dmesg (until mounted root
[ 0.015063] Movable zone start for each node
[ 0.015064] Early memory node ranges
[ 0.015064] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ 0.015066] node 0: [mem 0x0000000000100000-0x000000008ef6efff]
[ 0.015067] node 0: [mem 0x0000000094bff000-0x0000000094bfffff]
[ 0.015067] node 0: [mem 0x0000000100000000-0x000000085f7fffff]
[ 0.015071] Initmem setup node 0 [mem 0x0000000000001000-0x000000085f7fffff]
[ 0.015076] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.015102] On node 0, zone DMA: 97 pages in unavailable ranges
[ 0.018919] On node 0, zone DMA32: 23696 pages in unavailable ranges
[ 0.062269] On node 0, zone Normal: 13312 pages in unavailable ranges
[ 0.062287] On node 0, zone Normal: 2048 pages in unavailable ranges
[ 0.062349] Reserving Intel graphics memory at [mem 0x9c800000-0xa07fffff]
[ 0.063591] ACPI: PM-Timer IO Port: 0x1808
[ 0.063599] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.063601] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.063602] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.063602] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.063603] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[ 0.063604] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[ 0.063604] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[ 0.063605] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[ 0.063605] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[ 0.063606] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[ 0.063607] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[ 0.063607] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[ 0.063608] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[ 0.063608] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[ 0.063609] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[ 0.063609] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[ 0.063728] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ 0.063732] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.063733] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.063738] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.063739] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.063747] e820: update [mem 0x8979a000-0x8982afff] usable ==> reserved
[ 0.063756] TSC deadline timer available
[ 0.063757] smpboot: Allowing 8 CPUs, 0 hotplug CPUs
[ 0.063771] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.063773] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
[ 0.063774] PM: hibernation: Registered nosave memory: [mem 0x8979a000-0x8982afff]
[ 0.063776] PM: hibernation: Registered nosave memory: [mem 0x89fe0000-0x89fe0fff]
[ 0.063777] PM: hibernation: Registered nosave memory: [mem 0x8ef6f000-0x8f03efff]
[ 0.063778] PM: hibernation: Registered nosave memory: [mem 0x8f03f000-0x93f2efff]
[ 0.063779] PM: hibernation: Registered nosave memory: [mem 0x93f2f000-0x94b2efff]
[ 0.063779] PM: hibernation: Registered nosave memory: [mem 0x94b2f000-0x94bfefff]
[ 0.063781] PM: hibernation: Registered nosave memory: [mem 0x94c00000-0x991fffff]
[ 0.063781] PM: hibernation: Registered nosave memory: [mem 0x99200000-0x999fffff]
[ 0.063782] PM: hibernation: Registered nosave memory: [mem 0x99a00000-0xa07fffff]
[ 0.063782] PM: hibernation: Registered nosave memory: [mem 0xa0800000-0xbfffffff]
[ 0.063783] PM: hibernation: Registered nosave memory: [mem 0xc0000000-0xcfffffff]
[ 0.063784] PM: hibernation: Registered nosave memory: [mem 0xd0000000-0xfed1ffff]
[ 0.063784] PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfed7ffff]
[ 0.063785] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xffffffff]
[ 0.063786] [mem 0xd0000000-0xfed1ffff] available for PCI devices
[ 0.063788] Booting paravirtualized kernel on bare hardware
[ 0.063790] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.070121] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:8 nr_node_ids:1
[ 0.070328] percpu: Embedded 63 pages/cpu s221184 r8192 d28672 u262144
[ 0.070333] pcpu-alloc: s221184 r8192 d28672 u262144 alloc=1*2097152
[ 0.070336] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[ 0.070356] Fallback order for Node 0: 0
[ 0.070359] Built 1 zonelists, mobility grouping on. Total pages: 8186578
[ 0.070361] Policy zone: Normal
[ 0.070362] Kernel command line: BOOT_IMAGE=/vmlinuz-5.19-x86_64 root=UUID=c625808b-74b1-448d-8450-c40550e55a52 rw cryptdevice=UUID=e16b5219-<filter>:luks-e16b5219-<filter> root=/dev/mapper/luks-e16b5219-<filter> apparmor=1 security=apparmor udev.log_priority=3 ibt=off
[ 0.070454] Unknown kernel command line parameters "BOOT_IMAGE=/vmlinuz-5.19-x86_64 cryptdevice=UUID=e16b5219-<filter>:luks-e16b5219-<filter>", will be passed to user space.
[ 0.071730] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.072342] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.072516] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.135758] Memory: 32433224K/33266744K available (16391K kernel code, 2090K rwdata, 11244K rodata, 2116K init, 3508K bss, 833260K reserved, 0K cma-reserved)
[ 0.137489] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.137548] ftrace: allocating 45602 entries in 179 pages
[ 0.145877] ftrace: allocated 179 pages with 5 groups
[ 0.145996] Dynamic Preempt: full
[ 0.146140] rcu: Preemptible hierarchical RCU implementation.
[ 0.146140] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=8.
[ 0.146141] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.146142] Trampoline variant of Tasks RCU enabled.
[ 0.146143] Rude variant of Tasks RCU enabled.
[ 0.146143] Tracing variant of Tasks RCU enabled.
[ 0.146144] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.146145] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.151759] NR_IRQS: 20736, nr_irqs: 2048, preallocated irqs: 16
[ 0.152271] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.152837] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[ 0.152899] random: crng init done
[ 0.152926] Console: colour dummy device 80x25
[ 0.152944] printk: console [tty0] enabled
[ 0.152965] ACPI: Core revision 20220331
[ 0.153240] hpet: HPET dysfunctional in PC10. Force disabled.
[ 0.153241] APIC: Switch to symmetric I/O mode setup
[ 0.153243] DMAR: Host address width 39
[ 0.153244] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[ 0.153249] DMAR: dmar0: reg_base_addr fed90000 ver 4:0 cap 1c0000c40660462 ecap 29a00f0505e
[ 0.153251] DMAR: DRHD base: 0x000000fed85000 flags: 0x0
[ 0.153256] DMAR: dmar1: reg_base_addr fed85000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.153258] DMAR: DRHD base: 0x000000fed86000 flags: 0x0
[ 0.153262] DMAR: dmar2: reg_base_addr fed86000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.153263] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ 0.153268] DMAR: dmar3: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.153270] DMAR: RMRR base: 0x0000009c000000 end: 0x000000a07fffff
[ 0.153274] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 3
[ 0.153276] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[ 0.153277] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.160014] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.160016] x2apic enabled
[ 0.160114] Switched APIC routing to cluster x2apic.
[ 0.177253] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x28680fa287f, max_idle_ns: 440795281151 ns
[ 0.177259] Calibrating delay loop (skipped), value calculated using timer frequency.. 5608.00 BogoMIPS (lpj=9344000)
[ 0.177262] pid_max: default: 32768 minimum: 301
[ 0.180590] LSM: Security Framework initializing
[ 0.180590] landlock: Up and running.
[ 0.180590] Yama: becoming mindful.
[ 0.180590] LSM support for eBPF active
[ 0.180590] AppArmor: AppArmor initialized
[ 0.180590] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.180590] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.180590] CPU0: Thermal monitoring enabled (TM1)
[ 0.180590] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[ 0.180590] process: using mwait in idle threads
[ 0.180590] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[ 0.180590] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
[ 0.180590] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.180590] Spectre V2 : Mitigation: Enhanced IBRS
[ 0.180590] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.180590] Spectre V2 : Spectre v2 / PBRSB-eIBRS: Retire a single CALL on VMEXIT
[ 0.180590] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.180590] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[ 0.180590] Freeing SMP alternatives memory: 36K
[ 0.180590] smpboot: CPU0: 11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz (family: 0x6, model: 0x8c, stepping: 0x1)
[ 0.180590] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.180590] cblist_init_generic: Setting shift to 3 and lim to 1.
[ 0.180590] Performance Events: PEBS fmt4+-baseline, AnyThread deprecated, Icelake events, 32-deep LBR, full-width counters, Intel PMU driver.
[ 0.180590] ... version: 5
[ 0.180590] ... bit width: 48
[ 0.180590] ... generic registers: 8
[ 0.180590] ... value mask: 0000ffffffffffff
[ 0.180590] ... max period: 00007fffffffffff
[ 0.180590] ... fixed-purpose events: 4
[ 0.180590] ... event mask: 0001000f000000ff
[ 0.180590] Estimated ratio of average max frequency by base frequency (times 1024): 1499
[ 0.180590] rcu: Hierarchical SRCU implementation.
[ 0.180590] rcu: Max phase no-delay instances is 1000.
[ 0.180590] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.180590] smp: Bringing up secondary CPUs ...
