Keyboard backlight not working after suspend
When the laptop goes to sleep, the keyboard backlight turns off and does not turn on. Before the update to the new kernel (it was 6.1.41-1), the keyboard and touchpad did not work at all.
Additional detail:
❯ systemctl suspend
❯ journalctl --system --boot=0 --priority=3 | tail --lines=50
авг 09 15:36:49 n1ret-laptop kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.MHBR], AE_NOT_FOUND (20230331/psargs-330)
авг 09 15:36:49 n1ret-laptop kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PTID.PBAR], AE_NOT_FOUND (20230331/dsfield-500)
авг 09 15:36:50 n1ret-laptop kernel:
авг 09 15:36:50 n1ret-laptop kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
авг 09 15:36:51 n1ret-laptop kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
авг 09 15:36:51 n1ret-laptop bluetoothd[584]: src/adapter.c:reset_adv_monitors_complete() Failed to reset Adv Monitors: Failed (0x03)
авг 09 15:36:51 n1ret-laptop bluetoothd[584]: Failed to clear UUIDs: Failed (0x03)
авг 09 15:36:51 n1ret-laptop bluetoothd[584]: Failed to add UUID: Failed (0x03)
авг 09 15:36:51 n1ret-laptop bluetoothd[584]: Failed to set mode: Failed (0x03)
авг 09 15:36:51 n1ret-laptop kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
авг 09 15:36:52 n1ret-laptop kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
авг 09 15:36:59 n1ret-laptop gdm-password][1396]: gkr-pam: unable to locate daemon control file
авг 09 15:37:01 n1ret-laptop bluetoothd[584]: Failed to add UUID: Failed (0x03)
авг 09 15:38:46 n1ret-laptop kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
авг 09 15:55:09 n1ret-laptop bluetoothd[584]: Failed to add UUID: Failed (0x03)
авг 09 16:15:08 n1ret-laptop kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
авг 09 16:15:08 n1ret-laptop gdm[637]: GLib: Source ID 84 was not found when attempting to remove it
❯ lsusb -tv
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 10000M
    ID 1d6b:0003 Linux Foundation 3.0 root hub
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/12p, 480M
    ID 1d6b:0002 Linux Foundation 2.0 root hub
    |__ Port 8: Dev 2, If 0, Class=Video, Driver=uvcvideo, 480M
        ID 5986:9102 Bison Electronics Inc.
    |__ Port 8: Dev 2, If 1, Class=Video, Driver=uvcvideo, 480M
    |__ Port 10: Dev 3, If 0, Class=Wireless, Driver=btusb, 12M
        ID 8087:0033 Intel Corp.
    |__ Port 10: Dev 3, If 1, Class=Wireless, Driver=btusb, 12M
❯ sudo dmesg | grep usb
[    0.405317] usbcore: registered new interface driver usbfs
[    0.405317] usbcore: registered new interface driver hub
[    0.405317] usbcore: registered new device driver usb
[    0.506836] usbcore: registered new interface driver usbserial_generic
[    0.506839] usbserial: USB Serial support registered for generic
[    1.036363] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.04
[    1.036369] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.036372] usb usb1: Product: xHCI Host Controller
[    1.036375] usb usb1: Manufacturer: Linux 6.4.6-1-MANJARO xhci-hcd
[    1.036377] usb usb1: SerialNumber: 0000:00:14.0
[    1.040052] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.04
[    1.040057] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.040059] usb usb2: Product: xHCI Host Controller
[    1.040061] usb usb2: Manufacturer: Linux 6.4.6-1-MANJARO xhci-hcd
[    1.040062] usb usb2: SerialNumber: 0000:00:14.0
[    1.287352] usb 1-8: new high-speed USB device number 2 using xhci_hcd
[    1.444554] usb 1-8: New USB device found, idVendor=5986, idProduct=9102, bcdDevice= 6.01
[    1.444564] usb 1-8: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[    1.444567] usb 1-8: Product: BisonCam,NB Pro
[    1.444569] usb 1-8: Manufacturer: Sonix Technology Co., Ltd.
