I’d like to start by saying that I don’t think this is in any way related to Manjaro, i was just hoping that someone might have an idea of what might be going wrong because its driving me in sane!
So, as per the title, my laptop will just randomly miss out keystrokes while I am typing, it seems like the faster I type the worse it is. I have tried playing around with the keyboard delay settings but it does not seem to make any difference.
Here is my inix output. I’m happy to provide more details if required ![]()
Kernel: 5.11.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=65d5885c-1f8d-42d0-a615-04d160436b0f rw quiet apparmor=1
security=apparmor udev.log_priority=3 nouveau.modeset=0
Console: tty pts/2 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: Dell product: Inspiron 3793 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0C9WH2 v: A00 serial: <filter> UEFI: Dell v: 1.11.0
date: 08/17/2020
ID-1: BAT0 charge: 13.3 Wh (35.2%) condition: 37.8/42.0 Wh (90.1%)
volts: 11.1 min: 11.4 model: SWD-ATL3.618 DELL WJPC404 type: Li-ion
serial: <filter> status: Discharging
RAM: total: 7.55 GiB used: 3.11 GiB (41.2%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: DIMM A size: 8 GiB speed: 2667 MT/s type: DDR4 detail: synchronous
bus-width: 64 bits total: 64 bits manufacturer: SK Hynix
part-no: HMA81GS6DJR8N-VK serial: <filter>
Device-2: DIMM B size: No Module Installed
Info: Quad Core model: Intel Core i5-1035G1 bits: 64 type: MT MCP
arch: Ice Lake family: 6 model-id: 7E (126) stepping: 5 microcode: A0 cache:
L2: 6 MiB bogomips: 19048
Speed: 1302 MHz min/max: 400/3600 MHz base/boost: 2900/1200 volts: 1.0 V
ext-clock: 100 MHz Core speeds (MHz): 1: 1302 2: 1300 3: 1300 4: 1301
5: 1302 6: 1302 7: 1301 8: 1300
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2 avx512_vnni
avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi
avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp
rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1
tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel Iris Plus Graphics G1 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX230] vendor: Dell driver: nvidia
v: 460.67 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1d11
class-ID: 0302
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 0bda:5520 class-ID: 0e02 serial: <filter>
Display: server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: modesetting display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 128 size: 381x214mm (15.0x8.4")
diag: 437mm (17.2")
OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 21.0.3
direct render: Yes
Device-1: Intel Smart Sound Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:34c8
class-ID: 0403
Sound Server-1: ALSA v: k5.11.18-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 14.2 running: no
Sound Server-4: PipeWire v: 0.3.26 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8136
class-ID: 0200
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel port: 3000 bus-ID: 03:00.0
chip-ID: 168c:0042 class-ID: 0280
Local Storage: total: 1.03 TiB used: 49.3 GiB (4.7%)
model: PC SN520 NVMe WDC 128GB size: 119.24 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 rotation: SSD serial: <filter>
rev: 20220012 temp: 44.9 C scheme: GPT
SMART: yes health: PASSED on: 8d 13h cycles: 492
read-units: 4,559,128 [2.33 TB] written-units: 3,836,810 [1.96 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
family: Mobile HDD size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter>
rev: 0001 temp: 29 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 28d 10h cycles: 483
read: 212.69 GiB written: 273.7 GiB Old-Age: g-sense error rate: 123
Pre-Fail: attribute: Spin_Retry_Count value: 100 worst: 100 threshold: 97
Optical-1: /dev/sr0 vendor: PLDS model: DVD+-RW DU-8A5LH rev: 6D1M
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 118.95 GiB size: 116.52 GiB (97.96%)
used: 49.3 GiB (42.3%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2 label: N/A uuid: 65d5885c-1f8d-42d0-a615-04d160436b0f
used: 296 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: NO_LABEL uuid: F731-F39F
ID-1: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ext4 label: N/A
uuid: 1d698e65-bb46-46e3-b7a8-38fde5d717c9
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-3:2 info: MosArt 2.4G Keyboard Mouse type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 062a:5918 class-ID: 0301
Device-2: 1-6:3 info: Realtek Integrated_Webcam_HD type: Video
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 64.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3136
Processes: 235 Uptime: 1h 51m wakeups: 2 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 Packages: 1266 pacman: 1250 lib: 340
flatpak: 8 snap: 8 Shell: Bash (sudo) v: 5.1.4 running-in: konsole
inxi: 3.3.04