[ 0.180590] x86: Booting SMP configuration:
[ 0.180590] .... node #0, CPUs: #1 #2 #3 #4 #5 #6 #7
[ 0.196516] smp: Brought up 1 node, 8 CPUs
[ 0.196516] smpboot: Max logical packages: 1
[ 0.196516] smpboot: Total of 8 processors activated (44869.00 BogoMIPS)
[ 0.198389] devtmpfs: initialized
[ 0.198389] x86/mm: Memory block size: 128MB
[ 0.198744] ACPI: PM: Registering ACPI NVS region [mem 0x93f2f000-0x94b2efff] (12582912 bytes)
[ 0.198744] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.198744] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.198744] pinctrl core: initialized pinctrl subsystem
[ 0.200592] PM: RTC time: 07:30:51, date: 2022-09-23
[ 0.200956] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.201388] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.201745] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.202115] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.202125] audit: initializing netlink subsys (disabled)
[ 0.202132] audit: type=2000 audit(1663918251.023:1): state=initialized audit_enabled=0 res=1
[ 0.202132] thermal_sys: Registered thermal governor 'fair_share'
[ 0.202132] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.202132] thermal_sys: Registered thermal governor 'step_wise'
[ 0.202132] thermal_sys: Registered thermal governor 'user_space'
[ 0.202132] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.202132] cpuidle: using governor ladder
[ 0.202132] cpuidle: using governor menu
[ 0.202132] HugeTLB: can optimize 4095 vmemmap pages for hugepages-1048576kB
[ 0.202132] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.202132] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.202132] PCI: MMCONFIG for domain 0000 [bus 00-79] at [mem 0xc0000000-0xc79fffff] (base 0xc0000000)
[ 0.202132] PCI: MMCONFIG at [mem 0xc0000000-0xc79fffff] reserved in E820
[ 0.202132] PCI: Using configuration type 1 for base access
[ 0.202132] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.204203] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.204209] HugeTLB: can optimize 7 vmemmap pages for hugepages-2048kB
[ 0.204209] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.204209] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.207264] ACPI: Added _OSI(Module Device)
[ 0.207264] ACPI: Added _OSI(Processor Device)
[ 0.207264] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.207264] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.207264] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.207264] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.207264] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.283611] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.294394] ACPI: 14 ACPI AML tables successfully acquired and loaded
[ 0.295682] ACPI: EC: EC started
[ 0.295683] ACPI: EC: interrupt blocked
[ 0.296985] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.296986] ACPI: EC: Boot ECDT EC used to handle transactions
[ 0.313926] ACPI: Dynamic OEM Table Load:
[ 0.313926] ACPI: SSDT 0xFFFF914B8193DA00 0001CB (v02 PmRef Cpu0Psd 00003000 INTL 20191018)
[ 0.314504] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[ 0.315167] ACPI: Dynamic OEM Table Load:
[ 0.315172] ACPI: SSDT 0xFFFF914B8187DC00 000394 (v02 PmRef Cpu0Cst 00003001 INTL 20191018)
[ 0.315945] ACPI: Dynamic OEM Table Load:
[ 0.315949] ACPI: SSDT 0xFFFF914B8188B000 000647 (v02 PmRef Cpu0Ist 00003000 INTL 20191018)
[ 0.316781] ACPI: Dynamic OEM Table Load:
[ 0.316785] ACPI: SSDT 0xFFFF914B8187C000 00028B (v02 PmRef Cpu0Hwp 00003000 INTL 20191018)
[ 0.317256] ACPI: Dynamic OEM Table Load:
[ 0.317256] ACPI: SSDT 0xFFFF914B81883000 0008E7 (v02 PmRef ApIst 00003000 INTL 20191018)
[ 0.317256] ACPI: SSDT 0xFFFF914B8188D800 00048A (v02 PmRef ApHwp 00003000 INTL 20191018)
[ 0.317256] ACPI: SSDT 0xFFFF914B8188F000 0004D4 (v02 PmRef ApPsd 00003000 INTL 20191018)
[ 0.317256] ACPI: SSDT 0xFFFF914B8188C000 00048A (v02 PmRef ApCst 00003000 INTL 20191018)
[ 0.326352] ACPI: Interpreter enabled
[ 0.326393] ACPI: PM: (supports S0 S3 S4 S5)
[ 0.326394] ACPI: Using IOAPIC for interrupt routing
[ 0.326425] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.326426] PCI: Using E820 reservations for host bridge windows
[ 0.326837] ACPI: Enabled 9 GPEs in block 00 to 7F
[ 0.327247] ACPI: PM: Power Resource [PXP]
[ 0.327247] ACPI: PM: Power Resource [PUBS]
[ 0.329936] ACPI: PM: Power Resource [BTPR]
[ 0.334364] ACPI: PM: Power Resource [PXP]
[ 0.334596] ACPI: PM: Power Resource [MRST]
[ 0.334607] ACPI: PM: Power Resource [DRST]
[ 0.335438] ACPI: PM: Power Resource [PXP]
[ 0.339832] ACPI: PM: Power Resource [V0PR]
[ 0.339926] ACPI: PM: Power Resource [V1PR]
[ 0.340015] ACPI: PM: Power Resource [V2PR]
[ 0.341863] ACPI: PM: Power Resource [WRST]
[ 0.342027] ACPI: PM: Power Resource [TBT0]
[ 0.342054] ACPI: PM: Power Resource [TBT1]
[ 0.342077] ACPI: PM: Power Resource [D3C]
[ 0.575651] ACPI: PM: Power Resource [PIN]
[ 0.575662] ACPI: PM: Power Resource [PINP]
[ 0.576005] ACPI: PCI Root Bridge [PC00] (domain 0000 [bus 00-79])
[ 0.576010] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.581576] acpi PNP0A08:00: _OSC: platform does not support [AER]
[ 0.592513] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME PCIeCapability LTR DPC]
[ 0.592514] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.596481] PCI host bridge to bus 0000:00
[ 0.596482] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.596483] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.596484] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.596485] pci_bus 0000:00: root bus resource [mem 0xa0800000-0xbfffffff window]
[ 0.596485] pci_bus 0000:00: root bus resource [mem 0x4000000000-0x7fffffffff window]
[ 0.596487] pci_bus 0000:00: root bus resource [bus 00-79]
[ 0.711858] pci 0000:00:00.0: [8086:9a14] type 00 class 0x060000
[ 0.712195] pci 0000:00:02.0: [8086:9a49] type 00 class 0x030000
[ 0.712207] pci 0000:00:02.0: reg 0x10: [mem 0x603c000000-0x603cffffff 64bit]
[ 0.712216] pci 0000:00:02.0: reg 0x18: [mem 0x4000000000-0x400fffffff 64bit pref]
[ 0.712222] pci 0000:00:02.0: reg 0x20: [io 0x3000-0x303f]
[ 0.712246] pci 0000:00:02.0: BAR 2: assigned to efifb
[ 0.712247] pci 0000:00:02.0: DMAR: Skip IOMMU disabling for graphics
[ 0.712251] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.712289] pci 0000:00:02.0: reg 0x344: [mem 0x00000000-0x00ffffff 64bit]
[ 0.712291] pci 0000:00:02.0: VF(n) BAR0 space: [mem 0x00000000-0x06ffffff 64bit] (contains BAR0 for 7 VFs)
[ 0.712298] pci 0000:00:02.0: reg 0x34c: [mem 0x00000000-0x1fffffff 64bit pref]
[ 0.712300] pci 0000:00:02.0: VF(n) BAR2 space: [mem 0x00000000-0xdfffffff 64bit pref] (contains BAR2 for 7 VFs)
[ 0.712536] pci 0000:00:04.0: [8086:9a03] type 00 class 0x118000
[ 0.712556] pci 0000:00:04.0: reg 0x10: [mem 0x603d180000-0x603d19ffff 64bit]
