I got a Fujitsu Q555. A Atom Tablet-PC with a snap-on keyboard+trackpad dock. Runs dual-boot W10 and Manjaro.
I have run into this odd behaviour in Manjaro where when the system returns from sleep. The trackpad component of the KB+M device works a-ok, but the keyboard ceases to respond untill either i disconnect and reconnect the dock OR if i restart the system from Hibernation/Power-Off. Only when the system resumes from sleep.
This behaviour does not occur in W10 (kb works after sleep ends) nor with keyboards connected to the other USB-ports. Using inxi before/after resuming from sleep shows no difference. detecting the snap-on dock as Fujitsu Keyboard,Mouse USB device.
I’ve added the Inxi log below:
Kernel: 5.15.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=ebc5b48b-bc55-4c83-9726-53be5836209a rw quiet
resume=UUID=e692eac7-c206-4a70-94c1-dc2933ee0020 udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: FUJITSU product: STYLISTIC Q555 v: 10601582025
serial: <superuser required> Chassis: type: 10 v: STYLISTIC Q555
Mobo: FUJITSU model: FJNBC07 v: B1 serial: <superuser required>
UEFI: FUJITSU // Insyde v: Version 2.15 date: 10/06/2015
ID-1: BATC charge: 36.0 Wh (100.0%) condition: 36.0/36.5 Wh (98.7%)
volts: 4.3 min: 3.8 model: FUJITSU CP650624-01 type: Li-ion serial: <filter>
status: full cycles: 15
RAM: total: 3.72 GiB used: 1.29 GiB (34.7%)
RAM Report:
Info: model: Intel Atom Z3795 bits: 64 type: MCP arch: Silvermont
built: 2013-15 process: Intel 22nm family: 6 model-id: 0x37 (55) stepping: 8
microcode: 0x838
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB
desc: d-4x24 KiB; i-4x32 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 636 high: 843 min/max: 533/2399 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 843 2: 638 3: 533 4: 533
bogomips: 12805
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_perfmon bts
clflush cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
erms est flexpriority fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe
pclmulqdq pdcm pebs pge pni popcnt pse pse36 pti rdrand rdtscp rep_good
sep smep ss sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer tsc_known_freq tsc_reliable vme vmx vnmi
vpid xtopology xtpr
Type: spec_store_bypass status: Not affected
STIBP: disabled, RSB filling
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
vendor: Fujitsu driver: i915 v: kernel ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:0f31 class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 507x316mm (19.96x12.44")
s-diag: 597mm (23.52")
Monitor-1: eDP-1 model: Panasonic 0x4100 built: 2014 res: 1920x1200 hz: 60
dpi: 226 gamma: 1.2 size: 216x135mm (8.5x5.31") diag: 247mm (9.7")
ratio: 16:10 modes: 1920x1200
OpenGL: renderer: Mesa Intel HD Graphics (BYT) v: 4.2 Mesa 22.1.1
direct render: Yes
Message: No device data found.
Sound Server-1: ALSA v: k5.15.48-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.0 running: no
Sound Server-4: PipeWire v: 0.3.52 running: no
Message: No PCI device data found.
IF-ID-1: wlan0 state: down mac: <filter>
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
Local Storage: total: 116.48 GiB used: 31.03 GiB (26.6%)
ID-1: /dev/mmcblk1 maj-min: 179:24 model: SDU1 size: 58.24 GiB block-size:
physical: 512 B logical: 512 B type: SSD serial: <filter> scheme: MBR
SMART Message: Unknown smartctl error. Unable to generate data.
ID-2: /dev/mmcblk2 maj-min: 179:0 vendor: Samsung model: CGND3R
size: 58.24 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 0x7 scheme: GPT
ID-1: / raw-size: 12.41 GiB size: 12.11 GiB (97.61%) used: 10.67 GiB (88.1%)
fs: ext4 dev: /dev/mmcblk2p5 maj-min: 179:5 label: Manjaro
uuid: ebc5b48b-bc55-4c83-9726-53be5836209a
used: 292 KiB (0.1%) fs: vfat dev: /dev/mmcblk2p6 maj-min: 179:6 label: GRUB
uuid: 0F37-DE57
ID-3: /run/media/foxhood/9C33-6BBD raw-size: 58.22 GiB
size: 58.22 GiB (100.00%) used: 257.5 MiB (0.4%) fs: exfat
dev: /dev/mmcblk1p1 maj-min: 179:25 label: N/A uuid: 9C33-6BBD
ID-4: /run/media/foxhood/FADEF546DEF4FBA7 raw-size: 42.41 GiB
size: 42.41 GiB (100.00%) used: 19.52 GiB (46.0%) fs: ntfs
dev: /dev/mmcblk2p4 maj-min: 179:4 label: N/A uuid: FADEF546DEF4FBA7
ID-1: swap-1 type: partition size: 2.3 GiB used: 607.6 MiB (25.8%)
priority: -2 dev: /dev/mmcblk2p7 maj-min: 179:7 label: LSwap
uuid: e692eac7-c206-4a70-94c1-dc2933ee0020
ID-1: /dev/mmcblk2p1 maj-min: 179:1 size: 529 MiB fs: ntfs label: Herstel
uuid: C234E84C34E8454F
ID-2: /dev/mmcblk2p2 maj-min: 179:2 size: 100 MiB fs: vfat label: N/A
uuid: 34EC-B873
ID-3: /dev/mmcblk2p3 maj-min: 179:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 1-1:26 info: Fujitsu type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 04c5:148a class-ID: 0301
Hub-2: 1-4:3 info: Cypress Unprogrammed CY7C65632/34 hub HX2VL ports: 4
rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: 04b4:6570 class-ID: 0900
Hub-3: 2-0:1 info: Super-speed hub ports: 1 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 41.0 C mobo: N/A
Processes: 269 Uptime: 18h 15m wakeups: 139 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1
Packages: pacman: 1115 lib: 326 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.19
If any more specific logs are needed. Let me know, kinda new to the arch/manjaro world migrating from W10/Ubuntu.
