Hi,
I’m having trouble with keybindings on my recent (today) fresh Manjaro Sway installation.
I use a french keyboard, and I have :
input type:keyboard {
xkb_layout "fr"
xkb_numlock enable
in my config file. But for some reason keybinds are considered like if I was using qwerty.
For instance, kill is set with
$bindsym $mod+Shift+q kill
But I have to press $mod+Shift+a in order to trigger the kill command.
Except bindings, everything works fine, in azerty.
Am I missing something ? something to add in the config file to tell Sway that I’m using an azerty keyboard for bindings ?
Thanks