[ 0.713210] pci 0000:00:06.0: [8086:9a09] type 01 class 0x060400
[ 0.713341] pci 0000:00:06.0: PME# supported from D0 D3hot D3cold
[ 0.713390] pci 0000:00:06.0: PTM enabled (root), 4ns granularity
[ 0.714427] pci 0000:00:07.0: [8086:9a25] type 01 class 0x060400
[ 0.714523] pci 0000:00:07.0: PME# supported from D0 D3hot D3cold
[ 0.714549] pci 0000:00:07.0: DPC: RP PIO log size 0 is invalid
[ 0.714555] fbcon: Taking over console
[ 0.715848] pci 0000:00:07.2: [8086:9a27] type 01 class 0x060400
[ 0.715939] pci 0000:00:07.2: PME# supported from D0 D3hot D3cold
[ 0.715965] pci 0000:00:07.2: DPC: RP PIO log size 0 is invalid
[ 0.717335] pci 0000:00:08.0: [8086:9a11] type 00 class 0x088000
[ 0.717349] pci 0000:00:08.0: reg 0x10: [mem 0x603d1db000-0x603d1dbfff 64bit]
[ 0.717503] pci 0000:00:0a.0: [8086:9a0d] type 00 class 0x118000
[ 0.717516] pci 0000:00:0a.0: reg 0x10: [mem 0x603d1c0000-0x603d1c7fff 64bit]
[ 0.717551] pci 0000:00:0a.0: enabling Extended Tags
[ 0.717711] pci 0000:00:0d.0: [8086:9a13] type 00 class 0x0c0330
[ 0.717731] pci 0000:00:0d.0: reg 0x10: [mem 0x603d1b0000-0x603d1bffff 64bit]
[ 0.717821] pci 0000:00:0d.0: PME# supported from D3hot D3cold
[ 0.718411] pci 0000:00:0d.2: [8086:9a1b] type 00 class 0x0c0340
[ 0.718424] pci 0000:00:0d.2: reg 0x10: [mem 0x603d140000-0x603d17ffff 64bit]
[ 0.718433] pci 0000:00:0d.2: reg 0x18: [mem 0x603d1da000-0x603d1dafff 64bit]
[ 0.718477] pci 0000:00:0d.2: supports D1 D2
[ 0.718478] pci 0000:00:0d.2: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.718633] pci 0000:00:0d.3: [8086:9a1d] type 00 class 0x0c0340
[ 0.718646] pci 0000:00:0d.3: reg 0x10: [mem 0x603d100000-0x603d13ffff 64bit]
[ 0.718655] pci 0000:00:0d.3: reg 0x18: [mem 0x603d1d9000-0x603d1d9fff 64bit]
[ 0.718698] pci 0000:00:0d.3: supports D1 D2
[ 0.718699] pci 0000:00:0d.3: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.719088] pci 0000:00:14.0: [8086:a0ed] type 00 class 0x0c0330
[ 0.719113] pci 0000:00:14.0: reg 0x10: [mem 0x603d1a0000-0x603d1affff 64bit]
[ 0.719232] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.719752] pci 0000:00:14.2: [8086:a0ef] type 00 class 0x050000
[ 0.719776] pci 0000:00:14.2: reg 0x10: [mem 0x603d1d0000-0x603d1d3fff 64bit]
[ 0.719793] pci 0000:00:14.2: reg 0x18: [mem 0x603d1d8000-0x603d1d8fff 64bit]
[ 0.720339] pci 0000:00:14.3: [8086:a0f0] type 00 class 0x028000
[ 0.720720] pci 0000:00:14.3: reg 0x10: [mem 0x603d1cc000-0x603d1cffff 64bit]
[ 0.722652] pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
[ 0.724153] pci 0000:00:15.0: [8086:a0e8] type 00 class 0x0c8000
[ 0.725000] pci 0000:00:15.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.729330] pci 0000:00:15.3: [8086:a0eb] type 00 class 0x0c8000
[ 0.730177] pci 0000:00:15.3: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.733888] pci 0000:00:16.0: [8086:a0e0] type 00 class 0x078000
[ 0.733911] pci 0000:00:16.0: reg 0x10: [mem 0x603d1d5000-0x603d1d5fff 64bit]
[ 0.734004] pci 0000:00:16.0: PME# supported from D3hot
[ 0.734505] pci 0000:00:1f.0: [8086:a082] type 00 class 0x060100
[ 0.734918] pci 0000:00:1f.3: [8086:a0c8] type 00 class 0x040380
[ 0.734989] pci 0000:00:1f.3: reg 0x10: [mem 0x603d1c8000-0x603d1cbfff 64bit]
[ 0.735085] pci 0000:00:1f.3: reg 0x20: [mem 0x603d000000-0x603d0fffff 64bit]
[ 0.735253] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ 0.735569] pci 0000:00:1f.4: [8086:a0a3] type 00 class 0x0c0500
[ 0.735603] pci 0000:00:1f.4: reg 0x10: [mem 0x603d1d4000-0x603d1d40ff 64bit]
[ 0.735629] pci 0000:00:1f.4: reg 0x20: [io 0xefa0-0xefbf]
[ 0.735938] pci 0000:00:1f.5: [8086:a0a4] type 00 class 0x0c8000
[ 0.735956] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[ 0.736437] pci 0000:04:00.0: [144d:a80a] type 00 class 0x010802
[ 0.736452] pci 0000:04:00.0: reg 0x10: [mem 0xbc200000-0xbc203fff 64bit]
[ 0.736638] pci 0000:00:06.0: PCI bridge to [bus 04]
[ 0.736641] pci 0000:00:06.0: bridge window [mem 0xbc200000-0xbc2fffff]
[ 0.736670] pci 0000:00:07.0: PCI bridge to [bus 20-49]
[ 0.736673] pci 0000:00:07.0: bridge window [mem 0xb0000000-0xbc1fffff]
[ 0.736676] pci 0000:00:07.0: bridge window [mem 0x6000000000-0x601bffffff 64bit pref]
[ 0.736736] pci 0000:50:00.0: [8086:15ef] type 01 class 0x060400
[ 0.736808] pci 0000:50:00.0: enabling Extended Tags
[ 0.736950] pci 0000:50:00.0: supports D1 D2
[ 0.736951] pci 0000:50:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.737118] pci 0000:50:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x4 link at 0000:00:07.2 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[ 0.747293] pci 0000:00:07.2: PCI bridge to [bus 50-79]
[ 0.747296] pci 0000:00:07.2: bridge window [mem 0xa2000000-0xae1fffff]
[ 0.747298] pci 0000:00:07.2: bridge window [mem 0x6020000000-0x603bffffff 64bit pref]
[ 0.747384] pci 0000:51:02.0: [8086:15ef] type 01 class 0x060400
[ 0.747459] pci 0000:51:02.0: enabling Extended Tags
[ 0.747600] pci 0000:51:02.0: supports D1 D2
[ 0.747600] pci 0000:51:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.747776] pci 0000:51:04.0: [8086:15ef] type 01 class 0x060400
[ 0.747851] pci 0000:51:04.0: enabling Extended Tags
[ 0.747995] pci 0000:51:04.0: supports D1 D2
[ 0.747996] pci 0000:51:04.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.748176] pci 0000:50:00.0: PCI bridge to [bus 51-79]
[ 0.748187] pci 0000:50:00.0: bridge window [mem 0xa2000000-0xae1fffff]
[ 0.748194] pci 0000:50:00.0: bridge window [mem 0x6020000000-0x603bffffff 64bit pref]
[ 0.748280] pci 0000:52:00.0: [8086:15f0] type 00 class 0x0c0330
[ 0.748308] pci 0000:52:00.0: reg 0x10: [mem 0xae100000-0xae10ffff]
[ 0.748408] pci 0000:52:00.0: enabling Extended Tags
[ 0.748562] pci 0000:52:00.0: supports D1 D2
[ 0.748562] pci 0000:52:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.748693] pci 0000:52:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x4 link at 0000:00:07.2 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[ 0.748760] pci 0000:51:02.0: PCI bridge to [bus 52]
[ 0.748770] pci 0000:51:02.0: bridge window [mem 0xae100000-0xae1fffff]
[ 0.748828] pci 0000:51:04.0: PCI bridge to [bus 53-79]
[ 0.748838] pci 0000:51:04.0: bridge window [mem 0xa2000000-0xae0fffff]
[ 0.748845] pci 0000:51:04.0: bridge window [mem 0x6020000000-0x603bffffff 64bit pref]
[ 0.753349] ACPI: EC: interrupt unblocked
[ 0.753350] ACPI: EC: event unblocked
[ 0.753381] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.753382] ACPI: EC: GPE=0x6e
[ 0.753383] ACPI: \_SB_.PC00.LPCB.EC__: Boot ECDT EC initialization complete
[ 0.753384] ACPI: \_SB_.PC00.LPCB.EC__: EC: Used to handle transactions and events
[ 0.753436] iommu: Default domain type: Translated
[ 0.753437] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.753532] SCSI subsystem initialized
[ 0.753956] libata version 3.00 loaded.
