brtza
30 August 2020 09:44
1
While boot, I am getting this error.
[marko@marko-hpenvy ~]$ hostnamectl
Static hostname: marko-hpenvy
Icon name: computer-convertible
Chassis: convertible
Machine ID: 24e2c57f6ba84d06b308aa0bfc428c1c
Boot ID: af82a8aa5386476aa19adf8bcc9a13e3
Kernel: Linux 5.8.3-2-MANJARO
Architecture: x86-64
I would say:
Upgrade your UEFI/BIOS if possible
installing irqbalance could be helping. Don`t forget to start and enable the service.
Add pci=nomsi,noaer to GRUB_CMDLINE_LINUX= in /etc/default/grub and execute sudo update-grub in a terminal. (that should suppress the message and let the system boot)
Since it is a bug somehow by reading the kernel bug reports, idk what else could be done there.
Oh, I’m also getting this message at every bootup, but never care about it. Oopsie
But the system worked.
In a few parts I’m always having trouble (drivers for audio, ethernet and gpu) is this the cause?
Before changing the /etc/default/grub file permanently I would test it from the grub menu as proposed by Bogdan:
Please try this:
When you boot, while in the GRUB menu and you selected to boot the installer, pres e and add, to the kernel parameters line, this pci=nomsi,noaer
You can place it right after quiet .
Then press F10 to continue booting. You might have to do the same once the system is installed and you boot from it. Look on how to permanently add boot flags to boot.
If this helps to not show that message, then you can make it permanent by adding it to /etc/default/grub and then update gr…
this coming from this change in linux kernel
committed 08:05PM - 21 May 20 UTC
Replace the extra interrupt handling code and reuse the existing idtentry
machinery. This moves the irq stack switching on 64-bit from ASM...
Also effecting AMD 3600XT CPU kernel 5.8.11.1.
Grub fixes do not work. And installing irq balance is no solution.
brtza
9 October 2020 07:44
7
I didn’t find fix for this issue… I tried every kernel, same thing
i have the same problem,
Everyone should at least list their kernel and motherboard and bios version
I think this happened after i flashed the bios so it may be a bios update that caused it
Kernel : 5.9
Motherboard : Gigabyte X570 AORUS ELITE (rev. 1.0)
Bios : F31b
hi,
same here
kernel 5.9.1-1
mb: ASRock > B550 Phantom Gaming-ITX/ax
cpu: AMD Ryzen 7 3700X
Stevie
25 November 2020 19:26
10
Hi, same here:
Kernel: 5.9.10-1
Mainboard: ASUS B550m plus (updated bios didn’t change anything)
CPU: Ryzen 3600
phuhui
29 November 2020 02:09
11
Same thing, showing this after Bios upgrade
MSI X570 Game Plus
Bios: 7C37vAC1(Beta version)
Kernal: 5.9.11-2
Hi,
Bios update solved this problem and maybe triggered other problems … (under investigation)
I updated my BIOS and still no joy
Kernel : 5.9
Bios : F31o
@ lkovacs
ty for the update
Would you mind mentioning your motherboard and bios version that you upgraded to?
Hi sorry for late answer
my mobo: B550 Phantom Gaming-ITX/ax
latest bios : 1.80 with Update AMD AGESA Combo-AM4 V2 1.1.0.0 patch C
r4jk3
21 December 2020 19:37
15
Same problem during boot, with same hardware as yours:
Gigabyte x570 AORUS ELITE
Bios: F30
So still no solution to this?
I just updated to kernel 5.10 and the problem is fixed!!!
Stevie
5 January 2021 18:00
18
I updated the Kernel 5.10 too, but then it’s stuck on the no irq screen.
Generally my system is sorta bricked after the last updates (many programms won’t launch).
r4jk3
5 January 2021 20:57
19
I’ve also updated to Linux 5.10, but problem is still not fixed.
What motherboard and what version bios are you using I updated my motherboard to the latest version
