frameworks v: 6.26.0
wm: kwin_wayland with: krunner vt: 1 dm: SDDM Distro: Manjaro
base: Arch Linux
Type: Convertible System: LENOVO product: 82BH v: Yoga 7 14ITL5
serial: <superuser required> Chassis: type: 31 v: Yoga 7 14ITL5
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> part-nu: LENOVO_MT_82BH_BU_idea_FM_Yoga 7
14ITL5 uuid: <superuser required> Firmware: UEFI vendor: LENOVO
v: F5CN38WW date: 10/26/2020
ID-1: BAT0 charge: 71.7 Wh (100%) condition: 71.7/71 Wh (101%) volts: 17.15
min: 15.4 model: LGC L19L4PDC type: Li-poly serial: <filter> charging:
status: full cycles: 654
System RAM: total: 16 GiB available: 15.42 GiB used: 5.6 GiB (36.3%)
Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
Device-1: Controller0-ChannelA type: DDR4 detail: synchronous size: 8 GiB
speed: 3200 MT/s volts: curr: 1 width (bits): data: 64 total: 64
manufacturer: Micron Technology part-no: 4ATF1G64HZ-3G2E1 serial: N/A
Device-2: Controller1-ChannelA type: DDR4 detail: synchronous size: 8 GiB
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xBE
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
desc: 4x1.2 MiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 400 min/max: 400/4200 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 bogomips: 38720
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp
rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2
tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Type: indirect_target_selection mitigation: Aligned branch/return thunks
conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Type: vmscape status: Not affected
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
built: 2020-21 ports: active: DP-2 off: eDP-1 empty: DP-1, DP-3, DP-4,
HDMI-A-1, HDMI-A-2, HDMI-A-3, HDMI-A-4 bus-ID: 00:02.0 chip-ID: 8086:9a49
class-ID: 0300
Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:4 chip-ID: 174f:243f
alternate: fbdev,vesa dri: iris gpu: i915 display-ID: 0
Monitor-1: DP-2 model: H32T13 built: 2024 res: mode: 2560x1440 hz: 100
scale: 125% (1.25) to: 2048x1152 dpi: 93 gamma: 1.2 chroma: red: x: 0.682
y: 0.310 green: x: 0.208 y: 0.702 blue: x: 0.145 y: 0.051 white: x: 0.314
y: 0.329 size: 531x298mm (20.91x11.73") diag: 801mm (31.5") ratio: 16:9
modes: 2560x1440, 1920x1440, 1856x1392, 1792x1344, 2048x1152, 1920x1200,
1920x1080, 1600x1200, 1680x1050, 1680x945, 1400x1050, 1600x900,
1280x1024, 1440x900, 1280x960, 1360x768, 1280x800, 1152x864, 1280x768,
1280x720, 1024x768, 1024x576, 800x600, 848x480, 720x480, 640x480,
720x400, 640x400, 640x350
Monitor-2: eDP-1 model: ChiMei InnoLux 0x1402 built: 2018 res: 1920x1080
dpi: 158 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600
blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9
modes: 1920x1080
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 26.0.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL
GT2) device-ID: 8086:9a49 memory: 15.06 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.350 layers: 6 device: 0 type: integrated-gpu name: Intel
Iris Xe Graphics (TGL GT2) driver: mesa intel v: 26.0.6-arch1.1
device-ID: 8086:9a49 surfaces: N/A
x11: xdpyinfo, xprop, xrandr
Device-1: Intel 500 Series Family On-Package High Definition Audio
vendor: Lenovo driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel,
snd_soc_avs, snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:a0c8
class-ID: 0401
API: ALSA v: k6.12.90-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.5 status: off with: pipewire-media-session
status: active tools: pw-cat,pw-cli
Server-4: PulseAudio v: 17.0-98-gb096 status: active with:
tools: pacat,pactl
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:7 chip-ID: 8087:0026
