I noticed that when doing heavy IO (such as a duplicacy backup, zipping a ~2GB folder of ~60k files, etc) on my external drive, which I’m accessing via the ntfs3 driver, often times the command I was running would hang or segfault, or even cause my entire system to freeze up.
I believe switched to the ntfs3 driver when I was running kernel 5.10, and hadn’t noticed an issue until now - I just recently upgraded to 5.18 (I had upgraded to 5.15 and ran that for a while before 5.18 and I don’t think I had any issues at that point, though I don’t remember if I had pushed my disk this hard between then and now).
I’ve induced this a few times by running the following (I originally thought individual files were corrupted, but that turns out not to be the case): find . -type f -exec bash -c 'echo "[$(date)] Testing $0" && grep -a . "$0" > /dev/null || echo "File corrupted $0"' {} \; See below for what I see in journalctl a few different times this happened (which covers a few situations of a hang, segfault, and full system freeze, and each of the errors seems to be a bit different than the others). I’m aware some lines are cut off (got a bit lazy and just copied from what I got from journalctl in the terminal interactively), but I don’t think the rest of those lines should be super relevant (and I should be able to grab the missing bits if necessary).
Summary
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: invalid opcode: 0000 [#3] PREEMPT SMP PTI
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: CPU: 2 PID: 1085351 Comm: grep Tainted: P D W OE 5.18.7-1-MANJARO #1 c639cf6afa5daaf845fba4aada771cecb4c93806
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: Hardware name: Dell Inc. XPS 15 9570/02MJVY, BIOS 1.24.0 03/21/2022
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: RIP: 0010:handle_mm_fault+0x50/0x280
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: Code: d3 c7 40 18 00 00 00 00 65 48 ff 05 ba 53 d8 78 66 90 4c 8b 67 40 e8 7f d0 e7 ff 49 8b bc 24 98 03 00 00 e8 62 06 07 00 48 89 <c7> 48 85 c0 74 0a be 14 00 00 00 e8 60 6d ff ff e8 eb 09 e8 >
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: RSP: 0018:ffffabd713653ac8 EFLAGS: 00010206
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: RAX: ffff954911300000 RBX: 0000000000000215 RCX: ffffabd713653b78
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: RDX: ffff9548041ea0c0 RSI: 000056046c6e7000 RDI: ffff9548041ea0c0
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: RBP: ffff954a27a487d0 R08: ffff9548041ea0c0 R09: 0000000000000000
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: R10: 0000000000000000 R11: 0000000000000000 R12: ffff954900ee5940
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: R13: 000056046c6e7000 R14: ffffabd713653b78 R15: ffff954900ee59b8
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: FS: 00007fc17eb11740(0000) GS:ffff954c6c480000(0000) knlGS:0000000000000000
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: CR2: 000056046c6e7000 CR3: 0000000041914002 CR4: 00000000003706e0
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: Call Trace:
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: <TASK>
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: do_user_addr_fault+0x1be/0x680
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: exc_page_fault+0x74/0x170
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: asm_exc_page_fault+0x22/0x30
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: RIP: 0010:copy_user_enhanced_fast_string+0xe/0x40
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: Code: d1 f3 a4 31 c0 0f 01 ca c3 cc 8d 0c ca 89 ca eb 2b 66 66 2e 0f 1f 84 00 00 00 00 00 f3 0f 1e fa 0f 01 cb 83 fa 40 72 34 89 d1 <f3> a4 31 c0 0f 01 ca c3 cc 89 ca eb 05 0f 1f 44 00 00 83 f8 >
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: RSP: 0018:ffffabd713653c20 EFLAGS: 00050202
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: RAX: 0000000000000838 RBX: 0000000000000838 RCX: 0000000000000838
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: RDX: 0000000000000838 RSI: ffff95482d982000 RDI: 000056046c6e7000
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: RBP: ffffabd713653d90 R08: 0000000000000838 R09: ffffabd713653a40
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: R10: 00000000000007c8 R11: 0000000000000002 R12: 0000000000000838
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: R13: 0000000000000838 R14: ffffabd713653da0 R15: 0000000000000000
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: copy_page_to_iter+0x107/0x470
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: filemap_read+0x1cc/0x370
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: new_sync_read+0x13a/0x1c0
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: vfs_read+0x145/0x190
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: ksys_read+0x6f/0xf0
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: do_syscall_64+0x5f/0x90
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: ? syscall_exit_to_user_mode+0x26/0x50
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: ? do_syscall_64+0x6b/0x90
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: ? exc_page_fault+0x74/0x170
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: entry_SYSCALL_64_after_hwframe+0x44/0xae
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: RIP: 0033:0x7fc17e901b82
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: Code: c0 e9 b2 fe ff ff 50 48 8d 3d 2a 0e 0c 00 e8 15 f8 01 00 0f 1f 44 00 00 f3 0f 1e fa 64 8b 04 25 18 00 00 00 85 c0 75 10 0f 05 <48> 3d 00 f0 ff ff 77 56 c3 0f 1f 44 00 00 48 83 ec 28 48 89 >
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: RSP: 002b:00007ffe61af0038 EFLAGS: 00000246 ORIG_RAX: 0000000000000000
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: RAX: ffffffffffffffda RBX: 0000000000018000 RCX: 00007fc17e901b82
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: RDX: 0000000000018000 RSI: 000056046c6e7000 RDI: 0000000000000003
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: RBP: 000056046c6e7000 R08: 0000000000000000 R09: 00007fc17e9fe320
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: R10: 0000000000001000 R11: 0000000000000246 R12: 00007ffe61af0100
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: R13: 0000000000000003 R14: 0000000000001000 R15: 0000000000000003
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: </TASK>
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: Modules linked in: ntfs3 snd_seq_dummy snd_hrtimer snd_seq ccm rfcomm veth xt_nat xt_tcpudp xt_conntrack xt_MASQUERADE nf_conntrack_netlink nfnetlink xt_addrtype iptable_filter iptable_nat nf_na>
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: snd_hda_codec_hdmi nvidia_drm(POE) ath10k_core snd_soc_core snd_compress joydev snd_ctl_led ac97_bus snd_hda_codec_realtek mousedev dell_laptop nls_iso8859_1 ath dell_wmi vfat nvidia_modeset(PO>
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: processor_thermal_device_pci_legacy tpm drm_buddy processor_thermal_device rng_core video processor_thermal_rfim snd_timer processor_thermal_mbox ttm intel_hid processor_thermal_rapl int3400_th>
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: ---[ end trace 0000000000000000 ]---
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: RIP: 0010:__blk_flush_plug+0x36/0x160
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: Code: 8d 4f 18 41 56 49 89 fe 41 55 41 54 55 53 48 83 ec 28 89 74 24 0c 65 48 8b 04 25 28 00 00 00 48 89 44 24 20 31 c0 48 89 0c 24 <48> 8b 47 18 48 39 c1 0f 84 b0 00 00 00 48 8b 47 18 48 8d 5c >
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: RSP: 0018:ffffabd734067a98 EFLAGS: 00010246
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: RAX: 0000000000000000 RBX: 0000000000000000 RCX: ff00000000000018
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: RDX: ffff954a1116c180 RSI: 0000000000000001 RDI: ff00000000000000
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: RBP: 0000000000000002 R08: ffffffff88c083b0 R09: 00000000003d0900
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000102
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: R13: ffffffff88c083a8 R14: ff00000000000000 R15: ffffde8c88f04680
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: ------------[ cut here ]------------
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: Voluntary context switch within RCU read-side critical section!
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: WARNING: CPU: 2 PID: 1085351 at kernel/rcu/tree_plugin.h:318 rcu_note_context_switch+0x5a5/0x650
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: RIP: 0010:rcu_note_context_switch+0x5a5/0x650
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: Code: 00 00 00 00 0f 85 14 fd ff ff 49 89 bc 24 a0 00 00 00 e9 07 fd ff ff 48 c7 c7 50 a9 4f 88 c6 05 92 fc c9 01 01 e8 47 e5 a2 00 <0f> 0b e9 af fa ff ff 49 83 bc 24 98 00 00 00 00 49 8b 84 24 >
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: RSP: 0018:ffffabd713653c68 EFLAGS: 00010086
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: RAX: 0000000000000000 RBX: ffff954c6c4b3b40 RCX: 0000000000000027
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: RDX: ffff954c6c4a16a8 RSI: 0000000000000001 RDI: ffff954c6c4a16a0
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: RBP: 0000000000000000 R08: 0000000000000000 R09: ffffabd713653a78
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: R10: 0000000000000003 R11: ffffffff88ccaa08 R12: ffff9548041ea0c0
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: R13: ffff9548041ea0c0 R14: ffffabd713653da0 R15: 0000000000000000
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: FS: 0000000000000000(0000) GS:ffff954c6c480000(0000) knlGS:0000000000000000
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: __schedule+0xbd/0x11f0
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: schedule+0x4f/0xb0
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: rwsem_down_write_slowpath+0x1eb/0x5c0
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: exit_mmap+0x6b/0x1d0
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: mmput+0x59/0x140
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: do_exit+0x2db/0xac0
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: make_task_dead+0x55/0x60
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: rewind_stack_and_make_dead+0x17/0x17
Jul 11 12:44:01 JAROMANO-XPS-MAN kernel: Code: Unable to access opcode bytes at RIP 0x7fc17e901b58.