[ 0.753956] ACPI: bus type USB registered
[ 0.753956] usbcore: registered new interface driver usbfs
[ 0.753956] usbcore: registered new interface driver hub
[ 0.753956] usbcore: registered new device driver usb
[ 0.753961] pps_core: LinuxPPS API ver. 1 registered
[ 0.753962] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.753963] PTP clock support registered
[ 0.753967] EDAC MC: Ver: 3.0.0
[ 0.754297] Registered efivars operations
[ 0.754297] NetLabel: Initializing
[ 0.754297] NetLabel: domain hash size = 128
[ 0.754297] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.754297] NetLabel: unlabeled traffic allowed by default
[ 0.754297] mctp: management component transport protocol core
[ 0.754297] NET: Registered PF_MCTP protocol family
[ 0.754297] PCI: Using ACPI for IRQ routing
[ 0.782239] PCI: pci_cache_line_size set to 64 bytes
[ 0.782769] pci 0000:00:1f.5: can't claim BAR 0 [mem 0xfe010000-0xfe010fff]: no compatible bridge window
[ 0.783267] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[ 0.783268] e820: reserve RAM buffer [mem 0x8979a000-0x8bffffff]
[ 0.783269] e820: reserve RAM buffer [mem 0x89fe0000-0x8bffffff]
[ 0.783270] e820: reserve RAM buffer [mem 0x8ef6f000-0x8fffffff]
[ 0.783270] e820: reserve RAM buffer [mem 0x94c00000-0x97ffffff]
[ 0.783271] e820: reserve RAM buffer [mem 0x85f800000-0x85fffffff]
[ 0.783279] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.783279] pci 0000:00:02.0: vgaarb: bridge control possible
[ 0.783279] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=mem,locks=none
[ 0.783279] vgaarb: loaded
[ 0.784248] clocksource: Switched to clocksource tsc-early
[ 0.784345] VFS: Disk quotas dquot_6.6.0
[ 0.784355] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.784437] AppArmor: AppArmor Filesystem Enabled
[ 0.784455] pnp: PnP ACPI init
[ 0.786431] system 00:00: [io 0x0680-0x069f] has been reserved
[ 0.786434] system 00:00: [io 0x164e-0x164f] has been reserved
[ 0.786549] system 00:01: [io 0x1854-0x1857] has been reserved
[ 0.786604] pnp 00:04: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
[ 0.786636] system 00:04: [io 0x1800-0x189f] could not be reserved
[ 0.786637] system 00:04: [io 0x0800-0x087f] has been reserved
[ 0.786639] system 00:04: [io 0x0880-0x08ff] has been reserved
[ 0.786640] system 00:04: [io 0x0900-0x097f] has been reserved
[ 0.786641] system 00:04: [io 0x0980-0x09ff] has been reserved
[ 0.786642] system 00:04: [io 0x0a00-0x0a7f] has been reserved
[ 0.786644] system 00:04: [io 0x0a80-0x0aff] has been reserved
[ 0.786645] system 00:04: [io 0x0b00-0x0b7f] has been reserved
[ 0.786647] system 00:04: [io 0x0b80-0x0bff] has been reserved
[ 0.786648] system 00:04: [io 0x15e0-0x15ef] has been reserved
[ 0.786649] system 00:04: [io 0x1600-0x167f] could not be reserved
[ 0.786651] system 00:04: [io 0x1640-0x165f] could not be reserved
[ 0.786653] system 00:04: [mem 0xfed10000-0xfed13fff] has been reserved
[ 0.786655] system 00:04: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.786656] system 00:04: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.786658] system 00:04: [mem 0xfeb00000-0xfebfffff] has been reserved
[ 0.786660] system 00:04: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.786661] system 00:04: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 0.787423] pnp 00:05: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
[ 0.787447] system 00:05: [mem 0xfedc0000-0xfedc7fff] has been reserved
[ 0.787449] system 00:05: [mem 0xfeda0000-0xfeda0fff] has been reserved
[ 0.787451] system 00:05: [mem 0xfeda1000-0xfeda1fff] has been reserved
[ 0.787453] system 00:05: [mem 0xfed20000-0xfed7ffff] could not be reserved
[ 0.787454] system 00:05: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 0.787455] system 00:05: [mem 0xfed45000-0xfed8ffff] could not be reserved
[ 0.787457] system 00:05: [mem 0xfee00000-0xfeefffff] has been reserved
[ 0.787995] system 00:06: [io 0x1800-0x18fe] could not be reserved
[ 0.787998] system 00:06: [mem 0xfe000000-0xfe01ffff] has been reserved
[ 0.788000] system 00:06: [mem 0xfe04c000-0xfe04ffff] has been reserved
[ 0.788001] system 00:06: [mem 0xfe050000-0xfe0affff] has been reserved
[ 0.788003] system 00:06: [mem 0xfe0d0000-0xfe0fffff] has been reserved
[ 0.788005] system 00:06: [mem 0xfe200000-0xfe7fffff] has been reserved
[ 0.788006] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[ 0.788008] system 00:06: [mem 0xfd000000-0xfd68ffff] has been reserved
[ 0.788009] system 00:06: [mem 0xfd6b0000-0xfd6cffff] has been reserved
[ 0.788011] system 00:06: [mem 0xfd6f0000-0xfdffffff] has been reserved
[ 0.788299] system 00:07: [io 0x2000-0x20fe] has been reserved
[ 0.788836] pnp 00:09: disabling [mem 0x000c0000-0x000c3fff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
[ 0.788838] pnp 00:09: disabling [mem 0x000c8000-0x000cbfff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
[ 0.788840] pnp 00:09: disabling [mem 0x000d0000-0x000d3fff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
[ 0.788841] pnp 00:09: disabling [mem 0x000d8000-0x000dbfff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
[ 0.788843] pnp 00:09: disabling [mem 0x00000000-0x0009ffff] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit]
[ 0.788845] pnp 00:09: disabling [mem 0x000c0000-0x000c3fff disabled] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit]
[ 0.788847] pnp 00:09: disabling [mem 0x000c8000-0x000cbfff disabled] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit]
[ 0.788848] pnp 00:09: disabling [mem 0x000d0000-0x000d3fff disabled] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit]
[ 0.788850] pnp 00:09: disabling [mem 0x000d8000-0x000dbfff disabled] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit]
[ 0.788852] pnp 00:09: disabling [mem 0x000e0000-0x000e3fff] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit]
[ 0.788854] pnp 00:09: disabling [mem 0x000e8000-0x000ebfff] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit]
[ 0.788855] pnp 00:09: disabling [mem 0x000f0000-0x000fffff] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit]
[ 0.788857] pnp 00:09: disabling [mem 0x00100000-0xa07fffff] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit]
[ 0.788858] pnp 00:09: disabling [mem 0x00000000-0x0009ffff disabled] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
[ 0.788860] pnp 00:09: disabling [mem 0x000c0000-0x000c3fff disabled] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
[ 0.788862] pnp 00:09: disabling [mem 0x000c8000-0x000cbfff disabled] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
[ 0.788864] pnp 00:09: disabling [mem 0x000d0000-0x000d3fff disabled] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
