After updating to Plasma 6, in the system settings Kernel is no longer an option. I’m able to still update kernels through the command line but I would like to be able to do it via gui as well.
Try searching for “Manjaro Settings Manager”
Welcome to the forum! ![]()
The issue is known and has already been reported several times. The reason why you don’t get that option in the Plasma 6 System Settings is that the module for handling kernels has not yet been ported to qt6, so you’ll just have to be patient until it has.
That said, you can still get the GUI as part of the Manjaro Settings Manager, which should be available from the system menu. ![]()
Thank you!
