Hello,
I’m using the keyboard from Cooler Master Brand, Model CMStorm, witch has a blue led back-light. After installation Manjaro almost everything was working fine except accentuation, but is was fixed as with the command:
$ setxkbmap -model abnt2 -layout br -variant abnt2
Current Keyboard Settings
Keyboard Model: Generic | Generic 105-key PC - Default Keyboard Model
Portuguese Brazil - Portuguese (Brazil, no dead keys)
At windows the LED can be turned on/off through Scroll Lock key but unfortunately at Linux it doesn’t work so I did my home work and found the function to turn it on/off on linux so I found the command “xset led” and it worked. Follow, to next step was to make it work from user logon and I was able to create a simple script to make it work too.
The issue:
When the back-light LED is ON my numbers pad stop working, regardless if Num Lock is “on” or “off” and to make it work again I need to turn the back-light LED off.
I expect both being able to work together. Is there a way to fix this issue?
Kernel: 5.10.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=c2987d0a-3ccc-4056-bdcb-22de9c2fbb5f ro quiet apparmor=1
security=apparmor resume=UUID=87d4ac5e-e22c-413e-806a-74ff152a793e
udev.log_priority=3
Desktop: KDE Plasma 5.21.2 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop Mobo: Gigabyte model: GA-870A-UD3 v: x.x serial: <filter>
BIOS: Award v: F5 date: 08/01/2011
RAM: total: 7.77 GiB used: 1.78 GiB (23.0%)
Info: Quad Core model: AMD Phenom II X4 965 bits: 64 type: MCP arch: K10
family: 10 (16) model-id: 4 stepping: 3 microcode: 10000C8 L2 cache: 2 MiB
bogomips: 27336
Speed: 800 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800
Flags: 3dnow 3dnowext 3dnowprefetch abm apic clflush cmov cmp_legacy
constant_tsc cpuid cr8_legacy cx16 cx8 de extapic extd_apicid fpu fxsr
fxsr_opt ht hw_pstate ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext
monitor msr mtrr nonstop_tsc nopl npt nrip_save nx osvw pae pat pdpe1gb pge
pni popcnt pse pse36 rdtscp rep_good sep skinit sse sse2 sse4a svm svm_lock
syscall tsc vme vmmcall wdt
Type: spec_store_bypass status: Not affected
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Micro-Star MSI driver: amdgpu v: kernel bus ID: 01:00.0
chip ID: 1002:67df class ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: DVI-D-0 res: 1920x1080 hz: 60 dpi: 96
size: 510x290mm (20.1x11.4") diag: 587mm (23.1")
OpenGL: renderer: Radeon RX 570 Series (POLARIS10 DRM 3.40.0
5.10.19-1-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 20.3.4 direct render: Yes
Device-1: AMD SBx00 Azalia vendor: Gigabyte GA-880GMA-USB3
driver: snd_hda_intel v: kernel bus ID: 00:14.2 chip ID: 1002:4383
class ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 1002:aaf0 class ID: 0403
Sound Server: ALSA v: k5.10.19-1-MANJARO
vendor: Gigabyte driver: r8169 v: kernel port: 9e00 bus ID: 06:00.0
chip ID: 10ec:8168 class ID: 0200
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros TP-Link TL-WN821N v2 / TL-WN822N v1 802.11n
[Atheros AR9170]
type: USB driver: carl9170 bus ID: 2-4:2 chip ID: 0cf3:1002 class ID: ff00
serial: <filter>
IF: wlp0s19f2u4 state: down mac: <filter>
Message: No Bluetooth data was found.
Local Storage: total: 2.48 TiB used: 1.83 TiB (73.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 240GB
size: 223.58 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 00RL scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Corsair model: Corsair Force GS
size: 119.24 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 5.07 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Patriot model: Burst size: 223.57 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD
serial: <filter> rev: KB.3 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Crucial model: CT120BX100SSD1
size: 111.79 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: MU01 scheme: GPT
ID-5: /dev/sde maj-min: 8:64 vendor: Western Digital model: WD20PURZ-85GU6Y0
size: 1.82 TiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 0A80 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH22NS50 rev: TN02
dev-links: cdrom
ID-1: / raw size: 214.77 GiB size: 210.4 GiB (97.96%)
used: 28.47 GiB (13.5%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33
label: LINUX-SSD uuid: c2987d0a-3ccc-4056-bdcb-22de9c2fbb5f
ID-2: /home/<filter>/Games raw size: 111.79 GiB size: 109.53 GiB (97.98%)
used: 57.93 GiB (52.9%) fs: ext4 dev: /dev/sdd1 maj-min: 8:49
label: LINUX-GAMES uuid: 49fbfc03-2923-49f0-a550-312f1f31aae3
ID-3: /home/<filter>/HDD-DATA-NTFS raw size: 1.82 TiB
size: 1.82 TiB (100.00%) used: 1.74 TiB (95.8%) fs: ntfs dev: /dev/sde1
maj-min: 8:65 label: DATA_2T uuid: 28A6726FA6723CFE
dev: /dev/sdc2 maj-min: 8:34 label: N/A
uuid: 87d4ac5e-e22c-413e-806a-74ff152a793e
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: ntfs label: System Reserved
uuid: E680DA2C5F90FD24
ID-2: /dev/sda2 maj-min: 8:2 size: 223.48 GiB fs: ntfs label: WIN-SSD
uuid: 07492E03A516286B
ID-3: /dev/sdb1 maj-min: 8:17 size: 119.24 GiB fs: ntfs label: WIN-GAMES
uuid: EAE6EE7DE6EE4A01
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 5 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 5 rev: 2.0
Device-1: 2-4:2 info: Qualcomm Atheros TP-Link TL-WN821N v2 / TL-WN822N v1
802.11n [Atheros AR9170]
type: Network driver: carl9170 interfaces: 1 rev: 2.0 speed: 480 Mb/s
chip ID: 0cf3:1002 class ID: ff00 serial: <filter>
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 5 rev: 1.1 speed: 12 Mb/s
chip ID: 1d6b:0001 class ID: 0900
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 5 rev: 1.1 speed: 12 Mb/s
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-7: 7-0:1 info: Full speed (or root) Hub ports: 4 rev: 1.1 speed: 12 Mb/s
Device-1: 7-3:2 info: SINO WEALTH USB KEYBOARD type: Keyboard,HID
chip ID: 258a:0001 class ID: 0300
Device-2: 7-4:3 info: Pixart Imaging Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
chip ID: 093a:2521 class ID: 0301
Hub-8: 8-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-9: 9-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003 class ID: 0900
System Temperatures: cpu: 37.8 C mobo: N/A gpu: amdgpu temp: 42.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 924
Processes: 230 Uptime: 40m wakeups: 0 Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: 1352 pacman: 1345 lib: 424 flatpak: 7 Shell: Bash
v: 5.1.0 running in: yakuake inxi: 3.3.01
