Hello everyone,
I am running Manjaro Gnome on Ideapad IdeaPad 5 15ITL05, US keyboard.
As my hotkeys for settings, Brightness control and a few more are not functioning.
I tried xmodmap -pk
where there are assigned keys for brightness controls but those keycodes can not be found when I tried xve
The key event for Hotkeys does not show up for xve
How can I fix this? Please guide me through this.
Output for my xmodmap -pk
is :
232 0x1008ff03 (XF86MonBrightnessDown) 0x0000 (NoSymbol) 0x1008ff03 (XF86MonBrightnessDown)
233 0x1008ff02 (XF86MonBrightnessUp) 0x0000 (NoSymbol) 0x1008ff02 (XF86MonBrightnessUp)
My System Info is :
Kernel: 5.10.61-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=67c8fb25-f5c7-4db5-9154-2e1f04a7ab8c rw quiet splash apparmor=1
security=apparmor resume=UUID=7bc34073-1434-480d-b900-89ea33f1d837
udev.log_priority=3
Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Laptop System: LENOVO product: 82FG v: IdeaPad 5 15ITL05
serial: <filter> Chassis: type: 10 v: IdeaPad 5 15ITL05 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <filter> UEFI: LENOVO
v: FHCN41WW date: 05/17/2021
ID-1: BAT0 charge: 46.6 Wh (82.3%) condition: 56.6/57.0 Wh (99.4%)
volts: 13.0 min: 11.5 model: Celxpert L19C3PF5 type: Li-poly
serial: <filter> status: Charging cycles: 23
RAM: total: 15.42 GiB used: 6.63 GiB (43.0%)
Info: Quad Core model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 8C (140) stepping: 1 microcode: 88
cache: L2: 8 MiB bogomips: 38720
Speed: 606 MHz min/max: 400/2400 MHz Core speeds (MHz): 1: 606 2: 1014
3: 555 4: 858 5: 653 6: 988 7: 669 8: 940
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2 avx512_vnni
avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2 cdp_l2 clflush
clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl
dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma
fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp hwp_notify
hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single
lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good
sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo bus-ID: 3-5:3
chip-ID: 174f:2459 class-ID: fe01 serial: <filter>
Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: intel display-ID: 0 resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.2.1
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci alternate: snd_hda_intel,snd_sof_pci bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Sound Server-1: ALSA v: k5.10.61-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel port: 3000
bus-ID: 00:14.3 chip-ID: 8086:a0f0 class-ID: 0280
Device-2: Logitech Dell Wireless Mouse WM123 type: USB
driver: hid-generic,usbhid bus-ID: 3-1:2 chip-ID: 046d:c535 class-ID: 0300
bus-ID: 3-10:5 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 953.87 GiB used: 304.69 GiB (31.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS001TD9TNI-L2A0B
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 11010C10 temp: 34.9 C scheme: GPT
ID-1: / raw-size: 589.36 GiB size: 579.04 GiB (98.25%)
used: 195.58 GiB (33.8%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
label: N/A uuid: 67c8fb25-f5c7-4db5-9154-2e1f04a7ab8c
ID-2: /boot/efi raw-size: 500.9 MiB size: 499.9 MiB (99.80%)
used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
label: NO_LABEL uuid: 1424-B942
ID-3: /run/media/loserlord/New Volume raw-size: 244.14 GiB
size: 244.14 GiB (100.00%) used: 109.11 GiB (44.7%) fs: ntfs
dev: /dev/nvme0n1p4 maj-min: 259:4 label: New Volume uuid: 66DAA1ACDAA178C7
ID-1: swap-1 type: partition size: 15.62 GiB used: 512 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: 7bc34073-1434-480d-b900-89ea33f1d837
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: 2A72-BF77
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 103.65 GiB fs: ntfs label: N/A
uuid: 14E87364E87342D2
ID-4: /dev/nvme0n1p8 maj-min: 259:8 size: 508 MiB fs: ntfs label: N/A
uuid: 6E3292173291E3FD
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 3-1:2 info: Logitech Dell Wireless Mouse WM123 type: Mouse,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 98mA
Device-2: 3-5:3 info: Syntek Integrated Camera type: Video driver: uvcvideo
interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 174f:2459
Device-3: 3-7:4 info: Shenzhen Goodix Goodix FingerPrint Device
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 27c6:55a2 class-ID: ef00
Device-4: 3-10:5 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 37.0 C mobo: N/A
Processes: 310 Uptime: 2d 6h 30m wakeups: 19498 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: 1405 pacman: 1388 lib: 348
flatpak: 10 snap: 7 Shell: Zsh v: 5.8 running-in: gnome-terminal
inxi: 3.3.06
