I’m writting from Live USB… I was having a bad time updating, there was this big ~450 updates update… I had PGP signature issues. This time btw I was doing it after a clean reboot, in a TTY.
But while I was trying (for the n-th time) to run pacman -Syyu
after:
sudo pacman-mirrors
sudo pacman-key --populate archlinux manjaro
pacman-key --refresh-keys
… well the packages seemed to be uploading peacefully, but suddenly kernel panic! And when I rebooted, after a few seconds I got a message about no kernel being found. From there I was redirected to GRUB, but all (normal, advanced and recovery) options resulted in the exact same result.
So, I booted from a Live Manjaro ISO, and ran:
sudo su
mount /dev/vnme0n1p2 /mnt
mount -t proc proc /mnt/proc
mount -t sysfs sys /mnt/sys
mount -o bind /dev /mnt/dev
mount -t devpts pts /mnt/dev/pts
manjaro-chroot /mnt
The first thing I noticed was the ZSH sent a warning at every command I launched:
ERROR: ld.so: object '/usr/$LIB/librl_custom_isearch.so' from /etc/ld.so.preload cannot be preloaded (cannot open shared object file): ignored.
… but I guessed that it was harmless (though inconvenient).
I could rebuild successfully the kernel with mkinitcpio
using the kernel in my modules
folder.
But the final problem is: I want (because I read I sould) to run:
pacman -Syu linux
… but I can’t because pacman
sees no server whatsoever. I’m online, I can ping 1.1.1.1 from inside the chrooted environment. I’ve tried various mirrors by genrating local, default etc… mirror lists, I checked at least some were unquoted in /etc/pacman.d/mirrorlist
, but no, pacman
seems to be completely blind. The exact output is below:
> pacman -Syu linux root@manjaro
core.db failed to download
error: failed retrieving file 'core.db' from mirror.yandex.ru : Could not resolve host: mirror.yandex.ru
warning: too many errors from mirror.yandex.ru, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from irltoolkit.mm.fcix.net : Could not resolve host: irltoolkit.mm.fcix.net
warning: too many errors from irltoolkit.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ask4.mm.fcix.net : Could not resolve host: ask4.mm.fcix.net
warning: too many errors from ask4.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.snt.utwente.nl : Could not resolve host: ftp.snt.utwente.nl
warning: too many errors from ftp.snt.utwente.nl, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.alwyzon.net : Could not resolve host: mirror.alwyzon.net
warning: too many errors from mirror.alwyzon.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from southfront.mm.fcix.net : Could not resolve host: southfront.mm.fcix.net
warning: too many errors from southfront.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from linorg.usp.br : Could not resolve host: linorg.usp.br
warning: too many errors from linorg.usp.br, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from repo.ialab.dsu.edu : Could not resolve host: repo.ialab.dsu.edu
warning: too many errors from repo.ialab.dsu.edu, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.xeonbd.com : Could not resolve host: mirror.xeonbd.com
warning: too many errors from mirror.xeonbd.com, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.terrahost.no : Could not resolve host: mirror.terrahost.no
warning: too many errors from mirror.terrahost.no, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.ocf.berkeley.edu : Could not resolve host: mirrors.ocf.berkeley.edu
warning: too many errors from mirrors.ocf.berkeley.edu, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.cc.uoc.gr : Could not resolve host: ftp.cc.uoc.gr
warning: too many errors from ftp.cc.uoc.gr, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from nnenix.mm.fcix.net : Could not resolve host: nnenix.mm.fcix.net
warning: too many errors from nnenix.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.sjtug.sjtu.edu.cn : Could not resolve host: mirrors.sjtug.sjtu.edu.cn
warning: too many errors from mirrors.sjtug.sjtu.edu.cn, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors2.manjaro.org : Could not resolve host: mirrors2.manjaro.org
warning: too many errors from mirrors2.manjaro.org, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.csclub.uwaterloo.ca : Could not resolve host: mirror.csclub.uwaterloo.ca
warning: too many errors from mirror.csclub.uwaterloo.ca, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from kartolo.sby.datautama.net.id : Could not resolve host: kartolo.sby.datautama.net.id
warning: too many errors from kartolo.sby.datautama.net.id, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjarolinux-mirror.cloud.mu : Could not resolve host: manjarolinux-mirror.cloud.mu
warning: too many errors from manjarolinux-mirror.cloud.mu, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.gigenet.com : Could not resolve host: mirrors.gigenet.com
warning: too many errors from mirrors.gigenet.com, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.it4i.cz : Could not resolve host: mirror.it4i.cz
warning: too many errors from mirror.it4i.cz, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.rz.tu-bs.de : Could not resolve host: ftp.rz.tu-bs.de
