Hi,
I have a stupid problem with my monitor - Gigabyte M28U.
It has a KVM feature, so the mouse and the keyboard are plugged into to the monitor and the monitor is plugged into the PC.
Now, when I turn off the Manjaro, the keyboard and mouse still lights up - the monitor doesn’t turn them off. If I think about it, the external drive is also not turned off and it’s plugged directly to the PC.
BUT, if I put a computer to sleep, the keboard and mouse are turned off…
On Windows it works correctly in both cases.
Now I need to manually turn off the monitor when I turn off the system.
Any idea?
inxi -v7azy
Kernel: 6.6.16-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=2ebdd9cf-b85c-4f3a-8616-e5f1329cce20 rw quiet splash apparmor=1
Desktop: GNOME v: 45.4 tk: GTK v: 3.24.41 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 45.0.1 Distro: Manjaro
base: Arch Linux
Type: Desktop Mobo: Gigabyte model: B550 AORUS ELITE
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: F17c date: 09/20/2023
System RAM: total: 32 GiB available: 31.24 GiB used: 4.89 GiB (15.6%)
(unregistered) size: 8 GiB speed: 2133 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.Skill
part-no: F4-3600C19-8GVRB serial: N/A
Device-3: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA20102B
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
desc: 1x32 MiB
Speed (MHz): avg: 2571 high: 3585 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3537 2: 2200
3: 2200 4: 2200 5: 2200 6: 3585 7: 3544 8: 2568 9: 2220 10: 2200 11: 2200
12: 2200 bogomips: 88671
cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA102 [GeForce RTX 3080 Ti] vendor: Micro-Star MSI
driver: nvidia v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 06:00.0 chip-ID: 10de:2208 class-ID: 0300
Device-2: Sonix AUKEY PC-LM7 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 0c68:6888
class-ID: 0102 serial: <filter>
Display: x11 server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.4
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 3840x2160 s-size: <missing: xdpyinfo>
Monitor-1: Unknown-1 mapped: DP-2 res: 3840x2160 dpi: 155
size: 630x360mm (24.8x14.17") modes: 1024x768
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.06
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3080 Ti/PCIe/SSE2
memory: 11.72 GiB
API: Vulkan v: 1.3.276 layers: 10 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3080 Ti driver: nvidia v: 545.29.06 device-ID: 10de:2208
surfaces: xcb,xlib
Device-1: NVIDIA GA102 High Definition Audio vendor: Micro-Star MSI
bus-ID: 06:00.1 chip-ID: 10de:1aef class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
bus-ID: 08:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: DCMT USB Condenser Microphone
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-3:3 chip-ID: 31b2:0011 class-ID: 0300
serial: <filter>
Device-4: Creative Sound BlasterX G6
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-9:10 chip-ID: 041e:3256 class-ID: 0300
serial: <filter>
Device-5: Sonix AUKEY PC-LM7 driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.6.16-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
Device-2: Microsoft Xbox 360 Wireless Adapter driver: xpad type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:3 chip-ID: 045e:0719
class-ID: ff00 serial: <filter>
Device-1: Broadcom BCM20702A0 Bluetooth 4.0 driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:9 chip-ID: 0a5c:21e8
Local Storage: total: 5.66 TiB used: 1.15 TiB (20.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SKC3000D2048G
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 31.9 C
scheme: MBR
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: A-Data model: SX8200PNP
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 32B2T6TA temp: 41.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWD120 size: 1.82 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD
rpm: 7200 serial: <filter> fw-rev: ACF0 scheme: MBR
ID-4: /dev/sdb maj-min: 8:16 vendor: Kingston model: DataTraveler 3.0
size: 115.5 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.1
