The backlight for my laptop keyboard isn’t working.
Any idea how I can make sure it’s not hardware related? One hint is it used to work in the past But just stopped wokring at some point - hard to tell when bcs keyboard lighting isn’t needed all the time. The same happened with the super key, and that was a software issue, super key (to call start menu) just seems prone to being broken by updates (see several forum posts).
It normally has 5 brightness settings (including off) toggled with Fn+F4. Is it possible that an update also borked this key binding?
You have tuxedo-keyboard installed I presume? It’s available from the repositories.
I did not have it installed - didn’t know about it!
Installed it just now, but the backlight is still not working
if you’re fluent in german read this first at the tuxedo-page. you can install the driver from gitlab as described. there is a howto install at the gitlab-page.
https://www.tuxedocomputers.com/de/Infos/Hilfe-Support/Anleitungen/Tastatur-Treiber-fuer-TUXEDO-Computers-Modelle-mit-RGB-Tastatur-nachinstallieren.tuxedo
it’s also possible that you installed it because it was in the repos.in this case try the modprobe commands as described at the gitlab-page
I do speak German. You mean Github, yes? Why follow these instructions that are for other distros, when I can install it from the official Manjaro repo (which I did)?
The modprobe command fails:
[ben@paul-mnj ~]$ sudo modprobe tuxedo_keyboard
modprobe: FATAL: Module tuxedo_keyboard not found in directory /lib/modules/5.13.19-2-MANJARO
I don’t know if this says anything about my problem:
[ben@paul-mnj ~]$ cat /etc/modprobe.d/tuxedo_keyboard.conf
options tuxedo-keyboard mode=0 brightness=75 color_left=0xFFFFFF color_center=0xFFFFFF color_right=0xFFFFFF
tuxedo sagts doch auf seiner homepage selbst, wenn du manjaro nutzen willst nutze das von ihnen verlinkte github-repository und das gilt auch für das controlcenter tccd das du besser vorher installierst, das scheint grundlage zu sein.
Also auf der Seite, die du verlinkt hast, steht folgendes:
Manjaro-Anwender werden im offiziellem Manjaro-Repo fündig.
Die Controlcenter-App habe ich auch aus dem Repo installiert, zusammen mit dem Keyboard-Treiber.
Meine Tastatur ist allerdings auch keine RGB-Tastatur, das Licht ist einfärbig. Weiß nicht, ob das einen unterschied für den Treiber macht…
Wo genau steht das? Ich sollte also den Keyboard-Treiber ausm Repo wieder deinstallieren und von Github neu installieren?
da steht "Weitere Modi und technische Details finden Sie hier: GitHub - tuxedocomputers/tuxedo-keyboard: Kernel module for keyboard backlighting on TUXEDO Computers
ich habe dir die beiden links gegeben. den universellen treiber von tuxedo haben sie auf github hinterlegt und selbst den link habe ich dir gegeben.
gute nacht und schönes we
Es war ein Hardwareproblem. Ich habe den Laptop aufgemacht, und das Kabel für die Tastaturbeleuchtung hatte keinen Kontakt zum Motherboard, weil das hauchdünne Plastikplättchen von dem Verbindungsclip, das das Kabel festhält, abgebrochen ist.
