Hi I have a big problem some since I installed manjaro some times it freezes 3 it happened when I turned off the computer and once while I was starting firefox and every time my caps lock button flashes can you tell me the reason? Everything was fine thanks for the help
Should I change kernel?
I know nothing about your system and usecase - I have no idea.
You could provide some insight into your system.
Provide the links generated by the following commands (they will extract information needed to properly assess the situation)
pacman -Qqm | curl -F 'file=@-' https://0x0.st
pacman -Qqn | curl -F 'file=@-' https://0x0.st
pacman -Qdt | curl -F 'file=@-' https://0x0.st
inxi -Fzayc0 | curl -F 'file=@-' https://0x0.st
cat /etc/default/grub | curl -F 'file=@-' https://0x0.st
cat /etc/mkinitcpio.conf | curl -F 'file=@-' https://0x0.st
You haven’t provided any useful information.
Please read through the following link, and understand what is needed from you when you ask for support:
Cheers.
So I ran these commands now?
Please share …
Apart from the commands on the terminal nothing appeared, if it generated files where can I find them?
each command return a link to the output - stored at https://0x0.st/<filename.txt>
but of course if the host is not there - it wil fail
No sorry it didn’t fail, here’s the result screenshot
Kernel: 6.9.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
root=UUID=38f0fb62-e399-403c-a3d3-e8d3d2f9b0e7 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.4.0
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA507NV_FA507NV
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: FA507NV v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: FA507NV.312
date: 08/11/2023
ID-1: BAT1 charge: 48.1 Wh (52.4%) condition: 91.8/90.2 Wh (101.7%)
volts: 15.2 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
status: discharging
Info: model: AMD Ryzen 7 7735HS with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3+ gen: 4 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404102
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 586 high: 1397 min/max: 400/4829 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1397 2: 400 3: 400
4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 1397 11: 400 12: 1397 13: 400
14: 400 15: 400 16: 400 bogomips: 102244
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
affected
Device-1: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile] vendor: ASUSTeK
driver: nvidia v: 550.100 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
bus-ID: 01:00.0 chip-ID: 10de:28e0 class-ID: 0300
Device-2: AMD Rembrandt [Radeon 680M] vendor: ASUSTeK driver: amdgpu
v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,
DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, DP-8, Writeback-1 bus-ID: 35:00.0
chip-ID: 1002:1681 class-ID: 0300 temp: 44.0 C
Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 2b7e:b685
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
compositor: kwin_x11 driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux N156HMA-GA1 built: 2022
res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm:
drv: kms_swrast surfaceless: drv: nvidia x11: drv: radeonsi
inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.1.3-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 680M (radeonsi rembrandt
LLVM 18.1.8 DRM 3.57 6.9.10-1-MANJARO) device-ID: 1002:1681 memory: 500 MiB
unified: no
API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4060 Laptop GPU driver: nvidia v: 550.100 device-ID: 10de:28e0
surfaces: xcb,xlib device: 1 type: integrated-gpu name: AMD Radeon 680M
(RADV REMBRANDT) driver: mesa radv v: 24.1.3-manjaro1.1
device-ID: 1002:1681 surfaces: xcb,xlib
Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:22be class-ID: 0403
Device-2: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 35:00.1
chip-ID: 1002:1640 class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 35:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-4: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 35:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.9.10-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8852BE PCIe 802.11ax Wireless Network
vendor: AzureWave driver: rtw89_8852be v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:b852 class-ID: 0280
Device-1: IMC Networks Bluetooth Radio driver: btusb v: 0.8 type: USB
rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:3 chip-ID: 13d3:3571
Local Storage: total: 476.94 GiB used: 45.83 GiB (9.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN740 SDDPNQD-512G-1002 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 73101000 temp: 39.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 45.83 GiB (9.8%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 45.5 C mobo: N/A gpu: amdgpu temp: 44.0 C
Fan Speeds (rpm): cpu: 0
Memory: total: 16 GiB note: est. available: 14.84 GiB used: 3.17 GiB (21.4%)
Processes: 345 Power: uptime: 8m states: freeze,mem,disk suspend: s2idle
image: 5.9 GiB services: org_kde_powerdevil, power-profiles-daemon, upowerd
Init: systemd v: 256 default: graphical tool: systemctl
Packages: 1309 pm: pacman pkgs: 1298 libs: 362 tools: pamac pm: flatpak
pkgs: 11 Compilers: gcc: 14.1.1 alt: 13 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.35
leader edit: replaced image with system info
Not a screenshot - the text - I don’t read screenshots - so - text please …
share those links that appear below each command
but not as a screenshot - copy/paste as text
Those links when followed will get you and us the output.
It is impossible to say - your system looks fairly ordinary to me
It could be caused by the plymouth nvidia combination - but as I don’t run Nvidia I cannot say.
As you are using a AMD 7735 APU, I suggest you use a newer kernel - usually better support for AMD
On stable branch you linux 6.10.0 is the latest.
On unstable branch there is Nvidia 555 and Linux 6.11-rc1
The use of screenshots
Do not post images or screenshots as part of your topic. The forum is a technical forum not an image gallery.
– Forum Rules - Manjaro
I removed you screenshot and pasted you systeminfo from your link.
Please avoid images in the future.
The forum search engine cannot index images - they are not searchable like text - and finding information in other topics is a must on this forum.
Ok I won’t post any more images, now I have installed kernel 6.10.03 let’s hope we don’t have any more problems. I’ll let you know. But maybe I should set it to dedicated as default?
I turned off the computer, same problem, it freezes with flashing caps lock
Please test
- Boot the system
- Do not login
- switch to TTY e.g. CtrlAltF4
- login
- then run command
systemctl poweroff
When this does not trigger kernel panic it is Plasma related.
Reboot the system - login to the desktop as usual - then open a terminal and run
systemctl poweroff
If that does not trigger kernel panic either - I would deduce the kernel panic to be Plasma related - yet I have no way of verifying - as my AMD systems does not exhibit this kernel panic.
Plasma is 6.0.5 on stable branch - but extension, theme, sddm greeter etc you can get your hands on is created for 6.1 (upstream) - and this may cause unknown, unforeseen issues.
Ok, I tried it and it crashed
Which one ? First or second ?
At the first command
