I have a Minibook X from CHUWI, with:
- ManjaroLinux 21.3.3 Ruah
- Kernel 5.19.01
The mouse and keyboard sometimes stop working, its more frequently the trackpad. It appears to be random, sometimes it can go for hours and hours without any issue, other times, the trackpad stops on their tracks right after launch.
To revive one or both i run:
modprobe -r i2c_hid_acpi && modprobe i2c_hid_acpi
and all gets back to normal, working perfectly.
dmesg output pertaining to the events where they stop working (The trackpad in this case):
[ 1928.785322] i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=116283 end=116284) time 9 us, min 2543, max 2559, scanline start 2560, end 2561
[ 1934.737306] audit: type=1131 audit(1659869398.335:100): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2058.161450] i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=124045 end=124046) time 7 us, min 2543, max 2559, scanline start 2560, end 2561
[ 2167.569465] i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=130609 end=130610) time 9 us, min 2543, max 2559, scanline start 2560, end 2561
[ 2289.178355] i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=137905 end=137906) time 14 us, min 2543, max 2559, scanline start 2560, end 2562
[ 2356.283258] i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=141931 end=141932) time 9 us, min 2543, max 2559, scanline start 2560, end 2561
[ 2374.151230] i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=143003 end=143004) time 8 us, min 2543, max 2559, scanline start 2560, end 2561
[ 2380.318346] i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=143373 end=143374) time 7 us, min 2543, max 2559, scanline start 2560, end 2561
[ 2461.111529] audit: type=1100 audit(1659869924.717:101): pid=2935 uid=1000 auid=1000 ses=3 msg='op=PAM:authentication grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 2461.111699] audit: type=1101 audit(1659869924.717:102): pid=2935 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 2461.112555] audit: type=1103 audit(1659869924.717:103): pid=2935 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 2461.112789] audit: type=1105 audit(1659869924.717:104): pid=2935 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 2480.167104] input: GXTP738:00 27C6:011A as /devices/pci0000:00/0000:00:15.2/i2c_designware.2/i2c-2/i2c-GXTP738:00/0018:27C6:011A.0003/input/input31
[ 2480.167433] input: GXTP738:00 27C6:011A Stylus as /devices/pci0000:00/0000:00:15.2/i2c_designware.2/i2c-2/i2c-GXTP738:00/0018:27C6:011A.0003/input/input32
[ 2480.167626] input: GXTP738:00 27C6:011A UNKNOWN as /devices/pci0000:00/0000:00:15.2/i2c_designware.2/i2c-2/i2c-GXTP738:00/0018:27C6:011A.0003/input/input33
[ 2480.167742] input: GXTP738:00 27C6:011A Keyboard as /devices/pci0000:00/0000:00:15.2/i2c_designware.2/i2c-2/i2c-GXTP738:00/0018:27C6:011A.0003/input/input34
[ 2480.172813] hid-multitouch 0018:27C6:011A.0003: input,hidraw0: I2C HID v1.00 Keyboard [GXTP738:00 27C6:011A] on i2c-GXTP738:00
[ 2480.263024] input: SYNA3602:00 0911:5288 Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-SYNA3602:00/0018:0911:5288.0004/input/input35
[ 2480.263300] input: SYNA3602:00 0911:5288 Touchpad as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-SYNA3602:00/0018:0911:5288.0004/input/input36
[ 2480.263558] hid-multitouch 0018:0911:5288.0004: input,hidraw1: I2C HID v1.00 Mouse [SYNA3602:00 0911:5288] on i2c-SYNA3602:00
inxi:
Kernel: 5.19.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: initrd=\initramfs-5.19-x86_64.img
root=UUID=2f41c442-39ea-44e5-a9cf-f47167b23f68 rw
cryptdevice=UUID=2e7afc0a-1d7a-40cc-aa19-b839a3d19154:cryptlvm
Desktop: KDE Plasma v: 5.25.3 tk: Qt v: 5.15.5 wm: kwin_wayland vt: 2
Type: Laptop System: CHUWI Innovation And (ShenZhen) product: MiniBook X
v: N/A serial: <superuser required>
Mobo: N/A model: N/A serial: <superuser required> UEFI: N/A
v: ZW-BI-108-S105JWR120-JCB0E-082-C date: 03/24/2022
ID-1: BAT0 charge: 28.9 Wh (100.0%) condition: 28.9/28.9 Wh (100.0%)
volts: 8.7 min: N/A model: WB SR 1 WB Lion Battery type: Li-ion
serial: <filter> status: charging
RAM: total: 11.43 GiB used: 3.19 GiB (27.9%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Celeron N5100 bits: 64 type: MCP arch: Tremont