[    1.567544] usb 1-10: new full-speed USB device number 3 using xhci_hcd
[    1.708787] usb 1-10: New USB device found, idVendor=8087, idProduct=0033, bcdDevice= 0.00
[    1.708794] usb 1-10: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.220795] usbcore: registered new interface driver btusb
[    4.021612] usb 1-8: Found UVC 1.00 device BisonCam,NB Pro (5986:9102)
[    4.028538] usbcore: registered new interface driver uvcvideo
[  103.506745] usb 1-8: reset high-speed USB device number 2 using xhci_hcd
[ 2274.632524] usb 1-8: reset high-speed USB device number 2 using xhci_hcd
❯ inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 6.4.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.4-x86_64
    root=UUID=1ba39c39-8aa0-4006-863c-eac891e92e3e rw atkbd.reset i8042.nomux
    quiet splash apparmor=1 security=apparmor udev.log_priority=3
  Desktop: GNOME v: 44.3 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
  Type: Laptop System: ARDOR GAMING product: V15x_V17xPNKPNJPNH v: N/A
    serial: N/A Chassis: type: 10 serial: N/A
  Mobo: ARDOR GAMING model: V15x_V17xPNKPNJPNH serial: N/A UEFI: INSYDE
    v: 1.07.16TDC date: 11/04/2022
  ID-1: BAT0 charge: 10.9 Wh (20.6%) condition: 52.8/51.5 Wh (102.4%)
    volts: 14.6 min: 15.2 model: Notebook BAT type: Li-ion serial: <filter>
    status: discharging
  System RAM: total: 16 GiB available: 15.33 GiB used: 3.27 GiB (21.3%)
    igpu: 64 MiB
  Device-1: Controller0-ChannelA-DIMM0 type: DDR4 detail: synchronous
    size: 8 GiB speed: 3200 MT/s volts: curr: 1.2 width (bits): data: 64
    total: 64 manufacturer: Samsung part-no: M471A1K43EB1-CWE serial: <filter>
  Device-2: Controller1-ChannelA-DIMM0 type: DDR4 detail: synchronous
  Info: model: 12th Gen Intel Core i5-12500H socket: U3E1 bits: 64
    type: MST AMCP arch: Alder Lake gen: core 12 level: v3 note: check
    built: 2021+ process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154)
    stepping: 3 microcode: 0x42A
  Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
    cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB L2: 9 MiB
    desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
  Speed (MHz): avg: 2815 high: 3100 min/max: 400/4500:3300
    base/boost: 2079/4500 scaling: driver: intel_pstate governor: powersave
    volts: 0.9 V ext-clock: 100 MHz cores: 1: 639 2: 3100 3: 3100 4: 3100
    5: 3100 6: 3100 7: 3100 8: 3100 9: 3100 10: 3100 11: 3100 12: 3100 13: 3100
    14: 1014 15: 3100 16: 3100 bogomips: 99568
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb pebs
    pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good
    sdbg sep serialize sha_ni smap smep smx split_lock_detect ss ssbd sse sse2
    tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
    waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
    RSB filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel Alder Lake-P Integrated Graphics vendor: CLEVO/KAPOK
    driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
    ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1, HDMI-A-2
    bus-ID: 00:02.0 chip-ID: 8086:46a6 class-ID: 0300
  Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: CLEVO/KAPOK
    driver: nvidia v: 535.86.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-07) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 2 speed: 5 GT/s lanes: 8
    link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:25a2 class-ID: 0302
  Device-3: Bison BisonCam NB Pro driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:2 chip-ID: 5986:9102
    class-ID: 0e02
  Display: server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
    compositor: gnome-shell driver: X: loaded: modesetting,nvidia
    alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :1
    screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 model: BOE Display 0x0910 built: 2020 res: 1920x1080
    hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.0.4 renderer: Mesa Intel Graphics (ADL GT2)
    direct-render: Yes
  Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: CLEVO/KAPOK
    driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
    bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
  API: ALSA v: k6.4.6-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.75 status: n/a (root, process) tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: active (root, process)
    with: pulseaudio-alsa type: plugin tools: pacat,pactl
  Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
    vendor: CLEVO/KAPOK driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
  IF-ID-1: docker0 state: down mac: <filter>
  Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-10:3 chip-ID: 8087:0033 class-ID: e001
  Local Storage: total: 476.94 GiB used: 14.93 GiB (3.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVL2512HCJQ-00B00
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: GXA7601Q temp: 40.9 C
    scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 14.93 GiB (3.2%)
    fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 1ba39c39-8aa0-4006-863c-eac891e92e3e
    used: 288 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: N/A uuid: 3A2C-DE2A
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-8:2 info: Bison BisonCam NB Pro type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 5986:9102 class-ID: 0e02
  Device-2: 1-10:3 info: Intel type: bluetooth driver: btusb interfaces: 2
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
  System Temperatures: cpu: 40.0 C mobo: N/A
  Processes: 343 Uptime: 44m wakeups: 3 Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 1183 libs: 326 tools: gnome-software,pamac Shell: Zsh (sudo) v: 5.9
  default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.28
❯ sudo update-grub
Found linux image: /boot/vmlinuz-6.4-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.4-x86_64.img
Found initrd fallback image: /boot/initramfs-6.4-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
Problem have been solved. I did install clevo drivers.