[ 0.788865] pnp 00:09: disabling [mem 0x000d8000-0x000dbfff disabled] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
[ 0.788867] pnp 00:09: disabling [mem 0x000e0000-0x000e3fff disabled] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
[ 0.788869] pnp 00:09: disabling [mem 0x000e8000-0x000ebfff disabled] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
[ 0.788870] pnp 00:09: disabling [mem 0x000f0000-0x000fffff disabled] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
[ 0.788872] pnp 00:09: disabling [mem 0x00100000-0xa07fffff disabled] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
[ 0.788892] system 00:09: [mem 0xfec00000-0xfed3ffff] could not be reserved
[ 0.788894] system 00:09: [mem 0xfed4c000-0xffffffff] could not be reserved
[ 0.789168] pnp: PnP ACPI: found 10 devices
[ 0.794398] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.794439] NET: Registered PF_INET protocol family
[ 0.794579] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.796427] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.796481] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.796635] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.796866] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.796910] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.797024] MPTCP token hash table entries: 32768 (order: 7, 786432 bytes, linear)
[ 0.797115] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.797182] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.797234] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.797238] NET: Registered PF_XDP protocol family
[ 0.797242] pci 0000:00:07.0: bridge window [io 0x1000-0x0fff] to [bus 20-49] add_size 1000
[ 0.797244] pci 0000:51:04.0: bridge window [io 0x1000-0x0fff] to [bus 53-79] add_size 1000
[ 0.797246] pci 0000:50:00.0: bridge window [io 0x1000-0x0fff] to [bus 51-79] add_size 1000
[ 0.797247] pci 0000:00:07.2: bridge window [io 0x1000-0x0fff] to [bus 50-79] add_size 2000
[ 0.797252] clipped [mem size 0x00000000 64bit pref] to [mem size 0xfffffffffffa0000 64bit pref] for e820 entry [mem 0x0009f000-0x000fffff]
[ 0.797255] pci 0000:00:02.0: BAR 9: assigned [mem 0x4020000000-0x40ffffffff 64bit pref]
[ 0.797270] clipped [mem size 0x00000000 64bit] to [mem size 0xfffffffffffa0000 64bit] for e820 entry [mem 0x0009f000-0x000fffff]
[ 0.797272] pci 0000:00:02.0: BAR 7: assigned [mem 0x4010000000-0x4016ffffff 64bit]
[ 0.797274] pci 0000:00:07.0: BAR 13: assigned [io 0x4000-0x4fff]
[ 0.797275] pci 0000:00:07.2: BAR 13: assigned [io 0x5000-0x6fff]
[ 0.797276] clipped [mem size 0x00000000 64bit] to [mem size 0xfffffffffffa0000 64bit] for e820 entry [mem 0x0009f000-0x000fffff]
[ 0.797277] pci 0000:00:15.0: BAR 0: assigned [mem 0x4017000000-0x4017000fff 64bit]
[ 0.797689] clipped [mem size 0x00000000 64bit] to [mem size 0xfffffffffffa0000 64bit] for e820 entry [mem 0x0009f000-0x000fffff]
[ 0.797690] pci 0000:00:15.3: BAR 0: assigned [mem 0x4017001000-0x4017001fff 64bit]
[ 0.798088] clipped [mem size 0x00020000] to [mem size 0xfffffffffffc0000] for e820 entry [mem 0x0009f000-0x000fffff]
[ 0.798089] pci 0000:00:1f.5: BAR 0: assigned [mem 0xa0800000-0xa0800fff]
[ 0.798116] pci 0000:00:06.0: PCI bridge to [bus 04]
[ 0.798125] pci 0000:00:06.0: bridge window [mem 0xbc200000-0xbc2fffff]
[ 0.798133] pci 0000:00:07.0: PCI bridge to [bus 20-49]
[ 0.798134] pci 0000:00:07.0: bridge window [io 0x4000-0x4fff]
[ 0.798137] pci 0000:00:07.0: bridge window [mem 0xb0000000-0xbc1fffff]
[ 0.798139] pci 0000:00:07.0: bridge window [mem 0x6000000000-0x601bffffff 64bit pref]
[ 0.798142] pci 0000:50:00.0: BAR 13: assigned [io 0x5000-0x5fff]
[ 0.798144] pci 0000:51:04.0: BAR 13: assigned [io 0x5000-0x5fff]
[ 0.798145] pci 0000:51:02.0: PCI bridge to [bus 52]
[ 0.798153] pci 0000:51:02.0: bridge window [mem 0xae100000-0xae1fffff]
[ 0.798163] pci 0000:51:04.0: PCI bridge to [bus 53-79]
[ 0.798166] pci 0000:51:04.0: bridge window [io 0x5000-0x5fff]
[ 0.798171] pci 0000:51:04.0: bridge window [mem 0xa2000000-0xae0fffff]
[ 0.798175] pci 0000:51:04.0: bridge window [mem 0x6020000000-0x603bffffff 64bit pref]
[ 0.798183] pci 0000:50:00.0: PCI bridge to [bus 51-79]
[ 0.798185] pci 0000:50:00.0: bridge window [io 0x5000-0x5fff]
[ 0.798190] pci 0000:50:00.0: bridge window [mem 0xa2000000-0xae1fffff]
[ 0.798194] pci 0000:50:00.0: bridge window [mem 0x6020000000-0x603bffffff 64bit pref]
[ 0.798202] pci 0000:00:07.2: PCI bridge to [bus 50-79]
[ 0.798203] pci 0000:00:07.2: bridge window [io 0x5000-0x6fff]
[ 0.798205] pci 0000:00:07.2: bridge window [mem 0xa2000000-0xae1fffff]
[ 0.798207] pci 0000:00:07.2: bridge window [mem 0x6020000000-0x603bffffff 64bit pref]
[ 0.798210] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.798211] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.798212] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.798213] pci_bus 0000:00: resource 7 [mem 0xa0800000-0xbfffffff window]
[ 0.798214] pci_bus 0000:00: resource 8 [mem 0x4000000000-0x7fffffffff window]
[ 0.798214] pci_bus 0000:04: resource 1 [mem 0xbc200000-0xbc2fffff]
[ 0.798215] pci_bus 0000:20: resource 0 [io 0x4000-0x4fff]
[ 0.798216] pci_bus 0000:20: resource 1 [mem 0xb0000000-0xbc1fffff]
[ 0.798216] pci_bus 0000:20: resource 2 [mem 0x6000000000-0x601bffffff 64bit pref]
[ 0.798217] pci_bus 0000:50: resource 0 [io 0x5000-0x6fff]
[ 0.798218] pci_bus 0000:50: resource 1 [mem 0xa2000000-0xae1fffff]
[ 0.798219] pci_bus 0000:50: resource 2 [mem 0x6020000000-0x603bffffff 64bit pref]
[ 0.798219] pci_bus 0000:51: resource 0 [io 0x5000-0x5fff]
[ 0.798220] pci_bus 0000:51: resource 1 [mem 0xa2000000-0xae1fffff]
[ 0.798221] pci_bus 0000:51: resource 2 [mem 0x6020000000-0x603bffffff 64bit pref]
[ 0.798221] pci_bus 0000:52: resource 1 [mem 0xae100000-0xae1fffff]
[ 0.798222] pci_bus 0000:53: resource 0 [io 0x5000-0x5fff]
[ 0.798223] pci_bus 0000:53: resource 1 [mem 0xa2000000-0xae0fffff]
[ 0.798223] pci_bus 0000:53: resource 2 [mem 0x6020000000-0x603bffffff 64bit pref]
[ 0.799417] PCI: CLS 0 bytes, default 64
[ 0.799421] DMAR: Intel-IOMMU force enabled due to platform opt in
[ 0.799427] DMAR: No ATSR found
[ 0.799428] DMAR: No SATC found
[ 0.799430] DMAR: IOMMU feature fl1gp_support inconsistent
[ 0.799431] DMAR: IOMMU feature pgsel_inv inconsistent
[ 0.799432] DMAR: IOMMU feature nwfs inconsistent
[ 0.799432] DMAR: IOMMU feature dit inconsistent
[ 0.799433] DMAR: IOMMU feature sc_support inconsistent
[ 0.799434] DMAR: IOMMU feature dev_iotlb_support inconsistent
[ 0.799435] DMAR: dmar2: Using Queued invalidation
[ 0.799438] DMAR: dmar1: Using Queued invalidation
[ 0.799440] DMAR: dmar0: Using Queued invalidation
[ 0.799441] DMAR: dmar3: Using Queued invalidation
[ 0.799454] Trying to unpack rootfs image as initramfs...