Jul 11 12:44:46 JAROMANO-XPS-MAN rtkit-daemon[2449]: Supervising 1 threads of 1 processes of 1 users.
Jul 11 12:45:01 JAROMANO-XPS-MAN kernel: rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
Jul 11 12:45:01 JAROMANO-XPS-MAN kernel: rcu: Tasks blocked on level-0 rcu_node (CPUs 0-11): P1085351/1:b..l
Jul 11 12:45:01 JAROMANO-XPS-MAN kernel: (detected by 7, t=18002 jiffies, g=4095105, q=6392)
Jul 11 12:45:01 JAROMANO-XPS-MAN kernel: task:grep state:D stack: 0 pid:1085351 ppid:1085349 flags:0x00004002
Jul 11 12:45:01 JAROMANO-XPS-MAN kernel: Call Trace:
Jul 11 12:45:01 JAROMANO-XPS-MAN kernel: <TASK>
Jul 11 12:45:01 JAROMANO-XPS-MAN kernel: __schedule+0x37c/0x11f0
Jul 11 12:45:01 JAROMANO-XPS-MAN kernel: schedule+0x4f/0xb0
Jul 11 12:45:01 JAROMANO-XPS-MAN kernel: rwsem_down_write_slowpath+0x1eb/0x5c0
Jul 11 12:45:01 JAROMANO-XPS-MAN kernel: exit_mmap+0x6b/0x1d0
Jul 11 12:45:01 JAROMANO-XPS-MAN kernel: mmput+0x59/0x140
Jul 11 12:45:01 JAROMANO-XPS-MAN kernel: do_exit+0x2db/0xac0
Jul 11 12:45:01 JAROMANO-XPS-MAN kernel: make_task_dead+0x55/0x60
Jul 11 12:45:01 JAROMANO-XPS-MAN kernel: rewind_stack_and_make_dead+0x17/0x17
Jul 11 12:45:01 JAROMANO-XPS-MAN kernel: RIP: 0033:0x7fc17e901b82
Jul 11 12:45:01 JAROMANO-XPS-MAN kernel: RSP: 002b:00007ffe61af0038 EFLAGS: 00000246 ORIG_RAX: 0000000000000000
Jul 11 12:45:01 JAROMANO-XPS-MAN kernel: RAX: ffffffffffffffda RBX: 0000000000018000 RCX: 00007fc17e901b82
Jul 11 12:45:01 JAROMANO-XPS-MAN kernel: RDX: 0000000000018000 RSI: 000056046c6e7000 RDI: 0000000000000003
Jul 11 12:45:01 JAROMANO-XPS-MAN kernel: RBP: 000056046c6e7000 R08: 0000000000000000 R09: 00007fc17e9fe320
Jul 11 12:45:01 JAROMANO-XPS-MAN kernel: R10: 0000000000001000 R11: 0000000000000246 R12: 00007ffe61af0100
Jul 11 12:45:01 JAROMANO-XPS-MAN kernel: R13: 0000000000000003 R14: 0000000000001000 R15: 0000000000000003
Jul 11 12:45:01 JAROMANO-XPS-MAN kernel: </TASK>
Summary
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: BUG: unable to handle page fault for address: ffffffffffffff90
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: #PF: supervisor write access in kernel mode
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: #PF: error_code(0x0002) - not-present page
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: PGD 27e615067 P4D 27e615067 PUD 27e617067 PMD 0
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: Oops: 0002 [#1] PREEMPT SMP PTI
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: CPU: 5 PID: 190149 Comm: grep Tainted: P W OE 5.18.7-1-MANJARO #1 c639cf6afa5daaf845fba4aada771cecb4c93806
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: Hardware name: Dell Inc. XPS 15 9570/02MJVY, BIOS 1.24.0 03/21/2022
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: RIP: 0010:handle_mm_fault+0xb1/0x280
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: Code: c3 80 01 00 00 74 74 41 89 df 41 83 e7 40 0f 85 c5 00 00 00 f6 45 52 40 0f 85 aa 01 00 00 89 da 4c 89 ee 48 89 ef e8 8e ea ff <ff> 41 89 c4 45 85 ff 0f 85 cd 00 00 00 41 f7 c4 73 0c 00 00 >
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: RSP: 0018:ffffa8f0311afaf8 EFLAGS: 00010286
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: RAX: 0000000000000000 RBX: 0000000000000215 RCX: 0000000000000007
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: RDX: 0000000000000000 RSI: 8000000338611867 RDI: ffffcd2b0a717de8
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: RBP: ffff88e32cbb5af0 R08: 0000000000039688 R09: 0000000000000000
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: R10: ffff88e52c5795a8 R11: 0000000000000001 R12: ffff88e1d690dd80
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: R13: 0000558774a28000 R14: ffffa8f0311afba8 R15: 0000000000000000
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: FS: 00007fe31a09e740(0000) GS:ffff88e52c540000(0000) knlGS:0000000000000000
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: CR2: ffffffffffffff90 CR3: 0000000202a66001 CR4: 00000000003706e0
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: Call Trace:
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: <TASK>
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: do_user_addr_fault+0x1be/0x680
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: exc_page_fault+0x74/0x170
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: asm_exc_page_fault+0x22/0x30
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: RIP: 0010:copy_user_enhanced_fast_string+0xe/0x40
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: Code: d1 f3 a4 31 c0 0f 01 ca c3 cc 8d 0c ca 89 ca eb 2b 66 66 2e 0f 1f 84 00 00 00 00 00 f3 0f 1e fa 0f 01 cb 83 fa 40 72 34 89 d1 <f3> a4 31 c0 0f 01 ca c3 cc 89 ca eb 05 0f 1f 44 00 00 83 f8 >
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: RSP: 0018:ffffa8f0311afc50 EFLAGS: 00050206
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: RAX: 0000000000000049 RBX: 0000000000000049 RCX: 0000000000000049
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: RDX: 0000000000000049 RSI: ffff88e3fed31000 RDI: 0000558774a28000
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: RBP: ffffa8f0311afdc0 R08: 0000000000000049 R09: ffffa8f0311afa70
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: R10: 0000000000000fb7 R11: 0000000000000005 R12: 0000000000000049
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: R13: 0000000000000049 R14: ffffa8f0311afdd0 R15: 0000000000000000
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: copy_page_to_iter+0x107/0x470
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: filemap_read+0x1cc/0x370
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: new_sync_read+0x13a/0x1c0
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: vfs_read+0x145/0x190
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: ksys_read+0x6f/0xf0
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: do_syscall_64+0x5f/0x90
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: ? do_sys_openat2+0x98/0x160
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: ? syscall_exit_to_user_mode+0x26/0x50
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: ? do_syscall_64+0x6b/0x90
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: entry_SYSCALL_64_after_hwframe+0x44/0xae
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: RIP: 0033:0x7fe319f01b82
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: Code: c0 e9 b2 fe ff ff 50 48 8d 3d 2a 0e 0c 00 e8 15 f8 01 00 0f 1f 44 00 00 f3 0f 1e fa 64 8b 04 25 18 00 00 00 85 c0 75 10 0f 05 <48> 3d 00 f0 ff ff 77 56 c3 0f 1f 44 00 00 48 83 ec 28 48 89 >
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: RSP: 002b:00007ffec254fa88 EFLAGS: 00000246 ORIG_RAX: 0000000000000000
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: RAX: ffffffffffffffda RBX: 0000000000018000 RCX: 00007fe319f01b82
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: RDX: 0000000000018000 RSI: 0000558774a28000 RDI: 0000000000000003
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: RBP: 0000558774a28000 R08: 0000000000000000 R09: 00007fe319ffe320
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: R10: 0000000000001000 R11: 0000000000000246 R12: 00007ffec254fb50
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: R13: 0000000000000003 R14: 0000000000001000 R15: 0000000000000003
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: </TASK>
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: Modules linked in: ntfs3 snd_usb_audio ses snd_usbmidi_lib enclosure scsi_transport_sas snd_rawmidi uas usb_storage snd_seq_dummy snd_hrtimer snd_seq snd_seq_device ccm rfcomm veth xt_nat xt_tcp>
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: snd_soc_acpi_intel_match intel_tcc_cooling snd_hda_codec_realtek snd_soc_acpi x86_pkg_temp_thermal intel_powerclamp snd_hda_codec_generic coretemp snd_soc_core kvm_intel snd_compress nvidia(POE>
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: processor_thermal_mbox pcspkr spi_intel_pci typec_ucsi processor_thermal_rapl snd intel_lpss_pci drm_dp_helper i2c_smbus spi_intel mei_me typec rfkill intel_lpss intel_rapl_common i2c_hid_acpi >
Jul 11 16:11:12 JAROMANO-XPS-MAN kernel: ---[ end trace 0000000000000000 ]---
Summary
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: general protection fault, probably for non-canonical address 0xff00000000000018: 0000 [#2] PREEMPT SMP PTI
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: CPU: 2 PID: 373107 Comm: grep Tainted: P D W OE 5.18.7-1-MANJARO #1 c639cf6afa5daaf845fba4aada771cecb4c93806
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: Hardware name: Dell Inc. XPS 15 9570/02MJVY, BIOS 1.24.0 03/21/2022
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: RIP: 0010:__blk_flush_plug+0x36/0x160
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: Code: 8d 4f 18 41 56 49 89 fe 41 55 41 54 55 53 48 83 ec 28 89 74 24 0c 65 48 8b 04 25 28 00 00 00 48 89 44 24 20 31 c0 48 89 0c 24 <48> 8b 47 18 48 39 c1 0f 84 b0 00 00 00 48 8b 47 18 48 8d 5c >
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: RSP: 0018:ffffa8f01edffac0 EFLAGS: 00010246
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: RAX: 0000000000000000 RBX: 0000000000000000 RCX: ff00000000000018
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: RDX: ffff88e249474180 RSI: 0000000000000001 RDI: ff00000000000000
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: RBP: 0000000000000002 R08: ffffffffb2208b78 R09: 00000000003d0900
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000102
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: R13: ffffffffb2208b70 R14: ff00000000000000 R15: ffffcd2b0c2d86c0
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: FS: 00007fe195b71740(0000) GS:ffff88e52c480000(0000) knlGS:0000000000000000
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: CR2: 0000561eb8f86188 CR3: 0000000266d76004 CR4: 00000000003706e0
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: Call Trace:
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: <TASK>
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: io_schedule+0x41/0x70
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: folio_wait_bit_common+0x13d/0x3a0
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: ? folio_unlock+0x20/0x20
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: filemap_get_pages+0x5d2/0x630
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: filemap_read+0xd9/0x370
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: new_sync_read+0x13a/0x1c0
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: vfs_read+0x145/0x190
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: ksys_read+0x6f/0xf0
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: do_syscall_64+0x5f/0x90
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: ? syscall_exit_to_user_mode+0x26/0x50
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: ? do_syscall_64+0x6b/0x90
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: ? exc_page_fault+0x74/0x170
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: entry_SYSCALL_64_after_hwframe+0x44/0xae
