After the 2023-05-07 stable update, on Pulse 14, Manjaro KDE, the keyboard backlight does not start automatically.The laptop will turn on and the backlight will be OFF (even with the last state left at ON). Using Fn+Space returns backlight set to 0% (OFF), which means nothing happens since the backlight was already OFF. I can then Fn+Space again to turn it ON to whatever setting in my TCC settings. The backlight works coming from sleep.
On Githhub, I was asked to show the output of dkms status which is
Error! Could not locate dkms.conf file.
File: /var/lib/dkms/tuxedo-keyboard/3.0.8/source/dkms.conf does not exist.
Users there were surprised with this output and said the following
Seems like something broke on the package level on your system and tuxedo-keyboard did not get build at all. tuxedo-keyboard 3.2.3 should just build fine for linux 6.3.
They also recommended to come here since the output of dmks status should be different.
FYI TCC is at 2.0.4, tuxedo-keyboard-dkms 3.2.3 (Manjaro Official repositories - community), and kernel 6.3.0
