Kernel panic after Stable Update 2022.05.23
Hi, I got a problem.
After the update, I did a reboot and got a black screen right after boot from grub.
I could not boot with my default kernel: 5.15.41-1 LTS, recommended
I got a black screen and the light of my caps lock button kept flashing on and off. I could not turn the flashing off by pressing the caps lock button. Furthermore, I waited a long time, and it did not boot.
My (imperfect) solution:
I had to reboot and boot from grub with the previous kernel 5.10.117-1 LTS, this worked, and I can use my system again.
can you provide
sudo mhwd-kernel -li
sudo mhwd -li
also check theses points
Currently running: 5.10.117-1-MANJARO (linux510)
   * linux510
   * linux515
   * linux54
sudo mhwd -l
> 0000:00:02.0 (0300:8086:0126) Display controller Intel Corporation:
           video-linux            2018.05.04                true            PCI
can you report
inxi -Fza
sudo mhwd -li
ls /etc/mkinitcpio.d/*.preset
sudo ls /boot/initramfs-*
sudo ls /boot/vmlinuz-*
sudo ls /usr/lib/modules/*
pacman -Qs linux*
Here is what I tried to solve it:
  • clean caches
  • reinstall 5.15 kernel
  • reboot with 5.15 kernel → same problem
  • reboot with 5.15 kernel fallback initramfs (selected in grub) → same problem
inxi -Fza
  Kernel: 5.10.117-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    root=UUID=f44f71c2-0b91-4732-b385-f0c5575ace9a rw quiet
    cryptdevice=UUID=ede9c8ca-c628-4daa-b737-8a36f96c4ff6:luks-ede9c8ca-c628-4daa-b737-8a36f96c4ff6
    root=/dev/mapper/luks-ede9c8ca-c628-4daa-b737-8a36f96c4ff6
    resume=/dev/mapper/luks-ede9c8ca-c628-4daa-b737-8a36f96c4ff6 apparmor=1
    security=apparmor udev.log_priority=3 ipv6.disable=1 init_on_alloc=1
    init_on_free=1 oops=panic pti=on mce=0 slub_debug=FZ slab_nomerge
    mds=full,nosmt mitigations=auto,nosmt
  Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel, plank
    wm: xfwm v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux
    base: Arch Linux
  Type: Laptop System: LENOVO product: 42434YG v: ThinkPad T520
  Mobo: LENOVO model: 42434YG serial: <superuser required>
    UEFI-[Legacy]: LENOVO v: 8AET69WW (1.49 ) date: 06/14/2018
  ID-1: BAT0 charge: 0.3 Wh (100.0%) condition: 0.3/93.6 Wh (0.3%)
    volts: 12.2 min: 11.1 model: LGC 42T4912 type: Li-ion serial: <filter>
    status: not charging
  Info: model: Intel Core i7-2860QM bits: 64 type: MCP arch: Sandy Bridge
    family: 6 model-id: 0x2A (42) stepping: 7 microcode: 0x2F
  Topology: cpus: 1x cores: 4 smt: disabled cache: L1: 256 KiB
    desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 8 MiB
    desc: 1x8 MiB
  Speed (MHz): avg: 797 min/max: 800/3600 scaling: driver: intel_cpufreq
    governor: powersave cores: 1: 797 2: 797 3: 797 4: 797 bogomips: 19942
  Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  Type: l1tf
  Type: spectre_v2
    mitigation: Retpolines, IBPB: conditional, IBRS_FW, RSB filling
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
    vendor: Lenovo ThinkPad T520 driver: i915 v: kernel ports: active: LVDS-1
    empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3, VGA-1
    bus-ID: 00:02.0 chip-ID: 8086:0126 class-ID: 0300
  Device-2: Chicony Lenovo Integrated Camera (0.3MP) type: USB
    driver: uvcvideo bus-ID: 1-1.6:5 chip-ID: 04f2:b217 class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver:
    X: loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
    screens: 1
  Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
    s-diag: 485mm (19.11")
  Monitor-1: LVDS-1 model: Lenovo 0x40b1 built: 2009 res: 1600x900 hz: 60
    dpi: 118 gamma: 1.2 size: 345x194mm (13.58x7.64") diag: 396mm (15.6")
