Hi,
the keyboard input sometimes does not get registered by the OS. The keyboard input randomly stops working, even though the mouse and touchpad are still working. After a while (couple of minutes) it usually resolves. If not, I need to restart the computer. I tried plugging in an external keyboard when this occurs, but that does not work either.
This issue started when I reinstalled my system with hard drive encryption (LUKS). Before the reinstall I never noticed this problem.
The interesting thing is, that when I press the caps lock key, the indicator light of the caps lock key starts lighting, which tells me that this is not a hardware issue. I can toggle the caps lock without a problem, but none of the other keys seem to get registered by the OS.
Also, if I open up a terminal with my mouse, then the cursor block is not solid, but just has an outline, the same way when the terminal window is not focued. What I mean by this is that when everything is OK and the keyboard works and I open up a new terminal the terminal has this type of cursor: █ (block that is filled)
But when I open up a terminal in this “halted” state, when the keyboard is not responding it is like this (just like as it would be when a terminal is open but it is not the focused window): ▯ (block that is not filled)
Also, this issue occured more often after starting the system, but after I removed psensor from application autostart, it almost never occured anymore on startup.
I don’t know what could be the cause of this, but I suspect that some process could “halt” all keyboard input for some time. Any help is appreciated.
Here is the output of inxi -Fazy:
Kernel: 5.10.70-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=61a927f8-0135-4924-91d0-bb2ed9d0b728 rw quiet
cryptdevice=UUID=683ef627-fbd6-42b9-83f8-483f6126a588:luks-683ef627-fbd6-42b9-83f8-483f6126a588
root=/dev/mapper/luks-683ef627-fbd6-42b9-83f8-483f6126a588 apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Laptop System: Dell product: Inspiron 15 5501 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0C3R3K v: A00 serial: <filter> UEFI: Dell v: 1.3.0
date: 05/20/2020
ID-1: BAT0 charge: 53.0 Wh (100.0%) condition: 53.0/53.0 Wh (100.0%)
volts: 16.8 min: 15.0 model: SMP DELL 9077G06 type: Li-poly serial: <filter>
status: Full
Info: Quad Core model: Intel Core i5-1035G1 bits: 64 type: MT MCP
arch: Ice Lake family: 6 model-id: 7E (126) stepping: 5 microcode: A6 cache:
L2: 6 MiB
bogomips: 19048
Speed: 1276 MHz min/max: 400/3600 MHz Core speeds (MHz): 1: 1276 2: 1302
3: 1300 4: 1302 5: 1300 6: 1274 7: 1300 8: 1251
Device-1: Intel Iris Plus Graphics G1 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-6:3 chip-ID: 0bda:5538 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 21.2.3
direct render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_sof_pci bus-ID: 00:1f.3
chip-ID: 8086:34c8 class-ID: 0403
Sound Server-1: ALSA v: k5.10.70-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 3-10:4 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 339.73 GiB (71.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: BC511 NVMe 512GB
lanes: 4 type: SSD serial: <filter> rev: 11001101 temp: 35.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 339.7 GiB (72.6%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-683ef627-fbd6-42b9-83f8-483f6126a588
used: 448 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 52.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2671
Processes: 315 Uptime: 9h 8m wakeups: 10814 Memory: 15.41 GiB
used: 7.09 GiB (46.0%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1701 lib: 431 flatpak: 0 Shell: Bash v: 5.1.8
running-in: xfce4-terminal inxi: 3.3.08
