Kernels 5.18.7-1 and 5.19rc4-1 cannot boot
As the title suggests I may not be able to access the more recent kernels as a result of my cpu cooling hardware’s RGB.
I get the information from the screenshot you can see attached to this post. This is what makes me think it could be the issue. I am going to see if the RGB is separate in my coolers case which should be easy to find and test that way as I am guessing only fixes in the kernel by a programmer can fix this otherwise
My question is there any alternative solutions or is this actually not the problem? Am I wrong with what I think could be the issue?
I did not know how to get the below screenshot in any format or recover it after a crash just in case I am supposed to -_-.
Screenshot
  Kernel: 5.15.50-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    root=UUID=320b5aab-2cfa-4afb-adf0-ad664ace2fd6 rw quiet apparmor=1
  Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop System: Micro-Star product: MS-7D32 v: 1.0
    serial: <superuser required>
  Mobo: Micro-Star model: MAG Z690 TOMAHAWK WIFI DDR4 (MS-7D32) v: 1.0
    serial: <superuser required> UEFI: American Megatrends LLC. v: 1.20
    date: 03/02/2022
  ID-1: hidpp_battery_1 charge: 84% condition: N/A volts: 4.0 min: N/A
    model: Logitech G502 LIGHTSPEED Wireless Gaming Mouse type: N/A
    serial: <filter> status: discharging
  RAM: total: 15.42 GiB used: 3.45 GiB (22.4%)
  RAM Report:
  Info: model: 12th Gen Intel Core i7-12700K bits: 64 type: MST AMCP
    arch: Alder Lake gen: core 12 built: 2021 process: Intel 7 (10nm ESF)
    family: 6 model-id: 0x97 (151) stepping: 2 microcode: 0x1F
  Topology: cpus: 1x cores: 12 mt: 8 tpc: 2 st: 4 threads: 20 smt: enabled
    cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32 KiB, 4x64 KiB
    L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB desc: 1x25 MiB
  Speed (MHz): avg: 4662 high: 5000 min/max: 800/5000:3800 scaling:
    driver: intel_pstate governor: performance cores: 1: 4900 2: 4900 3: 4901
    4: 4900 5: 4890 6: 4900 7: 4889 8: 4200 9: 4997 10: 5000 11: 4989 12: 5000
    13: 4910 14: 4900 15: 4900 16: 4889 17: 3791 18: 3807 19: 3796 20: 3800
    bogomips: 144440
    arch_capabilities arch_lbr arch_perfmon art avx avx2 avx_vnni bmi1 bmi2 bts
    cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault
    cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
    movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
    pconfig pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
    rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap smep
    smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
    tm tm2 tme tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq
    umip vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec
    xsaveopt xsaves xtopology xtpr
  Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
  Device-1: Intel AlderLake-S GT1 vendor: Micro-Star MSI driver: i915
    v: kernel ports: active: none
    empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, HDMI-A-3, HDMI-A-4 bus-ID: 00:02.0
    chip-ID: 8086:4680 class-ID: 0380
  Device-2: NVIDIA GA102 [GeForce RTX 3080 Ti] vendor: Micro-Star MSI
    driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
    status: current (as of 2022-06) arch: Ampere process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:2208 class-ID: 0300
  Device-3: ARC Camera type: USB driver: snd-usb-audio,uvcvideo
    bus-ID: 1-7:5 chip-ID: 05a3:9331 class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
    loaded: nvidia gpu: i915,nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 5120x1440 s-dpi: 93 s-size: 1397x393mm (55.00x15.47")
    s-diag: 1451mm (57.13")
  Monitor-1: DP-0 pos: primary,right res: 2560x1440 hz: 165 dpi: 93
    size: 697x392mm (27.44x15.43") diag: 800mm (31.48") modes: N/A
  Monitor-2: DP-2 pos: primary,left res: 2560x1440 hz: 144 dpi: 93
    size: 697x393mm (27.44x15.47") diag: 800mm (31.5") modes: N/A
  Monitor-3: HDMI-0 size-res: N/A modes: N/A
  OpenGL: renderer: NVIDIA GeForce RTX 3080 Ti/PCIe/SSE2
    v: 4.6.0 NVIDIA 515.57 direct render: Yes
  Device-1: Intel Alder Lake-S HD Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel bus-ID: 1-10:8
    alternate: snd_sof_pci_intel_tgl chip-ID: 046d:0a78 class-ID: 0300