built: 2019 process: Intel 10nm family: 6 model-id: 0x9C (156) stepping: 0
microcode: 0x1D
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1.5 MiB desc: 1x1.5 MiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1020 high: 1100 min/max: 800/2800 scaling:
driver: intel_pstate governor: powersave cores: 1: 1100 2: 1100 3: 1100
4: 783 bogomips: 8912
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_capabilities
arch_perfmon art bts cat_l2 cdp_l2 clflush clflushopt clwb cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept ept_ad erms est flexpriority flush_l1d fpu fsgsbase fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri
msr mtrr nonstop_tsc nopl nx pae pat pbe pclmulqdq pdcm pebs pge pln pni
popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep
sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip vme vmx vnmi vpid waitpkg x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: mmio_stale_data status: Vulnerable: Clear CPU buffers attempted, no
microcode; SMT disabled
Type: srbds status: Vulnerable: No microcode
Device-1: Intel JasperLake [UHD Graphics] driver: i915 v: kernel
arch: Gen-11 process: Intel 10nm built: 2019-21 ports: active: DSI-1
empty: DP-1 bus-ID: 00:02.0 chip-ID: 8086:4e61 class-ID: 0300
Device-2: Generic USB Camera type: USB driver: uvcvideo bus-ID: 1-7:2
chip-ID: 0a03:b041 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_wayland driver: X: loaded: modesetting unloaded: vesa
alternate: fbdev gpu: i915 display-ID: 0
Monitor-1: DSI-1 res: 1280x800 size: N/A modes: N/A
OpenGL: renderer: Mesa Intel UHD Graphics (JSL) v: 4.6 Mesa 22.1.3
direct render: Yes
Device-1: Intel Jasper Lake HD Audio driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_icl bus-ID: 00:1f.3 chip-ID: 8086:4dc8
class-ID: 0403
Sound Server-1: ALSA v: k5.19.0-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.55 running: no
Device-1: Intel Wi-Fi 6 AX201 160MHz driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:4df0 class-ID: 0280
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-8:3
chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: disabled
rfk-block: hardware: no software: no address: see --recommends
Message: Unable to run lvs. Root privileges required.
Device-1: cryptlvm maj-min: 254:0 type: LUKS dm: dm-0 size: 396.47 GiB
Components:
p-1: sda5 maj-min: 8:5 size: 396.49 GiB
Local Storage: total: 476.94 GiB used: 15.33 GiB (3.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Netac model: SSD 512GB
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0A0 scheme: GPT
ID-1: / raw-size: 128 GiB size: 124.93 GiB (97.60%) used: 12.13 GiB (9.7%)
fs: ext4 dev: /dev/dm-2 maj-min: 254:2 mapped: volume-root label: N/A
uuid: N/A
ID-2: /boot/efi raw-size: 100 MiB size: 99.8 MiB (99.76%) used: 67.1 MiB
(67.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A uuid: 5BDE-D6A4
ID-3: /home raw-size: 128 GiB size: 124.93 GiB (97.60%) used: 3.13 GiB
(2.5%) fs: ext4 dev: /dev/dm-3 maj-min: 254:3 mapped: volume-home
label: N/A uuid: N/A
ID-1: swap-1 type: partition size: 6 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-1 maj-min: 254:1 mapped: volume-swap label: N/A
uuid: 4eae7288-c922-4c36-88a5-ee2543f79846
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
ID-2: /dev/sda3 maj-min: 8:3 size: 79.36 GiB fs: ntfs label: Windows
uuid: 48A2F693A2F6852A
ID-3: /dev/sda4 maj-min: 8:4 size: 1000 MiB fs: ntfs label: Recovery
uuid: 1CC0F76AC0F74892
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 8 rev: 2.0
Device-1: 1-7:2 info: Generic USB Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.1 speed: 480 Mb/s power: 500mA chip-ID: 0a03:b041
Device-2: 1-8:3 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 48.0 C mobo: N/A
Processes: 213 Uptime: 58m wakeups: 1 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 Packages:
pacman: 904 lib: 254 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.20
This is quite annoying as sometimes although not frequently, both stop working and i can’t call modprobe ![]()
Any help is hihly appreciated. If i missed posting important debugging information, just let me know .
Thak you so much for any help provided.