[ 0.799571] pci 0000:00:00.0: Adding to iommu group 0
[ 0.799579] pci 0000:00:02.0: Adding to iommu group 1
[ 0.799587] pci 0000:00:04.0: Adding to iommu group 2
[ 0.799602] pci 0000:00:06.0: Adding to iommu group 3
[ 0.799611] pci 0000:00:07.0: Adding to iommu group 4
[ 0.799619] pci 0000:00:07.2: Adding to iommu group 5
[ 0.799627] pci 0000:00:08.0: Adding to iommu group 6
[ 0.799634] pci 0000:00:0a.0: Adding to iommu group 7
[ 0.799648] pci 0000:00:0d.0: Adding to iommu group 8
[ 0.799655] pci 0000:00:0d.2: Adding to iommu group 8
[ 0.799662] pci 0000:00:0d.3: Adding to iommu group 8
[ 0.799675] pci 0000:00:14.0: Adding to iommu group 9
[ 0.799682] pci 0000:00:14.2: Adding to iommu group 9
[ 0.799690] pci 0000:00:14.3: Adding to iommu group 10
[ 0.799702] pci 0000:00:15.0: Adding to iommu group 11
[ 0.799710] pci 0000:00:15.3: Adding to iommu group 11
[ 0.799720] pci 0000:00:16.0: Adding to iommu group 12
[ 0.799737] pci 0000:00:1f.0: Adding to iommu group 13
[ 0.799745] pci 0000:00:1f.3: Adding to iommu group 13
[ 0.799752] pci 0000:00:1f.4: Adding to iommu group 13
[ 0.799760] pci 0000:00:1f.5: Adding to iommu group 13
[ 0.799776] pci 0000:04:00.0: Adding to iommu group 14
[ 0.799785] pci 0000:50:00.0: Adding to iommu group 15
[ 0.799794] pci 0000:51:02.0: Adding to iommu group 16
[ 0.799803] pci 0000:51:04.0: Adding to iommu group 17
[ 0.799818] pci 0000:52:00.0: Adding to iommu group 18
[ 0.800060] DMAR: Intel(R) Virtualization Technology for Directed I/O
[ 0.800061] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.800062] software IO TLB: mapped [mem 0x000000008579a000-0x000000008979a000] (64MB)
[ 0.800103] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x28680fa287f, max_idle_ns: 440795281151 ns
[ 0.800139] clocksource: Switched to clocksource tsc
[ 0.800156] platform rtc_cmos: registered platform RTC device (no PNP device found)
[ 0.800618] Initialise system trusted keyrings
[ 0.800624] Key type blacklist registered
[ 0.800642] workingset: timestamp_bits=41 max_order=23 bucket_order=0
[ 0.801165] zbud: loaded
[ 0.801317] integrity: Platform Keyring initialized
[ 0.801319] integrity: Machine keyring initialized
[ 0.807826] Key type asymmetric registered
[ 0.807828] Asymmetric key parser 'x509' registered
[ 0.860665] Freeing initrd memory: 23700K
[ 0.862055] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[ 0.862069] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.862087] io scheduler mq-deadline registered
[ 0.862088] io scheduler kyber registered
[ 0.862103] io scheduler bfq registered
[ 0.870756] pcieport 0000:00:06.0: PME: Signaling with IRQ 124
[ 0.870929] pcieport 0000:00:07.0: PME: Signaling with IRQ 125
[ 0.870941] pcieport 0000:00:07.0: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.871098] pcieport 0000:00:07.2: PME: Signaling with IRQ 126
[ 0.871109] pcieport 0000:00:07.2: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.871611] pcieport 0000:51:04.0: pciehp: Slot #4 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.871844] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.872032] Monitor-Mwait will be used to enter C-1 state
[ 0.872042] Monitor-Mwait will be used to enter C-2 state
[ 0.872045] Monitor-Mwait will be used to enter C-3 state
[ 0.872047] ACPI: \_SB_.PR00: Found 3 idle states
[ 0.873252] ACPI: AC: AC Adapter [AC] (on-line)
[ 0.873296] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[ 0.873320] ACPI: button: Sleep Button [SLPB]
[ 0.873337] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
[ 0.873351] ACPI: button: Lid Switch [LID]
[ 0.873365] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 0.873373] ACPI: button: Power Button [PWRB]
[ 0.890337] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.890339] ACPI: thermal: Thermal Zone [THM0] (52 C)
[ 0.890799] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.892376] hpet_acpi_add: no address or irqs in _CRS
[ 0.892397] Non-volatile memory driver v1.3
[ 0.892397] Linux agpgart interface v0.103
[ 0.892398] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[ 0.893238] ACPI: bus type drm_connector registered
[ 0.894623] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.894625] ehci-pci: EHCI PCI platform driver
[ 0.894629] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.894630] ohci-pci: OHCI PCI platform driver
[ 0.894634] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.894651] usbcore: registered new interface driver usbserial_generic
[ 0.894654] usbserial: USB Serial support registered for generic
[ 0.894724] rtc_cmos rtc_cmos: RTC can wake from S4
[ 0.896972] rtc_cmos rtc_cmos: registered as rtc0
[ 0.897341] rtc_cmos rtc_cmos: setting system clock to 2022-09-23T07:30:52 UTC (1663918252)
[ 0.897349] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
[ 0.897822] intel_pstate: Intel P-state driver initializing
[ 0.898267] intel_pstate: HWP enabled
[ 0.898393] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.898531] efifb: probing for efifb
[ 0.898537] efifb: framebuffer at 0x4000000000, using 9024k, total 9024k
[ 0.898538] efifb: mode is 1920x1200x32, linelength=7680, pages=1
[ 0.898539] efifb: scrolling: redraw
[ 0.898539] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.898605] Console: switching to colour frame buffer device 240x75
[ 0.900934] fb0: EFI VGA frame buffer device
[ 0.900964] hid: raw HID events driver (C) Jiri Kosina
[ 0.901054] intel_pmc_core INT33A1:00: initialized
[ 0.901107] drop_monitor: Initializing network drop monitor service
[ 0.907955] Initializing XFRM netlink socket
[ 0.908007] NET: Registered PF_INET6 protocol family
[ 0.910015] Segment Routing with IPv6
[ 0.910016] RPL Segment Routing with IPv6
[ 0.910022] In-situ OAM (IOAM) with IPv6
[ 0.910034] NET: Registered PF_PACKET protocol family
[ 0.912167] microcode: sig=0x806c1, pf=0x80, revision=0xa4
[ 0.912210] microcode: Microcode Update Driver: v2.2.
[ 0.912480] resctrl: L2 allocation detected
[ 0.912484] IPI shorthand broadcast: enabled
[ 0.912497] sched_clock: Marking stable (887935963, 24537185)->(947738355, -35265207)
[ 0.913773] registered taskstats version 1
[ 0.915109] Loading compiled-in X.509 certificates
[ 0.917292] Loaded X.509 cert 'Build time autogenerated kernel key: 3b6f14af699153518e62defe5abd4c2cfe5f18e7'
[ 0.918572] zswap: loaded using pool zstd/z3fold
[ 0.918907] Key type ._fscrypt registered
[ 0.918907] Key type .fscrypt registered
[ 0.918908] Key type fscrypt-provisioning registered
[ 0.918930] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.919724] integrity: Loading X.509 certificate: UEFI:db
[ 0.919736] integrity: Loaded X.509 cert 'Lenovo Ltd.: ThinkPad Product CA 2012: 838b1f54c1550463f45f98700640f11069265949'
[ 0.919736] integrity: Loading X.509 certificate: UEFI:db
[ 0.919744] integrity: Loaded X.509 cert 'Lenovo UEFI CA 2014: 4b91a68732eaefdd2c8ffffc6b027ec3449e9c8f'
[ 0.919744] integrity: Loading X.509 certificate: UEFI:db
[ 0.919758] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
[ 0.919758] integrity: Loading X.509 certificate: UEFI:db
[ 0.919767] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
[ 0.920359] blacklist: Problem blacklisting hash (-13)
[ 0.920372] blacklist: Problem blacklisting hash (-13)
[ 0.920383] blacklist: Problem blacklisting hash (-13)
[ 0.920394] blacklist: Problem blacklisting hash (-13)
[ 0.920405] blacklist: Problem blacklisting hash (-13)
[ 0.920415] blacklist: Problem blacklisting hash (-13)
[ 0.920425] blacklist: Problem blacklisting hash (-13)
[ 0.920437] blacklist: Problem blacklisting hash (-13)
[ 0.920447] blacklist: Problem blacklisting hash (-13)
[ 0.920457] blacklist: Problem blacklisting hash (-13)
[ 0.920468] blacklist: Problem blacklisting hash (-13)
[ 0.920478] blacklist: Problem blacklisting hash (-13)
[ 0.920489] blacklist: Problem blacklisting hash (-13)
[ 0.920500] blacklist: Problem blacklisting hash (-13)
[ 0.920510] blacklist: Problem blacklisting hash (-13)
[ 0.920520] blacklist: Problem blacklisting hash (-13)
[ 0.920531] blacklist: Problem blacklisting hash (-13)
[ 0.920542] blacklist: Problem blacklisting hash (-13)
[ 0.920554] blacklist: Problem blacklisting hash (-13)
[ 0.920564] blacklist: Problem blacklisting hash (-13)
[ 0.920574] blacklist: Problem blacklisting hash (-13)
[ 0.920584] blacklist: Problem blacklisting hash (-13)
[ 0.920597] blacklist: Problem blacklisting hash (-13)
[ 0.920607] blacklist: Problem blacklisting hash (-13)
[ 0.920618] blacklist: Problem blacklisting hash (-13)
[ 0.920628] blacklist: Problem blacklisting hash (-13)
[ 0.920638] blacklist: Problem blacklisting hash (-13)
[ 0.920757] blacklist: Problem blacklisting hash (-13)
[ 0.920766] blacklist: Problem blacklisting hash (-13)
[ 0.920801] blacklist: Problem blacklisting hash (-13)
[ 0.920826] blacklist: Problem blacklisting hash (-13)
[ 0.920860] blacklist: Problem blacklisting hash (-13)
[ 0.920882] blacklist: Problem blacklisting hash (-13)
[ 0.922608] PM: Magic number: 6:964:521
[ 0.922660] acpi LNXPOWER:05: hash matches
[ 0.922818] RAS: Correctable Errors collector initialized.
