Key could not be locally signed
I’m currently running into the issue
==> ERROR: 3B794DE6D4320FCE594F4171279E7CF5D8D56EC8 could not be locally signed.
which happens when trying to update
core/manjaro-keyring from 20230318-1 to 20230615-1.
Can confirm, the key should be removed but it does not because of the date:
Ah, the key is 2 times in the script also in:
pre_upgrade() {
	if [[ "$(vercmp $2 20220509-2)" -lt 0 ]]; then
		msg "Delete wrongly disabled keys"
		pacman-key -d 688E8F82879D0E25CE541426150C200743ED46D8
		pacman-key -d 3B794DE6D4320FCE594F4171279E7CF5D8D56EC8
So how to fix that? Is there going to be an update for the package?
Yep, sooner or later
Any chance to fix that in the meantime to get the error fixed and to be able to install the updates?
It’s already been fixed with manjaro-keyring 20230616-3.
It still errors here
The following solved it for me in the past:
$ sudo rm -rfv /etc/pacman.d/gnupg
$ sudo pacman-key --init
$ sudo pacman-key --populate archlinux
$ sudo pacman-key --populate manjaro
$ sudo pacman -Sy gnupg archlinux-keyring manjaro-keyring
$ sudo pacman -Syyu
thanks to @Zesko
This didn’t solve it for me, I had to Command out line 45 SigLevel = Required DatabaseOptional in /etc/pacman.conf
and add a line SigLevel = Optional TrustAll run all --init stuff and then after the update toggle line 45 back to normal.
