Hello,
does anyone know how to disable the keyboard backlight from fading continuously on/off? I don’t see the option in the System Settings and I haven’t been able to find a command for that.
These are my settings:
KDE Plasma Version: 5.27.4
KDE Frameworks Version: 5.104.0
Qt Version: 5.15.8
Kernel Version: 6.1.25-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 12 × 12th Gen Intel® Core™ i5-12450H
Memory: 15.3 GiB of RAM
Graphics Processor: Mesa Intel® Graphics
Manufacturer: ASUSTeK COMPUTER INC.
Product Name: ASUS TUF Dash F15 FX517ZE_FX517ZE
System Version: 1.0
Hi @bejuco ,
We needz moar infos! Please help us help you and provide the output of:
Edit:
Considering:
I recommend having a look here:
https://wiki.archlinux.org/title/Asusctl
Which is in the AUR, so can be installed with:
pamac build asusctl
More info:
https://asus-linux.org/
This may help:
https://wiki.archlinux.org/title/Keyboard_backlight
If the backlight behavior is more akin to customization effects, you may need a dedicated tool such as openrgb (if supported).
Open source RGB lighting control that doesn't depend on manufacturer software. For Windows, Linux, MacOS. Supports a wide variety of RGB components, peripherals, accessories, and lights...
linub
26 April 2023 09:33
4
how did you get the keyboard backlight to work in the first place?
i also have an asus tuf laptop.
Looks like AURA-support (BIOS) - my ASUS B550 can do - I donot like…
Hi @Mirdarthos , thanks you for all the info.
I was looking to the asusctl package but I’m getting some build errors, seems like its necessary to install supergfxctl
and for that I need to remove any distro provided methods of graphics switching (like prime) .
This is the inxi print:
Kernel: 6.1.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=f67db6a4-f0e2-45a3-a794-ba5e4c535873 rw ibt=off quiet
udev.log_priority=3 ibt=off
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: ASUS TUF Dash F15 FX517ZE_FX517ZE
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: FX517ZE v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: FX517ZE.316 date: 12/09/2022
ID-1: BAT1 charge: 70.0 Wh (100.0%) condition: 70.0/75.8 Wh (92.2%)
volts: 17.4 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
status: full
Device-1: wacom_battery_0 model: Wacom Intuos BT M serial: N/A charge: 100%
status: discharging
RAM: total: 15.25 GiB used: 2.36 GiB (15.4%)
Info: model: 12th Gen Intel Core i5-12450H bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x429
Topology: cpus: 1x cores: 8 mt: 4 tpc: 2 st: 4 threads: 12 smt: enabled
cache: L1: 704 KiB desc: d-4x32 KiB, 4x48 KiB; i-4x32 KiB, 4x64 KiB L2: 7 MiB
desc: 4x1.2 MiB, 1x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2179 high: 2500 min/max: 400/4400:3300 scaling:
driver: intel_pstate governor: powersave cores: 1: 691 2: 2500 3: 2500
4: 2500 5: 2500 6: 2500 7: 460 8: 2500 9: 2500 10: 2500 11: 2500 12: 2500
bogomips: 59916
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe
movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes
vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt
xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Alder Lake-P GT1 [UHD Graphics] vendor: ASUSTeK driver: i915
v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: eDP-1 empty: DP-1,DP-2 bus-ID: 0000:00:02.0 chip-ID: 8086:46a3
class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile] vendor: ASUSTeK
driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-03) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 bus-ID: 0000:01:00.0
chip-ID: 10de:25a0 class-ID: 0300
Device-3: Sonix USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-7:3 chip-ID: 322e:202c class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x153c built: 2021 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel Graphics (ADL GT2)
direct-render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 3-9:4
alternate: snd_sof_pci_intel_tgl chip-ID: 0b05:6206 class-ID: 0300
bus-ID: 0000:00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 0000:01:00.1 chip-ID: 10de:2291 class-ID: 0403
Device-3: ASUSTek C-Media Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid
API: ALSA v: k6.1.25-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.70 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-2: Intel Ethernet I219-LM vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 0000:00:1f.6 chip-ID: 8086:1a1e class-ID: 0200
IF: eno2 state: down mac: <filter>
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:5
chip-ID: 8087:0026 class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 1.38 TiB used: 38.38 GiB (2.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU512GZ
lanes: 4 type: SSD serial: <filter> rev: 002C temp: 28.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:8 vendor: Western Digital
model: WD BLACK SN750 SE 1TB size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 711250WD temp: 33.9 C scheme: GPT
ID-1: / raw-size: 226.56 GiB size: 221.95 GiB (97.96%)
used: 38.35 GiB (17.3%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: f67db6a4-f0e2-45a3-a794-ba5e4c535873
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 29.7 MiB (11.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM uuid: F6F2-D75A
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 226.57 GiB fs: ntfs
label: Windows uuid: FA0EF4C90EF48045
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 723 MiB fs: ntfs label: N/A
uuid: CC9A38E99A38D1A6
ID-4: /dev/nvme0n1p6 maj-min: 259:6 size: 22 GiB fs: ntfs label: RESTORE
uuid: 5870AAD970AABD5E
ID-5: /dev/nvme0n1p7 maj-min: 259:7 size: 200 MiB fs: vfat label: MYASUS
uuid: 98AB-216B
ID-6: /dev/nvme1n1p1 maj-min: 259:9 size: 16 MiB fs: <superuser required>
ID-7: /dev/nvme1n1p2 maj-min: 259:10 size: 931.5 GiB fs: ntfs
label: Archivos uuid: 3EFE4A1BFE49CBB9
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 20 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-1:2 info: Wacom CTL-6100WL [Intuos BT (M)] type: HID
driver: usbhid,wacom interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 056a:0378 class-ID: 0300 serial: <filter>
Device-2: 3-7:3 info: Sonix USB2.0 HD UVC WebCam type: Video
Device-3: 3-9:4 info: ASUSTek C-Media Audio type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 0b05:6206 class-ID: 0300
Device-4: 3-10:5 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 35.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 292 Uptime: 4m wakeups: 430 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1401 libs: 368 tools: pamac Shell: Bash v: 5.1.16
running-in: dolphin inxi: 3.3.26
Hi @maycne.sonahoz , thanks for the info. I tried with OpenRGB but my device is not listed. I guess is not supported. I also tried with brightnessctl
and xset
but none of them seem to have an option for animation/fading parameters.
Thank you, it was an AURA configuration in Windows. Not on the BIOS utility directly but in the desktop app.
Sorry everybody for opening a topic for such a silly error! Thank you and have a good day.
system
Closed
29 April 2023 20:38
10