[ 1.024994] ACPI: battery: Slot [BAT0] (battery present)
[ 1.029769] Freeing unused decrypted memory: 2036K
[ 1.030131] Freeing unused kernel image (initmem) memory: 2116K
[ 1.030133] Write protecting the kernel read-only data: 30720k
[ 1.030726] Freeing unused kernel image (text/rodata gap) memory: 2040K
[ 1.030948] Freeing unused kernel image (rodata/data gap) memory: 1044K
[ 1.036374] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.036377] rodata_test: all tests were successful
[ 1.036380] Run /init as init process
[ 1.036381] with arguments:
[ 1.036381] /init
[ 1.036382] with environment:
[ 1.036382] HOME=/
[ 1.036382] TERM=linux
[ 1.036383] BOOT_IMAGE=/vmlinuz-5.19-x86_64
[ 1.036383] cryptdevice=UUID=e16b5219-<filter>:luks-e16b5219-<filter>
[ 1.189837] i8042: PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,12
[ 1.190256] i8042: Warning: Keylock active
[ 1.192006] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.192036] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.193454] xhci_hcd 0000:00:0d.0: xHCI Host Controller
[ 1.193461] xhci_hcd 0000:00:0d.0: new USB bus registered, assigned bus number 1
[ 1.194523] xhci_hcd 0000:00:0d.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000000200009810
[ 1.194714] xhci_hcd 0000:00:0d.0: xHCI Host Controller
[ 1.194715] xhci_hcd 0000:00:0d.0: new USB bus registered, assigned bus number 2
[ 1.194716] xhci_hcd 0000:00:0d.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.194740] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.19
[ 1.194741] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.194742] usb usb1: Product: xHCI Host Controller
[ 1.194743] usb usb1: Manufacturer: Linux 5.19.7-1-MANJARO xhci-hcd
[ 1.194744] usb usb1: SerialNumber: 0000:00:0d.0
[ 1.194799] hub 1-0:1.0: USB hub found
[ 1.194805] hub 1-0:1.0: 1 port detected
[ 1.195100] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.19
[ 1.195101] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.195102] usb usb2: Product: xHCI Host Controller
[ 1.195103] usb usb2: Manufacturer: Linux 5.19.7-1-MANJARO xhci-hcd
[ 1.195103] usb usb2: SerialNumber: 0000:00:0d.0
[ 1.195141] hub 2-0:1.0: USB hub found
[ 1.195148] hub 2-0:1.0: 4 ports detected
[ 1.195961] cryptd: max_cpu_qlen set to 1000
[ 1.195990] usb: port power management may be unreliable
[ 1.196266] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.196271] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 1.197422] xhci_hcd 0000:00:14.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000000000009810
[ 1.197720] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.197723] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[ 1.197724] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.197772] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.19
[ 1.197774] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.197775] usb usb3: Product: xHCI Host Controller
[ 1.197777] usb usb3: Manufacturer: Linux 5.19.7-1-MANJARO xhci-hcd
[ 1.197778] usb usb3: SerialNumber: 0000:00:14.0
[ 1.197841] hub 3-0:1.0: USB hub found
[ 1.197878] hub 3-0:1.0: 12 ports detected
[ 1.199572] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.19
[ 1.199574] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.199575] usb usb4: Product: xHCI Host Controller
[ 1.199577] usb usb4: Manufacturer: Linux 5.19.7-1-MANJARO xhci-hcd
[ 1.199578] usb usb4: SerialNumber: 0000:00:14.0
[ 1.199795] hub 4-0:1.0: USB hub found
[ 1.199912] hub 4-0:1.0: 4 ports detected
[ 1.200797] xhci_hcd 0000:52:00.0: xHCI Host Controller
[ 1.200801] xhci_hcd 0000:52:00.0: new USB bus registered, assigned bus number 5
[ 1.202014] xhci_hcd 0000:52:00.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000200009810
[ 1.202324] xhci_hcd 0000:52:00.0: xHCI Host Controller
[ 1.202326] xhci_hcd 0000:52:00.0: new USB bus registered, assigned bus number 6
[ 1.202328] xhci_hcd 0000:52:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.202356] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.19
[ 1.202358] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.202359] usb usb5: Product: xHCI Host Controller
[ 1.202361] usb usb5: Manufacturer: Linux 5.19.7-1-MANJARO xhci-hcd
[ 1.202362] usb usb5: SerialNumber: 0000:52:00.0
[ 1.202936] hub 5-0:1.0: USB hub found
[ 1.202948] hub 5-0:1.0: 2 ports detected
[ 1.203549] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.19
[ 1.203670] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.203671] usb usb6: Product: xHCI Host Controller
[ 1.203673] usb usb6: Manufacturer: Linux 5.19.7-1-MANJARO xhci-hcd
[ 1.203674] usb usb6: SerialNumber: 0000:52:00.0
[ 1.203974] hub 6-0:1.0: USB hub found
[ 1.203985] hub 6-0:1.0: 2 ports detected
[ 1.204799] AVX2 version of gcm_enc/dec engaged.
[ 1.204824] AES CTR mode by8 optimization enabled
[ 1.212863] nvme 0000:04:00.0: platform quirk: setting simple suspend
[ 1.225668] nvme nvme0: pci function 0000:04:00.0
[ 1.230236] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 1.237746] nvme nvme0: Shutdown timeout set to 10 seconds
[ 1.240337] nvme nvme0: 8/0/0 default/read/poll queues
[ 1.242178] nvme0n1: p1 p2 p3 p4 p5 p6
[ 1.394896] device-mapper: uevent: version 1.0.3
[ 1.394995] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
[ 1.415479] Key type encrypted registered
[ 1.454116] usb 5-2: new high-speed USB device number 2 using xhci_hcd
[ 1.454154] usb 3-3: new full-speed USB device number 2 using xhci_hcd
[ 1.596349] usb 3-3: New USB device found, idVendor=06cb, idProduct=00fc, bcdDevice= 0.00
[ 1.596357] usb 3-3: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 1.596360] usb 3-3: SerialNumber: <filter>
[ 1.597468] usb 5-2: New USB device found, idVendor=17ef, idProduct=3080, bcdDevice=51.63
[ 1.597475] usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.597477] usb 5-2: Product: USB2.0 Hub
[ 1.597480] usb 5-2: Manufacturer: VIA Labs, Inc.
[ 1.597482] usb 5-2: SerialNumber: 00000000000000000000001
[ 1.599005] hub 5-2:1.0: USB hub found
[ 1.599220] hub 5-2:1.0: 5 ports detected
[ 1.720756] usb 3-4: new high-speed USB device number 3 using xhci_hcd
[ 1.723667] usb 6-2: new SuperSpeed Plus Gen 2x1 USB device number 2 using xhci_hcd
[ 1.741215] usb 6-2: New USB device found, idVendor=17ef, idProduct=307f, bcdDevice=51.63
[ 1.741223] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.741226] usb 6-2: Product: USB3.1 Hub
[ 1.741229] usb 6-2: Manufacturer: VIA Labs, Inc.
[ 1.741231] usb 6-2: SerialNumber: 00000000000000000000001
[ 1.744440] hub 6-2:1.0: USB hub found
[ 1.744693] hub 6-2:1.0: 4 ports detected
[ 1.863360] usb 3-4: New USB device found, idVendor=04f2, idProduct=b6ea, bcdDevice=60.18
[ 1.863368] usb 3-4: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 1.863371] usb 3-4: Product: Integrated Camera
[ 1.863374] usb 3-4: Manufacturer: Chicony Electronics Co.,Ltd.
[ 1.863376] usb 3-4: SerialNumber: 0001
[ 1.987421] usb 3-10: new full-speed USB device number 4 using xhci_hcd
[ 2.129835] usb 3-10: New USB device found, idVendor=8087, idProduct=0026, bcdDevice= 0.02
[ 2.129844] usb 3-10: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.320748] usb 5-2.1: new high-speed USB device number 3 using xhci_hcd
[ 2.465479] usb 5-2.1: New USB device found, idVendor=17ef, idProduct=3080, bcdDevice=51.33
[ 2.465488] usb 5-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.465491] usb 5-2.1: Product: USB2.0 Hub
[ 2.465493] usb 5-2.1: Manufacturer: VIA Labs, Inc.
[ 2.465495] usb 5-2.1: SerialNumber: 00000000000000000000001
[ 2.467276] hub 5-2.1:1.0: USB hub found
[ 2.467569] hub 5-2.1:1.0: 4 ports detected
[ 2.561957] usb 6-2.1: new SuperSpeed Plus Gen 2x1 USB device number 3 using xhci_hcd
[ 2.595628] usb 6-2.1: New USB device found, idVendor=17ef, idProduct=307f, bcdDevice=51.33
[ 2.595637] usb 6-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.595640] usb 6-2.1: Product: USB3.1 Hub
[ 2.595643] usb 6-2.1: Manufacturer: VIA Labs, Inc.
