Hello, i seem to be having a weird issue when playing any game that puts my system under load. Any buttons i press on the keyboard appear to be getting queued up faster than they can be processed, so if i press “w” for a while and then let go itll keep acting like im pressing it for a second or so, sometimes even more.
I really have no idea where to start with it, it sounds like it could be something to do with kwin or libinput according to others but havent had any luck finding out what to do.
Anyone know how i would start fixing this?
Kernel: 5.12.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=131e9ee0-8e8f-49c3-92f1-967416751be4 rw quiet apparmor=1
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Laptop System: IT Channel Pty product: P95_96_97Ex,Rx v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: IT Channel Pty model: P95_96_97Ex,Rx serial: <filter> UEFI: INSYDE
v: 1.07.01TMB date: 02/18/2019
ID-1: BAT0 charge: 56.8 Wh (100.0%) condition: 56.8/56.2 Wh (100.9%)
volts: 17.0 min: 15.2 model: Notebook BAT type: Li-ion serial: <filter>
status: Full
Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: EA cache: L2: 12 MiB
bogomips: 62431
Speed: 1212 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 1212 2: 800
3: 1005 4: 800 5: 800 6: 800 7: 862 8: 878 9: 3305 10: 4200 11: 957 12: 4140
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: CLEVO/KAPOK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: CLEVO/KAPOK
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f11 class-ID: 0300
Device-3: Acer BisonCam NB Pro type: USB driver: uvcvideo bus-ID: 1-8:8
chip-ID: 5986:9102 class-ID: 0e02
loaded: intel,nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2")
s-diag: 1052mm (41.4")
Monitor-1: eDP1 res: 1920x1080 dpi: 128 size: 380x210mm (15.0x8.3")
diag: 434mm (17.1")
Monitor-2: HDMI-1-0 res: 1920x1080 hz: 60 dpi: 305 size: 160x90mm (6.3x3.5")
diag: 184mm (7.2")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.2.1
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Sound Server-1: ALSA v: k5.12.19-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
port: 5000 bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
vendor: CLEVO/KAPOK driver: r8168 v: 8.049.02-NAPI modules: r8169 port: 3000
bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp8s0 state: down mac: <filter>
IF-ID-1: anbox0 state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: virbr0 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:10 chip-ID: 8087:0aaa class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
rfk-block: hardware: no software: no address: <filter>
Info: acl-mtu: 1021:4 sco-mtu: 96:6 link-policy: rswitch sniff
link-mode: slave accept
Local Storage: total: 2.84 TiB used: 1.16 TiB (40.9%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: N/A size: 62.5 GiB block-size:
physical: 512 B logical: 512 B type: SSD serial: <filter> scheme: MBR
SMART Message: Unknown smartctl error. Unable to generate data.
ID-2: /dev/sda maj-min: 8:0 vendor: TeamGroup model: TM8PS7001T
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 9A0 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000LX001-1RG174
type: HDD rpm: 5400 serial: <filter> rev: SDM1 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Samsung
model: Flash Drive DUO size: 29.88 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> rev: 1100 scheme: MBR
ID-1: / raw-size: 242.79 GiB size: 237.98 GiB (98.02%)
used: 113.98 GiB (47.9%) fs: ext4 dev: /dev/sda7 maj-min: 8:7
ID-2: /boot/efi raw-size: 99 MiB size: 95 MiB (95.96%)
used: 30.7 MiB (32.3%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: partition size: 9.54 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda5 maj-min: 8:5
System Temperatures: cpu: 58.0 C mobo: N/A
Processes: 367 Uptime: 34m wakeups: 1 Memory: 15.35 GiB
used: 4.49 GiB (29.2%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 alt: 10/9 clang: 12.0.1 Packages: 1820 pacman: 1811 lib: 521
flatpak: 0 snap: 9 Shell: Zsh v: 5.8 running-in: yakuake inxi: 3.3.06