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: RIP: 0033:0x7fe195901b82
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: Code: c0 e9 b2 fe ff ff 50 48 8d 3d 2a 0e 0c 00 e8 15 f8 01 00 0f 1f 44 00 00 f3 0f 1e fa 64 8b 04 25 18 00 00 00 85 c0 75 10 0f 05 <48> 3d 00 f0 ff ff 77 56 c3 0f 1f 44 00 00 48 83 ec 28 48 89 >
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: RSP: 002b:00007ffe568a7c58 EFLAGS: 00000246 ORIG_RAX: 0000000000000000
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: RAX: ffffffffffffffda RBX: 0000000000018000 RCX: 00007fe195901b82
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: RDX: 0000000000018000 RSI: 0000561eb8f6e000 RDI: 0000000000000003
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: RBP: 0000561eb8f6e000 R08: 0000000000000000 R09: 00007fe1959fe320
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: R10: 0000000000001000 R11: 0000000000000246 R12: 00007ffe568a7d20
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: R13: 0000000000000003 R14: 0000000000001000 R15: 0000000000000003
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: </TASK>
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: Modules linked in: ntfs3 snd_usb_audio ses snd_usbmidi_lib enclosure scsi_transport_sas snd_rawmidi uas usb_storage snd_seq_dummy snd_hrtimer snd_seq snd_seq_device ccm rfcomm veth xt_nat xt_tcp>
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: snd_soc_acpi_intel_match intel_tcc_cooling snd_hda_codec_realtek snd_soc_acpi x86_pkg_temp_thermal intel_powerclamp snd_hda_codec_generic coretemp snd_soc_core kvm_intel snd_compress nvidia(POE>
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: processor_thermal_mbox pcspkr spi_intel_pci typec_ucsi processor_thermal_rapl snd intel_lpss_pci drm_dp_helper i2c_smbus spi_intel mei_me typec rfkill intel_lpss intel_rapl_common i2c_hid_acpi >
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: ---[ end trace 0000000000000000 ]---
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: RIP: 0010:handle_mm_fault+0xb1/0x280
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: Code: c3 80 01 00 00 74 74 41 89 df 41 83 e7 40 0f 85 c5 00 00 00 f6 45 52 40 0f 85 aa 01 00 00 89 da 4c 89 ee 48 89 ef e8 8e ea ff <ff> 41 89 c4 45 85 ff 0f 85 cd 00 00 00 41 f7 c4 73 0c 00 00 >
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: RSP: 0018:ffffa8f0311afaf8 EFLAGS: 00010286
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: RAX: 0000000000000000 RBX: 0000000000000215 RCX: 0000000000000007
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: RDX: 0000000000000000 RSI: 8000000338611867 RDI: ffffcd2b0a717de8
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: RBP: ffff88e32cbb5af0 R08: 0000000000039688 R09: 0000000000000000
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: R10: ffff88e52c5795a8 R11: 0000000000000001 R12: ffff88e1d690dd80
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: R13: 0000558774a28000 R14: ffffa8f0311afba8 R15: 0000000000000000
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: ------------[ cut here ]------------
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: WARNING: CPU: 2 PID: 373107 at kernel/exit.c:741 do_exit+0x8af/0xac0
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: RIP: 0010:do_exit+0x8af/0xac0
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: Code: 89 ab 40 06 00 00 4c 89 a3 48 06 00 00 48 89 6c 24 10 e9 78 fd ff ff 48 8b bb 28 06 00 00 31 f6 e8 96 da ff ff e9 2c fd ff ff <0f> 0b e9 8b f7 ff ff 48 89 df e8 52 94 0e 00 e9 50 f9 ff ff >
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: RSP: 0018:ffffa8f01edffee0 EFLAGS: 00010286
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: RAX: 0000000000000000 RBX: ffff88e249474180 RCX: 0000000000000000
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: RDX: 0000000000000000 RSI: 0000000000000001 RDI: 000000000000000b
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: RBP: ffff88e249474180 R08: 0000000000000000 R09: ffffa8f01edff700
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: R10: 0000000000000003 R11: ffffffffb22caa08 R12: 000000000000000b
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: R13: ff00000000000018 R14: ffff88e249474180 R15: 0000000000000000
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: make_task_dead+0x55/0x60
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: rewind_stack_and_make_dead+0x17/0x17
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: BUG: kernel NULL pointer dereference, address: 0000000000000018
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: #PF: supervisor read access in kernel mode
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: #PF: error_code(0x0000) - not-present page
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: PGD 0 P4D 0
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: Oops: 0000 [#3] PREEMPT SMP PTI
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: CPU: 3 PID: 9321 Comm: usb-storage Tainted: P D W OE 5.18.7-1-MANJARO #1 c639cf6afa5daaf845fba4aada771cecb4c93806
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: RIP: 0010:__list_del_entry_valid+0x4/0xa0
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: Code: 78 18 b2 b1 e8 69 95 61 00 0f 0b eb e3 48 89 f2 48 89 c1 48 89 fe 48 c7 c7 c8 18 b2 b1 e8 50 95 61 00 0f 0b eb ca f3 0f 1e fa <48> 8b 17 48 8b 4f 08 48 b8 00 01 00 00 00 00 ad de 48 39 c2 >
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: RSP: 0018:ffffa8f0007a7cc8 EFLAGS: 00010086
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: RAX: 00000000ffffffff RBX: 0000000000000018 RCX: ffffa8f0007a7d28
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: RDX: 0000000000000000 RSI: 0000000000000003 RDI: 0000000000000018
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: RBP: 0000000000000000 R08: ffffa8f01edffb70 R09: ffffa8f0007a7d38
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: R10: 0000000000000001 R11: 0000000000000003 R12: ffffa8f0007a7d38
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: R13: 000000001dbbb060 R14: 00000000b091d343 R15: ffffa8f0007a7d28
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: FS: 0000000000000000(0000) GS:ffff88e52c4c0000(0000) knlGS:0000000000000000
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: CR2: 0000000000000018 CR3: 000000027e610003 CR4: 00000000003706e0
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: ep_poll_callback+0x1ca/0x280
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: ? __wake_up_common+0x76/0x170
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: ? folio_wake_bit+0xab/0x100
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: ? mpage_end_io+0xab/0xf0
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: ? blk_update_request+0x114/0x400
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: ? usb_stor_invoke_transport+0x43/0x4e0 [usb_storage 643e23ba68a36a2283499126e57256a4559347a4]
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: ? __blk_mq_free_request+0xaf/0xc0
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: ? release_everything+0xa0/0xa0 [usb_storage 643e23ba68a36a2283499126e57256a4559347a4]
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: ? scsi_end_request+0x27/0x1b0
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: ? scsi_io_completion+0x5a/0x7a0
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: ? usb_stor_control_thread+0x235/0x2a0 [usb_storage 643e23ba68a36a2283499126e57256a4559347a4]
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: ? kthread+0xde/0x110
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: ? kthread_complete_and_exit+0x20/0x20
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: ? ret_from_fork+0x22/0x30
Jul 11 16:24:44 JAROMANO-XPS-MAN kernel: note: usb-storage[9321] exited with preempt_count 1
Summary
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: BUG: unable to handle page fault for address: ffffffffffffff90
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: #PF: supervisor write access in kernel mode
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: #PF: error_code(0x0002) - not-present page
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: PGD 1dc615067 P4D 1dc615067 PUD 1dc617067 PMD 0
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: Oops: 0002 [#1] PREEMPT SMP PTI
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: CPU: 1 PID: 872312 Comm: grep Tainted: P OE 5.18.7-1-MANJARO #1 c639cf6afa5daaf845fba4aada771cecb4c93806
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: Hardware name: Dell Inc. XPS 15 9570/02MJVY, BIOS 1.24.0 03/21/2022
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: RIP: 0010:handle_mm_fault+0xb1/0x280
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: Code: c3 80 01 00 00 74 74 41 89 df 41 83 e7 40 0f 85 c5 00 00 00 f6 45 52 40 0f 85 aa 01 00 00 89 da 4c 89 ee 48 89 ef e8 8e ea ff <ff> 41 89 c4 45 85 ff 0f 85 cd 00 00 00 41 f7 c4 73 0c 00 00 >
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: RSP: 0018:ffffb4a434267a98 EFLAGS: 00010286
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: RAX: 0000000000000000 RBX: 0000000000000215 RCX: 0000000000000007
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: RDX: 0000000000000000 RSI: 800000001d2e6867 RDI: fffffc2a802b3368
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: RBP: ffff88b915085000 R08: 0000000000039688 R09: 0000000000000000
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: R10: ffff88bc6c479468 R11: 0000000000000001 R12: ffff88b903d70cc0
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: R13: 000055902744c000 R14: ffffb4a434267b48 R15: 0000000000000000
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: FS: 00007f6c6dc9d740(0000) GS:ffff88bc6c440000(0000) knlGS:0000000000000000
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: CR2: ffffffffffffff90 CR3: 0000000014c74002 CR4: 00000000003706e0
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: Call Trace:
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: <TASK>
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: do_user_addr_fault+0x1be/0x680
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: exc_page_fault+0x74/0x170
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: asm_exc_page_fault+0x22/0x30
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: RIP: 0010:copy_user_enhanced_fast_string+0xe/0x40
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: Code: d1 f3 a4 31 c0 0f 01 ca c3 cc 8d 0c ca 89 ca eb 2b 66 66 2e 0f 1f 84 00 00 00 00 00 f3 0f 1e fa 0f 01 cb 83 fa 40 72 34 89 d1 <f3> a4 31 c0 0f 01 ca c3 cc 89 ca eb 05 0f 1f 44 00 00 83 f8 >
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: RSP: 0018:ffffb4a434267bf0 EFLAGS: 00050206
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: RAX: 000000000000052e RBX: 000000000000052e RCX: 000000000000052e
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: RDX: 000000000000052e RSI: ffff88b81d2aa000 RDI: 000055902744c000
