Hi !
I received a notification to update my kernel.
I don’t know witch kernel I have to choice…
Thanks !
Hi !
Thanks !
If the two LTS kernels 5.10 and 5.15 work, then I would install them both.
Ok great but can I still use the 5.17 ?
Yes, you can still use kernel 5.17.
Then I would also install kernel 5.15 and test this one.
Kernel 5.17 is EOL !
Please do not use it
I removed the 5.17 but it’s still used. The 5.15 is installed but not used.
You need to reboot to change the kernel in use.
Can you show the grub menu ?
