Hello, I updated my kernel from 5.4 to 5.10, my audio doesn’t work now, i know how to downgrade my kernel but i want to use 5.10. My motherboard is a G41-M vs3 with 5.1 CH HD Audio (VIA® VT1705 Audio Codec). I got a intel core 2 quad cpu. I use built in speakers from my AL1917 Monitor.
Please, post
inxi -Aazy
Device-1: Intel NM10/ICH7 Family High Definition Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:27d8
class-ID: 0403
Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series]
vendor: PC Partner Limited driver: snd_hda_intel v: kernel bus-ID: 04:00.1
chip-ID: 1002:aab0 class-ID: 0403
Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
I think i need to downgrade ALSA
If 5.10 isn’t working out, then reboot and choose 5.4 from the GRUB menu. Hold Shift or tap Esc to access it if it doesn’t appear by default.
yeah i know, but i want to use 5.10 for newer features
Check if this works
pulseaudio --start
Had same problem.
also check the volume icon is set to the right output, mine switched to the 3.5 jack & i had to switch it back onboard sound.
pulseaudio was started
alright
didn’t work
