Hi,
I have latest 5.10.7 kernel installed. I often have issues in journalctl log, like:
wpa_supplicant[389]: nl80211: kernel reports: key addition failed
kernel: psmouse serio1: elantech: elantech_send_cmd query 0x00 failed.
systemd-modules-load[205]: Failed to find module 'v4l2loopback-dc'
and always these ones:
kernel: Bluetooth: hci0: don't support firmware rome 0x11020000
pipewire[1012]: Failed to receive portal pid: org.freedesktop.DBus.Error.NameHasNoOwner: Could not get PID of name 'org.freedesktop.portal.Desktop': no such name
When I have upper messages I may experience issues with my touchpad (it is seen as an ordinary mouse), very long shutdown times, stack trace spams in the logs. These errors appear sometimes only and a reboot fixes them most of the time.
This problems begun with 5.10 kernels. Now I cannot shift to 5.9 kernel, it stucks at boot always. Is this a hardware problem? Otherwise, how can I track the problem?
My inxi -Faz
result:
System: Kernel: 5.10.7-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=6b0569e6-71a6-459e-99cc-ac225fe06b91 rw
udev.log_priority=3 ec_sys.write_support=1 sysrq_always_enabled=1 systemd.unified_cgroup_hierarchy=true
resume=/dev/disk/by-uuid/19a0c71e-ed32-45ea-8489-9e31e24b22d7
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: Acer product: Aspire S3-391 v: V2.17 serial: <filter>
Mobo: Acer model: Hummingbird2 v: V2.17 serial: <filter> UEFI [Legacy]: Insyde v: 2.17 date: 07/18/2013
Battery: ID-1: BAT0 charge: 29.8 Wh condition: 33.9/35.5 Wh (96%) volts: 11.7/11.1 model: SANYO AP11D3F type: Li-ion
serial: <filter> status: Discharging
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M525 serial: <filter> charge: 100% (should be ignored)
rechargeable: yes status: Discharging
CPU: Info: Dual Core model: Intel Core i5-3317U bits: 64 type: MT MCP arch: Ivy Bridge family: 6 model-id: 3A (58)
stepping: 9 microcode: 21 L2 cache: 3 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 13574
Speed: 826 MHz min/max: 800/2600 MHz Core speeds (MHz): 1: 826 2: 1120 3: 866 4: 1791
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Type: srbds status: Vulnerable: No microcode
Graphics: Device-1: Intel 3rd Gen Core processor Graphics vendor: Acer Incorporated ALI driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:0166
Device-2: Chicony HD WebCam type: USB driver: uvcvideo bus ID: 3-4:2 chip ID: 04f2:b33b
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: intel unloaded: modesetting
alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0") s-diag: 414mm (16.3")
Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 120 size: 290x160mm (11.4x6.3") diag: 331mm (13")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 20.3.3 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
Sound Server: ALSA v: k5.10.7-3-MANJARO
Network: Device-1: Qualcomm Atheros AR9462 Wireless Network Adapter vendor: Foxconn driver: ath9k v: kernel port: 2040
bus ID: 02:00.0 chip ID: 168c:0034
Drives: Local Storage: total: 223.57 GiB used: 127.15 GiB (56.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SUV400S37240G size: 223.57 GiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 87RA
Partition: ID-1: / raw size: 182.62 GiB size: 178.75 GiB (97.88%) used: 127.15 GiB (71.1%) fs: ext4 dev: /dev/sda2
maj-min: 8:2
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.38 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3 maj-min: 8:3
Sensors: System Temperatures: cpu: 54.0 C mobo: 50.0 C
Info: Processes: 211 Uptime: 13m wakeups: 3 Memory: 3.67 GiB used: 2.12 GiB (57.8%) Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: pacman: 1850 lib: 465 Shell: Bash v: 5.1.0 running in: konsole inxi: 3.2.02