    ratio: 16:9 modes: 1600x900
  OpenGL: renderer: Mesa Intel HD Graphics 3000 (SNB GT2)
    v: 3.3 Mesa 22.0.4 compat-v: 3.1 direct render: Yes
    vendor: Lenovo ThinkPad T520 driver: snd_hda_intel v: kernel
    bus-ID: 00:1b.0 chip-ID: 8086:1c20 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.117-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.51 running: yes
  Device-1: Intel 82579LM Gigabit Network vendor: Lenovo ThinkPad T520
    driver: e1000e v: kernel port: 5080 bus-ID: 00:19.0 chip-ID: 8086:1502
    class-ID: 0200
  IF: enp0s25 state: down mac: <filter>
  Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
    chip-ID: 8086:0085 class-ID: 0280
  IF-ID-2: wwp0s29u1u4i6 state: down mac: <filter>
  Local Storage: total: 1.14 TiB used: 859.1 GiB (73.7%)
  ID-1: /dev/mmcblk0 maj-min: 179:0 model: 00000 size: 974.5 MiB
    block-size: physical: 512 B logical: 512 B type: SSD serial: <filter>
    scheme: MBR
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LM000-1EJ162
    size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
    speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: HPD3
    scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi)
    model: HTS721075A9E630 size: 698.64 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
    rev: A3J0 scheme: MBR
  ID-1: / raw-size: 125 GiB size: 121.98 GiB (97.58%) used: 47.84 GiB (39.2%)
    fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-ede9c8ca-c628-4daa-b737-8a36f96c4ff6
  ID-2: /home raw-size: 300 GiB size: 294.23 GiB (98.08%)
    used: 259.99 GiB (88.4%) fs: ext4 dev: /dev/dm-2 maj-min: 254:2
    mapped: luks-b2a2c0e2-acff-416a-8feb-85bb2695a1a4
  ID-3: /var raw-size: 40.76 GiB size: 39.82 GiB (97.70%)
    used: 10.18 GiB (25.6%) fs: ext4 dev: /dev/dm-1 maj-min: 254:1
    mapped: luks-f109e0a4-e102-4f32-9c39-28ff2de01439
  Kernel: swappiness: 5 (default 60) cache-pressure: 50 (default 100)
  ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: 50
    file: /var/lib/systemd-swap/swapfc/1
  System Temperatures: cpu: 50.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 1972
  Processes: 336 Uptime: 20m wakeups: 2 Memory: 15.51 GiB
  used: 5.39 GiB (34.8%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 12.1.0 clang: 13.0.1 Packages: 2385 pacman: 2365 lib: 507 flatpak: 4
  snap: 16 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.16
sudo mhwd -li
> Installed PCI configs:
/etc/mkinitcpio.d/linux510.preset  /etc/mkinitcpio.d/linux515.preset  /etc/mkinitcpio.d/linux54.preset
/boot/initramfs-5.10-x86_64-fallback.img  /boot/initramfs-5.15-x86_64-fallback.img  /boot/initramfs-5.4-x86_64-fallback.img
/boot/initramfs-5.10-x86_64.img		  /boot/initramfs-5.15-x86_64.img	    /boot/initramfs-5.4-x86_64.img
/boot/vmlinuz-5.10-x86_64  /boot/vmlinuz-5.15-x86_64  /boot/vmlinuz-5.4-x86_64
/usr/lib/modules/5.10.117-1-MANJARO:
build	      kernelbase	 modules.builtin	    modules.builtin.modinfo  modules.devname  modules.symbols	   updates
extramodules  modules.alias	 modules.builtin.alias.bin  modules.dep		     modules.order    modules.symbols.bin  vmlinuz
kernel	      modules.alias.bin  modules.builtin.bin	    modules.dep.bin	     modules.softdep  pkgbase
/usr/lib/modules/5.15.41-1-MANJARO:
build	      kernelbase	 modules.builtin	    modules.builtin.modinfo  modules.devname  modules.symbols	   vmlinuz
/usr/lib/modules/5.4.195-1-MANJARO:
/usr/lib/modules/extramodules-5.10-MANJARO:
vboxdrv.ko.xz  vboxnetadp.ko.xz  vboxnetflt.ko.xz  version
/usr/lib/modules/extramodules-5.15-MANJARO:
/usr/lib/modules/extramodules-5.4-MANJARO:
pacman -Qs linux*
local/alsa-lib 1.2.6.1-1
    An alternative implementation of Linux sound support