    bus-ID: 00:1f.3 serial: <filter> chip-ID: 8086:7ad0 class-ID: 0403
  Device-2: NVIDIA GA102 High Definition Audio vendor: Micro-Star MSI
    bus-ID: 01:00.1 chip-ID: 10de:1aef class-ID: 0403
  Device-3: Logitech G560 Gaming Speaker type: USB
    driver: hid-generic,snd-usb-audio,usbhid
  Device-4: Creative Sound Blaster X3 type: USB
    driver: cdc_acm,hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:17
    chip-ID: 041e:3264 class-ID: 0102 serial: <filter>
  Device-5: Micro Star USB Audio type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-5:4 chip-ID: 0db0:b202
    class-ID: 0300
  Device-6: ARC Camera type: USB driver: snd-usb-audio,uvcvideo
  Sound Server-1: ALSA v: k5.15.50-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.52 running: yes
  Device-1: Intel Alder Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:7af0 class-ID: 0280
  Device-2: Intel Ethernet I225-V vendor: Micro-Star MSI driver: igc
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0
    chip-ID: 8086:15f3 class-ID: 0200
  IF: enp4s0 state: down mac: <filter>
    bus-ID: 1-14:12 chip-ID: 8087:0026 class-ID: e001
  Local Storage: total: 5.68 TiB used: 175.69 GiB (3.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Samsung model: SSD 980 PRO 1TB
    lanes: 4 type: SSD serial: <filter> rev: 3B2QGXA7 temp: 50.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Corsair model: Force MP510
    size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: ECFM22.5 temp: 38.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Crucial model: CT2000BX500SSD1
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 030 scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM010-2EP102
    type: HDD rpm: 7200 serial: <filter> rev: CC43 scheme: GPT
  ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 QVO 2TB
    type: SSD serial: <filter> rev: 2B6Q scheme: GPT
  ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 175.69 GiB (9.6%)
    fs: ext4 dev: /dev/sdc2 maj-min: 8:34 label: N/A
    uuid: 320b5aab-2cfa-4afb-adf0-ad664ace2fd6
    used: 316 KiB (0.1%) fs: vfat dev: /dev/sdc1 maj-min: 8:33 label: NO_LABEL
    uuid: 1215-3F76
  ID-1: /dev/nvme0n1p1 maj-min: 259:5 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p2 maj-min: 259:6 size: 931.19 GiB fs: ntfs label: N/A
    uuid: 4AC2B047C2B03951
  ID-3: /dev/nvme0n1p3 maj-min: 259:7 size: 308 MiB fs: vfat
    label: NEW VOLUME uuid: 44EE-3B89
  ID-4: /dev/nvme1n1p1 maj-min: 259:1 size: 16 MiB fs: <superuser required>
  ID-5: /dev/nvme1n1p2 maj-min: 259:2 size: 223.25 GiB fs: ntfs label: N/A
    uuid: 56C01B89C01B6F0D
  ID-6: /dev/nvme1n1p3 maj-min: 259:3 size: 309 MiB fs: vfat
    label: NEW VOLUME uuid: 9EE2-6F60
  ID-7: /dev/sda1 maj-min: 8:1 size: 1.82 TiB fs: ntfs label: New Volume
    uuid: 42DED3DADED3C3F7
  ID-8: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: ntfs label: New Volume
    uuid: 8CDAE498DAE47FB6
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
  Device-1: 1-2:2 info: Micro Star MYSTIC LIGHT type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
    power: 500mA chip-ID: 1462:7d32 class-ID: 0300 serial: <filter>
  Device-2: 1-4:17 info: Creative Sound Blaster X3
    type: HID,Abstract (modem),CDC-Data,Audio
    driver: cdc_acm,hid-generic,snd-usb-audio,usbhid interfaces: 7 rev: 2.0
    speed: 480 Mb/s power: 100mA chip-ID: 041e:3264 class-ID: 0102
    serial: <filter>
  Device-3: 1-5:4 info: Micro Star USB Audio type: Audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 8 rev: 2.0
    speed: 480 Mb/s power: 100mA chip-ID: 0db0:b202 class-ID: 0300
  Device-4: 1-7:5 info: ARC Camera type: Video,Audio
    power: 500mA chip-ID: 05a3:9331 class-ID: 0102 serial: <filter>
  Device-5: 1-8:6 info: Logitech USB Receiver type: Mouse,Keyboard,HID
    driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 98mA
    chip-ID: 046d:c541 class-ID: 0300
  Device-6: 1-10:8 info: Logitech G560 Gaming Speaker type: Audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 2.0
    speed: 12 Mb/s chip-ID: 046d:0a78 class-ID: 0300 serial: <filter>
  Hub-2: 1-12:9 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Device-1: 1-12.1:18 info: Logitech PowerPlay Wireless Charging System