warning: too many errors from ftp.rz.tu-bs.de, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjaro.mirror.wearetriple.com : Could not resolve host: manjaro.mirror.wearetriple.com
warning: too many errors from manjaro.mirror.wearetriple.com, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjaro.grena.ge : Could not resolve host: manjaro.grena.ge
warning: too many errors from manjaro.grena.ge, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from codingflyboy.mm.fcix.net : Could not resolve host: codingflyboy.mm.fcix.net
warning: too many errors from codingflyboy.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.nluug.nl : Could not resolve host: ftp.nluug.nl
warning: too many errors from ftp.nluug.nl, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.uni-kl.de : Could not resolve host: ftp.uni-kl.de
warning: too many errors from ftp.uni-kl.de, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.koddos.net : Could not resolve host: mirror.koddos.net
warning: too many errors from mirror.koddos.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.ft.uam.es : Could not resolve host: mirrors.ft.uam.es
warning: too many errors from mirrors.ft.uam.es, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.ustc.edu.cn : Could not resolve host: mirrors.ustc.edu.cn
warning: too many errors from mirrors.ustc.edu.cn, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.ibakerserver.pt : Could not resolve host: mirror.ibakerserver.pt
warning: too many errors from mirror.ibakerserver.pt, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.truenetwork.ru : Could not resolve host: mirror.truenetwork.ru
warning: too many errors from mirror.truenetwork.ru, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.tuna.tsinghua.edu.cn : Could not resolve host: mirrors.tuna.tsinghua.edu.cn
warning: too many errors from mirrors.tuna.tsinghua.edu.cn, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.easyname.at : Could not resolve host: mirror.easyname.at
warning: too many errors from mirror.easyname.at, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.init7.net : Could not resolve host: mirror.init7.net
warning: too many errors from mirror.init7.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.sonic.net : Could not resolve host: mirrors.sonic.net
warning: too many errors from mirrors.sonic.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjaro.repo.cure.edu.uy : Could not resolve host: manjaro.repo.cure.edu.uy
warning: too many errors from manjaro.repo.cure.edu.uy, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from repos.silknet.com : Could not resolve host: repos.silknet.com
warning: too many errors from repos.silknet.com, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from coresite.mm.fcix.net : Could not resolve host: coresite.mm.fcix.net
warning: too many errors from coresite.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjaro.kurdy.org : Could not resolve host: manjaro.kurdy.org
warning: too many errors from manjaro.kurdy.org, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.jlu.edu.cn : Could not resolve host: mirrors.jlu.edu.cn
warning: too many errors from mirrors.jlu.edu.cn, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.xtom.jp : Could not resolve host: mirrors.xtom.jp
warning: too many errors from mirrors.xtom.jp, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.ufro.cl : Could not resolve host: mirror.ufro.cl
warning: too many errors from mirror.ufro.cl, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.xenyth.net : Could not resolve host: mirror.xenyth.net
warning: too many errors from mirror.xenyth.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.lysator.liu.se : Could not resolve host: ftp.lysator.liu.se
warning: too many errors from ftp.lysator.liu.se, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.fcix.net : Could not resolve host: mirror.fcix.net
warning: too many errors from mirror.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.nic.cz : Could not resolve host: mirrors.nic.cz
warning: too many errors from mirrors.nic.cz, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from volico.mm.fcix.net : Could not resolve host: volico.mm.fcix.net
warning: too many errors from volico.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjaro.ipacct.com : Could not resolve host: manjaro.ipacct.com
warning: too many errors from manjaro.ipacct.com, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjaro.mirror.garr.it : Could not resolve host: manjaro.mirror.garr.it
warning: too many errors from manjaro.mirror.garr.it, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.funami.tech : Could not resolve host: mirror.funami.tech
warning: too many errors from mirror.funami.tech, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftpmirror1.infania.net : Could not resolve host: ftpmirror1.infania.net
warning: too many errors from ftpmirror1.infania.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.dkm.cz : Could not resolve host: mirror.dkm.cz