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: RBP: ffffb4a434267d60 R08: 000000000000052e R09: ffffb4a434267a10
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: R10: 0000000000000ad2 R11: 0000000000000001 R12: 000000000000052e
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: R13: 000000000000052e R14: ffffb4a434267d70 R15: 0000000000000000
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: copy_page_to_iter+0x107/0x470
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: filemap_read+0x1cc/0x370
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: ? terminate_walk+0x21/0xf0
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: new_sync_read+0x13a/0x1c0
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: vfs_read+0x145/0x190
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: ksys_read+0x6f/0xf0
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: do_syscall_64+0x5f/0x90
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: ? __do_sys_newfstatat+0x4e/0x80
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: ? syscall_exit_to_user_mode+0x26/0x50
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: ? do_syscall_64+0x6b/0x90
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: entry_SYSCALL_64_after_hwframe+0x44/0xae
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: RIP: 0033:0x7f6c6db01b82
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: Code: c0 e9 b2 fe ff ff 50 48 8d 3d 2a 0e 0c 00 e8 15 f8 01 00 0f 1f 44 00 00 f3 0f 1e fa 64 8b 04 25 18 00 00 00 85 c0 75 10 0f 05 <48> 3d 00 f0 ff ff 77 56 c3 0f 1f 44 00 00 48 83 ec 28 48 89 >
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: RSP: 002b:00007ffca424ccf8 EFLAGS: 00000246 ORIG_RAX: 0000000000000000
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: RAX: ffffffffffffffda RBX: 0000000000018000 RCX: 00007f6c6db01b82
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: RDX: 0000000000018000 RSI: 000055902744c000 RDI: 0000000000000003
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: RBP: 000055902744c000 R08: 0000000000000000 R09: 00007f6c6dbfe320
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: R10: 0000000000001000 R11: 0000000000000246 R12: 00007ffca424cdc0
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: R13: 0000000000000003 R14: 0000000000001000 R15: 0000000000000003
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: </TASK>
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: Modules linked in: ntfs3 ccm snd_seq_dummy snd_hrtimer snd_seq rfcomm veth xt_nat xt_tcpudp xt_conntrack xt_MASQUERADE nf_conntrack_netlink nfnetlink xt_addrtype iptable_filter iptable_nat nf_na>
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: usb_storage joydev nvidia_modeset(POE) hid_multitouch mousedev ee1004 mei_hdcp mei_pxp mei_wdt mtd iTCO_vendor_support bluetooth snd_hda_codec_generic intel_rapl_msr dell_wmi_sysman wmi_bmof in>
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: rfkill soundcore psmouse spi_intel pcspkr processor_thermal_rapl drm_dp_helper intel_lpss_pci i2c_smbus mei intel_rapl_common ucsi_acpi tpm_crb intel_lpss idma64 intel_gtt intel_soc_dts_iosf ty>
Jul 11 18:01:14 JAROMANO-XPS-MAN kernel: ---[ end trace 0000000000000000 ]---
I’ll also add this one which was from yesterday when I first started noticing this. I’m not completely sure if all the logs here are related, but the timing is about right and it presents itself a bit differently so may be of interest.
Summary
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: general protection fault, probably for non-canonical address 0xff00000000000018: 0000 [#1] PREEMPT SMP PTI
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: CPU: 7 PID: 522209 Comm: grep Tainted: P W OE 5.18.7-1-MANJARO #1 c639cf6afa5daaf845fba4aada771cecb4c93806
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: Hardware name: Dell Inc. XPS 15 9570/02MJVY, BIOS 1.24.0 03/21/2022
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: RIP: 0010:__blk_flush_plug+0x36/0x160
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: Code: 8d 4f 18 41 56 49 89 fe 41 55 41 54 55 53 48 83 ec 28 89 74 24 0c 65 48 8b 04 25 28 00 00 00 48 89 44 24 20 31 c0 48 89 0c 24 <48> 8b 47 18 48 39 c1 0f 84 b0 00 00 00 48 8b 47 18 48 8d 5c >
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: RSP: 0018:ffffaf04f0d6faf8 EFLAGS: 00010246
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: RAX: 0000000000000000 RBX: 0000000000000000 RCX: ff00000000000018
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: RDX: ffff9666b4d18000 RSI: 0000000000000001 RDI: ff00000000000000
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: RBP: 0000000000000002 R08: ffffffff928085f0 R09: 00000000003d0900
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000102
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: R13: ffffffff928085e8 R14: ff00000000000000 R15: fffff2378a6d1000
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: FS: 00007fb2ef826740(0000) GS:ffff9667ac5c0000(0000) knlGS:0000000000000000
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: CR2: 0000565056afe188 CR3: 0000000401a1c001 CR4: 00000000003706e0
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: Call Trace:
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: <TASK>
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: io_schedule+0x41/0x70
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: folio_wait_bit_common+0x13d/0x3a0
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: ? folio_unlock+0x20/0x20
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: filemap_get_pages+0x5d2/0x630
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: ? terminate_walk+0x61/0xf0
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: filemap_read+0xd9/0x370
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: new_sync_read+0x13a/0x1c0
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: vfs_read+0x145/0x190
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: ksys_read+0x6f/0xf0
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: do_syscall_64+0x5f/0x90
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: ? syscall_exit_to_user_mode+0x26/0x50
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: ? do_syscall_64+0x6b/0x90
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: ? exc_page_fault+0x74/0x170
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: entry_SYSCALL_64_after_hwframe+0x44/0xae
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: RIP: 0033:0x7fb2ef701b82
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: Code: c0 e9 b2 fe ff ff 50 48 8d 3d 2a 0e 0c 00 e8 15 f8 01 00 0f 1f 44 00 00 f3 0f 1e fa 64 8b 04 25 18 00 00 00 85 c0 75 10 0f 05 <48> 3d 00 f0 ff ff 77 56 c3 0f 1f 44 00 00 48 83 ec 28 48 89 >
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: RSP: 002b:00007fff48921258 EFLAGS: 00000246 ORIG_RAX: 0000000000000000
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: RAX: ffffffffffffffda RBX: 0000000000018000 RCX: 00007fb2ef701b82
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: RDX: 0000000000018000 RSI: 0000565056ae6000 RDI: 0000000000000003
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: RBP: 0000565056ae6000 R08: 0000000000000000 R09: 00007fb2ef7fe320
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: R10: 0000000000001000 R11: 0000000000000246 R12: 00007fff48921320
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: R13: 0000000000000003 R14: 0000000000001000 R15: 0000000000000003
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: </TASK>
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: Modules linked in: ntfs3 ccm veth xt_nat xt_tcpudp xt_conntrack xt_MASQUERADE nf_conntrack_netlink nfnetlink xt_addrtype iptable_filter iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_i>
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: ecdh_generic mc snd_soc_acpi cdc_acm nvidia_drm(POE) usbhid snd_soc_core usb_storage snd_compress ac97_bus snd_pcm_dmaengine joydev snd_hda_intel mousedev nvidia_modeset(POE) intel_tcc_cooling >
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: ucsi_acpi pcspkr ttm soundcore processor_thermal_rapl spi_intel_pci intel_lpss_pci typec_ucsi mei_me i2c_smbus spi_intel rfkill drm_dp_helper i2c_hid_acpi intel_rapl_common typec intel_lpss tpm>
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: ---[ end trace 0000000000000000 ]---
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: ------------[ cut here ]------------
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: WARNING: CPU: 7 PID: 522209 at kernel/exit.c:741 do_exit+0x8af/0xac0
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: CPU: 7 PID: 522209 Comm: grep Tainted: P D W OE 5.18.7-1-MANJARO #1 c639cf6afa5daaf845fba4aada771cecb4c93806
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: RIP: 0010:do_exit+0x8af/0xac0
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: Code: 89 ab 40 06 00 00 4c 89 a3 48 06 00 00 48 89 6c 24 10 e9 78 fd ff ff 48 8b bb 28 06 00 00 31 f6 e8 96 da ff ff e9 2c fd ff ff <0f> 0b e9 8b f7 ff ff 48 89 df e8 52 94 0e 00 e9 50 f9 ff ff >
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: RSP: 0018:ffffaf04f0d6fee0 EFLAGS: 00010286
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: RAX: 0000000000000000 RBX: ffff9666b4d18000 RCX: 0000000000000000
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: RDX: 0000000000000000 RSI: 0000000000000001 RDI: 000000000000000b
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: RBP: ffff9666b4d18000 R08: 0000000000000000 R09: ffffaf04f0d6f730
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: R10: 0000000000000003 R11: ffffffff928caa08 R12: 000000000000000b
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: R13: ff00000000000018 R14: ffff9666b4d18000 R15: 0000000000000000
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: kernel tried to execute NX-protected page - exploit attempt? (uid: 0)
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: BUG: unable to handle page fault for address: ffffaf04f0d6fbd8
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: make_task_dead+0x55/0x60
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: #PF: supervisor instruction fetch in kernel mode
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: #PF: error_code(0x0011) - permissions violation
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: PGD 100000067
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: rewind_stack_and_make_dead+0x17/0x17
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: P4D 100000067 PUD 1001ca067 PMD 13f884067
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: PTE 80000002e83ae063
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: Oops: 0011 [#2] PREEMPT SMP PTI
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: CPU: 3 PID: 1096 Comm: usb-storage Tainted: P D W OE 5.18.7-1-MANJARO #1 c639cf6afa5daaf845fba4aada771cecb4c93806
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: RIP: 0010:0xffffaf04f0d6fbd8