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 1011.17 GiB used: 848.78 GiB (83.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBPNTY-1T00-1101 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 11170001 temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: USB 3.2Gen1
size: 57.3 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.1
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1.00
scheme: MBR
ID-1: / raw-size: 97.66 GiB size: 95.56 GiB (97.86%) used: 80.57 GiB (84.3%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 9a713eb6-3b19-4e57-96d2-46e15d2a47d4
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 9954-FF9D
ID-3: /home raw-size: 836.18 GiB size: 821.98 GiB (98.30%)
used: 768.22 GiB (93.5%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: N/A uuid: ef5ddeff-272d-411d-9a0a-49bae31e22a8
ID-1: swap-1 type: partition size: 19.53 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: fc2be996-aac5-49bf-8ff3-07e101a56602
ID-1: /dev/sda1 maj-min: 8:1 size: 5.28 GiB fs: iso9660
ID-2: /dev/sda2 maj-min: 8:2 size: 4 MiB fs: vfat label: MISO_EFI
uuid: C1C6-0176
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-1:10 info: SanDisk 3.2Gen1 type: mass storage
driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 224mA chip-ID: 0781:55a9 class-ID: 0806
serial: <filter>
Hub-4: 3-3:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 3-3.1:5 info: Yubicom Yubikey 4/5 OTP+U2F+CCID
type: keyboard,HID,smart card driver: hid-generic,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 30mA
chip-ID: 1050:0407 class-ID: 0b00
Device-2: 3-3.3:9 info: Logitech Logi Bolt Receiver
type: keyboard,mouse,HID driver: hid-generic,hid-multitouch,usbhid
interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 98mA chip-ID: 046d:c548 class-ID: 0300
Device-3: 3-3.4:8 info: xxxxxxxx USB Type-C Digital AV Adapter
type: billboard driver: N/A interfaces: 1 rev: 2.0
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 496mA
chip-ID: 343c:0000 class-ID: 1100 serial: <filter>
Device-4: 3-8:4 info: Syntek Integrated Camera type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 174f:243f class-ID: 0e02
serial: <filter>
Device-5: 3-9:6 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 06cb:00be class-ID: ff00 serial: <filter>
Device-6: 3-10:7 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 48.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: 3016 pm: pacman pkgs: 2997 libs: 604 tools: pamac,yay pm: flatpak
pkgs: 7 pm: snap pkgs: 12
1: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
2: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
3: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
4: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
5: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
6: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
8: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 312
1: cpu: 14.7% command: chromium pid: 7988 mem: 677.9 MiB (4.2%)
2: cpu: 12.6% command: konsole pid: 9574 mem: 250.2 MiB (1.5%)
3: cpu: 5.1% command: zsh pid: 9593 mem: 10.9 MiB (0.0%)
4: cpu: 5.0% command: floorp pid: 5533 mem: 709.5 MiB (4.4%)
5: cpu: 3.5% command: chromium pid: 7906 mem: 232.9 MiB (1.4%)
Memory top: 5 of 312
1: mem: 709.5 MiB (4.4%) command: floorp pid: 5533 cpu: 5.0%
2: mem: 677.9 MiB (4.2%) command: chromium pid: 7988 cpu: 14.7%
3: mem: 489.7 MiB (3.1%) command: chromium pid: 7867 cpu: 2.0%
4: mem: 451.0 MiB (2.8%) command: plasmashell pid: 2218 cpu: 0.8%
5: mem: 315.6 MiB (1.9%) command: baloorunner pid: 3195 cpu: 0.0%
Processes: 312 Power: uptime: 32m states: freeze,mem,disk suspend: s2idle
image: 6.13 GiB services: org_kde_powerdevil,upowerd Init: systemd v: 260
Compilers: clang: 22.1.5 gcc: 16.1.1 Shell: Zsh v: 5.9 default: Bash
v: 5.3.9 running-in: konsole inxi: 3.3.40