    type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s power: 498mA chip-ID: 046d:c53a class-ID: 0300
  Hub-3: 1-13:10 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Device-1: 1-13.3:13 info: Corsair LCD Cap for Elite Capellix coolers
    type: HID driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 480 Mb/s
    power: 288mA chip-ID: 1b1c:0c33 class-ID: 0300 serial: <filter>
  Device-2: 1-13.4:14 info: Corsair iCUE Commander CORE type: HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 480 Mb/s
    power: 100mA chip-ID: 1b1c:0c1c class-ID: 0300 serial: <filter>
  Device-3: 1-14:12 info: Intel AX201 Bluetooth type: Bluetooth
  Hub-4: 2-0:1 info: Super-speed hub ports: 9 rev: 3.1 speed: 20 Gb/s
  Device-1: 2-9:2 info: Elgato Systems GmbH Game Capture HD60 S
    type: <vendor specific> driver: N/A interfaces: 2 rev: 3.0 speed: 5 Gb/s
    power: 400mA chip-ID: 0fd9:0074 class-ID: ff00 serial: <filter>
  System Temperatures: cpu: 30.0 C mobo: N/A gpu: nvidia temp: 47 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 32%
  Processes: 400 Uptime: 1h 18m wakeups: 20 Init: systemd v: 251
  default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1
  Packages: pacman: 1305 lib: 378 flatpak: 0 Shell: Zsh v: 5.9 default: Bash
  v: 5.1.16 running-in: konsole inxi: 3.3.19
Update I tried without RGB stuff and got new crash points on both kernals with only mouse, keyboard, and monitors plugged in whilst RGB plugged out from within XD. I might just give up and await a stable release as I guess this might be up to kernal makers and manjaro people might not be able to help, but I am not sure how this all works :slight_smile:
As a result of the above I have change the title of his.
5.19 error
Screenshot
5.18 error
Screenshot
Hi @Dormant_Hero,
As 5.15 is the latest LTS version anyway, I’d say stick with it if it works.
Yes makes sense. I just wanted to see if improvements for alder lake on later kernals improved rpcs3 performance. I love tinkering since I started this whole linux journey.
Roger that boss.
That is awesome! Mainly because, with Linux specifically, you can.
Previously, IIRC, non-LTS kernels were called “Experimental.” So that might be the reason for the regression, and will possibly not be present in the next LTS version. But I’m not sure.
:man_shrugging:
I experience the same issue and I also use Intel 12th gen CPU ( i7-12700H)
5.17 works fine and i do not see any logs during boot, it instantly loads the DE.
When I switch to kernel version 5.18.7-1 or 5.19rc4-1 the logs appear instantly on boot.
After around 25 seconds, the boot process freezes for about 1 minute and then the screen turns black with a single frozen CLI cursor.
It seems that your system stops booting at different stages but also at the same time (around 7 to 8 seconds) - as my system does.
I think therefore, that this is the same bug.
ref: Manjaro completely freezes when resuming from standby and the external monitor is not turned on - #7 by kri
It’s quite unfortunate that these 2 Kernel versions wont’t work because the should include Intels Thread Director which would improve performance on intel 12th gen
It looks like something with new IBT technology proposed by Intel, which prevent drivers like nvidia driver from loading.
As thread After updating kernel to 5.18.3, system fails to start - Support[1] suggests, add ibt=off works. You might need to wait for a upstream rootfix, but currently, ibt=off might be the only way.
edited to include working link:
  1. sorry for that I could not put a link in the forum ↩︎
Just seen this response this morning. You are a true hero :pray: :prayer_beads:
I was able to boot into 5.19rc5-1 and it worked. I tested without just in case an update made it work but nope it was changing the boot options to include ibt=off.
I guess the only disadvantage is no android apps maybe? In which case I do not care.
Permanently changed it in /etc/default/ grub
This solved it for me too. I’m on an optimus notebook and I was skipping updates because of this.
Also btrfs is great for this sort of stuff. Your system is borked after an update? Just rollback and wait for a solution =)
I had no idea about that. I activated grub to roll back kernals as it offers you your previous kernal selection on boot.