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: Code: 00 00 88 fc d6 f0 04 af ff ff 38 fc d6 f0 04 af ff ff 00 00 00 00 00 00 00 00 f0 fc d6 f0 04 af ff ff 00 00 00 00 00 00 00 00 <d0> 14 d1 90 ff ff ff ff f0 fb d6 f0 00 00 00 00 00 00 00 00 >
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: RSP: 0018:ffffaf04c0997cd0 EFLAGS: 00010046
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: RAX: ffffaf04f0d6fbd8 RBX: ffffffff928085f0 RCX: ffffaf04c0997d28
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: RDX: 0000000000000000 RSI: 0000000000000003 RDI: ffffaf04f0d6fba8
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: RBP: 0000000000000000 R08: ffffaf04f0d6fba8 R09: ffffaf04c0997d38
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: R10: 0000000000000001 R11: 0000000000000003 R12: ffffaf04c0997d38
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: R13: 00000000f0d6fbf0 R14: 000000430007f7c9 R15: ffffaf04c0997d28
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: FS: 0000000000000000(0000) GS:ffff9667ac4c0000(0000) knlGS:0000000000000000
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: CR2: ffffaf04f0d6fbd8 CR3: 0000000283c10003 CR4: 00000000003706e0
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: ? __wake_up_common+0x76/0x170
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: ? folio_wake_bit+0xab/0x100
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: ? mpage_end_io+0xab/0xf0
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: ? blk_update_request+0x114/0x400
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: ? usb_stor_invoke_transport+0x43/0x4e0 [usb_storage 643e23ba68a36a2283499126e57256a4559347a4]
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: ? __blk_mq_free_request+0xaf/0xc0
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: ? release_everything+0xa0/0xa0 [usb_storage 643e23ba68a36a2283499126e57256a4559347a4]
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: ? scsi_end_request+0x27/0x1b0
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: ? scsi_io_completion+0x5a/0x7a0
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: ? usb_stor_control_thread+0x235/0x2a0 [usb_storage 643e23ba68a36a2283499126e57256a4559347a4]
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: ? kthread+0xde/0x110
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: ? kthread_complete_and_exit+0x20/0x20
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: ? ret_from_fork+0x22/0x30
Jul 10 20:35:11 JAROMANO-XPS-MAN kernel: note: usb-storage[1096] exited with preempt_count 1
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: watchdog: BUG: soft lockup - CPU#4 stuck for 22s! [Chrome_ChildIOT:507358]
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: Modules linked in: ntfs3 ccm veth xt_nat xt_tcpudp xt_conntrack xt_MASQUERADE nf_conntrack_netlink nfnetlink xt_addrtype iptable_filter iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_i>
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: ecdh_generic mc snd_soc_acpi cdc_acm nvidia_drm(POE) usbhid snd_soc_core usb_storage snd_compress ac97_bus snd_pcm_dmaengine joydev snd_hda_intel mousedev nvidia_modeset(POE) intel_tcc_cooling >
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: ucsi_acpi pcspkr ttm soundcore processor_thermal_rapl spi_intel_pci intel_lpss_pci typec_ucsi mei_me i2c_smbus spi_intel rfkill drm_dp_helper i2c_hid_acpi intel_rapl_common typec intel_lpss tpm>
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: CPU: 4 PID: 507358 Comm: Chrome_ChildIOT Tainted: P D W OE 5.18.7-1-MANJARO #1 c639cf6afa5daaf845fba4aada771cecb4c93806
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: Hardware name: Dell Inc. XPS 15 9570/02MJVY, BIOS 1.24.0 03/21/2022
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: RIP: 0010:smp_call_function_many_cond+0xfb/0x2e0
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: Code: 48 89 de e8 f7 c0 45 00 3b 05 01 5d cb 01 89 c7 73 22 48 63 c7 49 8b 0c 24 48 03 0c c5 e0 4a 18 92 8b 41 08 a8 01 74 0a f3 90 <8b> 51 08 83 e2 01 75 f6 eb cc 48 83 c4 48 5b 5d 41 5c 41 5d >
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: RSP: 0018:ffffaf04c71abb30 EFLAGS: 00000202
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: RAX: 0000000000000011 RBX: ffff9667ac533dc8 RCX: ffff9667ac5baae0
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: RDX: 0000000000000001 RSI: 0000000000000006 RDI: 0000000000000006
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: RBP: ffff9667ac532640 R08: 0000000000000000 R09: 0000000000000000
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: R10: 0000000000000000 R11: 0000000000000005 R12: ffff9667ac533dc0
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: R13: 0000000000000001 R14: ffff9667ac533dc0 R15: 0000000000000140
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: FS: 00007fc9537bf700(0000) GS:ffff9667ac500000(0000) knlGS:0000000000000000
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: CR2: 00003da232a5a008 CR3: 0000000374e56006 CR4: 00000000003706e0
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: Call Trace:
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: <TASK>
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: ? leave_mm+0x40/0x40
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: on_each_cpu_cond_mask+0x24/0x40
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: flush_tlb_mm_range+0xd1/0x100
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: unmap_page_range+0xbcc/0xf60
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: unmap_vmas+0x85/0x100
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: unmap_region+0xbe/0x120
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: __do_munmap+0x211/0x4d0
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: __vm_munmap+0x74/0x110
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: __x64_sys_munmap+0x1b/0x20
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: do_syscall_64+0x5f/0x90
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: ? do_syscall_64+0x6b/0x90
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: ? syscall_exit_to_user_mode+0x26/0x50
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: entry_SYSCALL_64_after_hwframe+0x44/0xae
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: RIP: 0033:0x7fc95706d73d
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: Code: 00 c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 23 37 0d 00 f7 d8 64 89 >
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: RSP: 002b:00007fc9537bdb38 EFLAGS: 00000246 ORIG_RAX: 000000000000000b
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: RAX: ffffffffffffffda RBX: 00007fc95173c000 RCX: 00007fc95706d73d
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: RDX: ffffc580965b142b RSI: 0000000000080000 RDI: 00007fc95173c000
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: RBP: 00007fc9537bdb60 R08: 0000000000000000 R09: 00003a7dc6eeeb40
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 00003a7dc71ec000
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: R13: 0000000000000400 R14: 0000000000080000 R15: 00003a7dc6ef0f00
Jul 10 20:35:44 JAROMANO-XPS-MAN kernel: </TASK>
Jul 10 20:35:52 JAROMANO-XPS-MAN kernel: nvme nvme0: I/O 329 QID 7 timeout, aborting
Jul 10 20:35:52 JAROMANO-XPS-MAN kernel: nvme nvme0: Abort status: 0x0
Jul 10 20:36:04 JAROMANO-XPS-MAN kernel: ath10k_pci 0000:3b:00.0: timed out waiting peer stats info
Jul 10 20:36:09 JAROMANO-XPS-MAN kernel: ath10k_pci 0000:3b:00.0: wmi command 90113 timeout, restarting hardware
Jul 10 20:36:09 JAROMANO-XPS-MAN kernel: ath10k_pci 0000:3b:00.0: could not request stats (-11)
Jul 10 20:36:09 JAROMANO-XPS-MAN kernel: ath10k_pci 0000:3b:00.0: could not request peer stats info: -108
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: watchdog: BUG: soft lockup - CPU#4 stuck for 48s! [Chrome_ChildIOT:507358]
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: Modules linked in: ntfs3 ccm veth xt_nat xt_tcpudp xt_conntrack xt_MASQUERADE nf_conntrack_netlink nfnetlink xt_addrtype iptable_filter iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_i>
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: ecdh_generic mc snd_soc_acpi cdc_acm nvidia_drm(POE) usbhid snd_soc_core usb_storage snd_compress ac97_bus snd_pcm_dmaengine joydev snd_hda_intel mousedev nvidia_modeset(POE) intel_tcc_cooling >
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: ucsi_acpi pcspkr ttm soundcore processor_thermal_rapl spi_intel_pci intel_lpss_pci typec_ucsi mei_me i2c_smbus spi_intel rfkill drm_dp_helper i2c_hid_acpi intel_rapl_common typec intel_lpss tpm>
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: CPU: 4 PID: 507358 Comm: Chrome_ChildIOT Tainted: P D W OEL 5.18.7-1-MANJARO #1 c639cf6afa5daaf845fba4aada771cecb4c93806
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: Hardware name: Dell Inc. XPS 15 9570/02MJVY, BIOS 1.24.0 03/21/2022
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: RIP: 0010:smp_call_function_many_cond+0xfb/0x2e0
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: Code: 48 89 de e8 f7 c0 45 00 3b 05 01 5d cb 01 89 c7 73 22 48 63 c7 49 8b 0c 24 48 03 0c c5 e0 4a 18 92 8b 41 08 a8 01 74 0a f3 90 <8b> 51 08 83 e2 01 75 f6 eb cc 48 83 c4 48 5b 5d 41 5c 41 5d >
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: RSP: 0018:ffffaf04c71abb30 EFLAGS: 00000202
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: RAX: 0000000000000011 RBX: ffff9667ac533dc8 RCX: ffff9667ac5baae0
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: RDX: 0000000000000001 RSI: 0000000000000006 RDI: 0000000000000006
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: RBP: ffff9667ac532640 R08: 0000000000000000 R09: 0000000000000000
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: R10: 0000000000000000 R11: 0000000000000005 R12: ffff9667ac533dc0
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: R13: 0000000000000001 R14: ffff9667ac533dc0 R15: 0000000000000140
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: FS: 00007fc9537bf700(0000) GS:ffff9667ac500000(0000) knlGS:0000000000000000
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: CR2: 00003da232a5a008 CR3: 0000000374e56006 CR4: 00000000003706e0
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: Call Trace:
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: <TASK>
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: ? leave_mm+0x40/0x40
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: on_each_cpu_cond_mask+0x24/0x40
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: flush_tlb_mm_range+0xd1/0x100
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: unmap_page_range+0xbcc/0xf60
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: unmap_vmas+0x85/0x100
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: unmap_region+0xbe/0x120
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: __do_munmap+0x211/0x4d0
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: __vm_munmap+0x74/0x110
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: __x64_sys_munmap+0x1b/0x20
