Kernel linux611-6.11.1-1 missing in grub after reboot
System booting and working fine, unstable branch.
Then sudo pacman -Suy answer No.
Open Manjaro Settings Manager, Kernels and install linux611-6.11.1-1, which installs linux611 6.11.1-1 and linux611-headers 6.11.1-1.
After reboot the newer kernel is missing.
VirtualBox_manjaro-kernel_missing
Perhaps for some reason the GRUB menu file didn’t get updated (it should be done automatically).
Check the timestamp on /boot/grub/grub.cfg, which might give you a clue. If necessary try running sudo update-grub. (Perhaps just give that a go anyway).
$ ls -l /boot/grub/grub.cfg
-rw-r--r-- 1 root root 9347 jun 19 13:24 /boot/grub/grub.cfg
Can’t update grub:
$ sudo update-grub
sudo: update-grub: command not found
Hmmm…
Curiously, update-grub seems to be a standalone package, though it shows as having been automatically installed on my own system. I only found out yesterday from the update’s thread here that update-grub is just a simplified wrapper for grub-mkconfig, so try:
sudo grub-mkconfig -o /boot/grub/grub.cfg
instead
@Tribble as well:
the sequence of commands which update-grub runs is:
sudo mkinitcpio -P
and then
the first creates the initrd, the second updates the grub config file
the second one alone might not work
Install update-grub - the kernel installer tool might rely on it being present.
If not installed (or to find out if it is):
sudo pacman -Syu update-grub
I think it was separated out at some point. Mine’s also an old installation, ~7yr, and I seem to recall using this command well before 2024 (oldest entry I can find for it in my bash history is from mid-March this year).
Working now:
$ sudo mkinitcpio -P
==> Building image from preset: /etc/mkinitcpio.d/linux516.preset: 'default'
==> Using configuration file: '/etc/mkinitcpio.conf'
  -> -k /boot/vmlinuz-5.16-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.16-x86_64.img
==> ERROR: specified kernel image does not exist: '/boot/vmlinuz-5.16-x86_64'
==> Building image from preset: /etc/mkinitcpio.d/linux516.preset: 'fallback'
  -> -k /boot/vmlinuz-5.16-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.16-x86_64-fallback.img -S autodetect
==> Building image from preset: /etc/mkinitcpio.d/linux519.preset: 'default'
  -> -k /boot/vmlinuz-5.19-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.19-x86_64.img
==> ERROR: specified kernel image does not exist: '/boot/vmlinuz-5.19-x86_64'
==> Building image from preset: /etc/mkinitcpio.d/linux519.preset: 'fallback'
  -> -k /boot/vmlinuz-5.19-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.19-x86_64-fallback.img -S autodetect
==> Building image from preset: /etc/mkinitcpio.d/linux610.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
  -> -k /boot/vmlinuz-6.10-x86_64 -g /boot/initramfs-6.10-x86_64.img
==> Starting build: '6.10.7-1-MANJARO'
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [kms]
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.10-x86_64.img'
  -> Early uncompressed CPIO image generation successful
==> Initcpio image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux610.preset: 'fallback'
  -> -k /boot/vmlinuz-6.10-x86_64 -g /boot/initramfs-6.10-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: 'ast'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.10-x86_64-fallback.img'
==> Building image from preset: /etc/mkinitcpio.d/linux611.preset: 'default'
  -> -k /boot/vmlinuz-6.11-x86_64 -g /boot/initramfs-6.11-x86_64.img
==> Starting build: '6.11.1-1-MANJARO'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.11-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux611.preset: 'fallback'
  -> -k /boot/vmlinuz-6.11-x86_64 -g /boot/initramfs-6.11-x86_64-fallback.img -S autodetect
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.11-x86_64-fallback.img'
==> Building image from preset: /etc/mkinitcpio.d/linux68.preset: 'default'
  -> -k /boot/vmlinuz-6.8-x86_64 -g /boot/initramfs-6.8-x86_64.img
==> ERROR: '/lib/modules/6.8.12-3-MANJARO' is not a valid kernel module directory
==> Building image from preset: /etc/mkinitcpio.d/linux68.preset: 'fallback'
  -> -k /boot/vmlinuz-6.8-x86_64 -g /boot/initramfs-6.8-x86_64-fallback.img -S autodetect
==> Building image from preset: /etc/mkinitcpio.d/linux69.preset: 'default'
  -> -k /boot/vmlinuz-6.9-x86_64 -g /boot/initramfs-6.9-x86_64.img
==> Starting build: '6.9.12-3-MANJARO'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.9-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux69.preset: 'fallback'
  -> -k /boot/vmlinuz-6.9-x86_64 -g /boot/initramfs-6.9-x86_64-fallback.img -S autodetect
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.9-x86_64-fallback.img'
$ sudo grub-mkconfig -o /boot/grub/grub.cfg
Found linux image: /boot/vmlinuz-6.11-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.11-x86_64.img
Found initrd fallback image: /boot/initramfs-6.11-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.10-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.10-x86_64.img
Found initrd fallback image: /boot/initramfs-6.10-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.9-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.9-x86_64.img
Found initrd fallback image: /boot/initramfs-6.9-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.8-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.8-x86_64.img
Found initrd fallback image: /boot/initramfs-6.8-x86_64-fallback.img
done
$ uname -r
6.11.1-1-MANJARO
Thanks for the help, but it’s clear there’s a bug in the manjaro update scripts.
My suspicion is that they’re relying on update-grub being installed. So if you haven’t yet done so, I’d suggest installing it.
Linux kernels 6.8 and 6.9 are not longer supported, you should have a look into Announcements before updating. Procedure would be to install a supported kernel, boot into it and then to remove the EOL kernels and no longer supprted kernels.
An additional comment on this: Having old unsupported kernels present is likely to cause issues with future upgrades. Particularly if you try to perform the upgrade while actually running one of these kernels.