[ 2.595645] usb 6-2.1: SerialNumber: 00000000000000000000001
[ 2.646734] hub 6-2.1:1.0: USB hub found
[ 2.647076] hub 6-2.1:1.0: 4 ports detected
[ 2.717415] usb 5-2.3: new high-speed USB device number 4 using xhci_hcd
[ 2.875293] usb 5-2.3: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 1.17
[ 2.875302] usb 5-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.875305] usb 5-2.3: Product: 4-Port USB 2.0 Hub
[ 2.875308] usb 5-2.3: Manufacturer: Generic
[ 2.877903] hub 5-2.3:1.0: USB hub found
[ 2.878995] hub 5-2.3:1.0: 4 ports detected
[ 2.938166] usb 6-2.3: new SuperSpeed USB device number 4 using xhci_hcd
[ 2.969321] usb 6-2.3: New USB device found, idVendor=0bda, idProduct=0411, bcdDevice= 1.17
[ 2.969330] usb 6-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.969333] usb 6-2.3: Product: 4-Port USB 3.0 Hub
[ 2.969336] usb 6-2.3: Manufacturer: Generic
[ 2.979549] hub 6-2.3:1.0: USB hub found
[ 2.980877] hub 6-2.3:1.0: 4 ports detected
[ 3.034083] usb 5-2.5: new high-speed USB device number 5 using xhci_hcd
[ 3.126576] usb 5-2.5: New USB device found, idVendor=2109, idProduct=8887, bcdDevice=31.81
[ 3.126584] usb 5-2.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.126587] usb 5-2.5: Product: 40AN
[ 3.126589] usb 5-2.5: Manufacturer: LENOVO
[ 3.126591] usb 5-2.5: SerialNumber: <filter>
[ 3.247374] usb 5-2.1.1: new high-speed USB device number 6 using xhci_hcd
[ 3.403675] usb 5-2.1.1: New USB device found, idVendor=17ef, idProduct=3081, bcdDevice=60.60
[ 3.403684] usb 5-2.1.1: New USB device strings: Mfr=10, Product=11, SerialNumber=0
[ 3.403688] usb 5-2.1.1: Product: USB2.0 HUB
[ 3.403690] usb 5-2.1.1: Manufacturer: Lenovo
[ 3.406424] hub 5-2.1.1:1.0: USB hub found
[ 3.406747] hub 5-2.1.1:1.0: 2 ports detected
[ 3.477424] usb 5-2.3.1: new high-speed USB device number 7 using xhci_hcd
[ 3.599485] usb 5-2.3.1: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 1.17
[ 3.599494] usb 5-2.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.599497] usb 5-2.3.1: Product: 4-Port USB 2.0 Hub
[ 3.599500] usb 5-2.3.1: Manufacturer: Generic
[ 3.602857] hub 5-2.3.1:1.0: USB hub found
[ 3.604949] hub 5-2.3.1:1.0: 4 ports detected
[ 3.664259] usb 6-2.1.2: new SuperSpeed USB device number 5 using xhci_hcd
[ 3.682241] usb 6-2.1.2: New USB device found, idVendor=17ef, idProduct=3082, bcdDevice=31.01
[ 3.682250] usb 6-2.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 3.682253] usb 6-2.1.2: Product: ThinkPad TBT 3 Dock
[ 3.682255] usb 6-2.1.2: Manufacturer: Realtek
[ 3.682257] usb 6-2.1.2: SerialNumber: <filter>
[ 3.754799] usb 6-2.3.1: new SuperSpeed USB device number 6 using xhci_hcd
[ 3.787085] usb 6-2.3.1: New USB device found, idVendor=0bda, idProduct=0411, bcdDevice= 1.17
[ 3.787094] usb 6-2.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.787097] usb 6-2.3.1: Product: 4-Port USB 3.0 Hub
[ 3.787099] usb 6-2.3.1: Manufacturer: Generic
[ 3.795374] hub 6-2.3.1:1.0: USB hub found
[ 3.796623] hub 6-2.3.1:1.0: 4 ports detected
[ 3.850753] usb 5-2.1.1.2: new full-speed USB device number 8 using xhci_hcd
[ 4.037407] usb 5-2.3.1.1: new high-speed USB device number 9 using xhci_hcd
[ 4.195446] usb 5-2.1.1.2: New USB device found, idVendor=17ef, idProduct=30cf, bcdDevice= 0.95
[ 4.195454] usb 5-2.1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.195457] usb 5-2.1.1.2: Product: ThinkPad Thunderbolt 3 Dock USB Audio
[ 4.195460] usb 5-2.1.1.2: Manufacturer: Lenovo
[ 4.195462] usb 5-2.1.1.2: SerialNumber: 000000000000
[ 4.257586] hid-generic 0003:17EF:30CF.0001: hiddev96,hidraw0: USB HID v1.11 Device [Lenovo ThinkPad Thunderbolt 3 Dock USB Audio] on usb-0000:52:00.0-2.1.1.2/input3
[ 4.257665] usbcore: registered new interface driver usbhid
[ 4.257669] usbhid: USB HID core driver
[ 4.447902] usb 5-2.3.1.1: New USB device found, idVendor=0bda, idProduct=4938, bcdDevice= 0.04
[ 4.447911] usb 5-2.3.1.1: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 4.447914] usb 5-2.3.1.1: Product: Realtek Audio USB
[ 4.447916] usb 5-2.3.1.1: Manufacturer: Generic
[ 4.447918] usb 5-2.3.1.1: SerialNumber: <filter>
[ 4.530777] usb 5-2.3.1.2: new full-speed USB device number 10 using xhci_hcd
[ 4.622962] usb 5-2.3.1.2: New USB device found, idVendor=0416, idProduct=0123, bcdDevice= 0.00
[ 4.622971] usb 5-2.3.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.622974] usb 5-2.3.1.2: Product: Ducky One2 SF RGB
[ 4.622976] usb 5-2.3.1.2: Manufacturer: Ducky
[ 4.622978] usb 5-2.3.1.2: SerialNumber: <filter>
[ 4.640067] input: Ducky Ducky One2 SF RGB as /devices/pci0000:00/0000:00:07.2/0000:50:00.0/0000:51:02.0/0000:52:00.0/usb5/5-2/5-2.3/5-2.3.1/5-2.3.1.2/5-2.3.1.2:1.0/0003:0416:0123.0002/input/input5
[ 4.694548] hid-generic 0003:0416:0123.0002: input,hidraw1: USB HID v1.10 Keyboard [Ducky Ducky One2 SF RGB] on usb-0000:52:00.0-2.3.1.2/input0
[ 4.695826] input: Ducky Ducky One2 SF RGB as /devices/pci0000:00/0000:00:07.2/0000:50:00.0/0000:51:02.0/0000:52:00.0/usb5/5-2/5-2.3/5-2.3.1/5-2.3.1.2/5-2.3.1.2:1.1/0003:0416:0123.0003/input/input6
[ 4.696113] hid-generic 0003:0416:0123.0003: input,hidraw2: USB HID v1.10 Mouse [Ducky Ducky One2 SF RGB] on usb-0000:52:00.0-2.3.1.2/input1
[ 4.697076] input: Ducky Ducky One2 SF RGB as /devices/pci0000:00/0000:00:07.2/0000:50:00.0/0000:51:02.0/0000:52:00.0/usb5/5-2/5-2.3/5-2.3.1/5-2.3.1.2/5-2.3.1.2:1.2/0003:0416:0123.0004/input/input7
[ 4.751081] hid-generic 0003:0416:0123.0004: input,hidraw3: USB HID v1.10 Keyboard [Ducky Ducky One2 SF RGB] on usb-0000:52:00.0-2.3.1.2/input2
[ 4.752317] input: Ducky Ducky One2 SF RGB as /devices/pci0000:00/0000:00:07.2/0000:50:00.0/0000:51:02.0/0000:52:00.0/usb5/5-2/5-2.3/5-2.3.1/5-2.3.1.2/5-2.3.1.2:1.3/0003:0416:0123.0005/input/input8
[ 4.807793] hid-generic 0003:0416:0123.0005: input,hidraw4: USB HID v1.10 Device [Ducky Ducky One2 SF RGB] on usb-0000:52:00.0-2.3.1.2/input3
[ 4.880772] usb 5-2.3.1.3: new full-speed USB device number 11 using xhci_hcd
[ 4.974521] usb 5-2.3.1.3: New USB device found, idVendor=046d, idProduct=c245, bcdDevice=69.00
[ 4.974530] usb 5-2.3.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.974534] usb 5-2.3.1.3: Product: Gaming Mouse G400
[ 4.974536] usb 5-2.3.1.3: Manufacturer: Logitech
[ 4.985334] input: Logitech Gaming Mouse G400 as /devices/pci0000:00/0000:00:07.2/0000:50:00.0/0000:51:02.0/0000:52:00.0/usb5/5-2/5-2.3/5-2.3.1/5-2.3.1.3/5-2.3.1.3:1.0/0003:046D:C245.0006/input/input9
[ 4.985597] hid-generic 0003:046D:C245.0006: input,hidraw5: USB HID v1.10 Mouse [Logitech Gaming Mouse G400] on usb-0000:52:00.0-2.3.1.3/input0
[ 4.986865] hid-generic 0003:046D:C245.0007: hiddev97,hidraw6: USB HID v1.10 Device [Logitech Gaming Mouse G400] on usb-0000:52:00.0-2.3.1.3/input1
# /me furiously entering the same password again and again until it works
[ 104.156408] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Quota mode: none.