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: do_syscall_64+0x5f/0x90
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: ? do_syscall_64+0x6b/0x90
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: ? syscall_exit_to_user_mode+0x26/0x50
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: entry_SYSCALL_64_after_hwframe+0x44/0xae
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: RIP: 0033:0x7fc95706d73d
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: Code: 00 c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 23 37 0d 00 f7 d8 64 89 >
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: RSP: 002b:00007fc9537bdb38 EFLAGS: 00000246 ORIG_RAX: 000000000000000b
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: RAX: ffffffffffffffda RBX: 00007fc95173c000 RCX: 00007fc95706d73d
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: RDX: ffffc580965b142b RSI: 0000000000080000 RDI: 00007fc95173c000
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: RBP: 00007fc9537bdb60 R08: 0000000000000000 R09: 00003a7dc6eeeb40
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 00003a7dc71ec000
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: R13: 0000000000000400 R14: 0000000000080000 R15: 00003a7dc6ef0f00
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: </TASK>
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: ath10k_pci 0000:3b:00.0: could not request stats (-108)
Jul 10 20:36:12 JAROMANO-XPS-MAN kernel: ath10k_pci 0000:3b:00.0: could not request peer stats info: -108
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: watchdog: BUG: soft lockup - CPU#0 stuck for 22s! [ThreadPoolForeg:522218]
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: Modules linked in: ntfs3 ccm veth xt_nat xt_tcpudp xt_conntrack xt_MASQUERADE nf_conntrack_netlink nfnetlink xt_addrtype iptable_filter iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_i>
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: ecdh_generic mc snd_soc_acpi cdc_acm nvidia_drm(POE) usbhid snd_soc_core usb_storage snd_compress ac97_bus snd_pcm_dmaengine joydev snd_hda_intel mousedev nvidia_modeset(POE) intel_tcc_cooling >
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: ucsi_acpi pcspkr ttm soundcore processor_thermal_rapl spi_intel_pci intel_lpss_pci typec_ucsi mei_me i2c_smbus spi_intel rfkill drm_dp_helper i2c_hid_acpi intel_rapl_common typec intel_lpss tpm>
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: CPU: 0 PID: 522218 Comm: ThreadPoolForeg Tainted: P D W OEL 5.18.7-1-MANJARO #1 c639cf6afa5daaf845fba4aada771cecb4c93806
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: Hardware name: Dell Inc. XPS 15 9570/02MJVY, BIOS 1.24.0 03/21/2022
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: RIP: 0010:smp_call_function_many_cond+0xfb/0x2e0
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: Code: 48 89 de e8 f7 c0 45 00 3b 05 01 5d cb 01 89 c7 73 22 48 63 c7 49 8b 0c 24 48 03 0c c5 e0 4a 18 92 8b 41 08 a8 01 74 0a f3 90 <8b> 51 08 83 e2 01 75 f6 eb cc 48 83 c4 48 5b 5d 41 5c 41 5d >
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: watchdog: BUG: soft lockup - CPU#9 stuck for 22s! [ThreadPoolForeg:518526]
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: RSP: 0018:ffffaf04f0d77b98 EFLAGS: 00000202
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: watchdog: BUG: soft lockup - CPU#10 stuck for 22s! [ThreadPoolForeg:522216]
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: RAX: 0000000000000011 RBX: ffff9667ac433dc8 RCX: ffff9667ac5b8f60
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: ccm veth xt_nat
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: RDX: 0000000000000001 RSI: 0000000000000006 RDI: 0000000000000006
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: RBP: ffff9667ac432640 R08: 0000000000000000 R09: 0000000000000000
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: ntfs3
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: xt_tcpudp
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: xt_conntrack
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: veth
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: xt_MASQUERADE nf_conntrack_netlink
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: xt_nat
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: nfnetlink
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: xt_addrtype
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: iptable_filter iptable_nat
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: nf_nat
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: nf_conntrack_netlink
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: nfnetlink xt_addrtype
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: R10: 0000000000000000 R11: 0000000000000005 R12: ffff9667ac433dc0
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: nf_defrag_ipv6 nf_defrag_ipv4
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: R13: 0000000000000001 R14: ffff9667ac433dc0 R15: 0000000000000140
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: libcrc32c br_netfilter bridge stp
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: FS: 00007fc94db54700(0000) GS:ffff9667ac400000(0000) knlGS:0000000000000000
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: llc overlay
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_seq_dummy snd_hrtimer
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: iptable_nat nf_nat
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: CR2: 0000212277dcb000 CR3: 0000000374e56002 CR4: 00000000003706f0
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: rfcomm
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: nf_defrag_ipv4
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: ses
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: enclosure scsi_transport_sas
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: br_netfilter
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_usb_audio snd_usbmidi_lib
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: bridge
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_rawmidi
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: stp
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_seq_device qrtr
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: Call Trace:
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: cmac hid_logitech_hidpp algif_hash
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: <TASK>
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: algif_skcipher af_alg
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: bnep uinput
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: ? leave_mm+0x40/0x40
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_seq rfcomm
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: nvidia_uvm(POE)
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_sof_pci_intel_cnl
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_sof_intel_hda_common
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: scsi_transport_sas
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: soundwire_intel
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: on_each_cpu_cond_mask+0x24/0x40
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_usbmidi_lib snd_rawmidi snd_seq_device
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: soundwire_generic_allocation
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: flush_tlb_mm_range+0xd1/0x100
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: soundwire_cadence snd_sof_intel_hda hid_logitech_dj
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: qrtr
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_sof_pci snd_sof_xtensa_dsp uas snd_sof
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: tlb_finish_mmu+0x118/0x1b0
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_sof_utils soundwire_bus
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: hid_logitech_hidpp
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: uvcvideo
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: algif_hash
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: btusb
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_hda_codec_hdmi
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: af_alg
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_soc_skl
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: btrtl
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: uinput
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: videobuf2_vmalloc btbcm
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: videobuf2_memops
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_soc_hdac_hda btintel videobuf2_v4l2 btmtk snd_ctl_led
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: zap_page_range+0x12b/0x190
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: soundwire_intel soundwire_generic_allocation
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_hda_ext_core
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: videobuf2_common
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_sof_intel_hda hid_logitech_dj
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_hda_codec_realtek snd_soc_sst_ipc
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: bluetooth
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: madvise_vma_behavior+0x58c/0xa10
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_sof_xtensa_dsp uas
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: videodev snd_hda_codec_generic
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: ? futex_wake+0x80/0x180
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_soc_sst_dsp snd_soc_acpi_intel_match
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: ? madvise_vma_anon_name+0x40/0x40
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: mc snd_soc_acpi
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: uvcvideo btusb
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: cdc_acm
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: madvise_walk_vmas+0xb5/0x120
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: nvidia_drm(POE) usbhid
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_soc_core
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: usb_storage
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: btrtl videobuf2_vmalloc btbcm
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_compress ac97_bus
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: do_madvise+0x18f/0x300
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_pcm_dmaengine joydev
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_hda_intel
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: mousedev
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: btintel videobuf2_v4l2 btmtk snd_ctl_led
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: nvidia_modeset(POE)
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: __x64_sys_madvise+0x2c/0x30
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: intel_tcc_cooling x86_pkg_temp_thermal
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: intel_powerclamp