local/alsa-utils 1.2.6-1
    Advanced Linux Sound Architecture - Utilities
local/android-udev 20220102-1
    Udev rules to connect Android devices to your linux box
local/apparmor 3.0.4-1
    Mandatory Access Control (MAC) using Linux Security Module (LSM)
local/archlinux-appstream-data 20220512-1
    Arch Linux application database for AppStream-based software centers
local/archlinux-keyring 20220424-1
    Arch Linux PGP keyring
local/avahi 0.8+22+gfd482a7-3
    Service Discovery for Linux using mDNS/DNS-SD -- compatible with Bonjour
local/clamtk 6.14-1
    Easy to use, light-weight, on-demand virus scanner for Linux systems
local/cpupower 5.17-1 (linux-tools)
    Linux kernel tool to examine and tune power saving related features of your processor
local/ecryptfs-utils 111-5
    Enterprise-class stacked cryptographic filesystem for Linux
local/efibootmgr 17-2
    Linux user-space application to modify the EFI Boot Manager
local/filesystem 2021.12.07-3
    Base Manjaro Linux files
local/firejail 0.9.68-1
    Linux namespaces sandbox program
local/flatpak 1:1.12.7-1
    Linux application sandboxing and distribution framework (formerly xdg-app)
local/grub-theme-manjaro 20.2-12
    Manjaro Linux grub theme
local/gufw 22.04-1
    Uncomplicated way to manage your Linux firewall
local/hdparm 9.63-2
    A shell utility for manipulating Linux IDE drive/driver parameters
local/ibus 1.5.26-2
    Next Generation Input Bus for Linux
local/illyria-wallpaper 1.4-1
    Official Wallpapers for the Manjarolinux 18.x release
local/inotify-tools 3.22.1.0-1
    inotify-tools is a C library and a set of command-line programs for Linux providing a simple interface to inotify.
local/iptables 1:1.8.8-1
    Linux kernel packet control tool (using legacy interface)
local/kconfig-hardened-check 0.5.17-1
    Tool for checking the security hardening options of the Linux kernel
local/keyutils 1.6.3-1
    Linux Key Management Utilities
local/kmod 29-3
    Linux kernel module management tools and library
local/ladspa 1.17-1
    Linux Audio Developer's Simple Plugin API (LADSPA)
local/lib32-alsa-lib 1.2.6.1-1
    An alternative implementation of Linux sound support (32 bit)
local/lib32-keyutils 1.6.3-1
    Linux Key Management Utilities (32-bit)
local/lib32-libva 2.14.0-1
    Video Acceleration (VA) API for Linux (32-bit)
local/lib32-libxshmfence 1.3-2
    a library that exposes a event API on top of Linux futexes (32-bit)
local/lib32-util-linux 2.38-1
    Miscellaneous system utilities for Linux (32-bit)
local/lib32-v4l-utils 1.22.1-1
    Userspace tools and conversion library for Video 4 Linux (32-bit)
local/libaio 0.3.113-1
    The Linux-native asynchronous I/O facility (aio) library
local/libcap-ng 0.8.3-1
    A library for Linux that makes using posix capabilities easy
local/libiec61883 1.2.0-6
    A higher level API for streaming DV, MPEG-2 and audio over Linux IEEE 1394
local/libimobiledevice 1.3.0-5
    Library that talks the protocols to support iPhone and iPod Touch devices on Linux
local/libraw1394 2.1.2-3
    Provides an API to the Linux IEEE1394 (FireWire) driver
local/liburing 2.1-1
    Linux-native io_uring I/O access library
local/libva 2.14.0-1
local/libxshmfence 1.3-2
local/linux-api-headers 5.17.5-2
    Kernel headers sanitized for use in userspace
local/linux-firmware 20220509.b19cbdc-1
    Firmware files for Linux
local/linux-firmware-whence 20220509.b19cbdc-1
    Firmware files for Linux - contains the WHENCE license file which documents the vendor license details
local/linux-latest-headers 5.10-1
    Header files and scripts for building modules for the latest kernel (metapackage)
local/linux-lts-headers 1:5.4-4