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: PMAP scheme: MBR
ID-1: / raw-size: 512 GiB size: 502.89 GiB (98.22%) used: 29.22 GiB (5.8%)
fs: ext4 dev: /dev/nvme1n1p5 maj-min: 259:8 label: N/A
uuid: 2ebdd9cf-b85c-4f3a-8616-e5f1329cce20
ID-2: /boot/efi raw-size: 100 MiB size: 99.2 MiB (99.21%)
used: 36.3 MiB (36.6%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:4 label: N/A
uuid: B4A8-3ECF
ID-3: /mnt/nvme0n1p5 raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
used: 393.97 GiB (20.7%) fs: ntfs dev: /dev/nvme0n1p5 maj-min: 259:2
label: Dane, programy i gry (drugi M.2) uuid: 01D96E1322AF7B60
ID-4: /mnt/nvme1n1p4 raw-size: 1.07 TiB size: 1.07 TiB (100.00%)
used: 756.25 GiB (69.0%) fs: ntfs dev: /dev/nvme1n1p4 maj-min: 259:7
label: Gry (pierwszy M.2) uuid: 01D83581418AD320
ID-5: /run/media/yan/Pendrajw raw-size: 115.5 GiB size: 115.5 GiB (100.00%)
used: 89.4 MiB (0.1%) fs: ntfs dev: /dev/sdb1 maj-min: 8:17 label: Pendrajw
uuid: 5C0AFAAC1E1A2BA7
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 1 KiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme1n1p2 maj-min: 259:5 size: 299.38 GiB fs: ntfs label: System
uuid: 01D83E19BFE5C2C0
ID-3: /dev/nvme1n1p3 maj-min: 259:6 size: 626 MiB fs: ntfs label: N/A
uuid: 1AD85F97D85F6FCD
ID-4: /dev/sda1 maj-min: 8:1 size: 1 KiB fs: <superuser required>
ID-5: /dev/sda5 maj-min: 8:5 size: 1016.71 GiB fs: ntfs label: Muzyka
uuid: 01D9715D825B2990
ID-6: /dev/sda6 maj-min: 8:6 size: 846.31 GiB fs: ntfs
label: Instalatory gier uuid: 01D9A875032BC360
Hub-2: 1-2:2 info: Realtek RTS5411 Hub ports: 5 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
Device-1: 1-2.1:4 info: ROCCAT Kone Aimo 16K type: mouse,keyboard
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1e7d:2e2c class-ID: 0300
Device-2: 1-2.2:6 info: Ducky One 3 RGB type: HID,keyboard,mouse
driver: hid-generic,usbhid interfaces: 5 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 3233:1311 class-ID: 0300
serial: <filter>
Device-3: 1-2.5:8 info: Realtek HID Device type: HID
chip-ID: 0bda:1100 class-ID: 0300
Device-4: 1-3:3 info: DCMT USB Condenser Microphone type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
chip-ID: 31b2:0011 class-ID: 0300 serial: <filter>
Hub-3: 1-6:5 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-7:7 info: Integrated Express RGB LED Controller type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
Device-2: 1-8:9 info: Broadcom BCM20702A0 Bluetooth 4.0 type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 chip-ID: 0a5c:21e8 class-ID: fe01 serial: <filter>
Device-3: 1-9:10 info: Creative Sound BlasterX G6 type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 5 rev: 2.0
chip-ID: 041e:3256 class-ID: 0300 serial: <filter>
Hub-4: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Device-1: 2-1:2 info: Kingston DataTraveler 100 G3/G4/SE9 G2/50 Kyson
type: mass storage driver: usb-storage interfaces: 1 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 504mA
chip-ID: 0951:1666 class-ID: 0806 serial: <filter>
Hub-5: 2-2:3 info: Realtek Hub ports: 3 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
Hub-6: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: Sonix AUKEY PC-LM7 type: video,audio
chip-ID: 0c68:6888 class-ID: 0102 serial: <filter>
Device-2: 3-3:3 info: Microsoft Xbox 360 Wireless Adapter type: WiFi
driver: xpad interfaces: 8 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 260mA chip-ID: 045e:0719 class-ID: ff00 serial: <filter>
Hub-7: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 47.2 C mobo: 31.0 C gpu: nvidia temp: 64 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 34%
Processes: 348 Power: uptime: 16m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB services: gsd-power,
tool: systemctl
Packages: 1409 pm: pacman pkgs: 1403 libs: 451 tools: gnome-software,pamac
pm: appimage pkgs: 0 pm: flatpak pkgs: 6 Compilers: clang: 16.0.6 gcc: 13.2.1
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.33
mhwd -li
NAME VERSION FREEDRIVER TYPE
video-nvidia 2023.03.23 false PCI