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: nvidia(POE)
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_hda_codec_realtek snd_soc_sst_ipc bluetooth
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: coretemp dell_laptop
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: do_syscall_64+0x5f/0x90
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: kvm_intel
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_hda_codec_generic
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_intel_dspcfg
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_intel_sdw_acpi
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_soc_acpi_intel_match
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: dell_wmi ath10k_pci
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: nls_iso8859_1
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: iTCO_wdt
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: ledtrig_audio
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: usbhid
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: hid_multitouch vfat ee1004 intel_pmc_bxt irqbypass ath10k_core
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: ? exit_to_user_mode_prepare+0x77/0x140
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_soc_core usb_storage
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: iTCO_vendor_support fat spi_nor mei_wdt
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: ? syscall_exit_to_user_mode+0x26/0x50
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: dell_smbios
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: ac97_bus
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: mei_pxp snd_hda_core crct10dif_pclmul
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: ? do_syscall_64+0x6b/0x90
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: dell_wmi_sysman crc32_pclmul
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: mei_hdcp ath
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: joydev
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: mtd
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: intel_rapl_msr
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: dcdbas firmware_attributes_class
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: nvidia_modeset(POE) intel_tcc_cooling x86_pkg_temp_thermal
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_hwdep
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: intel_powerclamp nvidia(POE)
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: dell_wmi_descriptor wmi_bmof
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: dell_laptop
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: ghash_clmulni_intel
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: kvm_intel snd_intel_dspcfg snd_intel_sdw_acpi
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: intel_wmi_thunderbolt mxm_wmi
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: entry_SYSCALL_64_after_hwframe+0x44/0xae
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: i915
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: ath10k_pci nls_iso8859_1
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: RIP: 0033:0x7fc95706da7b
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: mac80211 dell_smm_hwmon aesni_intel
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: Code: c3 48 8b 15 17 34 0d 00 f7 d8 64 89 02 b8 ff ff ff ff eb c2 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa b8 1c 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d e5 33 0d 00 f7 d8 64 89 >
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: crypto_simd
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: processor_thermal_device_pci_legacy
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_timer
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd_hda_codec hid_multitouch
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: RSP: 002b:00007fc94db53878 EFLAGS: 00000206
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: cryptd libarc4
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: ORIG_RAX: 000000000000001c
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: processor_thermal_device processor_thermal_rfim
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: RAX: ffffffffffffffda RBX: 00007fc94db54700 RCX: 00007fc95706da7b
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: drm_buddy rapl
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: RDX: 0000000000000004 RSI: 00000000007fb000 RDI: 00007fc94d354000
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: intel_cstate cfg80211
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: RBP: 00007fc94d354000 R08: 0000000000000000 R09: 000055c5a7177640
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: i2c_i801 snd
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: R10: 00007ffde4973080 R11: 0000000000000206 R12: 00007fc94eb552ae
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: intel_uncore
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: R13: 00007fc94eb552af R14: 00007fc94eb55480 R15: 00007fc94db53940
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: vfat ee1004 intel_pmc_bxt
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: processor_thermal_mbox
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: </TASK>
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: psmouse ucsi_acpi pcspkr
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: irqbypass
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: ttm soundcore processor_thermal_rapl
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: ath10k_core
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: spi_intel_pci intel_lpss_pci typec_ucsi mei_me
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: i2c_smbus spi_intel
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: spi_nor
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: rfkill drm_dp_helper i2c_hid_acpi
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: mei_wdt
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: intel_rapl_common typec intel_lpss
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: tpm_crb mei
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: idma64 intel_gtt intel_pch_thermal
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: crct10dif_pclmul dell_wmi_sysman
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: intel_soc_dts_iosf roles i2c_hid
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: crc32_pclmul mei_hdcp
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: tpm_tis int3403_thermal
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: int340x_thermal_zone dell_smo8800 tpm_tis_core
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: int3400_thermal acpi_thermal_rel wmi
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: tpm video
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: intel_hid
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: firmware_attributes_class snd_hwdep
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: mac_hid
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: rng_core acpi_pad sparse_keymap
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: ghash_clmulni_intel intel_wmi_thunderbolt
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: squashfs loop
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: mxm_wmi
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE)
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: i915 snd_pcm
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: fuse crypto_user
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: bpf_preload ip_tables x_tables
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: dell_smm_hwmon
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: ext4
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: aesni_intel crypto_simd
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: crc32c_generic
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: processor_thermal_device_pci_legacy snd_timer cryptd
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: crc16 mbcache jbd2
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: libarc4 processor_thermal_device
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: serio_raw rtsx_pci_sdmmc
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: processor_thermal_rfim
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: atkbd mmc_core libps2 vivaldi_fmap
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: nvme xhci_pci
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: crc32c_intel nvme_core rtsx_pci xhci_pci_renesas
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: cfg80211 i2c_i801
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: i8042 serio
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: snd intel_uncore processor_thermal_mbox psmouse
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: CPU: 9 PID: 518526 Comm: ThreadPoolForeg Tainted: P D W OEL 5.18.7-1-MANJARO #1 c639cf6afa5daaf845fba4aada771cecb4c93806
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: soundcore processor_thermal_rapl spi_intel_pci intel_lpss_pci typec_ucsi mei_me i2c_smbus
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: spi_intel rfkill drm_dp_helper i2c_hid_acpi
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: RSP: 0018:ffffaf04de70fb58 EFLAGS: 00000202
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: intel_lpss tpm_crb
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: RAX: 0000000000000011 RBX: ffff9667ac673dc8 RCX: ffff9667ac5bab80
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: mei idma64
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: RBP: ffff9667ac672640 R08: 0000000000000000 R09: 0000000000000000
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: intel_gtt
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: R10: 0000000000000000 R11: 0000000000000005 R12: ffff9667ac673dc0
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: R13: 0000000000000001 R14: ffff9667ac673dc0 R15: 0000000000000140
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: intel_pch_thermal intel_soc_dts_iosf roles
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: FS: 00007fc9506d9700(0000) GS:ffff9667ac640000(0000) knlGS:0000000000000000
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: i2c_hid tpm_tis int3403_thermal
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: CR2: 000023918968f008 CR3: 0000000374e56003 CR4: 00000000003706e0
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: wmi tpm video intel_hid mac_hid rng_core
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: acpi_pad sparse_keymap squashfs
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: loop
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: fuse crypto_user bpf_preload ip_tables x_tables
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: ext4 crc32c_generic crc16 mbcache jbd2 serio_raw rtsx_pci_sdmmc atkbd mmc_core libps2