    Header files and scripts for building modules for the latest LTS kernel (metapackage)
local/linux510 5.10.117-1
    The Linux510 kernel and modules
local/linux510-headers 5.10.117-1
    Header files and scripts for building modules for Linux510 kernel
local/linux510-virtualbox-host-modules 6.1.34-8 (linux510-extramodules)
    Host kernel modules for VirtualBox
local/linux515 5.15.41-1
    The Linux515 kernel and modules
local/linux515-headers 5.15.41-1
    Header files and scripts for building modules for Linux515 kernel
local/linux515-virtualbox-host-modules 6.1.34-9 (linux515-extramodules)
local/linux54 5.4.195-1
    The Linux54 kernel and modules
local/linux54-headers 5.4.195-1
    Header files and scripts for building modules for Linux54 kernel
local/linux54-virtualbox-host-modules 6.1.34-8 (linux54-extramodules)
local/lirc 1:0.10.1-12
    Linux Infrared Remote Control utilities
local/lynis 3.0.7-1
    Security and system auditing tool to harden Unix/Linux systems
local/man-pages 5.13-1
    Linux man pages
local/manjaro-application-utility 1.3.3-7
    A simple application utility for Manjaro Linux
local/manjaro-browser-settings 20220522-1
    Manjaro Linux settings browser defaults
local/manjaro-firmware 20160419-1
    Extra firmwares for Manjaro Linux
local/manjaro-hotfixes 2018.08-6
    Manjaro Linux Hotfixes
local/manjaro-settings-manager 0.5.7-4
    Manjaro Linux System Settings Tool
local/manjaro-settings-manager-notifier 0.5.7-4
    Manjaro Linux System Settings Tool (Notifier)
local/manjaro-system 20220202-2
    Manjaro Linux System - Update script
local/manjaro-wallpapers-18.0 1.4-3
local/mdadm 4.2-2
    A tool for managing/monitoring Linux md device arrays, also known as Software RAID
local/mhwd 0.6.5-2
    Manjaro Linux Hardware Detection library and application
local/mhwd-db 0.6.5-21
    Manjaro Linux Hardware Detection Database
local/ndctl 73-1
    Utility library for managing the libnvdimm (non-volatile memory device) sub-system in the Linux kernel
local/net-tools 2.10-1
    Configuration tools for Linux networking
local/pacman-mirrors 4.23.2-2
    Manjaro Linux mirror list for use by pacman
local/playonlinux 4.3.4-4
    GUI for managing Windows programs under linux
local/python-distro 1.7.0-1
    Linux OS platform information API
local/python-jade-application-kit 3.5.7-6
    Build hybrid web/desktop applications or wrappers on Linux, with Python, JavaScript, HTML5, and CSS3 and QTWebengine
local/python-pyinotify 0.9.6-11
    Python module used for monitoring filesystems events on Linux platforms with inotify.
local/python-selinux 0.2.1-7
    Pure-python selinux shim module for use in virtualenvs
local/signal-desktop 5.43.0-1
    Signal Private Messenger for Linux
local/squashfs-tools 4.5.1-1
    Tools for squashfs, a highly compressed read-only filesystem for Linux
local/stacer 1.1.0-1.2
    Linux System Optimizer and Monitoring
local/stoken 0.92-4
    RSA SecurID-compatible software token for Linux/UNIX systems
local/teams 1.5.00.10453-1
    Microsoft Teams for Linux is your chat-centered workspace in Office 365
local/timeshift 21.09.1-4
    A system restore utility for Linux
local/tlp 1.5.0-4
    Linux Advanced Power Management
local/usb_modeswitch 2.6.1-3
    Activating switchable USB devices on Linux.
local/util-linux 2.38-1
local/util-linux-libs 2.38-1
    util-linux runtime libraries
local/v4l-utils 1.22.1-1
local/wallpapers-juhraya 1.1-2
    Community Wallpapers for the Manjarolinux 18.1 Juhraya release
Looks like the updates module is missing doesn’t it?
can you remove
sudo pacman -Rs linux-lts-headers linux-latest-headers
why all theses options on boot ?
