Since a few weeks some keybind doesn’t work with XFCE.
The issues is only with the “super” key but not with each combinaison.
For example:
I’ve mapped ⊞ +w , ⊞ +m , ⊞ +& to firefox
, thunderbird
and amixer
and those don’t work.
But for ⊞ +é , ⊞ +f , ⊞ +c ⊞ +t with amixer
, thunar
, copyq
, terminator
, these do work!
If I remap the problematic keybind via the GUI, it will last until the next reboot and then it’s lost again.
Does someone have any idea where the problem lies?
Hi there! Make sure the file ~/.config/autostart/xcape.desktop
exists with the following content:
[Desktop Entry]
Encoding=UTF-8
Version=0.9.4
Type=Application
Name=xcape
Comment=
Exec=xcape -e 'Super_L=Alt_L|F1'
OnlyShowIn=XFCE;
RunHook=0
StartupNotify=false
Terminal=false
Hidden=false
and that the file is writeable by your user:
ls -al ~/.config/autostart/xcape.desktop
should give something like:
-rw-r--r-- 1 frolic_fringe frolic_fringe 9 Feb 24 10:06 xcape.desktop
(where the w
is important)
Fabby
February 24, 2021, 9:10am
3
As I’m an editor here on the site I’ve edited your post for readability. Please press the orange pencil at the top right of your post to see what I did so you can use the same tricks in the future…
cc @screwtape
I’ve also added some more detail to your answer as it might also be an issue of file rights.
@screwtape thanks, i had to create the file, check the perm and rebooted to no avail. The keybinds are still not working.
I forgot: I have the following script in my autostart :
#!/bin/bash
sleep 10
setxkbmap -option ctrl:nocaps
xcape -e ‘Control_L=Escape’
I have the feeling that it might be a locale problem:
S + c e f t x 2 é : works
S + w m & : doesn’t
Maybe my azerty belgian layout has something to do with it?
@Fabby thanks it’s def better… However the ⊞ render as a divided square on my system. imo it’s more confusing than a simple S .
Fabby
February 24, 2021, 2:14pm
5
Nondedju! Gaa zaait ook giene gemakkelijke! Whatever makes you happy is fine…
Ok, then my linux/manjaro-voodoo has reached it’s end - sorry. But you might be on the correct track.
tcheu dis, zullen nous dialect parler? Well that’s what i’m used to see online, thanks for understanding
Thanks, i’m not really sure how to go further, I guess I’ll roam the xfce forum.