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: vivaldi_fmap nvme xhci_pci crc32c_intel nvme_core rtsx_pci
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: xhci_pci_renesas i8042 serio
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: CPU: 10 PID: 522216 Comm: ThreadPoolForeg Tainted: P D W OEL 5.18.7-1-MANJARO #1 c639cf6afa5daaf845fba4aada771cecb4c93806
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: RIP: 0010:native_queued_spin_lock_slowpath+0x5e/0x200
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: Code: 00 77 74 f0 0f ba 2a 08 0f 92 c1 8b 02 0f b6 c9 c1 e1 08 30 e4 09 c8 3d ff 00 00 00 77 50 85 c0 74 0e 8b 02 84 c0 74 08 f3 90 <8b> 02 84 c0 75 f8 b8 01 00 00 00 66 89 02 65 48 ff 05 54 d3 >
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: RSP: 0018:ffffaf04d1a3fb30 EFLAGS: 00000202
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: ? do_futex+0xd8/0x190
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: RAX: 0000000000000101 RBX: ffff96673ee06de0 RCX: 0000000000000000
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: ? __x64_sys_futex+0x92/0x1d0
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: RDX: fffff2378ffb81a8 RSI: 0000000000000001 RDI: fffff2378ffb81a8
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: RBP: ffffaf04d1a3fc70 R08: ffff966665c1d928 R09: 0000000000000000
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: R10: ffff966446bf0000 R11: 0000000000000001 R12: fffff2378ffb8180
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: R13: 00007fc9517bc000 R14: fffff2378ffb81a8 R15: 0000000000000000
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: FS: 00007fc951fbc700(0000) GS:ffff9667ac680000(0000) knlGS:0000000000000000
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: CR2: 000018d2a0a78000 CR3: 0000000374e56001 CR4: 00000000003706e0
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: _raw_spin_lock+0x26/0x30
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: unmap_page_range+0x5b9/0xf60
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: RSP: 002b:00007fc9506d86e8 EFLAGS: 00000206 ORIG_RAX: 000000000000001c
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: ? dput+0x179/0x310
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: RAX: ffffffffffffffda RBX: 0000000000001000 RCX: 00007fc95706da7b
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: RDX: 0000000000000004 RSI: 0000000000001000 RDI: 00003a7dc7906000
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: RBP: 00007fc9506d8710 R08: 0000000000000000 R09: 0000000000000001
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: R10: 00003a7dc7868a20 R11: 0000000000000206 R12: 00000003a7dc7906
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: R13: 000055c5a7121ae8 R14: 00003a7dc7907000 R15: 00003a7dc7906000
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: zap_page_range+0x104/0x190
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: ? hrtimer_try_to_cancel+0x19/0x100
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: ? switch_fpu_return+0x4d/0xd0
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: RSP: 002b:00007fc951fbb878 EFLAGS: 00000206 ORIG_RAX: 000000000000001c
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: RAX: ffffffffffffffda RBX: 00007fc951fbc700 RCX: 00007fc95706da7b
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: RDX: 0000000000000004 RSI: 00000000007fb000 RDI: 00007fc9517bc000
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: RBP: 00007fc9517bc000 R08: 0000000000000000 R09: 000055c5a7177640
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: R10: 0000000000000000 R11: 0000000000000206 R12: 00007fc9506d82ae
Jul 10 20:36:16 JAROMANO-XPS-MAN kernel: R13: 00007fc9506d82af R14: 00007fc9506d8480 R15: 00007fc951fbb940
Output of inxi --admin --verbosity=7 --filter --no-host --width below
Summary
Kernel: 5.18.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: \\boot\vmlinuz-5.18-x86_64 rw root=/dev/nvme0n1p9 quiet splash
threadirqs initrd=boot\initramfs-5.18-x86_64.img
Console: pty pts/3 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: Dell product: XPS 15 9570 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 02MJVY v: A00 serial: <filter> UEFI: Dell v: 1.24.0
date: 03/21/2022
ID-1: BAT0 charge: 79.3 Wh (100.0%) condition: 79.3/84.4 Wh (94.0%)
volts: 12.6 min: 11.4 model: SMP DELL GPM0365 type: Li-ion serial: <filter>
status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K540/K545
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse M510
status: discharging
RAM: total: 15.28 GiB used: 7.93 GiB (51.9%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: DIMM A type: DDR4 detail: synchronous size: 8 GiB
speed: 2667 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits): data: 64
total: 64 manufacturer: 802C0000802C part-no: 8ATF1G64HZ-2G6E1
serial: <filter>
Device-2: DIMM B type: DDR4 detail: synchronous size: 8 GiB
serial: <filter>
Info: model: Intel Core i7-8750H socket: BGA1440 (U3E1) note: check bits: 64
type: MT MCP arch: Coffee Lake gen: core 8 built: 2018 process: Intel 14nm
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 3696 high: 4100 min/max: 800/4100 base/boost: 2277/4100
scaling: driver: intel_pstate governor: performance volts: 0.8 V
ext-clock: 100 MHz cores: 1: 4034 2: 4001 3: 4077 4: 2929 5: 3946 6: 1241
7: 4082 8: 4047 9: 4031 10: 3852 11: 4021 12: 4100 bogomips: 52815
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep sgx
sgx_lc smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell
driver: i915 v: kernel arch: Gen9.5 process: Intel 14nm built: 2016-20
ports: active: DP-3,eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Dell
driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Pascal process: TSMC 16nm
built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c8c class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-12:8 chip-ID: 0c45:671d class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.2 compositors:
1: xcompmgr 2: kwin_x11 driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1345 s-dpi: 96 s-size: 1013x354mm (39.88x13.94")
s-diag: 1073mm (42.25")
Monitor-1: DP-3 pos: primary,top-right model: Acer KG241Q P
serial: <filter> built: 2019 res: 1920x1080 dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: eDP-1 pos: bottom-l model: Sharp 0x149a built: 2018
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 22.1.2
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 1-2.1.4:7 alternate: snd_soc_skl,snd_sof_pci_intel_cnl
chip-ID: 0bda:4809 bus-ID: 00:1f.3 class-ID: 0300 chip-ID: 8086:a348
class-ID: 0403
Device-2: Realtek USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.18.7-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.1 running: no
Sound Server-4: PipeWire v: 0.3.52 running: yes
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Rivet Networks Killer Wireless-n/a/ac 1535 driver: ath10k_pci
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 3b:00.0
chip-ID: 168c:003e class-ID: 0280
IF: wlp59s0 state: up mac: <filter>
IF-ID-1: br-76cdcfd51056 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> scope: link
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: vethb43c90e state: up speed: 10000 Mbps duplex: full
mac: <filter>
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-4:4
chip-ID: 0cf3:e301 class-ID: e001
Local Storage: total: 4.1 TiB used: 947.38 GiB (22.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC401 NVMe 512GB
lanes: 4 type: SSD serial: <filter> rev: 80003E00 temp: 34.9 C scheme: GPT
SMART: yes health: PASSED on: 1y 60d 20h cycles: 1,260
read-units: 97,148,593 [49.7 TB] written-units: 110,257,180 [56.4 TB]
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Western Digital
model: WD My Passport 25E2 drive model: WD40NMZW-11GX6S1
family: Elements / My Passport (USB, AF) size: 3.64 TiB block-size:
physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD
rpm: 5400 serial: <filter> drive serial: <filter> rev: 4005
drive rev: 01.01A01 temp: 38 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 50d 16h cycles: 391
ID-1: / raw-size: 128 GiB size: 125.43 GiB (97.99%) used: 111.57 GiB (89.0%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p9 maj-min: 259:9 label: N/A
uuid: 994332f7-4c03-427b-bee9-acfefea7ea54
used: 6.2 MiB (1.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p7
maj-min: 259:7 label: N/A uuid: 97B2-3D16
ID-3: /home raw-size: 181.77 GiB size: 177.85 GiB (97.85%)
used: 153.83 GiB (86.5%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p10
maj-min: 259:10 label: N/A uuid: 96b60a94-62fb-46c9-b773-3290ded98132
ID-4: /run/media/jonathan/JAROMANO-DATA raw-size: 3.64 TiB
size: 3.64 TiB (100.00%) used: 681.97 GiB (18.3%) fs: ntfs3
block-size: 4096 B dev: /dev/sda1 maj-min: 8:1 label: JAROMANO-DATA
uuid: 068A84458A84336B
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p8 maj-min: 259:8 label: N/A
uuid: 7f1c2de8-3f17-4644-adc4-526641e92dbd
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 650 MiB fs: vfat label: ESP
uuid: 8A28-77FB
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: N/A label: N/A
uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 148.33 GiB fs: ntfs3
label: Windows Root uuid: 98EC7470EC744B10
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 990 MiB fs: ntfs3 label: N/A
uuid: DA2ACE6C2ACE44EB
ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 11.54 GiB fs: ntfs3 label: Image
uuid: 1A7CDBFD7CDBD19D
ID-6: /dev/nvme0n1p6 maj-min: 259:6 size: 1.08 GiB fs: ntfs3
label: DELLSUPPORT uuid: 6E88070B8806D20F
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-2: 1-2:3 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 045b:0209 class-ID: 0900
Hub-3: 1-2.1:5 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s
Device-1: 1-2.1.4:7 info: Realtek USB Audio type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 0bda:4809 class-ID: 0300
Device-2: 1-4:4 info: Qualcomm Atheros type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e301
class-ID: e001
Device-3: 1-7:6 info: Shenzhen Goodix Fingerprint Reader
type: Abstract (modem),CDC-Data driver: N/A interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 27c6:5395 class-ID: 0a00
serial: <filter>
Device-4: 1-12:8 info: Microdia Integrated_Webcam_HD type: Video
Hub-4: 2-0:1 info: Super-speed hub ports: 10 rev: 3.1 speed: 10 Gb/s
Hub-5: 2-2:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 045b:0210 class-ID: 0900
Hub-6: 2-2.1:3 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s
Device-1: 2-2.3:4 info: Western Digital My Passport (WD40NMZW)
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s
power: 896mA chip-ID: 1058:25e2 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 61.0 C pch: 55.0 C mobo: 52.0 C
Fan Speeds (RPM): cpu: 2517 fan-2: 2535
Processes: 346 Uptime: 25m wakeups: 6 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 alt: 11
clang: 13.0.1 Packages: 2136 note: see --pkg pacman: 2123 lib: 474
flatpak: 13 Shell: Bash (sudo) v: 5.1.16 running-in: konsole inxi: 3.3.19
I’m a bit out of my dept here, so any guidance on next steps are super appreciated. Thanks!
