Hello,
Everytime I log in, the keyboard stop responding. But it works to type my password. I already searched other threads, but it doesn’t really help.
From what I’ve seen in the Xorg logs, it might be because it thinks my keyboard is a mouse. My mouse is indeed connected to the USB port of my keyboard, because I don’t have enough wire length, and in the past it wasn’t an issue:
[ 5.983] (II) event8 - ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vM: device is a pointer
I’m using 5.4 kernel, but the issue was the same with 5.10. Here is the log from Xorg:
[ 5.886] (II) config/udev: Adding input device ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vKB (/dev/input/event7)
[ 5.886] (**) ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vKB: Applying InputClass "evdev keyboard catchall"
[ 5.886] (**) ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vKB: Applying InputClass "libinput keyboard catchall"
[ 5.886] (**) ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vKB: Applying InputClass "system-keyboard"
[ 5.886] (II) Using input driver 'libinput' for 'ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vKB'
[ 5.886] (**) ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vKB: always reports core events
[ 5.886] (**) Option "Device" "/dev/input/event7"
[ 5.886] (**) Option "_source" "server/udev"
[ 5.886] (II) event7 - ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vKB: is tagged by udev as: Keyboard
[ 5.887] (II) event7 - ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vKB: device is a keyboard
[ 5.887] (II) event7 - ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vKB: device removed
[ 5.912] (**) Option "config_info" "udev:/sys/devices/virtual/input/input33/event7"
[ 5.912] (II) XINPUT: Adding extended input device "ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vKB" (type: KEYBOARD, id 13)
[ 5.912] (**) Option "xkb_model" "pc105"
[ 5.912] (**) Option "xkb_layout" "fr"
[ 5.915] (II) event7 - ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vKB: is tagged by udev as: Keyboard
[ 5.915] (II) event7 - ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vKB: device is a keyboard
[ 5.916] (II) config/udev: removing device ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vM
[ 5.916] (II) event8 - ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vM: device removed
[ 5.979] (II) UnloadModule: "libinput"
[ 5.979] (II) config/udev: Adding input device ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vM (/dev/input/event8)
[ 5.979] (**) ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vM: Applying InputClass "evdev pointer catchall"
[ 5.979] (**) ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vM: Applying InputClass "libinput pointer catchall"
[ 5.980] (II) Using input driver 'libinput' for 'ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vM'
[ 5.980] (**) ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vM: always reports core events
[ 5.980] (**) Option "Device" "/dev/input/event8"
[ 5.980] (**) Option "_source" "server/udev"
[ 5.982] (II) event8 - ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vM: is tagged by udev as: Mouse
[ 5.983] (II) event8 - ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vM: device removed
[ 6.045] (**) Option "config_info" "udev:/sys/devices/virtual/input/input34/event8"
[ 6.046] (II) XINPUT: Adding extended input device "ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vM" (type: MOUSE, id 14)
[ 6.046] (**) Option "AccelerationScheme" "none"
[ 6.046] (**) ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vM: (accel) selected scheme none/0
[ 6.046] (**) ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vM: (accel) acceleration factor: 2.000
[ 6.046] (**) ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vM: (accel) acceleration threshold: 4
[ 6.048] (II) event8 - ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vM: is tagged by udev as: Mouse
[ 6.049] (II) event8 - ckb3: Corsair Gaming K95 RGB PLATINUM Keyboard vM: device is a pointer
Thanks!