warning: too many errors from mirror.dkm.cz, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjaro.ynh.ovh : Could not resolve host: manjaro.ynh.ovh
warning: too many errors from manjaro.ynh.ovh, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.datacenter.by : Could not resolve host: mirror.datacenter.by
warning: too many errors from mirror.datacenter.by, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.vinehost.net : Could not resolve host: mirror.vinehost.net
warning: too many errors from mirror.vinehost.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from quantum-mirror.hu : Could not resolve host: quantum-mirror.hu
warning: too many errors from quantum-mirror.hu, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.tsukuba.wide.ad.jp : Could not resolve host: ftp.tsukuba.wide.ad.jp
warning: too many errors from ftp.tsukuba.wide.ad.jp, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjaro.c3sl.ufpr.br : Could not resolve host: manjaro.c3sl.ufpr.br
warning: too many errors from manjaro.c3sl.ufpr.br, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.telepoint.bg : Could not resolve host: mirror.telepoint.bg
warning: too many errors from mirror.telepoint.bg, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjaro.mirror.liquidtelecom.com : Could not resolve host: manjaro.mirror.liquidtelecom.com
warning: too many errors from manjaro.mirror.liquidtelecom.com, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.gwdg.de : Could not resolve host: ftp.gwdg.de
warning: too many errors from ftp.gwdg.de, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.erickochen.nl : Could not resolve host: mirror.erickochen.nl
warning: too many errors from mirror.erickochen.nl, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.netix.net : Could not resolve host: mirrors.netix.net
warning: too many errors from mirrors.netix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.kku.ac.th : Could not resolve host: mirror.kku.ac.th
warning: too many errors from mirror.kku.ac.th, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ridgewireless.mm.fcix.net : Could not resolve host: ridgewireless.mm.fcix.net
warning: too many errors from ridgewireless.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from forksystems.mm.fcix.net : Could not resolve host: forksystems.mm.fcix.net
warning: too many errors from forksystems.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.23m.com : Could not resolve host: mirror.23m.com
warning: too many errors from mirror.23m.com, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.manjaro.org : Could not resolve host: mirrors.manjaro.org
warning: too many errors from mirrors.manjaro.org, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ba.mirror.garr.it : Could not resolve host: ba.mirror.garr.it
warning: too many errors from ba.mirror.garr.it, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.is.co.za : Could not resolve host: mirror.is.co.za
warning: too many errors from mirror.is.co.za, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from uvermont.mm.fcix.net : Could not resolve host: uvermont.mm.fcix.net
warning: too many errors from uvermont.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.free.org : Could not resolve host: ftp.free.org
warning: too many errors from ftp.free.org, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from fosszone.csd.auth.gr : Could not resolve host: fosszone.csd.auth.gr
warning: too many errors from fosszone.csd.auth.gr, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from opencolo.mm.fcix.net : Could not resolve host: opencolo.mm.fcix.net
warning: too many errors from opencolo.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ct.mirror.garr.it : Could not resolve host: ct.mirror.garr.it
warning: too many errors from ct.mirror.garr.it, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mnvoip.mm.fcix.net : Could not resolve host: mnvoip.mm.fcix.net
warning: too many errors from mnvoip.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from muug.ca : Could not resolve host: muug.ca
warning: too many errors from muug.ca, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.archlinux.tw : Could not resolve host: mirror.archlinux.tw
warning: too many errors from mirror.archlinux.tw, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.netcologne.de : Could not resolve host: mirror.netcologne.de
warning: too many errors from mirror.netcologne.de, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.psnc.pl : Could not resolve host: ftp.psnc.pl
warning: too many errors from ftp.psnc.pl, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from gsl-syd.mm.fcix.net : Could not resolve host: gsl-syd.mm.fcix.net
warning: too many errors from gsl-syd.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.up.pt : Could not resolve host: mirrors.up.pt
warning: too many errors from mirrors.up.pt, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.albony.xyz : Could not resolve host: mirror.albony.xyz
warning: too many errors from mirror.albony.xyz, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.xtom.de : Could not resolve host: mirrors.xtom.de