“init_on_alloc=1 init_on_free=1 oops=panic pti=on mce=0 slub_debug=FZ slab_nomerge”
try and check for any error
sudo mkinitcpio -P
any orphans else to remove ?
sudo pacman -Qdt
Hold on, I’m performing a timeshift snapshot. I’ll report back in about 30 minutes. Sorry, I think it will be 45 minutes or 60 minutes.
checking dependencies...
:: dkms optionally requires linux-headers: build modules against the Arch kernel
:: dkms optionally requires linux-lts-headers: build modules against the LTS kernel
Packages (3) linux54-headers-5.4.195-1  linux-latest-headers-5.10-1  linux-lts-headers-1:5.4-4
Total Removed Size:  113.60 MiB
:: Do you want to remove these packages? [Y/n]
(1/1) Remove DKMS modules
==> dkms remove --no-depmod vboxhost/6.1.34_OSE -k 5.4.195-1-MANJARO
==> depmod 5.4.195-1-MANJARO
(1/3) removing linux-latest-headers                                         [###########################################] 100%
(2/3) removing linux-lts-headers                                            [###########################################] 100%
(3/3) removing linux54-headers                                              [###########################################] 100%
(1/2) Arming ConditionNeedsUpdate...
(2/2) Updating module dependencies...
sudo mkinitcpio -P
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
  -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
==> Starting build: 5.10.117-1-MANJARO
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [fsck]
  -> Running build hook: [encrypt]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
  -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: qla1280
==> WARNING: Possibly missing firmware for module: qla2xxx
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
  -> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img
==> Starting build: 5.15.41-1-MANJARO
==> WARNING: Possibly missing firmware for module: qat_4xxx
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
  -> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'default'
  -> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64.img
==> Starting build: 5.4.195-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'fallback'
  -> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64-fallback.img
sudo pacman -Qdt
no output
can you check on 5.15 lts ?
and other case suppress theses options [(e)dit on grub line command]?
“init_on_alloc=1 init_on_free=1 oops=panic pti=on mce=0 slub_debug=FZ slab_nomerge"
Hi,
I still can’t boot into 5.15 after removing the linux headers.
However, thank you for your support, I think the problem is with this line
“init_on_alloc=1 init_on_free=1 oops=panic pti=on mce=0 slub_debug=FZ slab_nomerge" and especially oops=panic
but I have not tested it yet.
However, I rather just use the kernel 5.10. It works alright.
Thank you for your support.
I have similar problem with my OS, But with rather old PC configuration everything was running fine until last major update … around week ago , my pc just boots into Kernel panic mode no keys work except for hard reset … ““Kernel panic - not syncing: No working init found””
I tried to update and tried newer kernels using manjaro-chroot but nothing works. Please help … should I open a new thread ? … I am currently using Rosa linux installed on my other partition.
you should open a new thread
Do help me out here please since I have similar issue, should I open a new thread under KDE plasma support section ?
Did you try tapping shift on boot, and choose an older kernel in grub advanced menu?
Yes. I tried various kernels., I installed the 5.4LTS & 5.10 but same kernel-panic no working init found…
No keys work when its in panic mode … had to hard reset everytime so its kinda risky for me, my drive might corrupt due to that. I can chroot into the system via Rosa linux … I also tried Live Manjaro media but same thing the system works in chroot I can install or remove anything.
boot with USB live manjaro
open a terminal and a browser on this topic
and return
sudo manjaro-root -a
mhwd-kernel -li
mhwd -li
inxi -Fza
journalctl -b -1 -p4
exit ( end chroot )
sh-5.1# mhwd-kernel -li
Currently running: 5.15.32-1-MANJARO (linux515)
   * linux510
   * linux515
   * linux517
   * linux54
sh-5.1# mhwd -li
Getting some weird character “12” in inxi -Fza
sh-5.1# inxi -Fza
12System:
  12Kernel 5.15.32-1-MANJARO 12arch x86_64 12bits 64 12compiler gcc 12v 11.2.0
    12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro
    misolabel=MANJARO_KDE_2126 quiet systemd.show_status=1 apparmor=1 security=apparmor
    driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1 video=LVDS-1:d
  12Console N/A 12wm kwin_x11 12Distro Manjaro Linux 12base Arch Linux
12Machine:
  12Type Portable 12System Dell 12product Inspiron 1545 12v N/A 12serial <filter> 12Chassis 12type 8
    12serial <filter>
  12Mobo Dell 12model 0G848F 12serial <filter> 12BIOS Dell 12v A14 12date 12/07/2009
12Battery:
  12ID-1 BAT0 12charge 19.1 Wh (2.6%) 12condition 725.8/86.6 Wh (838.2%) 12volts 11.3 12min 11.1
    12model SMP DELL HP2879 12type Li-ion 12serial <filter> 12status N/A
12CPU:
  12Info 12model Intel Core2 Duo P8700 12socket Microprocessor 12bits 64 12type MCP 12arch Core Yorkfield
    12family 6 12model-id 0x17 (23) 12stepping 0xA (10) 12microcode 0xA0B
  12Topology 12cpus 1x 12cores 2 12smt <unsupported> 12cache 12L1 128 KiB 12desc d-2x32 KiB; i-2x32 KiB
    12L2 3 MiB 12desc 1x3 MiB
  12Speed (MHz) 12avg 2534 12min/max 800/2535 12boost enabled 12base/boost 2534/2534 12scaling
    12driver acpi-cpufreq 12governor schedutil 12volts 3.3 V 12ext-clock 266 MHz 12cores 121 2534 122 2534
    12bogomips 10112
  12Flags ht lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx
  12Vulnerabilities
  12Type itlb_multihit 12status KVM: VMX disabled
  12Type l1tf 12mitigation PTE Inversion; VMX: EPT disabled
  12Type mds 12status Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
  12Type meltdown 12mitigation PTI
  12Type spec_store_bypass 12status Vulnerable
  12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer sanitization
  12Type spectre_v2 12mitigation Retpolines, STIBP: disabled, RSB filling
  12Type srbds 12status Not affected
  12Type tsx_async_abort 12status Not affected
12Graphics:
  12Device-1 Intel Mobile 4 Series Integrated Graphics 12vendor Dell Inspiron 1545 12driver i915
    12v kernel 12ports 12active VGA-1 12empty DP-1,LVDS-1 12bus-ID 00:02.0 12chip-ID 8086:2a42 12class-ID 0300
  12Display 12server X.org 12v 1.21.1.3 12with Xwayland 12v 22.1.1 12compositor kwin_x11 12driver 12gpu i915
    12note  X driver n/a 12display-ID :0
  12Monitor-1 VGA-1 12model Dell D2015H 12serial <filter> 12built 2016 12res 1920x1080 12dpi 112 12gamma 1.2
    12size 435x239mm (17.13x9.41") 12diag 496mm (19.5") 12ratio 16:9 12modes 12max 1920x1080 12min 720x400
  12Message GL data unavailable for root.