warning: too many errors from mirrors.xtom.de, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.futureweb.be : Could not resolve host: mirror.futureweb.be
warning: too many errors from mirror.futureweb.be, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjaro.mirrors.lavatech.top : Could not resolve host: manjaro.mirrors.lavatech.top
warning: too many errors from manjaro.mirrors.lavatech.top, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.bouwhuis.network : Could not resolve host: mirror.bouwhuis.network
warning: too many errors from mirror.bouwhuis.network, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.nyist.edu.cn : Could not resolve host: mirror.nyist.edu.cn
warning: too many errors from mirror.nyist.edu.cn, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.alpix.eu : Could not resolve host: mirror.alpix.eu
warning: too many errors from mirror.alpix.eu, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.halifax.rwth-aachen.de : Could not resolve host: ftp.halifax.rwth-aachen.de
warning: too many errors from ftp.halifax.rwth-aachen.de, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.cicku.me : Could not resolve host: mirrors.cicku.me
warning: too many errors from mirrors.cicku.me, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ohioix.mm.fcix.net : Could not resolve host: ohioix.mm.fcix.net
warning: too many errors from ohioix.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.aarnet.edu.au : Could not resolve host: mirror.aarnet.edu.au
warning: too many errors from mirror.aarnet.edu.au, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.math.princeton.edu : Could not resolve host: mirror.math.princeton.edu
warning: too many errors from mirror.math.princeton.edu, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from nocix.mm.fcix.net : Could not resolve host: nocix.mm.fcix.net
warning: too many errors from nocix.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from edgeuno-bog2.mm.fcix.net : Could not resolve host: edgeuno-bog2.mm.fcix.net
warning: too many errors from edgeuno-bog2.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.tu-chemnitz.de : Could not resolve host: ftp.tu-chemnitz.de
warning: too many errors from ftp.tu-chemnitz.de, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.2degrees.nz : Could not resolve host: mirror.2degrees.nz
warning: too many errors from mirror.2degrees.nz, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from www.mirrorservice.org : Could not resolve host: www.mirrorservice.org
warning: too many errors from www.mirrorservice.org, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.linux.org.tr : Could not resolve host: ftp.linux.org.tr
warning: too many errors from ftp.linux.org.tr, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror1.sox.rs : Could not resolve host: mirror1.sox.rs
warning: too many errors from mirror1.sox.rs, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.kamtv.ru : Could not resolve host: mirror.kamtv.ru
warning: too many errors from mirror.kamtv.ru, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ftp.caliu.cat : Could not resolve host: ftp.caliu.cat
warning: too many errors from ftp.caliu.cat, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.atlas.net.co : Could not resolve host: mirrors.atlas.net.co
warning: too many errors from mirrors.atlas.net.co, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.xtom.ee : Could not resolve host: mirrors.xtom.ee
warning: too many errors from mirrors.xtom.ee, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.dotsrc.org : Could not resolve host: mirrors.dotsrc.org
warning: too many errors from mirrors.dotsrc.org, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from ossmirror.mycloud.services : Could not resolve host: ossmirror.mycloud.services
warning: too many errors from ossmirror.mycloud.services, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.zetup.net : Could not resolve host: mirror.zetup.net
warning: too many errors from mirror.zetup.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjaro.mirrors.uk2.net : Could not resolve host: manjaro.mirrors.uk2.net
warning: too many errors from manjaro.mirrors.uk2.net, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirrors.ucr.ac.cr : Could not resolve host: mirrors.ucr.ac.cr
warning: too many errors from mirrors.ucr.ac.cr, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from fastmirror.pp.ua : Could not resolve host: fastmirror.pp.ua
warning: too many errors from fastmirror.pp.ua, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.ufam.edu.br : Could not resolve host: mirror.ufam.edu.br
warning: too many errors from mirror.ufam.edu.br, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.phoepsilonix.love : Could not resolve host: mirror.phoepsilonix.love
warning: too many errors from mirror.phoepsilonix.love, skipping for the remainder of this transaction
error: failed to synchronize all databases (invalid url for server)
and this output comes out almost instanteneously: it’s not likely to be a network speed issue, I think.
Please help! I hope this all makes sense to someone.