12Audio:
  12Device-1 Intel 82801I HD Audio 12vendor Dell 12driver snd_hda_intel 12v kernel 12bus-ID 00:1b.0
    12chip-ID 8086:293e 12class-ID 0403
  12Sound Server-1 ALSA 12v k5.15.32-1-MANJARO 12running yes
  12Sound Server-2 JACK 12v 1.9.21 12running no
  12Sound Server-3 PulseAudio 12v 15.0 12running yes
  12Sound Server-4 PipeWire 12v 0.3.51 12running yes
12Network:
  12Device-1 Marvell 88E8040 PCI-E Fast Ethernet 12vendor Dell 12driver sky2 12v 1.30 12pcie 12gen 1
    12speed 2.5 GT/s 12lanes 1 12port de00 12bus-ID 09:00.0 12chip-ID 11ab:4354 12class-ID 0200
  12IF enp9s0 12state down 12mac <filter>
  12Device-2 Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter 12vendor AzureWave
    12driver ath9k 12v kernel 12pcie 12gen 1 12speed 2.5 GT/s 12lanes 1 12bus-ID 0c:00.0 12chip-ID 168c:0036
    12class-ID 0280
  12IF wlp12s0 12state up 12mac <filter>
12Bluetooth:
  12Device-1 IMC Networks 12type USB 12driver btusb 12v 0.8 12bus-ID 8-1:3 12chip-ID 13d3:3423 12class-ID e001
  12Report rfkill 12ID hci0 12rfk-id 1 12state down 12bt-service N/A 12rfk-block 12hardware no 12software yes
    12address see --recommends
12Drives:
  12Local Storage 12total 387.28 GiB 12used 13.02 GiB (3.4%)
  12ID-1 /dev/sda 12maj-min 8:0 12vendor Acer 12model SSD RE100 2.5 256GB 12size 238.47 GiB 12block-size
    12physical 512 B 12logical 512 B 12sata 3.2 12speed 3.0 Gb/s 12type SSD 12serial <filter> 12rev 2B0 12temp 54 C
  12SMART yes 12state enabled 12health PASSED 12on 56d 16h 12cycles 319 12read 7.5 MiB 12written 6.2 MiB
  12ID-2 /dev/sdb 12maj-min 8:16 12type USB 12model Mass Storage Device 12size 29.72 GiB 12block-size
    12physical 512 B 12logical 512 B 12type N/A 12serial <filter>
  12SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
  12ID-3 /dev/sdc 12maj-min 8:32 12type USB 12vendor Generic 12model Multi-Card 12size 119.08 GiB 12block-size
    12physical 512 B 12logical 512 B 12type N/A 12serial <filter> 12rev 1.00
12Partition:
  12ID-1 / 12raw-size 37.77 GiB 12size 37.77 GiB (100.00%) 12used 13.02 GiB (34.5%) 12fs btrfs
    12block-size 4096 B 12dev /dev/sdc3 12maj-min 8:35
12Swap:
  12Alert No swap data was found.
12Sensors:
  12System Temperatures 12cpu 54.0 C 12mobo N/A
  12Fan Speeds (RPM) 12cpu 3800
12Info:
  12Processes 224 12Uptime 14m 12wakeups 1 12Memory 3.79 GiB 12used 2.39 GiB (63.1%) 12Init systemd 12v 250
  12tool systemctl 12Compilers 12gcc 12.1.0 12clang 13.0.1 12Packages 12pacman 1213 12lib 331
  12Client Unknown Client: systemd 12inxi 3.3.16
sh-5.1# journalctl -b -1 -p4
No journal files were found.
Data from the specified boot (-1) is not available: No such boot ID in journal
inxi is not showing my system details properly, kernel parameters shown belongs to USB live media
this point , no driver Xorg for you old CPU,
it may explain why cpu reach 52 °C and Fans works at full speed 3800 ( may be check cooler systems )
with KDE are you using Xorg or Wayland ?
I agree the Cpu sometime goes upto 94 °C as my laptop is very old, Dell 1545(2010) but even Windows 10 on my other partition still works smoothly, anyways…I use Wayland and the X drivers are all installed but isn’t showing up in Inxi don’t know why … don’t understand what mess the last update on 24.05.22 did to my old PC…
SOLVED !! I can finally boot into my Manjaro KDE after nearly 15 days …
I was searching in Arch linux forums about kernel-panic error I stumbled upon on thread where the /usr/lib64 was NOT linking to /usr/lib as it should be. Thats all I restored the link and then
mkinitcpio -p linux
… thats it. Thanks to all for your kind help… I sincerely hope my little finding in future will help someone with similar issue. Thanks Team Manjaro …
